mcuboot test image became active confirm without external confirm from mcumgr
I am testing with NCS 2.3.0,  nrf5340dk, on an application based on smp_svr sample.
I was testing with mcumgr  and found an unexpected behavior.  Maybe its a feature I have unwittingly enabled.
I added the configuration from nrf/tests/modules/mcuboot/external_flash to my smp_server sample based application.
I used mcumgr image upload to send the file
I did mcumgr image test <hash>  to prepare the test.
I triggered a reset (reset button) and on my next call to image list, only 1 image was found and it was active confirmed state.  I thought this would only be allowed if I used mcumgr to confirm the image.
Did I unknowingly disable the image swap feature from mcuboot when I copied the externa_flash test?
Is this somehow part of the serial recovery settings in the externa_flash test?
  • I'm not interested in serial recovery.
    I'm trying to get nrf5340 cpuapp and cpunet non-simultaneous upgrade from external flash.
    From internal flash I was able to perform the update using the swap method to test the downloaded image. After switching to external flash the swap/test procedure no longer works.
    It seems like cpunet update requires CONFIG_BOOT_UPGRADE_ONLY and CONFIG_BOOT_UPGRADE_ONLY prevents the swap, is that correct?
    Ah, good to get that cleared up then.
    This probably related to this note from Working with the nRF5340:
    The application core can be reverted, but doing so bricks the network core upon revertion, as the reversion process fills the network core with the content currently in the RAM that pcd uses. To enable this, define the USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY Kconfig option in the project-level Kconfig file. When this is option is defined, you can enable it by setting :kconfig:option`CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY`.
    I checked with our developers, and this is also the case for non-simultaneous updates for the nRF5340.
    EDIT: No wait, this is only the case if you test both network an appliucation image at the same time.
    Let me do some more testing and get back to you.
    Sigurd Hellesvik
  • With my https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/smp/mcuboot_smp_uart_feat_external_flash sample, I am able to update the application and tag the new update as "test" and then it will revert back on next reset:
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    I: Starting bootloader
    I: Primary image: magic=good, swap_type=0x4, copy_done=0x1, image_ok=0x1
    I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: test
    I: Starting swap using move algorithm.
    I: Bootloader chainload address offset: 0x10000
    AAA this to see it change.
    I: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Swap type: revert
    Change this to see it change.
    Is this what you want?
    Sigurd Hellesvik
