Regarding commissioning a matter device
I'm getting the following error when I'm trying to commission my matter device using chip-tool downloaded from https://snapcraft.io/install/chip-tool/ubuntu, into the thread network formed by OTBR in docker.
"Failed in verifying 'Attestation Information' command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors".
Also OTBR and chip-tool are in linux x86 machine.
And I'm trying to commission Nanoleaf matter bulb.
Could anyone please help me to get rid of this error ?
  • Yeah it's advertising but now I'm getting error saying "Failed in verifying 'Attestation Information' command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors".
    The output log of terminal is shown below
    1687332180.797206][15779:15779] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /mnt/chip_kvs
    [1687332180.798764][15779:15779] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /mnt/chip_factory.ini
    [1687332180.798793][15779:15779] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /mnt/chip_config.ini
    [1687332180.798805][15779:15779] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /mnt/chip_counters.ini
    [1687332180.798998][15779:15779] CHIP:DL: writing settings to file (/mnt/chip_counters.ini-0SZGzF)
    [1687332180.799323][15779:15779] CHIP:DL: renamed tmp file to file (/mnt/chip_counters.ini)
    [1687332180.799330][15779:15779] CHIP:DL: NVS set: chip-counters/reboot-count = 41 (0x29)
    [1687332180.799676][15779:15779] CHIP:DL: Got Ethernet interface: enp2s0
    [1687332180.799807][15779:15779] CHIP:DL: Found the primary Ethernet interface:enp2s0
    [1687332180.799909][15779:15779] CHIP:DL: Got WiFi interface: wlp3s0
    [1687332180.800015][15779:15779] CHIP:DL: Found the primary WiFi interface:wlp3s0
    [1687332180.800038][15779:15779] CHIP:IN: UDP::Init bind&listen port=0
    [1687332180.800056][15779:15779] CHIP:IN: UDP::Init bound to port=46831
    [1687332180.800060][15779:15779] CHIP:IN: UDP::Init bind&listen port=0
    [1687332180.800073][15779:15779] CHIP:IN: UDP::Init bound to port=57258
    [1687332180.800077][15779:15779] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1687332180.800080][15779:15779] CHIP:IN: TransportMgr initialized
    [1687332180.800088][15779:15779] CHIP:FP: Initializing FabricTable from persistent storage
    [1687332180.800123][15779:15779] CHIP:TS: Last Known Good Time: 2023-01-04T15:21:56
    [1687332180.800483][15779:15779] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x8DA70BA28B057D3E, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1687332180.800753][15779:15779] CHIP:ZCL: Using ZAP configuration...
    [1687332180.800971][15779:15779] CHIP:DL: MDNS failed to join multicast group on enp2s0 for address type IPv4: ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
    [1687332180.801288][15779:15779] CHIP:CTL: System State Initialized...
    [1687332180.801301][15779:15779] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332180.801316][15779:15779] CHIP:CTL: Setting attestation nonce to random value
    [1687332180.801330][15779:15779] CHIP:CTL: Setting CSR nonce to random value
    [1687332180.801342][15779:15779] CHIP:IN: UDP::Init bind&listen port=5550
    [1687332180.801391][15779:15779] CHIP:IN: UDP::Init bound to port=5550
    [1687332180.801395][15779:15779] CHIP:IN: UDP::Init bind&listen port=5550
    [1687332180.801405][15779:15779] CHIP:IN: UDP::Init bound to port=5550
    [1687332180.801408][15779:15779] CHIP:IN: TransportMgr initialized
    [1687332180.801528][15779:15805] CHIP:DL: CHIP task running
    [1687332180.801685][15779:15805] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332180.801692][15779:15805] CHIP:CTL: Setting attestation nonce to random value
    [1687332180.801710][15779:15805] CHIP:CTL: Setting CSR nonce to random value
    [1687332180.801992][15779:15805] CHIP:CTL: Generating NOC
    [1687332180.802256][15779:15805] CHIP:FP: Validating NOC chain
    [1687332180.802694][15779:15805] CHIP:FP: NOC chain validation successful
    [1687332180.802727][15779:15805] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1687332180.802731][15779:15805] CHIP:TS: Last Known Good Time: 2023-01-04T15:21:56
    [1687332180.802735][15779:15805] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1687332180.802738][15779:15805] CHIP:TS: Retaining current Last Known Good Time
    [1687332180.803039][15779:15805] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1687332180.803239][15779:15805] CHIP:TS: Committing Last Known Good Time to storage: 2023-01-04T15:21:56
    [1687332180.803446][15779:15805] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 8DA70BA28B057D3E)
    [1687332180.803454][15779:15805] CHIP:IN: UDP::Init bind&listen port=5550
    [1687332180.803473][15779:15805] CHIP:IN: UDP::Init bound to port=5550
    [1687332180.803476][15779:15805] CHIP:IN: UDP::Init bind&listen port=5550
    [1687332180.803489][15779:15805] CHIP:IN: UDP::Init bound to port=5550
    [1687332180.803492][15779:15805] CHIP:IN: TransportMgr initialized
    [1687332180.804809][15779:15805] CHIP:CTL: Setting wifi credentials from parameters
    [1687332180.804814][15779:15805] CHIP:CTL: Setting attestation nonce to random value
    [1687332180.804821][15779:15805] CHIP:CTL: Setting CSR nonce to random value
    [1687332180.804825][15779:15805] CHIP:CTL: Setting PASE-only commissioning from parameters
    [1687332180.804847][15779:15805] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332180.804850][15779:15805] CHIP:CTL: Starting commissioning discovery over BLE
    [1687332180.804857][15779:15805] CHIP:CTL: Starting commissioning discovery over DNS-SD
    [1687332180.804921][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on enp2s0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000063: Cannot assign requested address
    [1687332180.805021][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000065: Network is unreachable
    [1687332180.805026][15779:15805] CHIP:DIS: mDNS broadcast had only partial success: 4 successes and 2 failures.
    [1687332180.806125][15779:15804] CHIP:DL: TRACE: Bus acquired for name C-3da3
    [1687332180.807967][15779:15805] CHIP:DL: PlatformBlueZInit init success
    [1687332180.809165][15779:15804] CHIP:BLE: BLE removing known devices.
    [1687332180.809756][15779:15804] CHIP:BLE: BLE initiating scan.
    [1687332180.929643][15779:15805] CHIP:DL: Long dispatch time: 124 ms, for event type 2
    [1687332180.933627][15779:15804] CHIP:BLE: Device FD:43:F6:0B:17:56 does not look like a CHIP device.
    [1687332180.939901][15779:15804] CHIP:BLE: Device 0F:30:69:85:1A:30 does not look like a CHIP device.
    [1687332180.960228][15779:15804] CHIP:BLE: Device 90:38:0C:EE:5F:BA does not look like a CHIP device.
    [1687332181.296349][15779:15804] CHIP:BLE: Device 28:DE:65:69:DA:69 does not look like a CHIP device.
    [1687332181.296961][15779:15804] CHIP:BLE: Device 2B:E6:FE:EB:2E:75 does not look like a CHIP device.
    [1687332181.297893][15779:15804] CHIP:BLE: Device 03:DB:05:38:1A:B8 does not look like a CHIP device.
    [1687332181.298745][15779:15804] CHIP:BLE: New device scanned: 48:22:54:5F:2B:F3
    [1687332181.298762][15779:15804] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1687332181.310504][15779:15804] CHIP:BLE: Scan complete notification without an active scan.
    [1687332181.806871][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on enp2s0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000063: Cannot assign requested address
    [1687332181.807126][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000065: Network is unreachable
    [1687332181.807166][15779:15805] CHIP:DIS: mDNS broadcast had only partial success: 3 successes and 2 failures.
    [1687332181.870917][15779:15804] CHIP:DL: ConnectDevice complete
    [1687332182.694439][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694453][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694458][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694460][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694464][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694466][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694471][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687332182.694474][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694477][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687332182.694480][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694483][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687332182.694486][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694491][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694494][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694498][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694500][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694508][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694511][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694515][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694517][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694521][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687332182.694524][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694532][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694536][15779:15804] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687332182.694542][15779:15804] CHIP:DL: New BLE connection 0x7f5948073de0, device 48:22:54:5F:2B:F3, path /org/bluez/hci0/dev_48_22_54_5F_2B_F3
    [1687332182.694575][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1687332182.694583][15779:15805] CHIP:CTL: Discovered device to be commissioned over BLE
    [1687332182.694592][15779:15805] CHIP:CTL: Attempting PASE connection to BLE
    [1687332182.694603][15779:15805] CHIP:IN: BleConnectionComplete: endPoint 0x563852c5eb20
    [1687332182.694646][15779:15805] CHIP:IN: SecureSession[0x7f594000ff10]: Allocated Type:1 LSID:19592
    [1687332182.694651][15779:15805] CHIP:SC: Assigned local session key ID 19592
    [1687332182.694672][15779:15805] CHIP:EM: <<< [E:64287i M:208376926] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1687332182.694683][15779:15805] CHIP:IN: (U) Sending msg 208376926 to IP address 'BLE'
    [1687332182.694689][15779:15805] CHIP:IN: Message appended to BLE send queue
    [1687332182.694694][15779:15805] CHIP:SC: Sent PBKDF param request
    [1687332182.694699][15779:15805] CHIP:CTL: Commission called for node ID 0x0000000000001548
    [1687332183.504402][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332183.579966][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1687332183.579992][15779:15805] CHIP:BLE: subscribe complete, ep = 0x563852c5eb20
    [1687332183.580017][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332183.580110][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332183.580128][15779:15805] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1687332183.580136][15779:15805] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1687332183.580142][15779:15805] CHIP:BLE: local and remote recv window size = 5
    [1687332183.580188][15779:15805] CHIP:IN: BLE EndPoint 0x563852c5eb20 Connection Complete
    [1687332183.669513][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332183.760194][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332183.760277][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332183.760351][15779:15805] CHIP:EM: >>> [E:64287i M:146526867] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1687332183.760366][15779:15805] CHIP:EM: Found matching exchange: 64287i, Delegate: 0x7f59400197d0
    [1687332183.760384][15779:15805] CHIP:SC: Received PBKDF param response
    [1687332183.760405][15779:15805] CHIP:SC: Peer assigned session ID 64722
    [1687332183.760419][15779:15805] CHIP:SC: Found MRP parameters in the message
    [1687332183.785073][15779:15805] CHIP:EM: <<< [E:64287i M:208376927] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1687332183.785092][15779:15805] CHIP:IN: (U) Sending msg 208376927 to IP address 'BLE'
    [1687332183.785125][15779:15805] CHIP:SC: Sent spake2p msg1
    [1687332183.806330][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on enp2s0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000063: Cannot assign requested address
    [1687332183.808861][15779:15805] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000065: Network is unreachable
    [1687332183.808870][15779:15805] CHIP:DIS: mDNS broadcast had only partial success: 3 successes and 2 failures.
    [1687332183.850412][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332184.795937][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332184.796032][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332184.796100][15779:15805] CHIP:EM: >>> [E:64287i M:146526868] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1687332184.796113][15779:15805] CHIP:EM: Found matching exchange: 64287i, Delegate: 0x7f59400197d0
    [1687332184.796127][15779:15805] CHIP:SC: Received spake2p msg2
    [1687332184.796876][15779:15805] CHIP:EM: <<< [E:64287i M:208376928] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1687332184.796895][15779:15805] CHIP:IN: (U) Sending msg 208376928 to IP address 'BLE'
    [1687332184.796930][15779:15805] CHIP:SC: Sent spake2p msg3
    [1687332184.885511][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332184.930866][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332184.931002][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332184.931097][15779:15805] CHIP:EM: >>> [E:64287i M:146526869] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1687332184.931117][15779:15805] CHIP:EM: Found matching exchange: 64287i, Delegate: 0x7f59400197d0
    [1687332184.931230][15779:15805] CHIP:SC: SecureSession[0x7f594000ff10]: Moving from state 'kEstablishing' --> 'kActive'
    [1687332184.931240][15779:15805] CHIP:IN: SecureSession[0x7f594000ff10]: Activated - Type:1 LSID:19592
    [1687332184.931244][15779:15805] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:19592 PSID:64722!
