(context nrfconnect, nrf52840)
Hello Hakon,
I am making a USB HID, with 2 OUT reports in my descriptor.
I use the .int_out_ready
interrupt with some success to get my out report from a PC.
(CONFIG_USB_HID_REPORTS not set)
however,with a
the USB frames for out reports bigger than 16 bytes get sliced in chuncks of 16 bytes (4 .int_out_ready interrupts of 16 bytes each, for a 57 bytes out report).
My descriptor has already been used in another product with no problem.
I have tried what you describe, but I don't even get the
which is worse in a sense.
I come here because doing what's described here does not help me.
And the CONFIG_USB_HID_REPORTS=2 does not make any sense for me.
I have no problem with the IN reports.
I use hidapi on the PC. And the
Here is the current state of my code (in report code not shown ).
static void int_in_ready_cb(const struct device *dev){ ARG_UNUSED(dev); if (!atomic_test_and_clear_bit(hid_ep_busy, HID_EPIN_BUSY_FLAG)) { LOG_WRN("IN endpoint callback without preceding buffer write"); }}uint8_t data_from_pc[65];static void int_out_ready_cb(const struct device *dev){ ARG_UNUSED(dev); uint32_t ret_bytes; hid_int_ep_read(hdev,data_from_pc,64,&ret_bytes); if (ret_bytes>2) processReceivedUSBMessage(data_from_pc);}int set_report_cb(const struct device *dev, struct usb_setup_packet *setup, int32_t *len, uint8_t **data){ uint8_t request_value[2]; sys_put_le16(setup->wValue, request_value); switch (request_value[1]) { case 0x02: // REPORT_TYPE_FEATURE// LOG_INF("Output report ID: %x", request_value[0]); processReceivedUSBMessage(*data); break; default: LOG_INF("Req: %x", request_value[1]); break; } return 0;}static const struct hid_ops ops ={ .int_in_ready = int_in_ready_cb,// .on_idle = on_idle_cb,// .protocol_change = protocol_cb,// .int_out_ready = int_out_ready_cb, .set_report = set_report_cb};static void status_cb(enum usb_dc_status_code status, const uint8_t *param){ switch (status) { case USB_DC_RESET: case USB_DC_DISCONNECTED: configured = false; break; case USB_DC_CONFIGURED: if (!configured) { int_in_ready_cb(hdev); configured = true; } break; case USB_DC_SOF: break; default: LOG_DBG("status %u unhandled", status); break; }}void usbEnable(void){ int ret = usb_enable(status_cb); if (ret != 0) { LOG_ERR("Failed to enable USB"); return; }}static int composite_pre_init(const struct device *dev){ hdev = device_get_binding("HID_0"); if (hdev == NULL) { LOG_ERR("Cannot get USB HID Device"); return -ENODEV; } LOG_INF("HID Device: dev %p", hdev); usb_hid_register_device(hdev, hid_report_desc, sizeof(hid_report_desc), &ops); atomic_set_bit(hid_ep_busy, HID_EPIN_BUSY_FLAG); if (usb_hid_set_proto_code(hdev, HID_BOOT_IFACE_CODE_NONE)) { LOG_WRN("Failed to set Protocol Code"); } return usb_hid_init(hdev);}SYS_INIT(composite_pre_init, APPLICATION, CONFIG_KERNEL_INIT_PRIORITY_DEVICE);##################################end of the report descriptor for the out reports 0x15, 0x00, // LOGICAL_MINIMUM (0)
0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255)
0x85, 0x80, // REPORT_ID (128)
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x10, // REPORT_COUNT (16)
0x09, 0x00, // USAGE (Undefined)
0x91, 0x82, // OUTPUT (Data,Var,Abs,Vol)
0x85, 0x81, // REPORT_ID (129)
0x95, 0x38, // REPORT_COUNT (36)
0xC0 /* END_COLLECTION */I have paid attention to uninstall the usb hid drivers in the PC
But that would not be enough.
