Request for Guidance and Documentation on ERASEPROTECT/APPROTECT/SECUREAPPROTECT
We've created an application for the nRF9160 non secure image with TF-M and are looking to add in ERASEPROTECT/APPROTECT/SECUREAPPROTECT functionality. From reading the Production Programming document I can see that when enabling ERASEPROTECT, APPROTECT, and SECUREAPPROTECT, the only way to recover the device is "if the installed firmware and the debugger both write the same non-zero 32-bit KEY value to ERASPROTECT.DISABLE (0x01C)"
My understanding is that since we already have a application that we want to build for non secure (for example, if it was the Blinky sample built for the nrf9160dk_nrf9160_ns with TF-M), we would need to create a separate secure image in order to write the non-zero 32-bit key value to ERASEPROTECT.DISABLE.
My questions are:
  1. How can we create a separate secure image with our nonsecure application? As I understand, the secure image should run first before handing over control of the execution to the nonsecure application. What would be the best way to add an additional secure image to something like the nonsecure Blinky sample? Would this be a child image?
  2. Is there any examples of how to interact with the ERASEPROTECT, APPROTECT, and SECUREAPPROTECT settings from the application side? I unfortunately don't have much experience working directly with various registers on the nRF9160 and would be happy to get any help possible, especially with regards to what needs to be provisioned to interact with the registers and if there is a getting started guide for tasks like this. I want to create a script that upon boot up of the nRF9160, the program:
    1. Checks if any of the ERASEPROTECT, APPROTECT, and SECUREAPPROTECT functionalities are not enabled. If any of these are not enabled, the program will enable the protection and perform a reset of the device. On the next boot up, all three of the protections should be enabled.
    2. If ERASEPROTECT, APPROTECT, and SECUREAPPROTECT are all enabled, it will write a 32-bit key to ERASPROTECT.DISABLE. This way, if we need to recover the device, we can use the SWD to write in the 32-bit key to trigger an erase all
    3. Finally, hands over execution to our nonsecure program
  3. Our current application uses MCUBOOT and supports OTA. Would ERASEPROTECT affect the application's ability to download new application updates and boot up with the new updates?
I've found some previous posts which seem to be quite helpful, however I'm still unsure of how I would need to go about integrating it into an existing nonsecure application.
This post seems fairly helpful in talking about how to create a non-ns script to remove erase protect. However, I'm having a bit of difficulty following/finding the documentation on modifying/reading contents for items like NRF_NVMC and NRF_UICR through the application, and what the particular bits like (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos) being set indicate.
Thank you in advance!
  • Hi everyone,
    I read through this Q&A and also this one and copied the same question from there, I wanted to test the working of ERASEPROTECT and disable it using the Jlink script shared in the discussions, but I am neither able to disable erase protection using the script nor nrfjprog --recover
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    void main(void)
            const uint32_t key = 0xDEADBEEF;
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
            while (NRF_NVMC->READY == NVMC_READY_READY_Busy);
            NRF_UICR->APPROTECT = 0x00000000;
            NRF_UICR->ERASEPROTECT = 0x00000000;
            NRF_UICR->SECUREAPPROTECT = 0x00000000;
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
            if (NRF_UICR_S->ERASEPROTECT != UICR_ERASEPROTECT_PALL_Unprotected)
                    NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK = (uint32_t)0x00000001;
                NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE = key;
            printk("Before Write Key.\n");
            printk("ERASEPROTECT     Addr    0x%p\n", &NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK);
            printk("ERASEPROTECT          0x%X\n",  NRF_UICR->ERASEPROTECT);
            printk("ERASEPROTECT.LOCK    0x%X\n",   NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK);
            printk("ERASEPROTECT.DISABLE 0x%X\n",   NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE);
            uint32_t count = 0;
            k_msleep(1000);
            while (count < 10)
                    k_msleep(1000);
                    printk("Count:: %u\r\n", count++);
    output:
    *** Booting Zephyr OS build zephyr-v2.3.0-22164-gb121d671c44c  ***
    Before Write Key.