    [1687332184.931253][15779:15805] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1687332184.931261][15779:15805] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332184.931266][15779:15805] CHIP:TOO: Pairing Success
    [1687332184.931270][15779:15805] CHIP:TOO: PASE establishment successful
    [1687332184.931276][15779:15805] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1687332184.931284][15779:15805] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1687332184.931290][15779:15805] CHIP:CTL: Sending request for commissioning information
    [1687332184.931310][15779:15805] CHIP:DMG: SendReadRequest ReadClient[0x7f594001b4c0]: Sending Read Request
    [1687332184.931391][15779:15805] CHIP:EM: <<< [E:64288i M:43174472] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    [1687332184.931410][15779:15805] CHIP:IN: (S) Sending msg 43174472 on secure session with LSID: 19592
    [1687332184.931460][15779:15805] CHIP:DMG: MoveToState ReadClient[0x7f594001b4c0]: Moving to [AwaitingIn]
    [1687332185.020497][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332185.156144][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.156288][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332185.246137][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.246235][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332185.246335][15779:15805] CHIP:EM: >>> [E:64288i M:188327128] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1687332185.246350][15779:15805] CHIP:EM: Found matching exchange: 64288i, Delegate: 0x7f594001b4d0
    [1687332185.246404][15779:15805] CHIP:DMG: ReportDataMessage =
    [1687332185.246413][15779:15805] CHIP:DMG: {
    [1687332185.246421][15779:15805] CHIP:DMG:     AttributeReportIBs =
    [1687332185.246436][15779:15805] CHIP:DMG:     [
    [1687332185.246443][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.246459][15779:15805] CHIP:DMG:         {
    [1687332185.246466][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.246478][15779:15805] CHIP:DMG:             {
    [1687332185.246488][15779:15805] CHIP:DMG:                 DataVersion = 0x4ff6d6f2,
    [1687332185.246497][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.246510][15779:15805] CHIP:DMG:                 {
    [1687332185.246522][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.246531][15779:15805] CHIP:DMG:                     Cluster = 0x31,
    [1687332185.246542][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1687332185.246556][15779:15805] CHIP:DMG:                 }
    [1687332185.246570][15779:15805] CHIP:DMG:
    [1687332185.246582][15779:15805] CHIP:DMG:                 Data = 20,
    [1687332185.246594][15779:15805] CHIP:DMG:             },
    [1687332185.246608][15779:15805] CHIP:DMG:
    [1687332185.246616][15779:15805] CHIP:DMG:         },
    [1687332185.246635][15779:15805] CHIP:DMG:
    [1687332185.246644][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.246657][15779:15805] CHIP:DMG:         {
    [1687332185.246664][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.246675][15779:15805] CHIP:DMG:             {
    [1687332185.246685][15779:15805] CHIP:DMG:                 DataVersion = 0x6b40079a,
    [1687332185.246698][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.246710][15779:15805] CHIP:DMG:                 {
    [1687332185.246718][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.246731][15779:15805] CHIP:DMG:                     Cluster = 0x28,
    [1687332185.246743][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0004,
    [1687332185.246756][15779:15805] CHIP:DMG:                 }
    [1687332185.246769][15779:15805] CHIP:DMG:
    [1687332185.246780][15779:15805] CHIP:DMG:                 Data = 257,
    [1687332185.246790][15779:15805] CHIP:DMG:             },
    [1687332185.246805][15779:15805] CHIP:DMG:
    [1687332185.246811][15779:15805] CHIP:DMG:         },
    [1687332185.246823][15779:15805] CHIP:DMG:
    [1687332185.246828][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.246843][15779:15805] CHIP:DMG:         {
    [1687332185.246852][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.246862][15779:15805] CHIP:DMG:             {
    [1687332185.246872][15779:15805] CHIP:DMG:                 DataVersion = 0x6b40079a,
    [1687332185.246882][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.246892][15779:15805] CHIP:DMG:                 {
    [1687332185.246903][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.246914][15779:15805] CHIP:DMG:                     Cluster = 0x28,
    [1687332185.246925][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1687332185.246935][15779:15805] CHIP:DMG:                 }
    [1687332185.246948][15779:15805] CHIP:DMG:
    [1687332185.246959][15779:15805] CHIP:DMG:                 Data = 4488,
    [1687332185.246968][15779:15805] CHIP:DMG:             },
    [1687332185.246980][15779:15805] CHIP:DMG:
    [1687332185.246989][15779:15805] CHIP:DMG:         },
    [1687332185.247006][15779:15805] CHIP:DMG:
    [1687332185.247012][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.247027][15779:15805] CHIP:DMG:         {
    [1687332185.247033][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.247040][15779:15805] CHIP:DMG:             {
    [1687332185.247055][15779:15805] CHIP:DMG:                 DataVersion = 0x80e5156d,
    [1687332185.247064][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.247070][15779:15805] CHIP:DMG:                 {
    [1687332185.247076][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.247082][15779:15805] CHIP:DMG:                     Cluster = 0x30,
    [1687332185.247087][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1687332185.247092][15779:15805] CHIP:DMG:                 }
    [1687332185.247101][15779:15805] CHIP:DMG:
    [1687332185.247113][15779:15805] CHIP:DMG:                 Data = 0,
    [1687332185.247123][15779:15805] CHIP:DMG:             },
    [1687332185.247136][15779:15805] CHIP:DMG:
    [1687332185.247145][15779:15805] CHIP:DMG:         },
    [1687332185.247157][15779:15805] CHIP:DMG:
    [1687332185.247163][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.247179][15779:15805] CHIP:DMG:         {
    [1687332185.247188][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.247201][15779:15805] CHIP:DMG:             {
    [1687332185.247209][15779:15805] CHIP:DMG:                 DataVersion = 0x80e5156d,
    [1687332185.247218][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.247225][15779:15805] CHIP:DMG:                 {
    [1687332185.247232][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.247245][15779:15805] CHIP:DMG:                     Cluster = 0x30,
    [1687332185.247260][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1687332185.247269][15779:15805] CHIP:DMG:                 }
    [1687332185.247281][15779:15805] CHIP:DMG:
    [1687332185.247292][15779:15805] CHIP:DMG:                 Data = 0,
    [1687332185.247302][15779:15805] CHIP:DMG:             },
    [1687332185.247310][15779:15805] CHIP:DMG:
    [1687332185.247319][15779:15805] CHIP:DMG:         },
    [1687332185.247338][15779:15805] CHIP:DMG:
    [1687332185.247344][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.247361][15779:15805] CHIP:DMG:         {
    [1687332185.247369][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.247380][15779:15805] CHIP:DMG:             {
    [1687332185.247391][15779:15805] CHIP:DMG:                 DataVersion = 0x80e5156d,
    [1687332185.247401][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.247412][15779:15805] CHIP:DMG:                 {
    [1687332185.247423][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.247439][15779:15805] CHIP:DMG:                     Cluster = 0x30,
    [1687332185.247448][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0001,
    [1687332185.247458][15779:15805] CHIP:DMG:                 }
    [1687332185.247475][15779:15805] CHIP:DMG:
    [1687332185.247486][15779:15805] CHIP:DMG:                 Data =
    [1687332185.247497][15779:15805] CHIP:DMG:                 {
    [1687332185.247509][15779:15805] CHIP:DMG:                     0x0 = 60,
    [1687332185.247519][15779:15805] CHIP:DMG:                     0x1 = 900,
    [1687332185.247530][15779:15805] CHIP:DMG:                 },
    [1687332185.247540][15779:15805] CHIP:DMG:             },
    [1687332185.247554][15779:15805] CHIP:DMG:
    [1687332185.247563][15779:15805] CHIP:DMG:         },
    [1687332185.247579][15779:15805] CHIP:DMG:
    [1687332185.247585][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.247602][15779:15805] CHIP:DMG:         {
    [1687332185.247611][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.247622][15779:15805] CHIP:DMG:             {
    [1687332185.247631][15779:15805] CHIP:DMG:                 DataVersion = 0x80e5156d,
    [1687332185.247641][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.247650][15779:15805] CHIP:DMG:                 {
    [1687332185.247661][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.247668][15779:15805] CHIP:DMG:                     Cluster = 0x30,
    [1687332185.247680][15779:15805] CHIP:DMG:                     Attribute = 0x0000_0000,
    [1687332185.247690][15779:15805] CHIP:DMG:                 }
    [1687332185.247702][15779:15805] CHIP:DMG:
    [1687332185.247712][15779:15805] CHIP:DMG:                 Data = 0,
    [1687332185.247721][15779:15805] CHIP:DMG:             },
    [1687332185.247734][15779:15805] CHIP:DMG:
    [1687332185.247742][15779:15805] CHIP:DMG:         },
    [1687332185.247758][15779:15805] CHIP:DMG:
    [1687332185.247769][15779:15805] CHIP:DMG:         AttributeReportIB =
    [1687332185.247781][15779:15805] CHIP:DMG:         {
    [1687332185.247787][15779:15805] CHIP:DMG:             AttributeDataIB =
    [1687332185.247798][15779:15805] CHIP:DMG:             {
    [1687332185.247806][15779:15805] CHIP:DMG:                 DataVersion = 0x4ff6d6f2,
    [1687332185.247816][15779:15805] CHIP:DMG:                 AttributePathIB =
    [1687332185.247827][15779:15805] CHIP:DMG:                 {
    [1687332185.247837][15779:15805] CHIP:DMG:                     Endpoint = 0x0,
    [1687332185.247848][15779:15805] CHIP:DMG:                     Cluster = 0x31,
    [1687332185.247858][15779:15805] CHIP:DMG:                     Attribute = 0x0000_FFFC,
    [1687332185.247867][15779:15805] CHIP:DMG:                 }
    [1687332185.247879][15779:15805] CHIP:DMG:
    [1687332185.247887][15779:15805] CHIP:DMG:                 Data = 1,
    [1687332185.247893][15779:15805] CHIP:DMG:             },
    [1687332185.247903][15779:15805] CHIP:DMG:
    [1687332185.247911][15779:15805] CHIP:DMG:         },
    [1687332185.247926][15779:15805] CHIP:DMG:
    [1687332185.247935][15779:15805] CHIP:DMG:     ],
    [1687332185.247970][15779:15805] CHIP:DMG:
    [1687332185.247980][15779:15805] CHIP:DMG:     SuppressResponse = true,
    [1687332185.247990][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332185.247998][15779:15805] CHIP:DMG: }
    [1687332185.248423][15779:15805] CHIP:CTL: ----- NetworkCommissioning Features: has WiFi. endpointid = 0
    [1687332185.248462][15779:15805] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1687332185.248473][15779:15805] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1687332185.248486][15779:15805] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1687332185.248495][15779:15805] CHIP:CTL: Arming failsafe (60 seconds)
    [1687332185.248528][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332185.248542][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332185.248588][15779:15805] CHIP:EM: <<< [E:64289i M:43174473] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332185.248601][15779:15805] CHIP:IN: (S) Sending msg 43174473 on secure session with LSID: 19592
    [1687332185.248637][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332185.335805][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332185.336694][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.336785][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332185.336893][15779:15805] CHIP:EM: >>> [E:64289i M:188327129] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332185.336909][15779:15805] CHIP:EM: Found matching exchange: 64289i, Delegate: 0x7f59480472a8
    [1687332185.336927][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332185.336961][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332185.336973][15779:15805] CHIP:DMG: {
    [1687332185.337001][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332185.337011][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332185.337274][15779:15805] CHIP:DMG:     [
    [1687332185.337285][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332185.337296][15779:15805] CHIP:DMG:         {
    [1687332185.337303][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332185.337314][15779:15805] CHIP:DMG:             {
    [1687332185.337323][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332185.337336][15779:15805] CHIP:DMG:                 {
    [1687332185.337347][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332185.337465][15779:15805] CHIP:DMG:                     ClusterId = 0x30,
    [1687332185.337478][15779:15805] CHIP:DMG:                     CommandId = 0x1,
    [1687332185.337488][15779:15805] CHIP:DMG:                 },
    [1687332185.337501][15779:15805] CHIP:DMG:
    [1687332185.337513][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332185.337523][15779:15805] CHIP:DMG:                 {
    [1687332185.337536][15779:15805] CHIP:DMG:                     0x0 = 0,
    [1687332185.337548][15779:15805] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687332185.337561][15779:15805] CHIP:DMG:                 },
    [1687332185.337570][15779:15805] CHIP:DMG:             },
    [1687332185.337584][15779:15805] CHIP:DMG:
    [1687332185.337593][15779:15805] CHIP:DMG:         },
    [1687332185.337609][15779:15805] CHIP:DMG:
    [1687332185.337617][15779:15805] CHIP:DMG:     ],
    [1687332185.337633][15779:15805] CHIP:DMG:
    [1687332185.337642][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332185.337652][15779:15805] CHIP:DMG: },
    [1687332185.337695][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687332185.337729][15779:15805] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1687332185.337744][15779:15805] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1687332185.337753][15779:15805] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1687332185.337765][15779:15805] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1687332185.337773][15779:15805] CHIP:CTL: Setting Regulatory Config
    [1687332185.337781][15779:15805] CHIP:CTL: Device does not support configurable regulatory location
    [1687332185.337816][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332185.337831][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332185.337884][15779:15805] CHIP:EM: <<< [E:64290i M:43174474] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332185.337901][15779:15805] CHIP:IN: (S) Sending msg 43174474 on secure session with LSID: 19592
    [1687332185.337945][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332185.337981][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332185.470705][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332185.516375][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.516487][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332185.516603][15779:15805] CHIP:EM: >>> [E:64290i M:188327130] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332185.516618][15779:15805] CHIP:EM: Found matching exchange: 64290i, Delegate: 0x7f594000a4c8
    [1687332185.516631][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332185.516654][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332185.516662][15779:15805] CHIP:DMG: {
    [1687332185.516672][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332185.516679][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332185.516690][15779:15805] CHIP:DMG:     [
    [1687332185.516696][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332185.516708][15779:15805] CHIP:DMG:         {
    [1687332185.516713][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332185.516725][15779:15805] CHIP:DMG:             {
    [1687332185.516731][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332185.516741][15779:15805] CHIP:DMG:                 {
    [1687332185.516749][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332185.516766][15779:15805] CHIP:DMG:                     ClusterId = 0x30,
    [1687332185.516774][15779:15805] CHIP:DMG:                     CommandId = 0x3,
    [1687332185.516780][15779:15805] CHIP:DMG:                 },
    [1687332185.516789][15779:15805] CHIP:DMG:
    [1687332185.516796][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332185.516805][15779:15805] CHIP:DMG:                 {
    [1687332185.516817][15779:15805] CHIP:DMG:                     0x0 = 0,
    [1687332185.516826][15779:15805] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687332185.516834][15779:15805] CHIP:DMG:                 },
    [1687332185.516841][15779:15805] CHIP:DMG:             },
    [1687332185.516850][15779:15805] CHIP:DMG:
    [1687332185.516856][15779:15805] CHIP:DMG:         },
    [1687332185.516867][15779:15805] CHIP:DMG:
    [1687332185.516872][15779:15805] CHIP:DMG:     ],
    [1687332185.516883][15779:15805] CHIP:DMG:
    [1687332185.516890][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332185.516895][15779:15805] CHIP:DMG: },
    [1687332185.516921][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1687332185.516936][15779:15805] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1687332185.516947][15779:15805] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1687332185.516954][15779:15805] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1687332185.516964][15779:15805] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1687332185.516969][15779:15805] CHIP:CTL: Sending request for PAI certificate
    [1687332185.516974][15779:15805] CHIP:CTL: Sending Certificate Chain request to 0x7f5940019780 device
    [1687332185.517014][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332185.517037][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332185.517075][15779:15805] CHIP:EM: <<< [E:64291i M:43174475] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332185.517088][15779:15805] CHIP:IN: (S) Sending msg 43174475 on secure session with LSID: 19592
    [1687332185.517127][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332185.517151][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332185.605674][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332185.741136][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.741249][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332185.921282][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332185.921402][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332186.011258][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332186.011405][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332186.011498][15779:15805] CHIP:EM: >>> [E:64291i M:188327131] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332186.011513][15779:15805] CHIP:EM: Found matching exchange: 64291i, Delegate: 0x7f59480472a8
    [1687332186.011531][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332186.011556][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332186.011563][15779:15805] CHIP:DMG: {
    [1687332186.011571][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332186.011578][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332186.011590][15779:15805] CHIP:DMG:     [
    [1687332186.011596][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332186.011613][15779:15805] CHIP:DMG:         {
    [1687332186.011624][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332186.011634][15779:15805] CHIP:DMG:             {
    [1687332186.011646][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332186.011653][15779:15805] CHIP:DMG:                 {
    [1687332186.011660][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332186.011669][15779:15805] CHIP:DMG:                     ClusterId = 0x3e,
    [1687332186.011682][15779:15805] CHIP:DMG:                     CommandId = 0x3,
    [1687332186.011691][15779:15805] CHIP:DMG:                 },
    [1687332186.011729][15779:15805] CHIP:DMG:
    [1687332186.011739][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332186.011751][15779:15805] CHIP:DMG:                 {
    [1687332186.011772][15779:15805] CHIP:DMG:                     0x0 = [
    [1687332186.011847][15779:15805] CHIP:DMG:                             0x30, 0x82, 0x01, 0xda, 0x30, 0x82, 0x01, 0x80, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x4a, 0x55, 0x95, 0xca, 0xad, 0x8e, 0xcb, 0xd9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x33, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x31, 0x31, 0x30, 0x33, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x8e, 0x78, 0x82, 0x5a, 0x5a, 0xa7, 0xc4, 0xc8, 0x9e, 0xd6, 0xa8, 0x78, 0x08, 0x67, 0x32, 0x2e, 0x6a, 0xbb, 0xaa, 0x01, 0x1a, 0xee, 0xa4, 0xec, 0x26, 0xdb, 0x64, 0xd4, 0x47, 0xbe, 0xc7, 0xc3, 0x16, 0x7d, 0xb4, 0x19, 0x8a, 0x21, 0x15, 0x65, 0x7f, 0x63, 0x32, 0xc5, 0x38, 0x15, 0xc2, 0xbd, 0x8f, 0xa2, 0x52, 0x9d, 0x9e, 0xa0, 0xf8, 0xad, 0xb1, 0x42, 0xa2, 0x
    [1687332186.011893][15779:15805] CHIP:DMG:                     ] (478 bytes)
    [1687332186.011905][15779:15805] CHIP:DMG:                 },
    [1687332186.011913][15779:15805] CHIP:DMG:             },
    [1687332186.011923][15779:15805] CHIP:DMG:
    [1687332186.011936][15779:15805] CHIP:DMG:         },
    [1687332186.011952][15779:15805] CHIP:DMG:
    [1687332186.011960][15779:15805] CHIP:DMG:     ],
    [1687332186.011975][15779:15805] CHIP:DMG:
    [1687332186.011984][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332186.011993][15779:15805] CHIP:DMG: },
    [1687332186.012030][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1687332186.012045][15779:15805] CHIP:CTL: Received certificate chain from the device
    [1687332186.012058][15779:15805] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1687332186.012071][15779:15805] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1687332186.012086][15779:15805] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1687332186.012095][15779:15805] CHIP:CTL: Sending request for DAC certificate
    [1687332186.012101][15779:15805] CHIP:CTL: Sending Certificate Chain request to 0x7f5940019780 device
    [1687332186.012133][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332186.012146][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332186.012196][15779:15805] CHIP:EM: <<< [E:64292i M:43174476] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332186.012213][15779:15805] CHIP:IN: (S) Sending msg 43174476 on secure session with LSID: 19592
    [1687332186.012260][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332186.012286][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332186.100647][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332186.236070][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332186.236203][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332186.461155][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332186.461288][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332186.551731][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332186.551898][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332186.552000][15779:15805] CHIP:EM: >>> [E:64292i M:188327132] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332186.552017][15779:15805] CHIP:EM: Found matching exchange: 64292i, Delegate: 0x7f59480058a8
    [1687332186.552038][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332186.552079][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332186.552088][15779:15805] CHIP:DMG: {
    [1687332186.552097][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332186.552106][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332186.552121][15779:15805] CHIP:DMG:     [
    [1687332186.552131][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332186.552145][15779:15805] CHIP:DMG:         {
    [1687332186.552152][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332186.552161][15779:15805] CHIP:DMG:             {
    [1687332186.552170][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332186.552183][15779:15805] CHIP:DMG:                 {
    [1687332186.552194][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332186.552206][15779:15805] CHIP:DMG:                     ClusterId = 0x3e,
    [1687332186.552217][15779:15805] CHIP:DMG:                     CommandId = 0x3,
    [1687332186.552228][15779:15805] CHIP:DMG:                 },
    [1687332186.552241][15779:15805] CHIP:DMG:
    [1687332186.552248][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332186.552259][15779:15805] CHIP:DMG:                 {
    [1687332186.552272][15779:15805] CHIP:DMG:                     0x0 = [
    [1687332186.552345][15779:15805] CHIP:DMG:                             0x30, 0x82, 0x01, 0xeb, 0x30, 0x82, 0x01, 0x90, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x50, 0x04, 0xca, 0x35, 0x9a, 0x9e, 0x85, 0x27, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x31, 0x31, 0x30, 0x33, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x41, 0x43, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x0c, 0x1d, 0xae, 0x80, 0x17, 0x17, 0xd1, 0x2f, 0xe3, 0xa6, 0x08, 0x50, 0xa2, 0x8b, 0x21, 0x03, 0xf6, 0xc2, 0x15, 0x6f, 0xe8, 0x9c, 0xa1, 0x9b, 0x59, 0xff, 0xf2, 0x2e, 0x42, 0xca, 0x25, 0x30, 0xe3, 0x10, 0xab, 0x72, 0x00, 0x
    [1687332186.552375][15779:15805] CHIP:DMG:                     ] (495 bytes)
    [1687332186.552389][15779:15805] CHIP:DMG:                 },
    [1687332186.552406][15779:15805] CHIP:DMG:             },
    [1687332186.552420][15779:15805] CHIP:DMG:
    [1687332186.552429][15779:15805] CHIP:DMG:         },
    [1687332186.552441][15779:15805] CHIP:DMG:
    [1687332186.552450][15779:15805] CHIP:DMG:     ],
    [1687332186.552466][15779:15805] CHIP:DMG:
    [1687332186.552474][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332186.552486][15779:15805] CHIP:DMG: },
    [1687332186.552526][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1687332186.552543][15779:15805] CHIP:CTL: Received certificate chain from the device
    [1687332186.552558][15779:15805] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1687332186.552568][15779:15805] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1687332186.552581][15779:15805] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1687332186.552590][15779:15805] CHIP:CTL: Sending Attestation Request to the device.
