Issues building sample code
The auto installed failed, so I had to do a manual install. I followed this tutorial:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/getting_started/installing.html
After some struggle, it seems that I'm almost there. While trying to compile I get this error:
  • Terminal under Vscode windows
"Building blinky
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:\nordic\myapps\blinky\build c:\nordic\myapps\blinky --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE""
usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
west: error: argument <command>: invalid choice: 'build' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')"
  • Vscode problems tab:
#include errors detected based on information provided by the configurationProvider setting. Squiggles are disabled for this translation unit (C:\nordic\myapps\blinky\src\main.c).
cannot open source file "syscall_list.h" (dependency of "C:\Users\JV\AppData\Local\Programs\Microsoft VS Code\zephyr\kernel.h")
cannot open source file "devicetree_generated.h" (dependency of "C:\Users\JV\AppData\Local\Programs\Microsoft VS Code\zephyr\drivers\gpio.h")
Support Info:
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19045",
    "vscode": "1.79.1",
    "electron": "22.5.7",
    "node": "v16.17.1"
  "system": {
    "date": "2023-06-14T17:21:10.381Z",
    "vscodeRoot": "c:\\Users\\JV\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "01:12:03",
    "osUptime": "01:52:35",
    "cpu": {
      "model": "Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz",
      "speed": "2594 MHz",
      "count": 4
    "memory": {
      "total": "31.93 GB",
      "free": "23.42 GB"
  "workspace": {
    "name": "Untitled (Workspace)",
    "workspaceFile": "1686670668724",
    "folders": [
      "c:\\vsCodeNordic\\blinky",
      "c:\\nordic\\myapps\\blinky"
  "extensions": {
    "internal": {
        "version": "2023.4.179",
        "path": "c:\\Users\\JV\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.4.179-win32-x64",
        "isActive": true
        "version": "2023.4.15",
        "path": "c:\\Users\\JV\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.4.15",
        "isActive": true
        "version": "2023.4.61",
        "path": "c:\\Users\\JV\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.4.61",
        "isActive": true
        "version": "2023.4.17",
        "path": "c:\\Users\\JV\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.4.17",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.0",
      "ms-vscode.cpptools": "1.16.0",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
      "ms-vscode.js-debug": "1.78.0",
      "ms-vscode.js-debug-companion": "1.0.18",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "cschlosser.doxdocgen": "1.4.0",
      "GitHub.vscode-pull-request-github": "0.66.1",
      "jeff-hykin.better-cpp-syntax": "1.17.2",
      "kiteco.kite": "0.147.0",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.21",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "ms-python.isort": "2022.8.0",
      "ms-python.python": "2023.10.1",
      "ms-python.vscode-pylance": "2023.6.10",
      "ms-toolsai.jupyter": "2023.5.1001582324",
      "ms-toolsai.jupyter-keymap": "1.1.2",
      "ms-toolsai.jupyter-renderers": "1.0.15",
      "ms-toolsai.vscode-jupyter-cell-tags": "0.1.8",
      "ms-toolsai.vscode-jupyter-slideshow": "0.1.5",
      "ms-vscode-remote.remote-containers": "0.295.0",
      "ms-vscode-remote.remote-ssh": "0.102.0",
      "ms-vscode-remote.remote-ssh-edit": "0.86.0",
      "ms-vscode-remote.remote-wsl": "0.79.5",
      "ms-vscode.remote-explorer": "0.4.0",
      "ms-vsliveshare.vsliveshare": "1.0.5873",
      "twxs.cmake": "0.0.17",
      "VisualStudioExptTeam.intellicode-api-usage-examples": "0.2.7",
      "VisualStudioExptTeam.vscodeintellicode": "1.2.30",
      "zenor.makefile-creator": "0.0.3"
  "tools": {
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.0",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.80c",
    "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.19.0",
    "nrfutil": "Not found",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\cmake.exe": "3.20.5",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Scripts\\west.exe": "1.0.0",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\python.exe": "3.8.2",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\ninja.exe": "1.9.0",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\gperf.exe": "3.1",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\dtc.exe": "1.4.7",
    "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\gn.exe": "2105",
    "c:\\ncs\\toolchains\\31f4403e35\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "sdks": [
