SD GATT procedure (2) failed on connection handle 0 with error: 0x0000000D.
Hello, everyone
I used NRF52832 as the center and tried to connect to a peripheral, but after connecting for a fixed period of time, the center would actively disconnect from the peripheral. This problem is inevitable. This seems to be the result of an abnormal connector? And unfortunately, I couldn't fix the problem by modifying the peripheral configuration, only by modifying the center code.
The central application code is very simple, just a serial port passthrough service, and handles AT instructions from the serial port.
I provided the sniffer's log file, the center's main code file, and the Soc's log file.
Thank you
<info> app: result=AT+CONN, cmp_len=7, ok_count=7, leng=21, at_code=7
<debug> ble_scan: Filter set on address 0x
<debug> ble_scan:  B6 FF 93 37 1D CA      |...7..
<debug> ble_scan: Scanning
<debug> ble_scan: Connecting
<debug> ble_scan: Connection status: 0
<debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
<debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
<info> app: Connecting to target B6FF93371DCA
<debug> nrf_ble_gq: Purging request queue with id: 0
<debug> nrf_ble_gq: Registering connection handle: 0x0000
<debug> ble_db_disc: Starting discovery of service with UUID 0xAE30 on connection handle 0x0.
<debug> nrf_ble_gq: Adding item to the request queue
<debug> nrf_ble_gq: GATTC Primary Services Discovery Request
<debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted                       again later.
<debug> nrf_ble_gq: Processing the request queue...
<debug> nrf_ble_gq: GATTC Primary Service Discovery Request
<debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
<debug> nrf_ble_gatt: max_rx_octets: 27
<debug> nrf_ble_gatt: max_tx_octets: 27
<debug> nrf_ble_gatt: max_rx_time: 328
<debug> nrf_ble_gatt: max_tx_time: 328
<error> nrf_ble_gq: SD GATT procedure (2) failed on connection handle 0 with error: 0x0000000D.
<debug> app: GATT Client Timeout.
<info> app: Disconnected.
<info> app: Disconnected. conn_handle: 0x0, reason: 0x16
DW2AT-R.pcapng
 * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_conn_state.h"
#include "at_cmd.h"
#define VERSION_STRING_APP	"ver:V1.0.0 build:"__DATE__" "__TIME__
static uint32_t find_adv_name(const ble_gap_evt_adv_report_t *p_adv_report, uint8_t *p_name);
static void AT_SCNT_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_SCAN_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_COMI_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_COMA_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_COLA_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_COSU_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_CONN_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_CONC_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_DISC_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_DATA_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_VERS_Handler(uint8_t *p_data, uint16_t data_len);
static void AT_TEST_Handler(uint8_t *p_data, uint16_t data_len);
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  0                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);                                             /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
#define SCAN_NAME_BUFFER_SIZE	(NRF_BLE_SCAN_NAME_MAX_LEN)	/*��ʱ�洢�㲥���֣�*/
#define SCAN_TIMEOUT_DEFAULT	(500)/**< Scan timeout in 10 ms units. @sa BLE_GAP_SCAN_TIMEOUT. */
static ble_gap_scan_params_t m_scan_param =
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = SCAN_TIMEOUT_DEFAULT,
    .scan_phys     = BLE_GAP_PHY_1MBPS,// 1 Mbps PHY