    [1687332186.552598][15779:15805] CHIP:CTL: Sending Attestation request to 0x7f5940019780 device
    [1687332186.552628][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332186.552639][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332186.552680][15779:15805] CHIP:EM: <<< [E:64293i M:43174477] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332186.552693][15779:15805] CHIP:IN: (S) Sending msg 43174477 on secure session with LSID: 19592
    [1687332186.552732][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332186.552742][15779:15805] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1687332186.552763][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332186.640430][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332186.911166][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332186.911258][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332187.046112][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332187.046244][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332187.046333][15779:15805] CHIP:EM: >>> [E:64293i M:188327133] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332187.046348][15779:15805] CHIP:EM: Found matching exchange: 64293i, Delegate: 0x7f5948040458
    [1687332187.046362][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332187.046393][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332187.046399][15779:15805] CHIP:DMG: {
    [1687332187.046404][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332187.046409][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332187.046419][15779:15805] CHIP:DMG:     [
    [1687332187.046423][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332187.046433][15779:15805] CHIP:DMG:         {
    [1687332187.046440][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332187.046448][15779:15805] CHIP:DMG:             {
    [1687332187.046453][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332187.046464][15779:15805] CHIP:DMG:                 {
    [1687332187.046472][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332187.046483][15779:15805] CHIP:DMG:                     ClusterId = 0x3e,
    [1687332187.046496][15779:15805] CHIP:DMG:                     CommandId = 0x1,
    [1687332187.046503][15779:15805] CHIP:DMG:                 },
    [1687332187.046513][15779:15805] CHIP:DMG:
    [1687332187.046519][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332187.046527][15779:15805] CHIP:DMG:                 {
    [1687332187.046535][15779:15805] CHIP:DMG:                     0x0 = [
    [1687332187.046586][15779:15805] CHIP:DMG:                             0x15, 0x30, 0x01, 0xeb, 0x30, 0x81, 0xe8, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x81, 0xda, 0x30, 0x81, 0xd7, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x44, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x37, 0x04, 0x35, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0x88, 0x11, 0x36, 0x02, 0x05, 0x01, 0x01, 0x18, 0x25, 0x03, 0x0a, 0x01, 0x2c, 0x04, 0x13, 0x43, 0x53, 0x41, 0x32, 0x32, 0x31, 0x36, 0x35, 0x4d, 0x41, 0x54, 0x34, 0x30, 0x31, 0x36, 0x35, 0x2d, 0x32, 0x34, 0x24, 0x05, 0x00, 0x24, 0x06, 0x00, 0x24, 0x07, 0x01, 0x24, 0x08, 0x02, 0x18, 0x31, 0x7d, 0x30, 0x7b, 0x02, 0x01, 0x03, 0x80, 0x14, 0xfe, 0x34, 0x3f, 0x95, 0x99, 0x47, 0x76, 0x3b, 0x61, 0xee, 0x45, 0x39, 0x13, 0x13, 0x38, 0x49, 0x4f, 0xe6, 0x7d, 0x8e, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x04, 0x47, 0x30, 0x45, 0x02, 0x21, 0x00, 0x89, 0x38, 0x2b, 0xe2, 0x94, 0x74, 0x5a, 0xea, 0x8c, 0x45, 0xf0, 0x5c, 0xf5, 0x8d, 0xb8, 0x41, 0xa2, 0x3e, 0x07, 0x68, 0x43, 0xdc, 0x6e, 0x36, 0xe7, 0x93, 0x99, 0x5c, 0x8f, 0xbb, 0x3d, 0x2f, 0x02, 0x20, 0x7f, 0x86, 0x94, 0xc5, 0xe3, 0x33, 0x7a, 0x5b, 0x28, 0x8f, 0xe1, 0x5c, 0x8b, 0x69, 0x2d, 0x08, 0x45, 0xd0, 0x3b, 0x9a, 0x1b, 0xc5, 0x9a, 0x3d, 0xb5, 0xd8, 0x9f, 0xf9, 0x8d, 0xb1, 0x7e, 0x29, 0x30, 0x02, 0x20, 0xae, 0x90, 0x62, 0x85, 0xb0, 0x60, 0x5a, 0xf8, 0x4f, 0x09, 0xcd, 0x07, 0x08, 0xbd, 0x28, 0x96, 0x4a, 0x4f, 0x05, 0xd5, 0x08, 0x13, 0x11, 0x8a, 0x79, 0x0f, 0x16, 0x37, 0xa4, 0x16, 0xc3, 0x3e, 0x24, 0x03, 0x00, 0x18,
    [1687332187.046615][15779:15805] CHIP:DMG:                     ] (278 bytes)
    [1687332187.046622][15779:15805] CHIP:DMG:                     0x1 = [
    [1687332187.046639][15779:15805] CHIP:DMG:                             0x74, 0xa1, 0xad, 0xe9, 0xf1, 0xae, 0xe3, 0x03, 0x15, 0xdb, 0x7d, 0x49, 0x67, 0x2f, 0x51, 0x74, 0xe9, 0xb8, 0xf2, 0x82, 0xfa, 0x31, 0x0c, 0x43, 0xc5, 0x0b, 0x5c, 0x5a, 0x64, 0x46, 0xa3, 0x30, 0x42, 0xfc, 0xb3, 0x0a, 0x3f, 0x7f, 0x68, 0xd1, 0xd6, 0xd6, 0x16, 0x89, 0xee, 0xeb, 0x7f, 0x69, 0x59, 0x1f, 0xd4, 0x47, 0x7a, 0x73, 0x80, 0x89, 0x6e, 0x10, 0xd4, 0xb6, 0x48, 0x3a, 0x96, 0x6b,
    [1687332187.046651][15779:15805] CHIP:DMG:                     ] (64 bytes)
    [1687332187.046658][15779:15805] CHIP:DMG:                 },
    [1687332187.046664][15779:15805] CHIP:DMG:             },
    [1687332187.046674][15779:15805] CHIP:DMG:
    [1687332187.046679][15779:15805] CHIP:DMG:         },
    [1687332187.046689][15779:15805] CHIP:DMG:
    [1687332187.046695][15779:15805] CHIP:DMG:     ],
    [1687332187.046705][15779:15805] CHIP:DMG:
    [1687332187.046712][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332187.046737][15779:15805] CHIP:DMG: },
    [1687332187.046783][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1687332187.046803][15779:15805] CHIP:CTL: Received Attestation Information from the device
    [1687332187.046816][15779:15805] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1687332187.046828][15779:15805] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 278/278
    [1687332187.046850][15779:15805] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1687332187.046860][15779:15805] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1687332187.046867][15779:15805] CHIP:CTL: Verifying attestation
    [1687332187.061090][15779:15805] CHIP:CTL: Failed in verifying 'Attestation Information' command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors
    [1687332187.061126][15779:15805] CHIP:CTL: Error on commissioning step 'AttestationVerification': '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:1075: CHIP Error 0x000000AC: Internal error'
    [1687332187.061132][15779:15805] CHIP:CTL: Failed to perform commissioning step 8
    [1687332187.061137][15779:15805] CHIP:CTL: Going from commissioning step 'AttestationVerification' with lastErr = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:1075: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
    [1687332187.061148][15779:15805] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:1075: CHIP Error 0x000000AC: Internal error'
    [1687332187.061153][15779:15805] CHIP:CTL: Expiring failsafe on proxy 0x7f5940019780
    [1687332187.061181][15779:15805] CHIP:DMG: ICR moving to [AddingComm]
    [1687332187.061189][15779:15805] CHIP:DMG: ICR moving to [AddedComma]
    [1687332187.061246][15779:15805] CHIP:EM: <<< [E:64294i M:43174478] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687332187.061256][15779:15805] CHIP:IN: (S) Sending msg 43174478 on secure session with LSID: 19592
    [1687332187.061301][15779:15805] CHIP:DMG: ICR moving to [CommandSen]
    [1687332187.061321][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332187.135649][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687332187.137969][15779:15804] CHIP:DL: Indication received, conn = 0x7f5948073de0
    [1687332187.138091][15779:15805] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687332187.138199][15779:15805] CHIP:EM: >>> [E:64294i M:188327134] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687332187.138216][15779:15805] CHIP:EM: Found matching exchange: 64294i, Delegate: 0x7f59480405b8
    [1687332187.138233][15779:15805] CHIP:DMG: ICR moving to [ResponseRe]
    [1687332187.138258][15779:15805] CHIP:DMG: InvokeResponseMessage =
    [1687332187.138265][15779:15805] CHIP:DMG: {
    [1687332187.138275][15779:15805] CHIP:DMG:     suppressResponse = false,
    [1687332187.138285][15779:15805] CHIP:DMG:     InvokeResponseIBs =
    [1687332187.138302][15779:15805] CHIP:DMG:     [
    [1687332187.138310][15779:15805] CHIP:DMG:         InvokeResponseIB =
    [1687332187.138327][15779:15805] CHIP:DMG:         {
    [1687332187.138336][15779:15805] CHIP:DMG:             CommandDataIB =
    [1687332187.138347][15779:15805] CHIP:DMG:             {
    [1687332187.138355][15779:15805] CHIP:DMG:                 CommandPathIB =
    [1687332187.138369][15779:15805] CHIP:DMG:                 {
    [1687332187.138383][15779:15805] CHIP:DMG:                     EndpointId = 0x0,
    [1687332187.138394][15779:15805] CHIP:DMG:                     ClusterId = 0x30,
    [1687332187.138414][15779:15805] CHIP:DMG:                     CommandId = 0x1,
    [1687332187.138424][15779:15805] CHIP:DMG:                 },
    [1687332187.138435][15779:15805] CHIP:DMG:
    [1687332187.138445][15779:15805] CHIP:DMG:                 CommandFields =
    [1687332187.138456][15779:15805] CHIP:DMG:                 {
    [1687332187.138472][15779:15805] CHIP:DMG:                     0x0 = 0,
    [1687332187.138486][15779:15805] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687332187.138495][15779:15805] CHIP:DMG:                 },
    [1687332187.138505][15779:15805] CHIP:DMG:             },
    [1687332187.138518][15779:15805] CHIP:DMG:
    [1687332187.138527][15779:15805] CHIP:DMG:         },
    [1687332187.138544][15779:15805] CHIP:DMG:
    [1687332187.138551][15779:15805] CHIP:DMG:     ],
    [1687332187.138566][15779:15805] CHIP:DMG:
    [1687332187.138574][15779:15805] CHIP:DMG:     InteractionModelRevision = 1
    [1687332187.138581][15779:15805] CHIP:DMG: },
    [1687332187.138616][15779:15805] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687332187.138636][15779:15805] CHIP:CTL: Failsafe disarmed
    [1687332187.138649][15779:15805] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
    [1687332187.138669][15779:15805] CHIP:TOO: Device commissioning Failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:1075: CHIP Error 0x000000AC: Internal error
    [1687332187.138685][15779:15805] CHIP:DIS: Closing all BLE connections
    [1687332187.138692][15779:15805] CHIP:IN: Clearing BLE pending packets.
    [1687332187.138718][15779:15805] CHIP:BLE: Auto-closing end point's BLE connection.
