nrf5340 net core upgrade
I just found that upgrade the net core need to set CONFIG_SERIAL=y and enable the UART in dts file, otherwise, it hangs on the network_core_pcd_cmdset function when upgrading the net core FW,  pcd_fw_copy_status_get() always returns 0.  Is this expected?  if yes, I would like to disable the net core's UART to save the current consumption, any workarounds?
static int network_core_pcd_cmdset(const void *src_addr, size_t len, bool wait)
	int err;
	/* Ensure that the network core is turned off */
	nrf_reset_network_force_off(NRF_RESET, true);
	err = pcd_cmd_write(src_addr, len, PCD_NET_CORE_APP_OFFSET);
	if (err != 0) {
		LOG_INF("Error while writing PCD cmd: %d", err);
		return err;
	nrf_reset_network_force_off(NRF_RESET, false);
	LOG_INF("Turned on network core");
	if (!wait) {
		return 0;
	do {
		/* Wait for 1 second to avoid issue where network core
		 * is unable to write to shared RAM.
		k_busy_wait(1 * USEC_PER_SEC);
		err = pcd_fw_copy_status_get();
	} while (err == PCD_STATUS_COPY);
	if (err == PCD_STATUS_COPY_FAILED) {
		LOG_ERR("Network core update failed");
		return err;
	LOG_INF("Turned off network core");
	network_core_pcd_tidy();
	return 0;
  • Jason said:
    by the way, if CONFIG_RESET_ON_FATAL_ERROR=n, what will happen on the network core when a fatal error occurs, crash, or ...?
    The network core will not reset on its own, and must be reset by other means.
    For example, from nRF5340 RESET: "When the application core performs a soft reset, the network core is held in reset, see Network Force-OFF. A soft reset in the network core will only cause the network core to reset."
    Depending a bit on your application, you might want the network core to reset automatically or not, so that would be up to you.
    Sigurd Hellesvik