    ERASEPROTECT     Addr    0x0x50006500
    ERASEPROTECT          0x0
    ERASEPROTECT.LOCK    0x1
    ERASEPROTECT.DISABLE 0x0
    Count:: 0
    Count:: 1
    Count:: 2
    Count:: 3
    Count:: 4
    Count:: 5
    Count:: 6
    Count:: 7
    Count:: 8
    Count:: 9
    jlink script:
    USB 960093400
    SWDSelect
    SWDWriteDP 1 0x50000000
    SWDWriteDP 2 0x04000010
    SWDWriteAP 3 0xDEADBEEF
    sleep 10000
    SWDWriteDP 2 0x04000000
    SWDWriteAP 0 0x00000001
    SWDReadAP 0
    SWDReadAP 0
    sleep 5000
    SWDWriteAP 0 0x00000000
    SWDReadAP 0
    SWDReadAP 0
    sleep 1000
    exit
    Help needed.
    Dinesh Kumar K
  • The problem is likely with the code setting both ERASEPROTECT.LOCK and ERASEPROTECT.DISABLE. These can't both be set. If you read the documentation on ERASEPROTECT.LOCK, you will see that it prevents ERASEPROTECT.DISABLE from being set until next boot. You cannot set them both in sequence like this. Notice how in the output ERASEPROTECT.DISABLE never actually get set to 0xDEADBEEF, it just stays at 0x0 because it was previously locked.
    I stated in my original post that ERASEPROTECT.LOCK could optionally be set if ERASEPROTECT.DISABLE is not to be set on bootup.
    If serial recovery is not activated at boot, you can optionally prevent ERASEPROTECT.DISABLE from being written to until next reboot by setting NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK = (uint32_t)0x00000001
    Try just removing these lines and it should properly set ERASEPROTECT.DISABLE
    Unfortunately, the nRF9160 you flashed with your previous code cannot be recovered now, you'll need to get a new board. Also, the command nrfjprog --recover can't be used to disable ERASEPROTECT since there is no way to supply it the key. Your script looks to be correct, and that is the only way to properly disable ERASEPROTECT and perform and ERASEALL.
  • Hi Rory,
    Apologies for the day delay in response, I've been pulled to a different project for the last bit and am just able to get back into this project.
    I've setup my device to use the MCUboot edit and am able to successfully replicate having the MCUboot file set a key and using the JLink Commander script to remove the ERASEPROTECT! Thank you for your help! I will continue with testing the JLink Commander script to flash the hex file and set the protections.
    The only thing I'd hope for on, which may be a bit out of scope, is if there's a better way to locate the code that sets the script to be closer to the application directory. This way my coworkers can replicate this without making a more-so in-tree change. I've been able to create a script based off of this response to set the key when built for the nrf9160dk_nrf9160 (not ns) -- I'm curious if there's a way to merge a compiled hex file built for the nrf9160dk_nrf9160 into a separate nrf9160dk_nrf9160_ns application.
     Thank you again for the help, Rory!
  • Hi Simon,
    Similar to what Rory mentioned in editing MCUboot, is there an easy way to create a bootloader with the code to set the UICR registers in the secure domain that occurs before or after the MCUboot bootloader?
    Alternatively, is there a way have a complied hex of a script of your linked ticket included to be run with a non secure application with a multi-image build? I've tried to follow the multi-image build instructions and some examples from the nrf sdk, but unfortunately I haven't had much luck in getting it to work. I can share a zip of what I am working on, if helpful.
    Another way I can think of this is to ask how one could add the ERASEPROTECT.disable key write into the nRF Asset Tracker V2 application? Would the best way still be to edit MCUboot directly?
    Edit to add:
    Is there possibly a good way in TFM to create a function that can execute in the secure environment that is invoked from the non-secure side? E.g. The non secure side calls function in secure side to write a value into the UICR ERASEPROTECT.disable?
  • Hi Edward
    Why do you need to change UICR data from the bootloader? It is recommended to leave the UICR alone, as bootloader addresses are stored there for example, so it's easy to tread wrong. If you have data that needs to be changed more often, I'd suggest using a dedicated flash page to store this instead of UICR.
    Why exactly do you need to make changes to UICR during runtime?
    Simon
