Does mbedtls APIs (sha256.h) use the hardware acceleration?
Hello Nordic team,
I'm currently looking into mbedtls on nRF5340, I'm using nRF NCS SDK 2.1.0
I wanted to calculate the HASH of the firmware image, I already developed one API that calculate and provide me a HASH of firmware image,
But I am unsure that API internally used the nRF5340 hardware acceleration feature or not? If not, then please provide me a sample code that used the hardware-acceleration internally?
Below is my API that provide me a HASH of firmware image.
void calculate_file_hash(unsigned char *hash_value, size_t hash_size)
    uint8_t buffer[READ_FLASH_BYTES];
    size_t bytes_read, address = QSPI_OTA_HEADER_START_ADDRESS;
    int rc = 0u;
    LOG_INF("calculate_file_hash");
    mbedtls_sha256_context sha256_ctx;
    mbedtls_sha256_init(&sha256_ctx);
    mbedtls_sha256_starts(&sha256_ctx, /*is224=*/0);
    for(bytes_read = 210539; bytes_read > 0; )       // For Net core
        if(bytes_read >= READ_FLASH_BYTES)
            rc = external_flash_sector_read(address, buffer, READ_FLASH_BYTES);
            if(rc != 0U)
                LOG_INF("Error in flash reading(%x)", rc);
            mbedtls_sha256_update(&sha256_ctx, buffer, READ_FLASH_BYTES);
            memset(buffer, 0xFF, READ_FLASH_BYTES);
            rc = external_flash_sector_read(address, buffer, bytes_read);
            if(rc != 0U)
            mbedtls_sha256_update(&sha256_ctx, buffer, bytes_read);
            bytes_read = bytes_read - READ_FLASH_BYTES;
            bytes_read = 0;
        address = address + READ_FLASH_BYTES;
        // LOG_INF("address = %x, bytes_read = %d", address, bytes_read);
    mbedtls_sha256_finish(&sha256_ctx, hash_value);
    mbedtls_sha256_free(&sha256_ctx);
Thanks in advance,
Kaushik
  • Hi Dejans,
    As per describe in above two answers (For matter->lock sample code),
    Can you please confirm that, is it the same behavior at your side as well or not?
    Kaushik Parsana
    I have reproduced your issue.
    There are some changes which you could make to enable successful building of your project. Here are required configuration changes in prj.conf:
    CONFIG_NORDIC_SECURITY_BACKEND=y
    #CONFIG_CC3XX_BACKEND=y
    CONFIG_MBEDTLS_SHA256_C=y
    #CONFIG_PSA_CRYPTO_DRIVER_CC3XX
    I have added an overlay file in Kconfig fragments, but this is not mandatory for having successful builds:
    -DCONF_OVERLAY:STRING="board/nrf5340dk_nrf5340_cpuapp.overlay"
    I have also built lock sample with the shield by adding these Kconfig fragments:
    -Dhci_rpmsg_SHIELD:STRING="nrf7002_ek_coex"
    In both cases builds were successful.
    As a confirmation of activated hardware acceleration, CONFIG_MBEDTLS_SHA256_ALT=y was present in build\zephyr\.conf file.
    Dejan
  • Hi Dejans,
    What I understand from your answer is, if "CONFIG_MBEDTLS_SHA256_ALT=y" present in my build\zephyr\.config file then mbedtls SHA256 API(Like below) internally used the hardware acceleration?
    List of SHA256 API used in HASH calculation:
        mbedtls_sha256_update(&sha256_ctx, buffer, strlen((const char*)buffer));
    Kaushik
    As far as I know, this should be the case. However, I have had a discussion with our developers. Suggestion for you would be to put #error inside mbedtls_sha256_init() in the file modules/crypto/mbedtls/library/sha256.c. If it builds without error, then it must be coming from ALT configuration.
    Dejan
  • Thanks, dejans,
    I had confirmed the things and it is working.
    Kaushik Parsana