    [1687332187.138724][15779:15805] CHIP:DL: Closing BLE GATT connection (con 0x7f5948073de0)
    [1687332187.138759][15779:15805] CHIP:IN: SecureSession[0x7f594000ff10]: MarkForEviction Type:1 LSID:19592
    [1687332187.138767][15779:15805] CHIP:SC: SecureSession[0x7f594000ff10]: Moving from state 'kActive' --> 'kPendingEviction'
    [1687332187.138815][15779:15805] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687332187.138830][15779:15805] CHIP:IN: SecureSession[0x7f594000ff10]: Released - Type:1 LSID:19592
    [1687332187.138858][15779:15804] CHIP:DL: BluezDisconnect peer=48:22:54:5F:2B:F3
    [1687332187.138958][15779:15779] CHIP:CTL: Shutting down the commissioner
    [1687332187.138983][15779:15779] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332187.139034][15779:15779] CHIP:CTL: Shutting down the controller
    [1687332187.139044][15779:15779] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1687332187.139055][15779:15779] CHIP:FP: Forgetting fabric 0x1
    [1687332187.139071][15779:15779] CHIP:TS: Pending Last Known Good Time: 2023-01-04T15:21:56
    [1687332187.139162][15779:15779] CHIP:TS: Previous Last Known Good Time: 2023-01-04T15:21:56
    [1687332187.139170][15779:15779] CHIP:TS: Reverted Last Known Good Time to previous value
    [1687332187.139193][15779:15779] CHIP:CTL: Shutting down the commissioner
    [1687332187.139201][15779:15779] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687332187.139231][15779:15779] CHIP:CTL: Shutting down the controller
    [1687332187.139240][15779:15779] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1687332187.139350][15779:15779] CHIP:DMG: IM WH moving to [Uninitialized]
    [1687332187.139357][15779:15779] CHIP:DMG: IM WH moving to [Uninitialized]
    [1687332187.139364][15779:15779] CHIP:DMG: IM WH moving to [Uninitialized]
    [1687332187.139371][15779:15779] CHIP:DMG: IM WH moving to [Uninitialized]
    [1687332187.139380][15779:15779] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1687332187.139409][15779:15779] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1687332187.139428][15779:15779] CHIP:FP: Shutting down FabricTable
    [1687332187.139439][15779:15779] CHIP:TS: Pending Last Known Good Time: 2023-01-04T15:21:56
    [1687332187.139494][15779:15779] CHIP:TS: Previous Last Known Good Time: 2023-01-04T15:21:56
    [1687332187.139501][15779:15779] CHIP:TS: Reverted Last Known Good Time to previous value
    [1687332187.139630][15779:15779] CHIP:DL: writing settings to file (/mnt/chip_counters.ini-SvHZOZ)
    [1687332187.139859][15779:15779] CHIP:DL: renamed tmp file to file (/mnt/chip_counters.ini)
    [1687332187.139883][15779:15779] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1687332187.139893][15779:15779] CHIP:DL: Inet Layer shutdown
    [1687332187.139901][15779:15779] CHIP:DL: BLE shutdown
    [1687332187.140579][15779:15779] CHIP:DL: System Layer shutdown
    [1687332189.797401][15779:15779] CHIP:TOO: Run command failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:1075: CHIP Error 0x000000AC: Internal error
  • Hi
    Error 101, during AttestationInformation informs about unavailable PAA on the controller side, if the client use non-default DAC/PAI generated on non-default PAA in their sample (in FactoryData) then he/she needs to provider path to chip-tool where the PAA is stored.
    ./chip-tool pairing ble-thread <nodeid> hex:<thread_dataset> <setupcode> <discriminator> --paa-trust-store-path <path_to_paa>
    https://github.com/nrfconnect/sdk-connectedhomeip/blob/master/src/credentials/attestation_verifier/DeviceAttestationVerifier.h#L35
    Let me know if this solves the issue you're observing
    Andreas
  • Ok on mentioning the path to paa, It resolved attestation verification error Thank you so much.
    But I got one more error(about operatioalsessionsetup) now could you please look into that.
    The terminal output is as follows
    1687452601.894221][124848:124848] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1687452601.898066][124848:124848] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1687452601.898141][124848:124848] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1687452601.898170][124848:124848] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1687452601.898355][124848:124848] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-ywQTl1)
    [1687452601.898594][124848:124848] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1687452601.898617][124848:124848] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
    [1687452601.898894][124848:124848] CHIP:DL: Got Ethernet interface: enp2s0
    [1687452601.899028][124848:124848] CHIP:DL: Found the primary Ethernet interface:enp2s0
    [1687452601.899230][124848:124848] CHIP:DL: Got WiFi interface: wlp3s0
    [1687452601.899418][124848:124848] CHIP:DL: Found the primary WiFi interface:wlp3s0
    [1687452601.899462][124848:124848] CHIP:IN: UDP::Init bind&listen port=0
    [1687452601.899496][124848:124848] CHIP:IN: UDP::Init bound to port=33789
    [1687452601.899504][124848:124848] CHIP:IN: UDP::Init bind&listen port=0
    [1687452601.899526][124848:124848] CHIP:IN: UDP::Init bound to port=37925
    [1687452601.899533][124848:124848] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1687452601.899541][124848:124848] CHIP:IN: TransportMgr initialized
    [1687452601.899563][124848:124848] CHIP:FP: Initializing FabricTable from persistent storage
    [1687452601.899642][124848:124848] CHIP:TS: Last Known Good Time: 2023-06-21T16:18:47
    [1687452601.901028][124848:124848] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x10B023A18AE28C7A, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1687452601.902918][124848:124848] CHIP:ZCL: Using ZAP configuration...
    [1687452601.906681][124848:124848] CHIP:CTL: System State Initialized...
    [1687452601.916843][124848:124848] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452601.916922][124848:124848] CHIP:CTL: Setting attestation nonce to random value
    [1687452601.916988][124848:124848] CHIP:CTL: Setting CSR nonce to random value
    [1687452601.917034][124848:124848] CHIP:IN: UDP::Init bind&listen port=5550
    [1687452601.917099][124848:124848] CHIP:IN: UDP::Init bound to port=5550
    [1687452601.917112][124848:124848] CHIP:IN: UDP::Init bind&listen port=5550
    [1687452601.917156][124848:124848] CHIP:IN: UDP::Init bound to port=5550
    [1687452601.917168][124848:124848] CHIP:IN: TransportMgr initialized
    [1687452601.917412][124848:124851] CHIP:DL: CHIP task running
    [1687452601.917481][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1687452601.917714][124848:124851] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452601.917740][124848:124851] CHIP:CTL: Setting attestation nonce to random value
    [1687452601.917824][124848:124851] CHIP:CTL: Setting CSR nonce to random value
    [1687452601.918759][124848:124851] CHIP:CTL: Generating NOC
    [1687452601.921097][124848:124851] CHIP:FP: Validating NOC chain
    [1687452601.924594][124848:124851] CHIP:FP: NOC chain validation successful
    [1687452601.924755][124848:124851] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1687452601.924772][124848:124851] CHIP:TS: Last Known Good Time: 2023-06-21T16:18:47
    [1687452601.924781][124848:124851] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1687452601.924843][124848:124851] CHIP:TS: Retaining current Last Known Good Time
    [1687452601.927284][124848:124851] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1687452601.929337][124848:124851] CHIP:TS: Committing Last Known Good Time to storage: 2023-06-21T16:18:47
    [1687452601.930756][124848:124851] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 10B023A18AE28C7A)
    [1687452601.930848][124848:124851] CHIP:IN: UDP::Init bind&listen port=5550
    [1687452601.930952][124848:124851] CHIP:IN: UDP::Init bound to port=5550
    [1687452601.930983][124848:124851] CHIP:IN: UDP::Init bind&listen port=5550
    [1687452601.931052][124848:124851] CHIP:IN: UDP::Init bound to port=5550
    [1687452601.931110][124848:124851] CHIP:IN: TransportMgr initialized
    [1687452601.949223][124848:124851] CHIP:CTL: Setting wifi credentials from parameters
    [1687452601.949247][124848:124851] CHIP:CTL: Setting attestation nonce to random value
    [1687452601.949279][124848:124851] CHIP:CTL: Setting CSR nonce to random value
    [1687452601.949334][124848:124851] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452601.949344][124848:124851] CHIP:CTL: Starting commissioning discovery over BLE
    [1687452601.949364][124848:124851] CHIP:CTL: Starting commissioning discovery over DNS-SD
    [1687452601.957813][124848:124850] CHIP:DL: TRACE: Bus acquired for name C-e7b0
    [1687452601.980398][124848:124851] CHIP:DL: PlatformBlueZInit init success
    [1687452601.993381][124848:124850] CHIP:BLE: BLE removing known devices.
    [1687452602.279460][124848:124850] CHIP:BLE: BLE initiating scan.
    [1687452602.280717][124848:124851] CHIP:DL: Long dispatch time: 332 ms, for event type 2
    [1687452602.349329][124848:124850] CHIP:BLE: Device 6C:E9:45:5C:64:BC does not look like a CHIP device.
    [1687452602.416462][124848:124850] CHIP:BLE: New device scanned: 48:22:54:5F:2B:F3
    [1687452602.416513][124848:124850] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1687452603.291685][124848:124850] CHIP:DL: ConnectDevice complete
    [1687452604.046310][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046344][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046356][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046364][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046383][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046393][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046413][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687452604.046421][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046430][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687452604.046438][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046448][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0001
    [1687452604.046457][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046481][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046488][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046505][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046515][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046538][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046546][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046561][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046570][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046585][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service000c
    [1687452604.046595][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046616][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046624][124848:124850] CHIP:DL: Char1 /org/bluez/hci0/dev_48_22_54_5F_2B_F3/service0013
    [1687452604.046644][124848:124850] CHIP:DL: New BLE connection 0x7f121c06fff0, device 48:22:54:5F:2B:F3, path /org/bluez/hci0/dev_48_22_54_5F_2B_F3
    [1687452604.046742][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1687452604.046799][124848:124851] CHIP:CTL: Discovered device to be commissioned over BLE
    [1687452604.046868][124848:124851] CHIP:CTL: Attempting PASE connection to BLE
    [1687452604.046927][124848:124851] CHIP:IN: BleConnectionComplete: endPoint 0x55baaf17e4e0
    [1687452604.047253][124848:124851] CHIP:IN: SecureSession[0x7f121400f400]: Allocated Type:1 LSID:44403
    [1687452604.047273][124848:124851] CHIP:SC: Assigned local session key ID 44403
    [1687452604.047348][124848:124851] CHIP:EM: <<< [E:17868i S:0 M:94851716] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1687452604.047375][124848:124851] CHIP:IN: (U) Sending msg 94851716 to IP address 'BLE'
    [1687452604.047389][124848:124851] CHIP:IN: Message appended to BLE send queue
    [1687452604.047399][124848:124851] CHIP:SC: Sent PBKDF param request
    [1687452604.047411][124848:124851] CHIP:CTL: Commission called for node ID 0x000000000000A219
    [1687452604.438200][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452604.507030][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1687452604.507063][124848:124851] CHIP:BLE: subscribe complete, ep = 0x55baaf17e4e0
    [1687452604.507552][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452604.507643][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452604.507679][124848:124851] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1687452604.507692][124848:124851] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1687452604.507703][124848:124851] CHIP:BLE: local and remote recv window size = 5
    [1687452604.508125][124848:124851] CHIP:IN: BLE EndPoint 0x55baaf17e4e0 Connection Complete
    [1687452604.595850][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452604.688014][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452604.688153][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452604.688256][124848:124851] CHIP:EM: >>> [E:17868i S:0 M:218364218] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1687452604.688280][124848:124851] CHIP:EM: Found matching exchange: 17868i, Delegate: 0x7f1214012e60
    [1687452604.688305][124848:124851] CHIP:SC: Received PBKDF param response
    [1687452604.688383][124848:124851] CHIP:SC: Peer assigned session ID 42461
    [1687452604.688437][124848:124851] CHIP:SC: Found MRP parameters in the message
    [1687452604.765211][124848:124851] CHIP:EM: <<< [E:17868i S:0 M:94851717] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1687452604.765248][124848:124851] CHIP:IN: (U) Sending msg 94851717 to IP address 'BLE'
    [1687452604.765797][124848:124851] CHIP:SC: Sent spake2p msg1
    [1687452604.821203][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452605.766245][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452605.766398][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452605.766514][124848:124851] CHIP:EM: >>> [E:17868i S:0 M:218364219] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1687452605.766542][124848:124851] CHIP:EM: Found matching exchange: 17868i, Delegate: 0x7f1214012e60
    [1687452605.766565][124848:124851] CHIP:SC: Received spake2p msg2
    [1687452605.768598][124848:124851] CHIP:EM: <<< [E:17868i S:0 M:94851718] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1687452605.768705][124848:124851] CHIP:IN: (U) Sending msg 94851718 to IP address 'BLE'
    [1687452605.769591][124848:124851] CHIP:SC: Sent spake2p msg3
    [1687452605.900381][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452605.900908][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452605.901210][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452605.901384][124848:124851] CHIP:EM: >>> [E:17868i S:0 M:218364220] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1687452605.901432][124848:124851] CHIP:EM: Found matching exchange: 17868i, Delegate: 0x7f1214012e60
    [1687452605.901849][124848:124851] CHIP:SC: SecureSession[0x7f121400f400, LSID:44403]: State change 'kEstablishing' --> 'kActive'
    [1687452605.901880][124848:124851] CHIP:IN: SecureSession[0x7f121400f400]: Activated - Type:1 LSID:44403
    [1687452605.901900][124848:124851] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:44403 PSID:42461!