static ble_gap_conn_params_t m_conn_param =
  .min_conn_interval 	= (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL, UNIT_1_25_MS),         /**< Minimum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
  .max_conn_interval 	= (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL, UNIT_1_25_MS),         /**< Maximum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
  .slave_latency 		= (uint16_t)NRF_BLE_SCAN_SLAVE_LATENCY,             /**< Slave Latency in number of connection events, see @ref BLE_GAP_CP_LIMITS.*/
  .conn_sup_timeout 	= (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_SUPERVISION_TIMEOUT, UNIT_10_MS),          /**< Connection Supervision Timeout in 10 ms units, see @ref BLE_GAP_CP_LIMITS.*/
#define UART_TIMER_TIMEOUT (30)
APP_TIMER_DEF(m_uart_rx_tmr);
static uint8_t uart_rx_buf[BLE_NUS_MAX_DATA_LEN];
static uint8_t uart_rx_index = 0;
static uint16_t uart_rx_leng = 0;
/* at command define */
static volatile uint8_t at_received = 0;	//at data has received
static volatile at_code_typ at_process = AT_NULL;
at_member_str const at_member_array[] = {
	{AT_COMI, AT_COMI_CODE},
	{AT_COMA, AT_COMA_CODE},
	{AT_COLA, AT_COLA_CODE},
	{AT_COSU, AT_COSU_CODE},
	{AT_SCNT, AT_SCNT_CODE},
	{AT_SCAN, AT_SCAN_CODE},
	{AT_CONN, AT_CONN_CODE},
	{AT_CONC, AT_CONC_CODE},
	{AT_DISC, AT_DISC_CODE},
	{AT_DATA, AT_DATA_CODE},
	{AT_VERS, AT_VERS_CODE},
	{AT_TEST, AT_TEST_CODE},
	{NULL, AT_NULL}
/* current connection param define */
struct curr_conn_param_str {
	uint8_t channel;
	uint8_t filter_address[6];
} curr_conn_param = {0, 0, 0, 0, 0, 0, 0};
uint16_t conn_handle_array[2] = {BLE_CONN_HANDLE_INVALID,BLE_CONN_HANDLE_INVALID};
#define GET_CHANNEL_INDEX_BY_BLE_NUS_C(conn_handle_) (m_ble_nus_c[0].conn_handle == conn_handle_)?(0):(1)
#define GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(conn_handle_) (conn_handle_array[0] == conn_handle_)?(0):(1)
#define GET_CHANNEL_ACTIVE(channel_) (m_ble_nus_c[channel_].conn_handle == BLE_CONN_HANDLE_INVALID)?(0):(1)
/**@brief NUS UUID.
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
static uint8_t const m_name[] = "OTC Clarity Units-R";
static uint8_t const m_address[] = {0x11, 0x00, 0x40, 0x37, 0x03, 0x80};
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
static uint8_t const m_name_l[] = "OTC Clarity Units-L";
static uint8_t const m_address_l[] = {0x10, 0x00, 0x40, 0x37, 0x03, 0x80};
static void scan_reconfig(void)
	ret_code_t          err_code;
	nrf_ble_scan_stop();
	nrf_ble_scan_filters_disable(&m_scan);
	nrf_ble_scan_all_filter_remove(&m_scan);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_name_l);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, m_address_l);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
//    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
//    APP_ERROR_CHECK(ret);
//�����豸��ַ
void device_stor(ble_nus_c_t * p_ble_nus_c,ble_gap_evt_connected_t const * p_addr)
	p_ble_nus_c->addr.addr[0] = p_addr->peer_addr.addr[0];
	p_ble_nus_c->addr.addr[1] = p_addr->peer_addr.addr[1];
	p_ble_nus_c->addr.addr[2] = p_addr->peer_addr.addr[2];
	p_ble_nus_c->addr.addr[3] = p_addr->peer_addr.addr[3];
	p_ble_nus_c->addr.addr[4] = p_addr->peer_addr.addr[4];
	p_ble_nus_c->addr.addr[5] = p_addr->peer_addr.addr[5];
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
				if (at_process == AT_CONN_CODE)
					printf("OK+CONNE\r\n");
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
			  //device_stor(&m_ble_nus_c[p_scan_evt->params.connected.conn_handle],p_connected);
			  device_stor(&m_ble_nus_c[curr_conn_param.channel],p_connected);
             // Scan is automatically stopped by the connection.
