Undefined reference error while trying to use out-of-tree driver
I have create small project with a sensor driver that does not exist in main source tree. But when I trying to compile it I have an error undefined reference to `__device_dts_ord_84'.
-- Zephyr version: 3.2.99 (/home/quard/ncs/zephyr), build: v3.2.99-ncs2
[174/184] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/quard/Projects/learn/nRF/si1145_demo/build/zephyr/zephyr_pre0.map
: && ccache /home/quard/.local/zephyr-sdk-0.15.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/quard/Projects/learn/nRF/si1145_demo/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/sensor/lis2dh/libdrivers__sensor__lis2dh.a  zephyr/drivers/sensor/lis2mdl/libdrivers__sensor__lis2mdl.a  zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a  zephyr/drivers/sensor/stmemsc/libdrivers__sensor__stmemsc.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/quard/.local/zephyr-sdk-0.15.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v7e-m/nofp"  -L/home/quard/Projects/learn/nRF/si1145_demo/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn && cd /home/quard/Projects/learn/nRF/si1145_demo/build/zephyr && /usr/bin/cmake -E echo
/home/quard/.local/zephyr-sdk-0.15.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `main':
/home/quard/Projects/learn/nRF/si1145_demo/src/main.c:23: undefined reference to `__device_dts_ord_84'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/quard/Projects/learn/nRF/si1145_demo/build
Based on a error message it seems like driver is not a part of final linkage command and I could not find how to add it. I have checked a few different repositories that implements out-of-tree drivers and they are looks similar for me.
Code available github.com/.../si1145-drv-demo.
Thanks ahead.
  • So, still no success with a sensor driver.
    With i2c1 as a device compat code is compiled but DEVICE_DT_GET_ANY returns NULL.
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    Hello World! bbc_microbit_v2
    Failed to get device binding
    As soon as I change compat to the sensor value I got the same error as it was before.
    [3/11] Linking C executable zephyr/zephyr_pre0.elf
    /home/quard/Projects/learn/nRF/si1145_demo/src/main.c:30: undefined reference to `__device_dts_ord_88'
    Also I have replace __ASSERT macros with ifs because it seems like they are doesn't work at least I don't get the error.
  • So I tested with your code and changed to
    "const struct device *const dev = DEVICE_DT_GET_ANY(DT_NODELABEL(uvsens));"
    And that compiles for the BBC Micro board.
    Could you try that and see if you can detect the sensor?
    Runar
  • Yes code compiles but it returns NULL instead of device binding.
    Seems like it will be easier to implement device support without creating the Zephyr driver.
  • I think that might be the easiest way as of now. I have checked with other coworkers also without finding anything wrong that stands out. I'm sorry that I could not be more helpful.
    Regards
    Runar