    [1687452605.901932][124848:124851] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1687452605.901969][124848:124851] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452605.901987][124848:124851] CHIP:TOO: Pairing Success
    [1687452605.902002][124848:124851] CHIP:TOO: PASE establishment successful
    [1687452605.902017][124848:124851] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1687452605.902037][124848:124851] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1687452605.902051][124848:124851] CHIP:CTL: Sending request for commissioning information
    [1687452605.902090][124848:124851] CHIP:DMG: SendReadRequest ReadClient[0x7f1214015030]: Sending Read Request
    [1687452605.902312][124848:124851] CHIP:EM: <<< [E:17869i S:44403 M:253297760] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    [1687452605.902346][124848:124851] CHIP:IN: (S) Sending msg 253297760 on secure session with LSID: 44403
    [1687452605.903001][124848:124851] CHIP:DMG: MoveToState ReadClient[0x7f1214015030]: Moving to [AwaitingIn]
    [1687452605.990716][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452606.126102][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452606.126213][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452606.261649][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452606.261771][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452606.261914][124848:124851] CHIP:EM: >>> [E:17869i S:44403 M:60129857] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1687452606.261933][124848:124851] CHIP:EM: Found matching exchange: 17869i, Delegate: 0x7f1214015040
    [1687452606.262000][124848:124851] CHIP:DMG: ReportDataMessage =
    [1687452606.262011][124848:124851] CHIP:DMG: {
    [1687452606.262017][124848:124851] CHIP:DMG:     AttributeReportIBs =
    [1687452606.262031][124848:124851] CHIP:DMG:     [
    [1687452606.262039][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262056][124848:124851] CHIP:DMG:         {
    [1687452606.262070][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262079][124848:124851] CHIP:DMG:             {
    [1687452606.262088][124848:124851] CHIP:DMG:                 DataVersion = 0x7d966455,
    [1687452606.262096][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.262105][124848:124851] CHIP:DMG:                 {
    [1687452606.262113][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.262122][124848:124851] CHIP:DMG:                     Cluster = 0x31,
    [1687452606.262130][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1687452606.262140][124848:124851] CHIP:DMG:                 }
    [1687452606.262157][124848:124851] CHIP:DMG:
    [1687452606.262168][124848:124851] CHIP:DMG:                 Data = 20,
    [1687452606.262177][124848:124851] CHIP:DMG:             },
    [1687452606.262190][124848:124851] CHIP:DMG:
    [1687452606.262224][124848:124851] CHIP:DMG:         },
    [1687452606.262241][124848:124851] CHIP:DMG:
    [1687452606.262249][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262260][124848:124851] CHIP:DMG:         {
    [1687452606.262269][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262279][124848:124851] CHIP:DMG:             {
    [1687452606.262288][124848:124851] CHIP:DMG:                 DataVersion = 0xdf9981e7,
    [1687452606.262298][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.262305][124848:124851] CHIP:DMG:                 {
    [1687452606.262314][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.262323][124848:124851] CHIP:DMG:                     Cluster = 0x28,
    [1687452606.262333][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0004,
    [1687452606.262345][124848:124851] CHIP:DMG:                 }
    [1687452606.262356][124848:124851] CHIP:DMG:
    [1687452606.262365][124848:124851] CHIP:DMG:                 Data = 257,
    [1687452606.262373][124848:124851] CHIP:DMG:             },
    [1687452606.262384][124848:124851] CHIP:DMG:
    [1687452606.262392][124848:124851] CHIP:DMG:         },
    [1687452606.262408][124848:124851] CHIP:DMG:
    [1687452606.262415][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262427][124848:124851] CHIP:DMG:         {
    [1687452606.262435][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262444][124848:124851] CHIP:DMG:             {
    [1687452606.262453][124848:124851] CHIP:DMG:                 DataVersion = 0xdf9981e7,
    [1687452606.262461][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.262476][124848:124851] CHIP:DMG:                 {
    [1687452606.262485][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.262494][124848:124851] CHIP:DMG:                     Cluster = 0x28,
    [1687452606.262504][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1687452606.262512][124848:124851] CHIP:DMG:                 }
    [1687452606.262522][124848:124851] CHIP:DMG:
    [1687452606.262532][124848:124851] CHIP:DMG:                 Data = 4488,
    [1687452606.262540][124848:124851] CHIP:DMG:             },
    [1687452606.262551][124848:124851] CHIP:DMG:
    [1687452606.262559][124848:124851] CHIP:DMG:         },
    [1687452606.262575][124848:124851] CHIP:DMG:
    [1687452606.262582][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262598][124848:124851] CHIP:DMG:         {
    [1687452606.262605][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262617][124848:124851] CHIP:DMG:             {
    [1687452606.262625][124848:124851] CHIP:DMG:                 DataVersion = 0xb7683cad,
    [1687452606.262635][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.262646][124848:124851] CHIP:DMG:                 {
    [1687452606.262655][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.262665][124848:124851] CHIP:DMG:                     Cluster = 0x30,
    [1687452606.262674][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0003,
    [1687452606.262698][124848:124851] CHIP:DMG:                 }
    [1687452606.262709][124848:124851] CHIP:DMG:
    [1687452606.262721][124848:124851] CHIP:DMG:                 Data = 0,
    [1687452606.262730][124848:124851] CHIP:DMG:             },
    [1687452606.262742][124848:124851] CHIP:DMG:
    [1687452606.262751][124848:124851] CHIP:DMG:         },
    [1687452606.262769][124848:124851] CHIP:DMG:
    [1687452606.262777][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262791][124848:124851] CHIP:DMG:         {
    [1687452606.262799][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262810][124848:124851] CHIP:DMG:             {
    [1687452606.262820][124848:124851] CHIP:DMG:                 DataVersion = 0xb7683cad,
    [1687452606.262832][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.262842][124848:124851] CHIP:DMG:                 {
    [1687452606.262852][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.262863][124848:124851] CHIP:DMG:                     Cluster = 0x30,
    [1687452606.262873][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0002,
    [1687452606.262882][124848:124851] CHIP:DMG:                 }
    [1687452606.262895][124848:124851] CHIP:DMG:
    [1687452606.262905][124848:124851] CHIP:DMG:                 Data = 0,
    [1687452606.262913][124848:124851] CHIP:DMG:             },
    [1687452606.262927][124848:124851] CHIP:DMG:
    [1687452606.262935][124848:124851] CHIP:DMG:         },
    [1687452606.262954][124848:124851] CHIP:DMG:
    [1687452606.262961][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.262977][124848:124851] CHIP:DMG:         {
    [1687452606.262985][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.262996][124848:124851] CHIP:DMG:             {
    [1687452606.263005][124848:124851] CHIP:DMG:                 DataVersion = 0xb7683cad,
    [1687452606.263019][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.263030][124848:124851] CHIP:DMG:                 {
    [1687452606.263040][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.263050][124848:124851] CHIP:DMG:                     Cluster = 0x30,
    [1687452606.263060][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0001,
    [1687452606.263069][124848:124851] CHIP:DMG:                 }
    [1687452606.263081][124848:124851] CHIP:DMG:
    [1687452606.263090][124848:124851] CHIP:DMG:                 Data =
    [1687452606.263101][124848:124851] CHIP:DMG:                 {
    [1687452606.263112][124848:124851] CHIP:DMG:                     0x0 = 60,
    [1687452606.263123][124848:124851] CHIP:DMG:                     0x1 = 900,
    [1687452606.263134][124848:124851] CHIP:DMG:                 },
    [1687452606.263143][124848:124851] CHIP:DMG:             },
    [1687452606.263158][124848:124851] CHIP:DMG:
    [1687452606.263167][124848:124851] CHIP:DMG:         },
    [1687452606.263185][124848:124851] CHIP:DMG:
    [1687452606.263192][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.263207][124848:124851] CHIP:DMG:         {
    [1687452606.263215][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.263224][124848:124851] CHIP:DMG:             {
    [1687452606.263234][124848:124851] CHIP:DMG:                 DataVersion = 0xb7683cad,
    [1687452606.263244][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.263255][124848:124851] CHIP:DMG:                 {
    [1687452606.263267][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.263276][124848:124851] CHIP:DMG:                     Cluster = 0x30,
    [1687452606.263291][124848:124851] CHIP:DMG:                     Attribute = 0x0000_0000,
    [1687452606.263300][124848:124851] CHIP:DMG:                 }
    [1687452606.263311][124848:124851] CHIP:DMG:
    [1687452606.263321][124848:124851] CHIP:DMG:                 Data = 0,
    [1687452606.263330][124848:124851] CHIP:DMG:             },
    [1687452606.263342][124848:124851] CHIP:DMG:
    [1687452606.263351][124848:124851] CHIP:DMG:         },
    [1687452606.263368][124848:124851] CHIP:DMG:
    [1687452606.263376][124848:124851] CHIP:DMG:         AttributeReportIB =
    [1687452606.263390][124848:124851] CHIP:DMG:         {
    [1687452606.263398][124848:124851] CHIP:DMG:             AttributeDataIB =
    [1687452606.263410][124848:124851] CHIP:DMG:             {
    [1687452606.263419][124848:124851] CHIP:DMG:                 DataVersion = 0x7d966455,
    [1687452606.263429][124848:124851] CHIP:DMG:                 AttributePathIB =
    [1687452606.263438][124848:124851] CHIP:DMG:                 {
    [1687452606.263448][124848:124851] CHIP:DMG:                     Endpoint = 0x0,
    [1687452606.263468][124848:124851] CHIP:DMG:                     Cluster = 0x31,
    [1687452606.263478][124848:124851] CHIP:DMG:                     Attribute = 0x0000_FFFC,
    [1687452606.263486][124848:124851] CHIP:DMG:                 }
    [1687452606.263497][124848:124851] CHIP:DMG:
    [1687452606.263506][124848:124851] CHIP:DMG:                 Data = 1,
    [1687452606.263514][124848:124851] CHIP:DMG:             },
    [1687452606.263525][124848:124851] CHIP:DMG:
    [1687452606.263533][124848:124851] CHIP:DMG:         },
    [1687452606.263544][124848:124851] CHIP:DMG:
    [1687452606.263553][124848:124851] CHIP:DMG:     ],
    [1687452606.263587][124848:124851] CHIP:DMG:
    [1687452606.263596][124848:124851] CHIP:DMG:     SuppressResponse = true,
    [1687452606.263604][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452606.263610][124848:124851] CHIP:DMG: }
    [1687452606.264216][124848:124851] CHIP:CTL: ----- NetworkCommissioning Features: has WiFi. endpointid = 0
    [1687452606.264279][124848:124851] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1687452606.265021][124848:124851] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1687452606.265052][124848:124851] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1687452606.265067][124848:124851] CHIP:CTL: Arming failsafe (60 seconds)
    [1687452606.265130][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452606.265481][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452606.265622][124848:124851] CHIP:EM: <<< [E:17870i S:44403 M:253297761] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452606.265647][124848:124851] CHIP:IN: (S) Sending msg 253297761 on secure session with LSID: 44403
    [1687452606.265913][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452606.350927][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452606.354711][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452606.354930][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452606.355295][124848:124851] CHIP:EM: >>> [E:17870i S:44403 M:60129858] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452606.355321][124848:124851] CHIP:EM: Found matching exchange: 17870i, Delegate: 0x7f121c071398
    [1687452606.355346][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452606.355391][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452606.355403][124848:124851] CHIP:DMG: {
    [1687452606.355455][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452606.355466][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452606.355493][124848:124851] CHIP:DMG:     [
    [1687452606.355542][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452606.355562][124848:124851] CHIP:DMG:         {
    [1687452606.355571][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452606.355581][124848:124851] CHIP:DMG:             {
    [1687452606.355597][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452606.355614][124848:124851] CHIP:DMG:                 {
    [1687452606.355632][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452606.355650][124848:124851] CHIP:DMG:                     ClusterId = 0x30,
    [1687452606.355670][124848:124851] CHIP:DMG:                     CommandId = 0x1,
    [1687452606.355684][124848:124851] CHIP:DMG:                 },
    [1687452606.355698][124848:124851] CHIP:DMG:
    [1687452606.355708][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452606.355721][124848:124851] CHIP:DMG:                 {
    [1687452606.355740][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452606.355757][124848:124851] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687452606.355776][124848:124851] CHIP:DMG:                 },
    [1687452606.355790][124848:124851] CHIP:DMG:             },
    [1687452606.355817][124848:124851] CHIP:DMG:
    [1687452606.355828][124848:124851] CHIP:DMG:         },
    [1687452606.355851][124848:124851] CHIP:DMG:
    [1687452606.355880][124848:124851] CHIP:DMG:     ],
    [1687452606.355906][124848:124851] CHIP:DMG:
    [1687452606.355917][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452606.355929][124848:124851] CHIP:DMG: },
    [1687452606.356084][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687452606.356137][124848:124851] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1687452606.356177][124848:124851] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1687452606.356216][124848:124851] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1687452606.356256][124848:124851] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1687452606.356282][124848:124851] CHIP:CTL: Setting Regulatory Config
    [1687452606.356305][124848:124851] CHIP:CTL: Device does not support configurable regulatory location
    [1687452606.356402][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452606.443640][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452606.443755][124848:124851] CHIP:EM: <<< [E:17871i S:44403 M:253297762] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452606.443784][124848:124851] CHIP:IN: (S) Sending msg 253297762 on secure session with LSID: 44403
    [1687452606.444781][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452606.444892][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452606.530417][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452606.577938][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452606.578085][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452606.578258][124848:124851] CHIP:EM: >>> [E:17871i S:44403 M:60129859] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452606.578290][124848:124851] CHIP:EM: Found matching exchange: 17871i, Delegate: 0x7f121400eaa8
    [1687452606.578317][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452606.578373][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452606.578389][124848:124851] CHIP:DMG: {
    [1687452606.578405][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452606.578420][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452606.578449][124848:124851] CHIP:DMG:     [
    [1687452606.578463][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452606.578490][124848:124851] CHIP:DMG:         {
    [1687452606.578505][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452606.578526][124848:124851] CHIP:DMG:             {
    [1687452606.578542][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452606.578560][124848:124851] CHIP:DMG:                 {
    [1687452606.578578][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452606.578597][124848:124851] CHIP:DMG:                     ClusterId = 0x30,
    [1687452606.578617][124848:124851] CHIP:DMG:                     CommandId = 0x3,
    [1687452606.578633][124848:124851] CHIP:DMG:                 },
    [1687452606.578656][124848:124851] CHIP:DMG:
    [1687452606.578674][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452606.578695][124848:124851] CHIP:DMG:                 {
    [1687452606.578716][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452606.578739][124848:124851] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687452606.578759][124848:124851] CHIP:DMG:                 },
    [1687452606.578776][124848:124851] CHIP:DMG:             },
    [1687452606.578803][124848:124851] CHIP:DMG:
    [1687452606.578817][124848:124851] CHIP:DMG:         },
    [1687452606.578844][124848:124851] CHIP:DMG:
    [1687452606.578855][124848:124851] CHIP:DMG:     ],
    [1687452606.578877][124848:124851] CHIP:DMG:
    [1687452606.578888][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452606.578899][124848:124851] CHIP:DMG: },
    [1687452606.578951][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1687452606.579681][124848:124851] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1687452606.579712][124848:124851] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1687452606.579727][124848:124851] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1687452606.579748][124848:124851] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1687452606.579761][124848:124851] CHIP:CTL: Sending request for PAI certificate
    [1687452606.579772][124848:124851] CHIP:CTL: Sending Certificate Chain request to 0x7f1214012e10 device
    [1687452606.579818][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452606.580298][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452606.580438][124848:124851] CHIP:EM: <<< [E:17872i S:44403 M:253297763] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452606.580468][124848:124851] CHIP:IN: (S) Sending msg 253297763 on secure session with LSID: 44403
    [1687452606.580909][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452606.581016][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452606.665704][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452606.802103][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452606.802374][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.026679][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452607.026824][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.116817][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452607.117056][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.117177][124848:124851] CHIP:EM: >>> [E:17872i S:44403 M:60129860] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452607.117202][124848:124851] CHIP:EM: Found matching exchange: 17872i, Delegate: 0x7f121c071398