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
            	printf("OK+CONN%dS\r\n", curr_conn_param.channel);
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             if (at_process == AT_SCAN_CODE)
				if ((GET_CHANNEL_ACTIVE(0)) || (GET_CHANNEL_ACTIVE(1)))
					if (GET_CHANNEL_ACTIVE(0))
						bsp_indication_set(BSP_INDICATE_USER_SCANNER_END_ONLY_1);
						bsp_indication_set(BSP_INDICATE_USER_SCANNER_END_ONLY_0);
					bsp_indication_set(BSP_INDICATE_USER_SCANNER_END);
				 printf("OK+SCANE\r\n");
				if (curr_conn_param.channel)
            	printf("OK+CONNF\r\n");
         } break;
		 case NRF_BLE_SCAN_EVT_NOT_FOUND:
				 uint8_t name_buffer[SCAN_NAME_BUFFER_SIZE];
				 memset(name_buffer, 0, SCAN_NAME_BUFFER_SIZE);
				 ble_gap_evt_adv_report_t const * p_adv = p_scan_evt->params.p_not_found;
				 if(find_adv_name(p_adv, name_buffer) != NRF_SUCCESS)
					 printf("OK+SCAN%02X%02X%02X%02X%02X%02X:%d:%s\r\n",
						p_adv->peer_addr.addr[0],
						p_adv->peer_addr.addr[1],
						p_adv->peer_addr.addr[2],
						p_adv->peer_addr.addr[3],
						p_adv->peer_addr.addr[4],
						p_adv->peer_addr.addr[5],
						p_adv->rssi,
						name_buffer
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(bool use_filter)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = use_filter;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
	init_scan.p_scan_param     = &m_scan_param;
	init_scan.p_conn_param     = &m_conn_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
	if (use_filter)
		err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, curr_conn_param.filter_address);
		err_code = nrf_ble_scan_filters_disable(&m_scan);
		err_code = nrf_ble_scan_all_filter_remove(&m_scan);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_name);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, m_address);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    //ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[GET_CHANNEL_INDEX_BY_BLE_NUS_C(p_evt->conn_handle)], p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len, uint8_t channel)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    printf("OK+DATA%d:%d:", channel, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
        } while (ret_val == NRF_ERROR_BUSY);*/
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
			if ((at_process == AT_NULL) && (at_received == 0) && (uart_rx_index < sizeof(uart_rx_buf)))
				UNUSED_VARIABLE(app_uart_get(&uart_rx_buf[uart_rx_index++]));
				APP_ERROR_CHECK(app_timer_start(m_uart_rx_tmr, APP_TIMER_TICKS(UART_TIMER_TIMEOUT), NULL));
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
			NRF_LOG_INFO("receive data for mac: %02X %02X %02X %02X %02X %02X\r\n",
							p_ble_nus_c->addr.addr[0],
							p_ble_nus_c->addr.addr[1],
							p_ble_nus_c->addr.addr[2],
							p_ble_nus_c->addr.addr[3],
							p_ble_nus_c->addr.addr[4],
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len, GET_CHANNEL_INDEX_BY_BLE_NUS_C(p_ble_nus_c->conn_handle));
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
           // scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
        	APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
            //err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c[curr_conn_param.channel], p_ble_evt->evt.gap_evt.conn_handle, NULL);
            conn_handle_array[curr_conn_param.channel] = p_ble_evt->evt.gap_evt.conn_handle;
            err_code = bsp_indication_set((curr_conn_param.channel)?(BSP_INDICATE_USER_CHANNEL_1_ACTIVE):(BSP_INDICATE_USER_CHANNEL_0_ACTIVE));
            // start discovery of services. The NUS Client waits for a discovery result
            //err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle);
            err_code = ble_db_discovery_start(&m_db_disc[curr_conn_param.channel], p_ble_evt->evt.gap_evt.conn_handle);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
            	NRF_LOG_INFO("central counter two!");
//            	scan_reconfig();
//            	scan_start();
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
            printf("OK+LOST%d:%02X%02X%02X%02X%02X%02X\r\n", GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle),
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[0],
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[1],
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[2],
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[3],
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[4],
            													m_ble_nus_c[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)].addr.addr[5]
            	(GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle))?
            	(BSP_INDICATE_USER_CHANNEL_1_INVALID):(BSP_INDICATE_USER_CHANNEL_0_INVALID));
            conn_handle_array[GET_CHANNEL_INDEX_BY_CONN_HANDLE_ARR(p_gap_evt->conn_handle)] = BLE_CONN_HANDLE_INVALID;
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
  //  ret_code_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Handle events from leds timer.
