I have a customer that wants to provide me with .a file for some confidential algorithm they want to run. I am tasked with implementing this into my firmware.
Using the links below I have been able to compile in the .a file along with its associated header file. I can even use the #include to include the header file. However, when I start to call functions from the header file, the ld.exe returns an undefined reference exception.
My file structure is below, as well as my CMakelists.txt. It appears that I have followed the links and the example for linking an external library perfectly. Can I get some support to what I am missing, or what I should try next?
Thanks
CMakeLists.txt:
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(hello_world)
target_sources(app PRIVATE src/main.c)
set(insight_src_dir ${CMAKE_CURRENT_SOURCE_DIR}/insight)
set(INSIGHT_LIB_DIR ${insight_src_dir}/lib)
set(INSIGHT_INCLUDE_DIR ${insight_src_dir}/inc)
add_library(insight_lib STATIC IMPORTED GLOBAL)
set_target_properties(insight_lib PROPERTIES IMPORTED_LOCATION ${INSIGHT_LIB_DIR}/insight.a)
set_target_properties(insight_lib PROPERTIES INTERFACE_INCLUDE_DIRECTORIES ${INSIGHT_INCLUDE_DIR})
target_link_libraries(app PUBLIC insight_lib)
Here is my folder structure:
hello_world
> build
> insight
- header.h
> lib
- library.a
> src
- main.c
- CMakeLists.txt
- prj.conf