    [1687452607.117225][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452607.117261][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452607.117271][124848:124851] CHIP:DMG: {
    [1687452607.117284][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452607.117297][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452607.117316][124848:124851] CHIP:DMG:     [
    [1687452607.117324][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452607.117341][124848:124851] CHIP:DMG:         {
    [1687452607.117352][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452607.117364][124848:124851] CHIP:DMG:             {
    [1687452607.117375][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452607.117389][124848:124851] CHIP:DMG:                 {
    [1687452607.117401][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452607.117414][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452607.117426][124848:124851] CHIP:DMG:                     CommandId = 0x3,
    [1687452607.117438][124848:124851] CHIP:DMG:                 },
    [1687452607.117451][124848:124851] CHIP:DMG:        %C2%A0
    [1687452607.117462][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452607.117474][124848:124851] CHIP:DMG:                 {
    [1687452607.117486][124848:124851] CHIP:DMG:                     0x0 = [
    [1687452607.117732][124848:124851] CHIP:DMG:                             0x30, 0x82, 0x01, 0xda, 0x30, 0x82, 0x01, 0x80, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x4a, 0x55, 0x95, 0xca, 0xad, 0x8e, 0xcb, 0xd9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x33, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x31, 0x31, 0x30, 0x33, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x8e, 0x78, 0x82, 0x5a, 0x5a, 0xa7, 0xc4, 0xc8, 0x9e, 0xd6, 0xa8, 0x78, 0x08, 0x67, 0x32, 0x2e, 0x6a, 0xbb, 0xaa, 0x01, 0x1a, 0xee, 0xa4, 0xec, 0x26, 0xdb, 0x64, 0xd4, 0x47, 0xbe, 0xc7, 0xc3, 0x16, 0x7d, 0xb4, 0x19, 0x8a, 0x21, 0x15, 0x65, 0x7f, 0x63, 0x32, 0xc5, 0x38, 0x15, 0xc2, 0xbd, 0x8f, 0xa2, 0x52, 0x9d, 0x9e, 0xa0, 0xf8, 0xad, 0xb1, 0x42, 0xa2, 0x
    [1687452607.117822][124848:124851] CHIP:DMG:                     ] (478 bytes)
    [1687452607.117847][124848:124851] CHIP:DMG:                 },
    [1687452607.117867][124848:124851] CHIP:DMG:             },
    [1687452607.117898][124848:124851] CHIP:DMG:
    [1687452607.117916][124848:124851] CHIP:DMG:         },
    [1687452607.117944][124848:124851] CHIP:DMG:
    [1687452607.117962][124848:124851] CHIP:DMG:     ],
    [1687452607.117994][124848:124851] CHIP:DMG:
    [1687452607.118013][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452607.118031][124848:124851] CHIP:DMG: },
    [1687452607.118119][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1687452607.118158][124848:124851] CHIP:CTL: Received certificate chain from the device
    [1687452607.118190][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1687452607.118230][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1687452607.118257][124848:124851] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1687452607.118275][124848:124851] CHIP:CTL: Sending request for DAC certificate
    [1687452607.118330][124848:124851] CHIP:CTL: Sending Certificate Chain request to 0x7f1214012e10 device
    [1687452607.118391][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452607.118414][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452607.118509][124848:124851] CHIP:EM: <<< [E:17873i S:44403 M:253297764] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452607.118566][124848:124851] CHIP:IN: (S) Sending msg 253297764 on secure session with LSID: 44403
    [1687452607.119252][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452607.119426][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452607.250729][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452607.431292][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452607.431527][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.611766][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452607.611893][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.703993][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452607.704145][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452607.704342][124848:124851] CHIP:EM: >>> [E:17873i S:44403 M:60129861] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452607.704365][124848:124851] CHIP:EM: Found matching exchange: 17873i, Delegate: 0x7f121c071a18
    [1687452607.704387][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452607.704424][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452607.704440][124848:124851] CHIP:DMG: {
    [1687452607.704457][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452607.704471][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452607.704500][124848:124851] CHIP:DMG:     [
    [1687452607.704514][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452607.704547][124848:124851] CHIP:DMG:         {
    [1687452607.704566][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452607.704586][124848:124851] CHIP:DMG:             {
    [1687452607.704604][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452607.704624][124848:124851] CHIP:DMG:                 {
    [1687452607.704644][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452607.704666][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452607.704686][124848:124851] CHIP:DMG:                     CommandId = 0x3,
    [1687452607.704704][124848:124851] CHIP:DMG:                 },
    [1687452607.704727][124848:124851] CHIP:DMG:
    [1687452607.704744][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452607.704766][124848:124851] CHIP:DMG:                 {
    [1687452607.704785][124848:124851] CHIP:DMG:                     0x0 = [
    [1687452607.704898][124848:124851] CHIP:DMG:                             0x30, 0x82, 0x01, 0xeb, 0x30, 0x82, 0x01, 0x90, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x50, 0x04, 0xca, 0x35, 0x9a, 0x9e, 0x85, 0x27, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x31, 0x31, 0x30, 0x33, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x49, 0x31, 0x1b, 0x30, 0x19, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x12, 0x54, 0x50, 0x2d, 0x4c, 0x69, 0x6e, 0x6b, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x41, 0x43, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x31, 0x38, 0x38, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x30, 0x31, 0x30, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x0c, 0x1d, 0xae, 0x80, 0x17, 0x17, 0xd1, 0x2f, 0xe3, 0xa6, 0x08, 0x50, 0xa2, 0x8b, 0x21, 0x03, 0xf6, 0xc2, 0x15, 0x6f, 0xe8, 0x9c, 0xa1, 0x9b, 0x59, 0xff, 0xf2, 0x2e, 0x42, 0xca, 0x25, 0x30, 0xe3, 0x10, 0xab, 0x72, 0x00, 0x
    [1687452607.704958][124848:124851] CHIP:DMG:                     ] (495 bytes)
    [1687452607.704976][124848:124851] CHIP:DMG:                 },
    [1687452607.704994][124848:124851] CHIP:DMG:             },
    [1687452607.705017][124848:124851] CHIP:DMG:
    [1687452607.705028][124848:124851] CHIP:DMG:         },
    [1687452607.705054][124848:124851] CHIP:DMG:
    [1687452607.705064][124848:124851] CHIP:DMG:     ],
    [1687452607.705088][124848:124851] CHIP:DMG:
    [1687452607.705100][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452607.705112][124848:124851] CHIP:DMG: },
    [1687452607.705166][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1687452607.705190][124848:124851] CHIP:CTL: Received certificate chain from the device
    [1687452607.705211][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1687452607.705226][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1687452607.705245][124848:124851] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1687452607.705257][124848:124851] CHIP:CTL: Sending Attestation Request to the device.
    [1687452607.705270][124848:124851] CHIP:CTL: Sending Attestation request to 0x7f1214012e10 device
    [1687452607.705317][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452607.705332][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452607.705413][124848:124851] CHIP:EM: <<< [E:17874i S:44403 M:253297765] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452607.705434][124848:124851] CHIP:IN: (S) Sending msg 253297765 on secure session with LSID: 44403
    [1687452607.705853][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452607.705870][124848:124851] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1687452607.705903][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452607.790613][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452608.061527][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452608.061634][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452608.241597][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452608.241747][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452608.241886][124848:124851] CHIP:EM: >>> [E:17874i S:44403 M:60129862] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452608.241908][124848:124851] CHIP:EM: Found matching exchange: 17874i, Delegate: 0x7f121c071f98
    [1687452608.241939][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452608.241981][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452608.241994][124848:124851] CHIP:DMG: {
    [1687452608.242010][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452608.242022][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452608.242052][124848:124851] CHIP:DMG:     [
    [1687452608.242064][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452608.242091][124848:124851] CHIP:DMG:         {
    [1687452608.242102][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452608.242115][124848:124851] CHIP:DMG:             {
    [1687452608.242135][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452608.242147][124848:124851] CHIP:DMG:                 {
    [1687452608.242158][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452608.242176][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452608.242192][124848:124851] CHIP:DMG:                     CommandId = 0x1,
    [1687452608.242207][124848:124851] CHIP:DMG:                 },
    [1687452608.242226][124848:124851] CHIP:DMG:
    [1687452608.242238][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452608.242255][124848:124851] CHIP:DMG:                 {
    [1687452608.242271][124848:124851] CHIP:DMG:                     0x0 = [
    [1687452608.242355][124848:124851] CHIP:DMG:                             0x15, 0x30, 0x01, 0xeb, 0x30, 0x81, 0xe8, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x81, 0xda, 0x30, 0x81, 0xd7, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x44, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x37, 0x04, 0x35, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0x88, 0x11, 0x36, 0x02, 0x05, 0x01, 0x01, 0x18, 0x25, 0x03, 0x0a, 0x01, 0x2c, 0x04, 0x13, 0x43, 0x53, 0x41, 0x32, 0x32, 0x31, 0x36, 0x35, 0x4d, 0x41, 0x54, 0x34, 0x30, 0x31, 0x36, 0x35, 0x2d, 0x32, 0x34, 0x24, 0x05, 0x00, 0x24, 0x06, 0x00, 0x24, 0x07, 0x01, 0x24, 0x08, 0x02, 0x18, 0x31, 0x7d, 0x30, 0x7b, 0x02, 0x01, 0x03, 0x80, 0x14, 0xfe, 0x34, 0x3f, 0x95, 0x99, 0x47, 0x76, 0x3b, 0x61, 0xee, 0x45, 0x39, 0x13, 0x13, 0x38, 0x49, 0x4f, 0xe6, 0x7d, 0x8e, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x04, 0x47, 0x30, 0x45, 0x02, 0x21, 0x00, 0x89, 0x38, 0x2b, 0xe2, 0x94, 0x74, 0x5a, 0xea, 0x8c, 0x45, 0xf0, 0x5c, 0xf5, 0x8d, 0xb8, 0x41, 0xa2, 0x3e, 0x07, 0x68, 0x43, 0xdc, 0x6e, 0x36, 0xe7, 0x93, 0x99, 0x5c, 0x8f, 0xbb, 0x3d, 0x2f, 0x02, 0x20, 0x7f, 0x86, 0x94, 0xc5, 0xe3, 0x33, 0x7a, 0x5b, 0x28, 0x8f, 0xe1, 0x5c, 0x8b, 0x69, 0x2d, 0x08, 0x45, 0xd0, 0x3b, 0x9a, 0x1b, 0xc5, 0x9a, 0x3d, 0xb5, 0xd8, 0x9f, 0xf9, 0x8d, 0xb1, 0x7e, 0x29, 0x30, 0x02, 0x20, 0x25, 0x86, 0x64, 0x0e, 0x7e, 0x68, 0x0b, 0x9d, 0x5b, 0xa4, 0x60, 0x79, 0x87, 0x16, 0x35, 0x84, 0x97, 0xa8, 0xcc, 0x78, 0x86, 0x86, 0xaa, 0x41, 0xca, 0xde, 0xfc, 0xde, 0x85, 0x30, 0x7d, 0x71, 0x24, 0x03, 0x00, 0x18,
    [1687452608.242395][124848:124851] CHIP:DMG:                     ] (278 bytes)
    [1687452608.242405][124848:124851] CHIP:DMG:                     0x1 = [
    [1687452608.242429][124848:124851] CHIP:DMG:                             0xc9, 0xed, 0x56, 0xb1, 0x00, 0x14, 0xcf, 0xe1, 0x80, 0x54, 0x23, 0xf7, 0x75, 0x14, 0xc4, 0xe9, 0xef, 0x6c, 0x0c, 0xaa, 0x5b, 0x21, 0x5b, 0x28, 0x1e, 0x9e, 0x88, 0xa6, 0xd8, 0x24, 0x2a, 0xc9, 0x3c, 0xae, 0x02, 0x5a, 0x38, 0xcc, 0xba, 0x2b, 0x13, 0x07, 0xf9, 0x1f, 0x5d, 0x5d, 0x01, 0x5b, 0xd6, 0xd0, 0x56, 0x95, 0x4d, 0x8e, 0x0e, 0x5e, 0xc9, 0x44, 0xe7, 0xc5, 0x42, 0x12, 0x1d, 0x23,
    [1687452608.242447][124848:124851] CHIP:DMG:                     ] (64 bytes)
    [1687452608.242455][124848:124851] CHIP:DMG:                 },
    [1687452608.242465][124848:124851] CHIP:DMG:             },
    [1687452608.242479][124848:124851] CHIP:DMG:
    [1687452608.242487][124848:124851] CHIP:DMG:         },
    [1687452608.242501][124848:124851] CHIP:DMG:
    [1687452608.242509][124848:124851] CHIP:DMG:     ],
    [1687452608.242527][124848:124851] CHIP:DMG:
    [1687452608.242535][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452608.242543][124848:124851] CHIP:DMG: },
    [1687452608.242582][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1687452608.242601][124848:124851] CHIP:CTL: Received Attestation Information from the device
    [1687452608.242618][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1687452608.242629][124848:124851] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 278/278
    [1687452608.242656][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1687452608.242670][124848:124851] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1687452608.242678][124848:124851] CHIP:CTL: Verifying attestation
    [1687452608.289841][124848:124851] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
    [1687452608.289921][124848:124851] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
    [1687452608.289936][124848:124851] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
    [1687452608.289961][124848:124851] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
    [1687452608.289975][124848:124851] CHIP:CTL: Sending CSR request to 0x7f1214012e10 device
    [1687452608.290080][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452608.290115][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452608.290302][124848:124851] CHIP:EM: <<< [E:17875i S:44403 M:253297766] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452608.290360][124848:124851] CHIP:IN: (S) Sending msg 253297766 on secure session with LSID: 44403
    [1687452608.291105][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452608.291178][124848:124851] CHIP:CTL: Sent CSR request, waiting for the CSR
    [1687452608.291281][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452608.375209][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452609.006156][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452609.006367][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452609.231165][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452609.231292][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452609.231433][124848:124851] CHIP:EM: >>> [E:17875i S:44403 M:60129863] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452609.231457][124848:124851] CHIP:EM: Found matching exchange: 17875i, Delegate: 0x7f121c071a18
    [1687452609.231477][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452609.231524][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452609.231532][124848:124851] CHIP:DMG: {
    [1687452609.231539][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452609.231546][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452609.231562][124848:124851] CHIP:DMG:     [
    [1687452609.231570][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452609.231586][124848:124851] CHIP:DMG:         {
    [1687452609.231595][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452609.231607][124848:124851] CHIP:DMG:             {
    [1687452609.231616][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452609.231631][124848:124851] CHIP:DMG:                 {
    [1687452609.231642][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452609.231653][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452609.231664][124848:124851] CHIP:DMG:                     CommandId = 0x5,
    [1687452609.231673][124848:124851] CHIP:DMG:                 },
    [1687452609.231686][124848:124851] CHIP:DMG:
    [1687452609.231696][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452609.231707][124848:124851] CHIP:DMG:                 {
    [1687452609.231719][124848:124851] CHIP:DMG:                     0x0 = [
    [1687452609.231787][124848:124851] CHIP:DMG:                             0x15, 0x30, 0x01, 0xce, 0x30, 0x81, 0xcb, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x01, 0x80, 0xae, 0x4f, 0x36, 0x64, 0x52, 0x7a, 0x15, 0x0a, 0x07, 0x01, 0xbc, 0x74, 0x92, 0xbf, 0x75, 0x6d, 0x2a, 0x39, 0xbc, 0xcb, 0x9f, 0x32, 0x73, 0x0a, 0x26, 0xd4, 0xe3, 0xbe, 0x6f, 0x92, 0x1b, 0x67, 0x66, 0x18, 0x86, 0xf5, 0x11, 0x21, 0xcb, 0xcc, 0x10, 0x05, 0xef, 0x81, 0xb8, 0xef, 0xc2, 0x51, 0xed, 0x89, 0x22, 0x7d, 0x83, 0xa6, 0xe7, 0x40, 0x63, 0x1f, 0x9c, 0xc0, 0xfb, 0xe3, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x49, 0x00, 0x30, 0x46, 0x02, 0x21, 0x00, 0xf6, 0xb1, 0x6d, 0x87, 0xa6, 0xb7, 0x59, 0xdf, 0x93, 0x04, 0x13, 0x3a, 0x2e, 0x51, 0x01, 0xb4, 0x0e, 0xeb, 0x24, 0xca, 0x0d, 0xa2, 0x8f, 0xd7, 0x26, 0x1e, 0xeb, 0x5f, 0x33, 0x14, 0x37, 0xb6, 0x02, 0x21, 0x00, 0xf3, 0x23, 0x48, 0x23, 0xa4, 0x08, 0xeb, 0x68, 0x26, 0x7b, 0x25, 0x27, 0xa0, 0xf7, 0xc1, 0x9f, 0x96, 0x74, 0xa2, 0x91, 0x73, 0x28, 0x40, 0x99, 0xcd, 0x87, 0xff, 0xad, 0x5b, 0xad, 0x32, 0xff, 0x30, 0x02, 0x20, 0xc4, 0x53, 0xe4, 0x80, 0x93, 0xd0, 0x93, 0x3b, 0x3e, 0xf7, 0xdd, 0xc8, 0x00, 0xde, 0x48, 0x35, 0x94, 0x51, 0x0d, 0x7c, 0xcc, 0x66, 0xd1, 0xc3, 0xc6, 0x64, 0xd6, 0x17, 0x82, 0x77, 0x4e, 0xfb, 0x18,
    [1687452609.231824][124848:124851] CHIP:DMG:                     ] (246 bytes)
    [1687452609.231833][124848:124851] CHIP:DMG:                     0x1 = [
    [1687452609.231876][124848:124851] CHIP:DMG:                             0x4d, 0xf4, 0x88, 0x4b, 0x7f, 0xba, 0x85, 0x5d, 0xb8, 0x3b, 0xd8, 0x80, 0xbb, 0x4a, 0x3b, 0xf8, 0x09, 0xbd, 0x2a, 0x4c, 0x26, 0xf0, 0xeb, 0xd2, 0x41, 0x0b, 0x90, 0xde, 0x15, 0x31, 0x6d, 0x56, 0x32, 0x58, 0xcd, 0xf2, 0x04, 0x4d, 0xfe, 0xe6, 0xe1, 0x8a, 0xef, 0xa8, 0x2f, 0x2b, 0x63, 0xc7, 0xba, 0x1d, 0x63, 0xfc, 0x3c, 0xd4, 0x16, 0xdf, 0x9e, 0xbe, 0xc3, 0x1b, 0xea, 0x99, 0xcf, 0x69,
    [1687452609.231900][124848:124851] CHIP:DMG:                     ] (64 bytes)
    [1687452609.231916][124848:124851] CHIP:DMG:                 },
    [1687452609.231951][124848:124851] CHIP:DMG:             },
    [1687452609.231965][124848:124851] CHIP:DMG:
    [1687452609.231973][124848:124851] CHIP:DMG:         },
    [1687452609.231988][124848:124851] CHIP:DMG:
    [1687452609.231996][124848:124851] CHIP:DMG:     ],
    [1687452609.232012][124848:124851] CHIP:DMG:
    [1687452609.232021][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452609.232028][124848:124851] CHIP:DMG: },
    [1687452609.232070][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
    [1687452609.232090][124848:124851] CHIP:CTL: Received certificate signing request from the device
    [1687452609.232107][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
    [1687452609.232117][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
    [1687452609.232130][124848:124851] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
    [1687452609.239406][124848:124851] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
    [1687452609.239429][124848:124851] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
    [1687452609.239437][124848:124851] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
    [1687452609.239445][124848:124851] CHIP:CTL: Getting certificate chain for the device from the issuer
    [1687452609.243630][124848:124851] CHIP:CTL: Verifying Certificate Signing Request