 * @note Timer handler does not support returning an error code.
 * Errors from bsp_led_indication() are not propagated.
 * @param[in]   p_context   parameter registered in timer start function.
static void uart_timer_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
	uart_rx_leng = uart_rx_index;
	uart_rx_index = 0;
	at_received = 1;
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
	err_code = app_timer_create(&m_uart_rx_tmr, APP_TIMER_MODE_SINGLE_SHOT, uart_timer_handler);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    init.p_gatt_queue  = &m_ble_gatt_queue;
    for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
	    err_code = ble_nus_c_init(&m_ble_nus_c[i], &init);
/**@brief Function for initializing leds. */
static void leds_init(void)
    //bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    //err_code = bsp_btn_ble_init(NULL, &startup_event);
    //APP_ERROR_CHECK(err_code);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        //nrf_pwr_mgmt_run();
static at_code_typ at_get_code(void *param, uint16_t leng)
	at_code_typ code = AT_NULL;
	uint16_t ok_count;
	uint16_t cmp_leng;
	uint8_t *p_at_str;
	uint8_t *p_param;
	if (at_received)
		at_member_str *p_at_member = (at_member_str *)at_member_array;
		while (p_at_member->string != NULL)
			ok_count = 0;
			cmp_leng = 0;
			p_at_str = (uint8_t *)p_at_member->string;
			p_param = (uint8_t *)param;
			while ((*p_at_str != '\0') && (cmp_leng < leng))
				cmp_leng++;
				if (*p_at_str++ == *p_param++)
					ok_count++;
			if (ok_count == strlen((const char *)p_at_member->string))
				code = p_at_member->code;
				NRF_LOG_INFO("result=%s, cmp_len=%d, ok_count=%d, leng=%d, at_code=%d", p_at_member->string, cmp_leng, ok_count, leng, code);
			p_at_member++;
		at_received = 0;
	return code;
static void uart_puts(uint8_t *p_data, uint16_t data_len)
	ret_code_t ret_val;
		do
	uint8_t i;
	uint32_t  index = 0;
	uint8_t * p_data;
	p_data = p_adv_report->data.p_data;
	while (index < p_adv_report->data.len)
	  uint8_t field_length = p_data[index];
	  uint8_t field_type   = p_data[index + 1];
	  if ((field_type == BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME) || (field_type == BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME))
		  for(i=0;i<field_length-1;i++)
			  *p_name++ = p_data[index+2+i];
			  if (i >= SCAN_NAME_BUFFER_SIZE - 1)
		  return NRF_SUCCESS;
	  index += field_length + 1;
	return NRF_ERROR_NOT_FOUND;
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    scan_init(false);
    // Start execution.
    printf("BLE UART central example started. zsl:%s\r\n", __TIME__);
    NRF_LOG_INFO("BLE UART central example started. zsl:%s", __TIME__);
    //scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
		if (at_process == AT_NULL)
			at_process = at_get_code(uart_rx_buf, uart_rx_leng);
			switch(at_process)
				case AT_COMI_CODE:
					AT_COMI_Handler(uart_rx_buf, uart_rx_leng);
				case AT_COMA_CODE:
					AT_COMA_Handler(uart_rx_buf, uart_rx_leng);
				case AT_COLA_CODE:
					AT_COLA_Handler(uart_rx_buf, uart_rx_leng);
				case AT_COSU_CODE:
					AT_COSU_Handler(uart_rx_buf, uart_rx_leng);
				case AT_SCNT_CODE:
					AT_SCNT_Handler(uart_rx_buf, uart_rx_leng);
				case AT_SCAN_CODE:
					AT_SCAN_Handler(uart_rx_buf, uart_rx_leng);
				case AT_CONN_CODE:
					AT_CONN_Handler(uart_rx_buf, uart_rx_leng);
				case AT_CONC_CODE:
					AT_CONC_Handler(uart_rx_buf, uart_rx_leng);
				case AT_DISC_CODE:
					AT_DISC_Handler(uart_rx_buf, uart_rx_leng);
				case AT_DATA_CODE:
					AT_DATA_Handler(uart_rx_buf, uart_rx_leng);
				case AT_VERS_CODE:
					AT_VERS_Handler(uart_rx_buf, uart_rx_leng);
				case AT_TEST_CODE:
					AT_TEST_Handler(uart_rx_buf, uart_rx_leng);
				default:break;
AT+SCNT[P]
P: [1~ 9] [?]
