Zephyr UART Async receive drops a single character
I'm using the async API for UART and I have noticed that, shortly after initialisation, I receive a single character with the UART_RX_READY event. This character is 0xff - and I suspect that's just the GPIO lines changing state. This character is easy to ignore, however it seems to break the internal state of the RX API. All future calls will have an offset of +1, but the total length (of all API requests in aggregate) will be correct. This causes us to ignore the first character in our buffer, and take one more than we should (not out-of-bounds, but stale/uninitialised memory).
I suspect we're getting an interrupt that we received data during the initialisation process, and that's throwing us off.
To fix this, I wait for the first UART_RX_READY event, call uart_rx_disable(), and then wait for the UART_RX_DISABLED message. Once that's done, I re-enable with uart_rx_enable() and the system seems to work reliably. I've got four of these devices in the field reading a couple thousand octets per day, and so far it seems to be working just fine!
I'm using SDK v2.2.0, but didn't see any relevant changes in the changelog.
Here's some partial code which has the complete TX/RX path:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
static int setup(void) {
int rc;
LOG_DBG("Initialising serial tunnel...");
rc = gpio_pin_configure_dt(&tunnel_power_pin_spec, GPIO_OUTPUT_INACTIVE);
if (rc < 0)
LOG_ERR("Failed to configure power control pin.");
return rc;
rc = gpio_pin_configure_dt(&tunnel_power_led_spec, GPIO_OUTPUT_INACTIVE);
if (rc < 0)
LOG_ERR("Failed to configure power LED.");
return rc;
if (!device_is_ready(tunnel_port))
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Let me know if I've missed anything! For now, our workaround is fine - but it seems like a bug that will bite again in future :)