    [1687452609.245995][124848:124851] CHIP:CTL: Generating NOC
    [1687452609.246334][124848:124851] CHIP:CTL: Providing certificate chain to the commissioner
    [1687452609.246364][124848:124851] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
    [1687452609.246388][124848:124851] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
    [1687452609.246517][124848:124851] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
    [1687452609.246529][124848:124851] CHIP:CTL: Sending root certificate to the device
    [1687452609.246583][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452609.246600][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452609.246703][124848:124851] CHIP:EM: <<< [E:17876i S:44403 M:253297767] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452609.246739][124848:124851] CHIP:IN: (S) Sending msg 253297767 on secure session with LSID: 44403
    [1687452609.247555][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452609.247678][124848:124851] CHIP:CTL: Sent root certificate to the device
    [1687452609.248271][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452609.321031][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452609.410599][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452609.771333][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452609.771536][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452609.771701][124848:124851] CHIP:EM: >>> [E:17876i S:44403 M:60129864] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452609.771725][124848:124851] CHIP:EM: Found matching exchange: 17876i, Delegate: 0x7f121c071f98
    [1687452609.771745][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452609.771778][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452609.771788][124848:124851] CHIP:DMG: {
    [1687452609.771799][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452609.771809][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452609.771826][124848:124851] CHIP:DMG:     [
    [1687452609.771835][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452609.771852][124848:124851] CHIP:DMG:         {
    [1687452609.771964][124848:124851] CHIP:DMG:             CommandStatusIB =
    [1687452609.772051][124848:124851] CHIP:DMG:             {
    [1687452609.772072][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452609.772123][124848:124851] CHIP:DMG:                 {
    [1687452609.772171][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452609.772196][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452609.772230][124848:124851] CHIP:DMG:                     CommandId = 0xb,
    [1687452609.772275][124848:124851] CHIP:DMG:                 },
    [1687452609.772308][124848:124851] CHIP:DMG:
    [1687452609.772452][124848:124851] CHIP:DMG:                 StatusIB =
    [1687452609.772474][124848:124851] CHIP:DMG:                 {
    [1687452609.772493][124848:124851] CHIP:DMG:                     status = 0x00 (SUCCESS),
    [1687452609.772511][124848:124851] CHIP:DMG:                 },
    [1687452609.772537][124848:124851] CHIP:DMG:
    [1687452609.772553][124848:124851] CHIP:DMG:             },
    [1687452609.772579][124848:124851] CHIP:DMG:
    [1687452609.772594][124848:124851] CHIP:DMG:         },
    [1687452609.772621][124848:124851] CHIP:DMG:
    [1687452609.772635][124848:124851] CHIP:DMG:     ],
    [1687452609.772659][124848:124851] CHIP:DMG:
    [1687452609.772674][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452609.772687][124848:124851] CHIP:DMG: },
    [1687452609.772754][124848:124851] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
    [1687452609.772779][124848:124851] CHIP:CTL: Device confirmed that it has received the root certificate
    [1687452609.772804][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
    [1687452609.772819][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
    [1687452609.772840][124848:124851] CHIP:CTL: Performing next commissioning step 'SendNOC'
    [1687452609.772926][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452609.772946][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452609.773014][124848:124851] CHIP:EM: <<< [E:17877i S:44403 M:253297768] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452609.773034][124848:124851] CHIP:IN: (S) Sending msg 253297768 on secure session with LSID: 44403
    [1687452609.773541][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452609.773593][124848:124851] CHIP:CTL: Sent operational certificate to the device
    [1687452609.773650][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452609.951173][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452610.130522][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452610.220512][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452611.211192][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452611.211290][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452611.211422][124848:124851] CHIP:EM: >>> [E:17877i S:44403 M:60129865] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452611.211442][124848:124851] CHIP:EM: Found matching exchange: 17877i, Delegate: 0x7f121c071a18
    [1687452611.211459][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452611.211490][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452611.211500][124848:124851] CHIP:DMG: {
    [1687452611.211510][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452611.211518][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452611.211535][124848:124851] CHIP:DMG:     [
    [1687452611.211543][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452611.211562][124848:124851] CHIP:DMG:         {
    [1687452611.211570][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452611.211582][124848:124851] CHIP:DMG:             {
    [1687452611.211593][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452611.211604][124848:124851] CHIP:DMG:                 {
    [1687452611.211616][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452611.211627][124848:124851] CHIP:DMG:                     ClusterId = 0x3e,
    [1687452611.211637][124848:124851] CHIP:DMG:                     CommandId = 0x8,
    [1687452611.211646][124848:124851] CHIP:DMG:                 },
    [1687452611.211658][124848:124851] CHIP:DMG:
    [1687452611.211667][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452611.211681][124848:124851] CHIP:DMG:                 {
    [1687452611.211693][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452611.211704][124848:124851] CHIP:DMG:                     0x1 = 1,
    [1687452611.211714][124848:124851] CHIP:DMG:                 },
    [1687452611.211724][124848:124851] CHIP:DMG:             },
    [1687452611.211737][124848:124851] CHIP:DMG:
    [1687452611.211746][124848:124851] CHIP:DMG:         },
    [1687452611.211760][124848:124851] CHIP:DMG:
    [1687452611.211768][124848:124851] CHIP:DMG:     ],
    [1687452611.211783][124848:124851] CHIP:DMG:
    [1687452611.211792][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452611.211800][124848:124851] CHIP:DMG: },
    [1687452611.211839][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
    [1687452611.211881][124848:124851] CHIP:CTL: Device returned status 0 on receiving the NOC
    [1687452611.211895][124848:124851] CHIP:CTL: Operational credentials provisioned on device 0x7f1214012e10
    [1687452611.211904][124848:124851] CHIP:TOO: Secure Pairing Success
    [1687452611.211911][124848:124851] CHIP:TOO: CASE establishment successful
    [1687452611.211926][124848:124851] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
    [1687452611.211936][124848:124851] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
    [1687452611.211945][124848:124851] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'WiFiNetworkSetup'
    [1687452611.211958][124848:124851] CHIP:CTL: Performing next commissioning step 'WiFiNetworkSetup'
    [1687452611.211998][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452611.212013][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452611.212069][124848:124851] CHIP:EM: <<< [E:17878i S:44403 M:253297769] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452611.212088][124848:124851] CHIP:IN: (S) Sending msg 253297769 on secure session with LSID: 44403
    [1687452611.212455][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452611.212577][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452611.301524][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452611.303744][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452611.303826][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452611.303982][124848:124851] CHIP:EM: >>> [E:17878i S:44403 M:60129866] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452611.304008][124848:124851] CHIP:EM: Found matching exchange: 17878i, Delegate: 0x7f121c071f98
    [1687452611.304032][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452611.304072][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452611.304084][124848:124851] CHIP:DMG: {
    [1687452611.304099][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452611.304114][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452611.304144][124848:124851] CHIP:DMG:     [
    [1687452611.304154][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452611.304178][124848:124851] CHIP:DMG:         {
    [1687452611.304188][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452611.304202][124848:124851] CHIP:DMG:             {
    [1687452611.304215][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452611.304230][124848:124851] CHIP:DMG:                 {
    [1687452611.304242][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452611.304253][124848:124851] CHIP:DMG:                     ClusterId = 0x31,
    [1687452611.304264][124848:124851] CHIP:DMG:                     CommandId = 0x5,
    [1687452611.304273][124848:124851] CHIP:DMG:                 },
    [1687452611.304285][124848:124851] CHIP:DMG:
    [1687452611.304295][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452611.304306][124848:124851] CHIP:DMG:                 {
    [1687452611.304323][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452611.304340][124848:124851] CHIP:DMG:                     0x2 = 0,
    [1687452611.304355][124848:124851] CHIP:DMG:                 },
    [1687452611.304367][124848:124851] CHIP:DMG:             },
    [1687452611.304388][124848:124851] CHIP:DMG:
    [1687452611.304399][124848:124851] CHIP:DMG:         },
    [1687452611.304420][124848:124851] CHIP:DMG:
    [1687452611.304431][124848:124851] CHIP:DMG:     ],
    [1687452611.304455][124848:124851] CHIP:DMG:
    [1687452611.304465][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452611.304476][124848:124851] CHIP:DMG: },
    [1687452611.304523][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1687452611.305367][124848:124851] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
    [1687452611.305393][124848:124851] CHIP:CTL: Successfully finished commissioning step 'WiFiNetworkSetup'
    [1687452611.305403][124848:124851] CHIP:CTL: Commissioning stage next step: 'WiFiNetworkSetup' -> 'FailsafeBeforeWiFiEnable'
    [1687452611.305416][124848:124851] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeWiFiEnable'
    [1687452611.305432][124848:124851] CHIP:CTL: Arming failsafe (132 seconds)
    [1687452611.305462][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452611.305473][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452611.305521][124848:124851] CHIP:EM: <<< [E:17879i S:44403 M:253297770] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452611.305536][124848:124851] CHIP:IN: (S) Sending msg 253297770 on secure session with LSID: 44403
    [1687452611.305991][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452611.306030][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452611.390404][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452611.392744][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452611.392963][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452611.393084][124848:124851] CHIP:EM: >>> [E:17879i S:44403 M:60129867] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452611.393104][124848:124851] CHIP:EM: Found matching exchange: 17879i, Delegate: 0x7f121c071a18
    [1687452611.393119][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452611.393151][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452611.393158][124848:124851] CHIP:DMG: {
    [1687452611.393165][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452611.393172][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452611.393186][124848:124851] CHIP:DMG:     [
    [1687452611.393198][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452611.393214][124848:124851] CHIP:DMG:         {
    [1687452611.393227][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452611.393243][124848:124851] CHIP:DMG:             {
    [1687452611.393258][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452611.393274][124848:124851] CHIP:DMG:                 {
    [1687452611.393290][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452611.393307][124848:124851] CHIP:DMG:                     ClusterId = 0x30,
    [1687452611.393322][124848:124851] CHIP:DMG:                     CommandId = 0x1,
    [1687452611.393336][124848:124851] CHIP:DMG:                 },
    [1687452611.393352][124848:124851] CHIP:DMG:
    [1687452611.393366][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452611.393381][124848:124851] CHIP:DMG:                 {
    [1687452611.393397][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452611.393415][124848:124851] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687452611.393431][124848:124851] CHIP:DMG:                 },
    [1687452611.393443][124848:124851] CHIP:DMG:             },
    [1687452611.393464][124848:124851] CHIP:DMG:
    [1687452611.393474][124848:124851] CHIP:DMG:         },
    [1687452611.393492][124848:124851] CHIP:DMG:
    [1687452611.393500][124848:124851] CHIP:DMG:     ],
    [1687452611.393527][124848:124851] CHIP:DMG:
    [1687452611.393537][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452611.393547][124848:124851] CHIP:DMG: },
    [1687452611.393596][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687452611.393621][124848:124851] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1687452611.393639][124848:124851] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeWiFiEnable'
    [1687452611.393650][124848:124851] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeWiFiEnable' -> 'WiFiNetworkEnable'
    [1687452611.393664][124848:124851] CHIP:CTL: Setting wifi connection time min = 20
    [1687452611.393679][124848:124851] CHIP:CTL: Performing next commissioning step 'WiFiNetworkEnable'
    [1687452611.393726][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452611.393743][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452611.393804][124848:124851] CHIP:EM: <<< [E:17880i S:44403 M:253297771] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452611.393826][124848:124851] CHIP:IN: (S) Sending msg 253297771 on secure session with LSID: 44403
    [1687452611.394073][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452611.394122][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452611.479303][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452612.282310][124848:124851] CHIP:CTL: Commissioning discovery over BLE failed: src/platform/Linux/bluez/ChipDeviceScanner.cpp:175: CHIP Error 0x00000032: Timeout
    [1687452612.282387][124848:124851] CHIP:-: src/platform/Linux/bluez/ChipDeviceScanner.cpp:175: CHIP Error 0x00000032: Timeout at src/controller/SetUpCodePairer.cpp:323
    [1687452612.282442][124848:124851] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:175: CHIP Error 0x00000032: Timeout
    [1687452613.955670][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452613.955786][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452616.520570][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452616.568147][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452616.568958][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452616.569246][124848:124851] CHIP:EM: >>> [E:17880i S:44403 M:60129868] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452616.569301][124848:124851] CHIP:EM: Found matching exchange: 17880i, Delegate: 0x7f121c071f98
    [1687452616.569345][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452616.569424][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452616.569446][124848:124851] CHIP:DMG: {
    [1687452616.569478][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452616.569499][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452616.569541][124848:124851] CHIP:DMG:     [
    [1687452616.569566][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452616.569614][124848:124851] CHIP:DMG:         {
    [1687452616.569638][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452616.569664][124848:124851] CHIP:DMG:             {
    [1687452616.569686][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452616.569715][124848:124851] CHIP:DMG:                 {
    [1687452616.569753][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452616.569781][124848:124851] CHIP:DMG:                     ClusterId = 0x31,
    [1687452616.569814][124848:124851] CHIP:DMG:                     CommandId = 0x7,
    [1687452616.569840][124848:124851] CHIP:DMG:                 },
    [1687452616.569872][124848:124851] CHIP:DMG:
    [1687452616.569900][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452616.569923][124848:124851] CHIP:DMG:                 {
    [1687452616.569946][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452616.569997][124848:124851] CHIP:DMG:                     0x2 = NULL
    [1687452616.570035][124848:124851] CHIP:DMG:                 },
    [1687452616.570057][124848:124851] CHIP:DMG:             },
    [1687452616.570094][124848:124851] CHIP:DMG:
    [1687452616.570114][124848:124851] CHIP:DMG:         },
    [1687452616.570140][124848:124851] CHIP:DMG:
    [1687452616.570154][124848:124851] CHIP:DMG:     ],
    [1687452616.570184][124848:124851] CHIP:DMG:
    [1687452616.570200][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452616.570215][124848:124851] CHIP:DMG: },
    [1687452616.570306][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1687452616.570357][124848:124851] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
    [1687452616.570396][124848:124851] CHIP:CTL: Successfully finished commissioning step 'WiFiNetworkEnable'
    [1687452616.570425][124848:124851] CHIP:CTL: Commissioning stage next step: 'WiFiNetworkEnable' -> 'FindOperational'
    [1687452616.570459][124848:124851] CHIP:CTL: Performing next commissioning step 'FindOperational'
    [1687452616.570475][124848:124851] CHIP:CSM: FindOrEstablishSession: PeerId = [1:000000000000A219]
    [1687452616.570495][124848:124851] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1687452616.570538][124848:124851] CHIP:DIS: OperationalSessionSetup[1:000000000000A219]: State change 1 --> 2
    [1687452616.571152][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452616.770875][124848:124851] CHIP:DIS: Checking node lookup status after 201 ms
    [1687452619.265913][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452621.741998][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452621.742248][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452624.440940][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452626.917726][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452626.917846][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452629.616637][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452632.092342][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452632.092493][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452632.951991][124848:124851] CHIP:DIS: Timeout waiting for mDNS resolution.