      "version": "2.4.0",
      "path": "c:\\ncs"
  "toolchains": [
      "version": "2.4.0",
      "path": "c:\\ncs\\toolchains\\31f4403e35"
  "connectedDevices": [],
  "deviceProvider": "nrfutil",
  "config": {
      "topdir": "C:\\ncs",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.4.0}"
      "ozonePath": "",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true,
      "taskBindings": {},
      "debugging": {
        "backend": "nRF Debug",
        "flash": true,
        "bindings": {}
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "dbgServerLogfile": null
  "environment": {
    "westExe": "west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\JV",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\JV",
      "Path": "c:\\ncs\\toolchains\\31f4403e35\\mingw64\\bin;c:\\ncs\\toolchains\\31f4403e35\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\31f4403e35\\opt\\bin;c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\31f4403e35\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Scripts;C:\\Program Files (x86)\\Intel\\iCLS Client\\;C:\\Program Files\\Intel\\iCLS Client\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\NoteBook FanControl\\;C:\\Octave\\Octave-5.1.0.0\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\MATLAB\\R2020b\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Nmap;C:\\Program Files (x86)\\Dr. Memory\\bin\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\JV\\.dotnet\\tools;C:\\Program Files (x86)\\Atmel\\Flip 3.4.7\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files\\wget\\bin;C:\\ncs\\toolchains\\31f4403e35;",
      "ZEPHYR_BASE": "c:\\ncs\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk",
      "PYTHONPATH": "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin;c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Lib;c:\\ncs\\toolchains\\31f4403e35\\opt\\bin\\Lib\\site-packages",
      "Python3_ROOT": "c:\\ncs\\toolchains\\31f4403e35\\opt\\bin"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\Intel\\iCLS Client\\;C:\\Program Files\\Intel\\iCLS Client\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\NoteBook FanControl\\;C:\\Octave\\Octave-5.1.0.0\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\MATLAB\\R2020b\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Nmap;C:\\Program Files (x86)\\Dr. Memory\\bin\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\JV\\.dotnet\\tools;C:\\Program Files (x86)\\Atmel\\Flip 3.4.7\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files\\wget\\bin;C:\\ncs\\toolchains\\31f4403e35;",
      "PATH": "C:\\Program Files (x86)\\Intel\\iCLS Client\\;C:\\Program Files\\Intel\\iCLS Client\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\NoteBook FanControl\\;C:\\Octave\\Octave-5.1.0.0\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\MATLAB\\R2020b\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\JV\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Nmap;C:\\Program Files (x86)\\Dr. Memory\\bin\\;C:\\Users\\JV\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\JV\\.dotnet\\tools;C:\\Program Files (x86)\\Atmel\\Flip 3.4.7\\bin;C:\\Program Files\\Graphviz\\bin;C:\\Users\\JV\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files\\wget\\bin;C:\\ncs\\toolchains\\31f4403e35;"
    "toolchainPath": "c:\\ncs\\toolchains\\31f4403e35",
    "toolchainBinPath": "c:\\ncs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.4.0"
  "terminal": {
    "shell": null,
    "defaultProfile": null
What I'm missing now?
  • Hi Jose,
    It's always best to have an automatic installation. Probably the issue of not downloading the SDK was caused because of a slow or unstable internet connection or maybe some GitHub issues.
    Also, you need the SDK files in the location C:/ncs/v2.4.0. But in your case, the SDK files have been installed directly into C:/ncs and this can cause issues later on, as the .west file can be hidden anywhere in there.
    It would be great if you could install them into C:/ncs/v2.4.0. Also, the errors that you see are because of an incomplete installation, so now if you go to the SDK folder and open a terminal and try west update, it should be fixed.
    -Priyanka
  • Automatic installation may be the way, but I followed the all steps by the letter (both, auto and manual)
    At the company we have two high speed connections,  the back up kicks in when the other goes down.
    I did try the west update from that folder several times.
    Don't worry, just close the case... I will try solething else
  • Hi Jose,
    Did you try storing all the SDK files in the location  C:/ncs/v2.4.0 and then try the west update in there? Please do try this and let me know how it goes.
    -Priyanka
