NRF9160 DNS getaddrinfo error
Hello everyone,
I'm trying to connect to my UDP server with only the hostname.
I have validate my connection to my UDP server with an IP static and know i want to use an hostname to find my IP and establish a connection to my UDP server.
My issue occur when i try to get this IP address.
I have try an example to establish a connection between my board and my UDP server. To do that i have use this example : Modem Shell
I have test this command : sock connect -a "address"' -p 1800 -f inet -t dgram  -> All OK
After the first command, i have test this one: sock send -i 0 -d testing -> my UDP server correctly receive the message
So i have study the code of this example to be able to get the IP address of a specific address.
This is my code for the moment :
int server_init(void)
    int err = -EINVAL;
    struct sock_info *socket_info; // = reserve_socket_id();
    if (socket_info == NULL) {
		printk("socket creation failed; MAX SOCKETS exceeeded");
    /* Get address */
	err = sock_getaddrinfo(socket_info, 1, 2, "myaddress.net", 1800, 0);
	if (err) {
		printk("err get address : %d \r\n",err);
        //goto connect_error;
    printk("OK\r\n");
	return 0;
static int sock_getaddrinfo(
	struct sock_info *socket_info,
	int family,
	int type,
	char *address,
	int port,
	int pdn_cid)
	int err;
	struct addrinfo hints = {
		.ai_family = 1,
		.ai_socktype = 2,
    char pdn_serv[12];
	char *service = NULL;
	err = getaddrinfo(address, service, &hints, &socket_info->addrinfo);
    if (err) {
			if (err == DNS_EAI_SYSTEM) {
				printk("getaddrinfo() failed, err %d errno %d", err, errno);
			} else {
				printk("getaddrinfo() failed, err %d", err);
			return -EADDRNOTAVAIL;
	/* Set port to address info */
	((struct sockaddr_in *)socket_info->addrinfo->ai_addr)->sin_port =htons(1800);
	return 0;
My code compile with no problem and after a flash when i debug initialisation of my module, i have this :
1) socket creation failed; MAX SOCKETS exceeeded
2) getaddrinfo() failed, err -11 errno 115
3) err get address : -125"
 I understand the first error, it's because my socket_info is NULL, that not a problem because for the moment i need only 1 socket
The line where the problem come from is : err = getaddrinfo(address, service, &hints, &socket_info->addrinfo);
And i have no idea how to solve this problem,
Do you have advice for me ?
Lam
    Thanks for your help,
    I found this solution that works great and come from Modem Shell example and more precisely in in sock folder.
    I share solution maybe this can help someone.
    int getIP_fromHost(void){
        // struct addrinfo res;
        // struct addrinfo hint;
        int err = -EINVAL;
        struct sock_info *socket_info = reserve_socket_id();
            return 1;
        /* Get address */
    	err = sock_getaddrinfo(socket_info, 1, 2, "your_udp_server", 1800, 0);
    	if (err) {
            return 1;
        char addr_str[INET_ADDRSTRLEN];
        for (struct addrinfo *ai = socket_info->addrinfo; ai != NULL; ai = ai->ai_next) {
            zsock_inet_ntop(ai->ai_family, &((struct sockaddr_in *)ai->ai_addr)->sin_addr, addr_str, sizeof(addr_str));
           	printk("IP address: %s\n", addr_str);
        strcpy(ip_UDPServer,addr_str);
        // Clean up.
        freeaddrinfo(socket_info->addrinfo);
        return 0;
    static struct sock_info *reserve_socket_id(void)
    	struct sock_info *socket_info = NULL;
    	int socket_id = 0;
    	while (socket_id < MAX_SOCKETS) {
    		if (!sockets[socket_id].in_use) {
    			socket_info = &(sockets[socket_id]);
    			//sock_info_clear(socket_info);
                //freeaddrinfo(socket_info->addrinfo);
                memset(socket_info, 0, sizeof(struct sock_info));
                socket_info->id = -1;
    	        socket_info->fd = -1;
    	        socket_info->log_receive_data = true;
    	        socket_info->recv_data_len_expected = -1;
    	        socket_info->recv_print_format = SOCK_RECV_PRINT_FORMAT_STR;
    			socket_info->id = socket_id;
    			socket_info->send_info.parent = socket_info;
    		socket_id++;
    	return socket_info;
    static int sock_getaddrinfo(struct sock_info *socket_info, int family, int type, char *address, int port, int pdn_cid)
    	int err;
    		.ai_family = AF_INET,       //1
    		.ai_socktype = SOCK_DGRAM,  //2
            .ai_next = NULL,
            .ai_addr = NULL,
            .ai_protocol = 0   //any protocol
        //char pdn_serv[12];
    	//char *service = NULL;
    	err = getaddrinfo(address, NULL, &hints, &socket_info->addrinfo);
        if (err) {
    			} else {
    	return 0;
    Best reagrds,
    Lam
