NRF9160 AWS IOT no connection possible.
Dear
We are bussy with oure first NRF IOT application, in the past we used AWS as cloud environment.
Now we want to write some data in the cloud based on the NRF9160-DK board.
After a clean and up to date, setup from the Nordic SDK and downloading the stock AWS example with the needed adaption, described in the tutorial online, like the URL to the cloud and adding downloading the 3 certificates into the device with AT CMD project.
We run in some problem, after programming the AWS project we got this error:
I can’t find what -119 problem means?
*** Booting Zephyr OS build v3.3.99-ncs1 ***
I: The AWS IoT sample started, version: v1.0.0
E: AWS IoT library could be initialized, error: 0
E: Adding application specific topics succes, error: 0
E: Modem could be configured, error: 0
E: initializing modem info module, error: 0
+CEREG: 2,"0C3F","02C93C01",7
I: LTE cell changed: Cell ID: 46742529, Tracking area: 3135
+CSCON: 1
I: RRC mode: Connected
+CEREG: 1,"0C3F","02C93C01",7,,,"11100000","00000110"
I: Network registration status: Connected - home network
I: PSM parameter update: TAU: 3600, Active time: -1
%XTIME: "80","32604161952580","01"
I: Date time obtained
I: Next connection retry in 5 seconds
I: AWS_IOT_EVT_CONNECTING
W: connection_poll_start failed, error: -119
E: aws_iot_connect, error: -119
How can we solve this problem or what configuration is missing?
  • emsys said:
    I added the lines by myself and got this error: "warning: attempt to assign the value 'y' to the undefined symbol AWS_IOT_LOG_LEVE_DBG" i added this to prj.conf
    I'm sorry, that was a typo on my end. It should be CONFIG_AWS_IOT_LOG_LEVEL_DBG=y.
    emsys said:
    Maybe, HOST name is changed the other are stock values.
    Which sec_tag did you write the credentials to? 201?
    And what did you name the device in AWS and the device certificate?
  • Hello
    Sorry for the delay, other project gets a bigger priority.
    The problem is still exist.
    I update my certificate without any success.
    This the output from the debug trace
    Connection poll in progress
    E: getaddrinfo, error -11
    E: client_broker_init, error: -10
    I changed this 3 lines
    CONFIG_AWS_IOT_CLIENT_ID_STATIC="AWS_Thing"
    CONFIG_AWS_IOT_BROKER_HOST_NAME="avbdfegwrkr9hu-ats.iot.eu-west-1.amazonaws.com"
    CONFIG_AWS_IOT_SEC_TAG=16842750
    The tag was changed to this number by uploading the certificates.
  • Could you enable debug logging in the aws_iot library to see if that gives us some more information?
    Also, if you disable minimal logging, it will be easier to see where various log lines come from.
    CONFIG_LOG_MODE_MINIMAL=n
    Also, if you can take a modem trace, that would be helpful.
  • Modem Trace:
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    I: Trace thread ready
    I: Trace level override: 2
    +CSCON: 1
    %XTIME: "40","32116191900540","00"
    I: Next connection retry in 30 seconds
    W: getaddrinfo, error: -11
  • That is log from the application, not the modem.
    Please see the link in my previous reply on how to take a modem trace.
