nrf5340 ble full stack in network core
hello there was a problem configuring the project.
i want build uart central, peripheral project with rpc_host.
The uart peripheral project built fine with -DCONFIG_BT_RPC_STACK=y, but the uart central project failed to build even with DCONFIG_BT_RPC_STACK=y added.
Is there something wrong with this? Or is this not supported for all projects yet?
this is build error log.
it looks like flash memory overflow.
[278/291] Linking C static library zephyr\kernel\libkernel.a
[279/291] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\Users\jaesun\Desktop\work\NORDIC\toolchains\v2.3.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D C:\Users\jaesun\Desktop\work\NORDIC\ble_full_stack\central_uart\build\rpc_host\zephyr && C:\Users\jaesun\Desktop\work\NORDIC\toolchains\v2.3.0\opt\bin\cmake.exe -E echo ""
c:/users/jaesun/desktop/work/nordic/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
c:/users/jaesun/desktop/work/nordic/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 19289 bytes
collect2.exe: error: ld returned 1 exit status
[6/286] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (C:/Users/jaesun/Desktop/work/NORDIC/v2.3.0/zephyr), build: v3.2.99-ncs2
[271/286] Linking C executable zephyr\zephyr_pre0.elf
FAILED: modules/nrf/samples/rpc_host_subimage-prefix/src/rpc_host_subimage-stamp/rpc_host_subimage-build rpc_host/zephyr/zephyr.hex rpc_host/zephyr/zephyr.elf rpc_host/zephyr/merged_CPUNET.hex
cmd.exe /C "cd /D C:\Users\jaesun\Desktop\work\NORDIC\ble_full_stack\central_uart\build\rpc_host && C:\Users\jaesun\Desktop\work\NORDIC\toolchains\v2.3.0\opt\bin\cmake.exe --build . --"
[273/286] Generating dev_handles.c
FATAL ERROR: command exited with status 1: 'c:\Users\jaesun\Desktop\work\NORDIC\toolchains\v2.3.0\opt\bin\cmake.EXE' --build 'c:\Users\jaesun\Desktop\work\NORDIC\ble_full_stack\central_uart\build'
*  The terminal process terminated with exit code: 1.
*  Terminal will be reused by tasks, press any key to close it.
  • hello dejans.
    i add CONFIG_BT_PERIPHERAL=n
    # Enable the UART driver
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_UARTE0=y
    CONFIG_SERIAL=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    # Enable the BLE stack with GATT Client configuration
    CONFIG_BT=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_SMP=y
    CONFIG_BT_GATT_CLIENT=y
    # Enable the BLE modules from NCS
    CONFIG_BT_NUS_CLIENT=y
    CONFIG_BT_SCAN=y
    CONFIG_BT_SCAN_FILTER_ENABLE=y
    CONFIG_BT_SCAN_UUID_CNT=1
    CONFIG_BT_GATT_DM=y
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    # This example requires more workqueue stack
    # Enable bonding
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    # Config logger
    # CONFIG_LOG=y
    # CONFIG_USE_SEGGER_RTT=y
    # CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_UART=n
    # CONFIG_LOG_PRINTK=n
    # CONFIG_ASSERT=y
    it compiled well.
    but run my application
    ble central device print this log infinitely.
    it seem like ble central function not working
    *** Booting Zephyr OS build v3.2.99-ncs2 ***
    I have tested central_uart sample (building for nrf5340dk_nrf5340_cpuapp) from VS Code with additional Cmake argument -DCONFIG_BT_RPC_STACK=y. I have successfully reproduced the issue with different rpc_host.conf configurations. We will discuss this internally. I will get back to you when I get new information related to your problem.
    Dejan
    I have reported the issue internally. I will get back to you when I get new information.
    Please note that due to vacations and reduced staffing, getting the reply might be delayed. Thank you for your patience and understanding.
    Dejan
    To provide a short update, we are looking into your problem. I am expecting to get back to you by the end of next week.
    Dejan
    We are still looking into your problem.
    Thank you for your patience.
    Dejan
