Cannot connect to J-Link
I am evaluating nRF52840 DK in the following development environment:
  • Contiki-NG ver 4.7 running in the standard Contiki container. Per Contiki, the container has all the required development tools for Nordic devices.
After connecting the DK it is present as two devices: ttyACM0 and ttyACM1. I further validated that Contiki recognizes it and can connect:
make TARGET=nrf52840 motelist-all
python ../../tools/motelist/motelist.py
Port          Serial        VID     PID     Product  Vendor
/dev/ttyACM0  0x1050232358  0x1366  0x1051  J-Link   SEGGER
/dev/ttyACM1  0x1050232358  0x1366  0x1051  J-Link   SEGGER
However, when programming the DK, I get the following error. Also attached is the requested log.log file.
I tried with different cables and the two device ports listed above to no avail.
make TARGET=nrf52840 PORT=/dev/ttyACM0 hello-world.upload
nrfjprog -f nrf52  --sectorerase --program build/nrf52840/dk/hello-world.hex
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
../../arch/cpu/nrf52840/Makefile.nrf52840:127: recipe for target 'hello-world.upload' failed
make: *** [hello-world.upload] Error 33
[2023-Jun-29 19:29:05] [ info] --------------------------------------------------------------------------------
[2023-Jun-29 19:29:05] [ info] nrfjprog -f nrf52 --sectorerase --program build/nrf52840/dk/hello-world.hex --log
[2023-Jun-29 19:29:05] [ info] nrfjprog version 10.12.1
[2023-Jun-29 19:29:05] [debug] [ nRF0x0] - open_dll
[2023-Jun-29 19:29:05] [ info] [ nRF0x0] - Load library at /opt/nrfjprog/libjlinkarm_nrf52_nrfjprogdll.so.
[2023-Jun-29 19:29:05] [ info] [ nRF0x0] - Library loaded, loading member functions.
[2023-Jun-29 19:29:05] [ info] [ nRF0x0] - Member functions succesfully loaded.
[2023-Jun-29 19:29:05] [ info] [Backend] - Logger callback at 0x565740e0 registered in Segger backend logger.
[2023-Jun-29 19:29:05] [ info] [  JLink] - [Info    ] [JLink     ] Logger callback at 0x565740e0 registered in JLink logger.
[2023-Jun-29 19:29:05] [debug] [nRF520x0] - open
[2023-Jun-29 19:29:05] [debug] [Backend] - open_dll
[2023-Jun-29 19:29:05] [ info] [Backend] - No J-Link DLL path was provided. Attempting to auto detect.
[2023-Jun-29 19:29:05] [ info] [Backend] - Load library at /opt/SEGGER/JLink/libjlinkarm_x86.so.
[2023-Jun-29 19:29:05] [ info] [Backend] - Library loaded, loading member functions.
[2023-Jun-29 19:29:05] [ info] [Backend] - Member functions succesfully loaded.
[2023-Jun-29 19:29:05] [debug] [Backend] - dll_version
[2023-Jun-29 19:29:05] [ info] [Backend] - Segger dll version 6.88.a loaded.
[2023-Jun-29 19:29:05] [debug] [ nRF0x0] - enum_emu_snr
[2023-Jun-29 19:29:05] [debug] [nRF520x0] - enum_emu_snr
[2023-Jun-29 19:29:05] [debug] [Backend] - is_connected_to_emu
[2023-Jun-29 19:29:05] [debug] [Backend] - enum_emu_snr
[2023-Jun-29 19:29:05] [debug] [Backend] - ---just_enum_emu_snr
[2023-Jun-29 19:29:05] [debug] [Backend] - ---just_get_num_emus
[2023-Jun-29 19:29:06] [debug] [Backend] - is_connected_to_emu
[2023-Jun-29 19:29:06] [debug] [ nRF0x0] - connect_to_emu_with_snr
[2023-Jun-29 19:29:06] [debug] [nRF520x0] - connect_to_emu_with_snr
[2023-Jun-29 19:29:06] [debug] [Backend] - connect_to_emu_with_snr
[2023-Jun-29 19:29:06] [debug] [Backend] - ---just_enum_emu_snr
[2023-Jun-29 19:29:06] [debug] [Backend] - ---just_get_num_emus
[2023-Jun-29 19:29:08] [debug] [Backend] - ---just_connect_to_emu_with_snr
[2023-Jun-29 19:29:08] [debug] [Backend] - ---just_connect_to_emu_without_snr
[2023-Jun-29 19:29:08] [ info] [Backend] - Segger logging enabled.
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ]    ***** Error:
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] Cannot connect to J-Link.
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] - 12.528ms returns "Cannot connect to J-Link."
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] JLINK_HasError()
[2023-Jun-29 19:29:08] [ info] [Backend] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.'
[2023-Jun-29 19:29:08] [debug] [Backend] - is_connected_to_emu
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] JLINK_IsOpen()
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] - 0.009ms returns 0x00
[2023-Jun-29 19:29:08] [debug] [ nRF0x0] - close_dll
[2023-Jun-29 19:29:08] [debug] [nRF520x0] - close
[2023-Jun-29 19:29:08] [debug] [Backend] - close
[2023-Jun-29 19:29:08] [debug] [Backend] - disconnect_from_emu
[2023-Jun-29 19:29:08] [ info] [  JLink] - [Info    ] [JLink     ] - 0.010ms returns 0x00
[2023-Jun-29 19:29:08] [debug] [Backend] - Segger Backend closed.
[2023-Jun-29 19:29:08] [debug] [nRF520x0] - nRF family DLL closed
Thank you for your answer.
  • 1. You need to select one of the x64 downloads. However, the choice of installer depends on the Linux distribution you are using. If you have a Debian-based distribution, you can use the *.deb package.
    2. The only additional package that should be installed is the J-link driver.
    Installing the nRF Command Line Tools
  • I installed nRF command line tools on the Linux VM, which runs on the same machine. Running the command you requested leads to the following:
    nrfjprog -e
    [error] [ Client] - Encountered error -90: Command read_device_info executed for 17 milliseconds with result -90
    [error] [ Worker] - Access protection is enabled, can't read device version.
    [error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 23 milliseconds with result -90
    [error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.
    ERROR: The operation attempted is unavailable due to readback protection in
    ERROR: your device. Please use --recover to unlock the device.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    What is the next step?
  • Similar results when running directly from the Mac computer:
    nrfjprog -e
    [error] [ Client] - Encountered error -90: Command read_device_info executed for 3 milliseconds with result -90
    [error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 3 milliseconds with result -90
  • nrfjprog is able to communicate with the nRF chip now. As the error message suggests, you can run 'nrfjprog --recover' to turn off readback protection on the chip.
  • What is readback protection? Who set it up in the first place? Will I need to do that with all the devices I bought? Is it discussed in the user guide?
