High current comsumption when GPIO and BLE enabled on nRF5340-DK
I am testing on nRF5340-DK(0.11.0) with nrf connect sdk(v2.4.0).
And Measuring current consumption.
When I added GPIO (button) to the scan_adv sample, High current consumption.
What is the problem?
modified scan_adv sample
/* main.c - Application main entry point */
 * Copyright (c) 2015-2016 Intel Corporation
#include <zephyr/types.h>
#include <stddef.h>
#include <zephyr/sys/util.h>
#include <zephyr/bluetooth/hci.h>
#define SW0_NODE	DT_ALIAS(sw0)
#if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios,
						      {0});
static struct gpio_callback button_cb_data;
static uint8_t mfg_data[] = { 0xff, 0xff, 0x00 };
static const struct bt_data ad[] = {
	BT_DATA(BT_DATA_MANUFACTURER_DATA, mfg_data, 3),
static void scan_cb(const bt_addr_le_t *addr, int8_t rssi, uint8_t adv_type,
		    struct net_buf_simple *buf)
	mfg_data[2]++;
	struct bt_le_scan_param scan_param = {
		.type       = BT_HCI_LE_SCAN_PASSIVE,
		.options    = BT_LE_SCAN_OPT_NONE,
		.interval   = 0x0010,
		.window     = 0x0010,
	int err;
#if 0
	if (!gpio_is_ready_dt(&button)) {
		return 0;
	err = gpio_pin_configure_dt(&button, GPIO_INPUT);
	if (err != 0) {
		return 0;
	err = gpio_pin_interrupt_configure_dt(&button,
					      GPIO_INT_EDGE_BOTH/*GPIO_INT_EDGE_TO_ACTIVE*/);
	if (err != 0) {
		return 0;
	printk("Starting Scanner/Advertiser Demo\n");
	/* Initialize the Bluetooth Subsystem */
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return 0;
	printk("Bluetooth initialized\n");
	err = bt_le_scan_start(&scan_param, scan_cb);
	if (err) {
		printk("Starting scanning failed (err %d)\n", err);
		return 0;
	do {
		k_sleep(K_MSEC(400));
#if 0
		/* Start advertising */
		err = bt_le_adv_start(BT_LE_ADV_NCONN, ad, ARRAY_SIZE(ad),
				      NULL, 0);
		if (err) {
			printk("Advertising failed to start (err %d)\n", err);
			return 0;
		err = bt_le_adv_stop();
		if (err) {
			printk("Advertising failed to stop (err %d)\n", err);
			return 0;
	} while (1);
	return 0;
GPIO disabled(3.62mA average)
GPIO enabled (3.99mA average)
