Request for Guidance and Documentation on ERASEPROTECT/APPROTECT/SECUREAPPROTECT
We've created an application for the nRF9160 non secure image with TF-M and are looking to add in ERASEPROTECT/APPROTECT/SECUREAPPROTECT functionality. From reading the Production Programming document I can see that when enabling ERASEPROTECT, APPROTECT, and SECUREAPPROTECT, the only way to recover the device is "if the installed firmware and the debugger both write the same non-zero 32-bit KEY value to ERASPROTECT.DISABLE (0x01C)"
My understanding is that since we already have a application that we want to build for non secure (for example, if it was the Blinky sample built for the nrf9160dk_nrf9160_ns with TF-M), we would need to create a separate secure image in order to write the non-zero 32-bit key value to ERASEPROTECT.DISABLE.
My questions are:
  1. How can we create a separate secure image with our nonsecure application? As I understand, the secure image should run first before handing over control of the execution to the nonsecure application. What would be the best way to add an additional secure image to something like the nonsecure Blinky sample? Would this be a child image?
  2. Is there any examples of how to interact with the ERASEPROTECT, APPROTECT, and SECUREAPPROTECT settings from the application side? I unfortunately don't have much experience working directly with various registers on the nRF9160 and would be happy to get any help possible, especially with regards to what needs to be provisioned to interact with the registers and if there is a getting started guide for tasks like this. I want to create a script that upon boot up of the nRF9160, the program:
    1. Checks if any of the ERASEPROTECT, APPROTECT, and SECUREAPPROTECT functionalities are not enabled. If any of these are not enabled, the program will enable the protection and perform a reset of the device. On the next boot up, all three of the protections should be enabled.
    2. If ERASEPROTECT, APPROTECT, and SECUREAPPROTECT are all enabled, it will write a 32-bit key to ERASPROTECT.DISABLE. This way, if we need to recover the device, we can use the SWD to write in the 32-bit key to trigger an erase all
    3. Finally, hands over execution to our nonsecure program
  3. Our current application uses MCUBOOT and supports OTA. Would ERASEPROTECT affect the application's ability to download new application updates and boot up with the new updates?
I've found some previous posts which seem to be quite helpful, however I'm still unsure of how I would need to go about integrating it into an existing nonsecure application.
This post seems fairly helpful in talking about how to create a non-ns script to remove erase protect. However, I'm having a bit of difficulty following/finding the documentation on modifying/reading contents for items like NRF_NVMC and NRF_UICR through the application, and what the particular bits like (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos) being set indicate.
Thank you in advance!
  • blasph said:
    My impression was that the ERASEPROTECT.disable key had to be set on each reboot. Does the ERASEPROTECT.disable key persist across reboots, and only need to be set once then?
    Good catch!
    You are correct, so my suggestion is not really useful.
    Additionally, there is a bug in the docs on ERASEPROTECT.DISABLE: The register is not RW, but is R1.
    So you can not read out the value to verify that the data is set. (It will always read 0).
    blasph said:
    - I copied over the relevant CMakeLists.txt additions from the tfm_secure_peripheral sample and merged them into my main CMakeLists.txt file
    - Modified the secure_peripheral_partition.c file to no longer use the sample peripherals and only generate and set the key (and removed the init and while loop from the tfm_spp_main, as I only need this code to run once at boot up and not again)
    - copied over my modified secure_peripheral_partition directory
    - copied over the prj.conf symbols CONFIG_TFM_IPC=y and CONFIG_TFM_ISOLATION_LEVEL=1 from the sample. The TFM_PROFILE_NOT_SET=y makes my project not build, but I've also removed this symbol from the sample and the sample still works
    From just reading the steps, they seem reasonable to me.
    blasph said:
    When running my application, I see the key now gets set properly, but my main application fails to run. Would it be possible for me to create a private ticket to see if I could get some help with this final integration step?
    Definitely! Just create a ticket and reference this one.
  • Hi Sigurd,
    Thank you for letting me know!
    I have just created a private ticket about this. Thank you!