    [1687452634.657278][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452637.179756][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452637.179964][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452639.743137][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452642.218824][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452642.218979][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452644.782981][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452647.259407][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452647.259530][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452647.575946][124848:124851] CHIP:DIS: Timeout waiting for mDNS resolution.
    [1687452649.824605][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452652.300762][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452652.300904][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452654.910774][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452657.385939][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452657.386187][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452659.950321][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452661.572108][124848:124851] CHIP:DIS: Checking node lookup status after 45002 ms
    [1687452661.572166][124848:124851] CHIP:DIS: OperationalSessionSetup[1:000000000000A219]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout
    [1687452661.572174][124848:124851] CHIP:DIS: Retrying operational DNS-SD discovery. Attempts remaining: 2
    [1687452661.572580][124848:124851] CHIP:CTL: Session establishment failed for <000000000000A219, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 60 seconds
    [1687452661.572616][124848:124851] CHIP:CTL: Arming failsafe (120 seconds)
    [1687452661.572704][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452661.572720][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452661.572835][124848:124851] CHIP:EM: <<< [E:17881i S:44403 M:253297772] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452661.572874][124848:124851] CHIP:IN: (S) Sending msg 253297772 on secure session with LSID: 44403
    [1687452661.573430][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452661.661895][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452661.663849][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452661.664045][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452661.664367][124848:124851] CHIP:EM: >>> [E:17881i S:44403 M:60129869] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452661.664405][124848:124851] CHIP:EM: Found matching exchange: 17881i, Delegate: 0x7f121c071a18
    [1687452661.664444][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452661.664538][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452661.664561][124848:124851] CHIP:DMG: {
    [1687452661.664585][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452661.664610][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452661.664654][124848:124851] CHIP:DMG:     [
    [1687452661.664671][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452661.664715][124848:124851] CHIP:DMG:         {
    [1687452661.664734][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452661.664761][124848:124851] CHIP:DMG:             {
    [1687452661.664785][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452661.664816][124848:124851] CHIP:DMG:                 {
    [1687452661.664842][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452661.664867][124848:124851] CHIP:DMG:                     ClusterId = 0x30,
    [1687452661.664891][124848:124851] CHIP:DMG:                     CommandId = 0x1,
    [1687452661.664914][124848:124851] CHIP:DMG:                 },
    [1687452661.664941][124848:124851] CHIP:DMG:
    [1687452661.664963][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452661.664989][124848:124851] CHIP:DMG:                 {
    [1687452661.665019][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452661.665049][124848:124851] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687452661.665100][124848:124851] CHIP:DMG:                 },
    [1687452661.665113][124848:124851] CHIP:DMG:             },
    [1687452661.665135][124848:124851] CHIP:DMG:
    [1687452661.665146][124848:124851] CHIP:DMG:         },
    [1687452661.665168][124848:124851] CHIP:DMG:
    [1687452661.665179][124848:124851] CHIP:DMG:     ],
    [1687452661.665202][124848:124851] CHIP:DMG:
    [1687452661.665213][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452661.665226][124848:124851] CHIP:DMG: },
    [1687452661.665305][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687452661.665330][124848:124851] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
    [1687452661.665363][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452661.772628][124848:124851] CHIP:DIS: Checking node lookup status after 200 ms
    [1687452664.227600][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452666.702503][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452666.702616][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452669.267403][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452671.744272][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452671.744380][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452674.308755][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452676.784292][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452676.784495][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452679.348665][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452681.825275][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452681.825496][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452684.390052][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452686.865185][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452686.865383][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452689.429427][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452691.907434][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452691.907665][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452692.576205][124848:124851] CHIP:DIS: Timeout waiting for mDNS resolution.
    [1687452694.471086][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452696.946584][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452696.946696][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452699.510715][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452702.031830][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452702.032022][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452704.596406][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452706.574555][124848:124851] CHIP:DIS: Checking node lookup status after 45002 ms
    [1687452706.574604][124848:124851] CHIP:DIS: OperationalSessionSetup[1:000000000000A219]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout
    [1687452706.574612][124848:124851] CHIP:DIS: Retrying operational DNS-SD discovery. Attempts remaining: 1
    [1687452706.574808][124848:124851] CHIP:CTL: Session establishment failed for <000000000000A219, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 60 seconds
    [1687452706.574825][124848:124851] CHIP:CTL: Arming failsafe (120 seconds)
    [1687452706.574868][124848:124851] CHIP:DMG: ICR moving to [AddingComm]
    [1687452706.574882][124848:124851] CHIP:DMG: ICR moving to [AddedComma]
    [1687452706.574958][124848:124851] CHIP:EM: <<< [E:17882i S:44403 M:253297773] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1687452706.574979][124848:124851] CHIP:IN: (S) Sending msg 253297773 on secure session with LSID: 44403
    [1687452706.575309][124848:124851] CHIP:DMG: ICR moving to [CommandSen]
    [1687452706.666098][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452706.670371][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452706.670718][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452706.670986][124848:124851] CHIP:EM: >>> [E:17882i S:44403 M:60129870] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1687452706.671025][124848:124851] CHIP:EM: Found matching exchange: 17882i, Delegate: 0x7f121c071a18
    [1687452706.671064][124848:124851] CHIP:DMG: ICR moving to [ResponseRe]
    [1687452706.671130][124848:124851] CHIP:DMG: InvokeResponseMessage =
    [1687452706.671149][124848:124851] CHIP:DMG: {
    [1687452706.671173][124848:124851] CHIP:DMG:     suppressResponse = false,
    [1687452706.671195][124848:124851] CHIP:DMG:     InvokeResponseIBs =
    [1687452706.671236][124848:124851] CHIP:DMG:     [
    [1687452706.671261][124848:124851] CHIP:DMG:         InvokeResponseIB =
    [1687452706.671312][124848:124851] CHIP:DMG:         {
    [1687452706.671331][124848:124851] CHIP:DMG:             CommandDataIB =
    [1687452706.671360][124848:124851] CHIP:DMG:             {
    [1687452706.671395][124848:124851] CHIP:DMG:                 CommandPathIB =
    [1687452706.671460][124848:124851] CHIP:DMG:                 {
    [1687452706.671484][124848:124851] CHIP:DMG:                     EndpointId = 0x0,
    [1687452706.671512][124848:124851] CHIP:DMG:                     ClusterId = 0x30,
    [1687452706.671532][124848:124851] CHIP:DMG:                     CommandId = 0x1,
    [1687452706.671549][124848:124851] CHIP:DMG:                 },
    [1687452706.671577][124848:124851] CHIP:DMG:
    [1687452706.671599][124848:124851] CHIP:DMG:                 CommandFields =
    [1687452706.671626][124848:124851] CHIP:DMG:                 {
    [1687452706.671656][124848:124851] CHIP:DMG:                     0x0 = 0,
    [1687452706.671688][124848:124851] CHIP:DMG:                     0x1 = "" (0 chars),
    [1687452706.671715][124848:124851] CHIP:DMG:                 },
    [1687452706.671745][124848:124851] CHIP:DMG:             },
    [1687452706.671787][124848:124851] CHIP:DMG:
    [1687452706.671804][124848:124851] CHIP:DMG:         },
    [1687452706.671850][124848:124851] CHIP:DMG:
    [1687452706.671905][124848:124851] CHIP:DMG:     ],
    [1687452706.671947][124848:124851] CHIP:DMG:
    [1687452706.671972][124848:124851] CHIP:DMG:     InteractionModelRevision = 1
    [1687452706.671990][124848:124851] CHIP:DMG: },
    [1687452706.672078][124848:124851] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1687452706.672152][124848:124851] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
    [1687452706.672217][124848:124851] CHIP:DMG: ICR moving to [AwaitingDe]
    [1687452706.774521][124848:124851] CHIP:DIS: Checking node lookup status after 200 ms
    [1687452709.231716][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452711.707681][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452711.707803][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452714.272973][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452716.748325][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452716.748437][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452719.312930][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1687452721.790439][124848:124850] CHIP:DL: Indication received, conn = 0x7f121c06fff0
    [1687452721.790644][124848:124851] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1687452721.918195][124848:124848] CHIP:CTL: Shutting down the commissioner
    [1687452721.918268][124848:124848] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452721.918398][124848:124848] CHIP:DIS: Closing all BLE connections
    [1687452721.918423][124848:124848] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1687452721.918462][124848:124848] CHIP:BLE: CancelBleIncompleteConnection() failed, err = src/platform/Linux/BLEManagerImpl.cpp:732: CHIP Error 0x0000002D: Not Implemented
    [1687452721.918493][124848:124848] CHIP:IN: Clearing BLE pending packets.
    [1687452721.918976][124848:124848] CHIP:BLE: Auto-closing end point's BLE connection.
    [1687452721.919001][124848:124848] CHIP:DL: Closing BLE GATT connection (con 0x7f121c06fff0)
    [1687452721.919083][124848:124850] CHIP:DL: BluezDisconnect peer=48:22:54:5F:2B:F3
    [1687452723.821825][124848:124848] CHIP:IN: SecureSession[0x7f121400f400]: MarkForEviction Type:1 LSID:44403
    [1687452723.821861][124848:124848] CHIP:SC: SecureSession[0x7f121400f400, LSID:44403]: State change 'kActive' --> 'kPendingEviction'
    [1687452723.821904][124848:124848] CHIP:IN: SecureSession[0x7f121400f400]: Released - Type:1 LSID:44403
    [1687452723.821926][124848:124848] CHIP:CTL: Shutting down the controller
    [1687452723.821946][124848:124848] CHIP:DIS: OperationalSessionSetup[1:000000000000A219]: Cancelling incomplete address resolution as device is being deleted.
    [1687452723.821988][124848:124848] CHIP:CTL: Device connection failed. Error src/app/OperationalSessionSetup.cpp:450: CHIP Error 0x00000074: The operation has been cancelled
    [1687452723.822007][124848:124848] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1687452723.822026][124848:124848] CHIP:FP: Forgetting fabric 0x1
    [1687452723.822045][124848:124848] CHIP:TS: Pending Last Known Good Time: 2023-06-21T16:18:47
    [1687452723.822204][124848:124848] CHIP:TS: Previous Last Known Good Time: 2023-06-21T16:18:47
    [1687452723.822294][124848:124848] CHIP:TS: Reverted Last Known Good Time to previous value
    [1687452723.822366][124848:124848] CHIP:CTL: Shutting down the commissioner
    [1687452723.822382][124848:124848] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1687452723.822454][124848:124848] CHIP:CTL: Shutting down the controller
    [1687452723.822472][124848:124848] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1687452723.822554][124848:124850] CHIP:DL: Bluez disconnected
    [1687452723.822572][124848:124850] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    [1687452723.822573][124848:124848] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1687452723.822640][124848:124848] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1687452723.822736][124848:124848] CHIP:FP: Shutting down FabricTable
    [1687452723.822770][124848:124848] CHIP:TS: Pending Last Known Good Time: 2023-06-21T16:18:47
    [1687452723.822915][124848:124848] CHIP:TS: Previous Last Known Good Time: 2023-06-21T16:18:47
    [1687452723.822927][124848:124848] CHIP:TS: Reverted Last Known Good Time to previous value
    [1687452723.823131][124848:124848] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-hSvwT1)
    [1687452723.823511][124848:124848] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1687452723.823553][124848:124848] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1687452723.823568][124848:124848] CHIP:DL: Inet Layer shutdown
    [1687452723.823580][124848:124848] CHIP:DL: BLE shutdown
    [1687452723.823601][124848:124848] CHIP:BLE: CancelBleIncompleteConnection() failed, err = src/ble/BleLayer.cpp:372: CHIP Error 0x00000003: Incorrect state
    [1687452723.825022][124848:124848] CHIP:DL: System Layer shutdown
    [1687452723.825324][124848:124848] CHIP:TOO: Run command failure: ../examples/chip-tool/commands/common/CHIPCommand.cpp:550: CHIP Error 0x00000032: Timeout
    I've edited your replies so that the log outputs are in a code snippet box. Please attach your logs to a snippet box in the future so it becomes easier to navigate the case in case the logs are long:
    I don't think the issue here is the operationalsessionsetup. I believe that error masks up another error you see, which is
    This timeout error suggests that commissioning fails somewhere. Either because of the device not advertising that it is commissionable, that you can't find it or other. Nonetheless it looks like a timeout issue
    I think I will go back to my initial recommendations regarding starting at https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/protocols/matter/index.html
    • Go through the Matter overview subpage, watch the Matter webinar and familiarize yourself with the concepts
    • Go through the getting started with Matter subpage which contains another webinar regarding how to test Matter samples in nRF Connect SDK and how finishes with how to test with commercial Matter ecosystems
    This should hopefully set you up for success!
    Andreas