	uint8_t param = *(p_data + sizeof(AT_SCNT) - 1);
	if (data_len <= (sizeof(AT_SCNT) - 1))
		return;
	if (param == '?')
		printf("OK+Get:%d\r\n", m_scan_param.timeout/100);
	else if ((param >= '1') && (param <= '9'))
		m_scan_param.timeout = (param - '0')*100;
		scan_init(false);
		printf("OK+Set:%d\r\n", m_scan_param.timeout/100);
	if ((GET_CHANNEL_ACTIVE(0)) && (GET_CHANNEL_ACTIVE(1)))
		return;
	printf("OK+SCANS\r\n");
			bsp_indication_set(BSP_INDICATE_USER_SCANNER_START_ONLY_1);
			bsp_indication_set(BSP_INDICATE_USER_SCANNER_START_ONLY_0);
		bsp_indication_set(BSP_INDICATE_USER_SCANNER_START);
	scan_init(false);
	scan_start();
	int8_t interval = 0;
	uint8_t param = *(p_data + sizeof(AT_COMI) - 1);
		return;
	if (param == '?')
		switch (m_conn_param.min_conn_interval)
			case (uint16_t)MSEC_TO_UNITS(7.5, UNIT_1_25_MS):interval = 0;break;
			case (uint16_t)MSEC_TO_UNITS(10, UNIT_1_25_MS):interval = 1;break;
			case (uint16_t)MSEC_TO_UNITS(15, UNIT_1_25_MS):interval = 2;break;
			case (uint16_t)MSEC_TO_UNITS(20, UNIT_1_25_MS):interval = 3;break;
			case (uint16_t)MSEC_TO_UNITS(25, UNIT_1_25_MS):interval = 4;break;
			case (uint16_t)MSEC_TO_UNITS(30, UNIT_1_25_MS):interval = 5;break;
			case (uint16_t)MSEC_TO_UNITS(35, UNIT_1_25_MS):interval = 6;break;
			case (uint16_t)MSEC_TO_UNITS(40, UNIT_1_25_MS):interval = 7;break;
			case (uint16_t)MSEC_TO_UNITS(45, UNIT_1_25_MS):interval = 8;break;
			case (uint16_t)MSEC_TO_UNITS(60, UNIT_1_25_MS):interval = 9;break;
			default:interval = -1;break;
		printf("OK+Get:%d\r\n", interval);
	else if ((param >= '0') && (param <= '9'))
		switch (param)
			case '0':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(7.5, UNIT_1_25_MS);break;
			case '1':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(10, UNIT_1_25_MS);break;
			case '2':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(15, UNIT_1_25_MS);break;
			case '3':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(20, UNIT_1_25_MS);break;
			case '4':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(25, UNIT_1_25_MS);break;
			case '5':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(30, UNIT_1_25_MS);break;
			case '6':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(35, UNIT_1_25_MS);break;
			case '7':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(40, UNIT_1_25_MS);break;
			case '8':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(45, UNIT_1_25_MS);break;
			case '9':m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(60, UNIT_1_25_MS);break;
				m_conn_param.min_conn_interval = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL, UNIT_1_25_MS);
		scan_init(false);
		printf("OK+Set:%d\r\n", param-'0');
	uint8_t param = *(p_data + sizeof(AT_COMA) - 1);
		return;
	if (param == '?')
		switch (m_conn_param.max_conn_interval)
		switch (param)
			case '0':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(7.5, UNIT_1_25_MS);break;
			case '1':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(10, UNIT_1_25_MS);break;
			case '2':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(15, UNIT_1_25_MS);break;
			case '3':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(20, UNIT_1_25_MS);break;
			case '4':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(25, UNIT_1_25_MS);break;
			case '5':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(30, UNIT_1_25_MS);break;
			case '6':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(35, UNIT_1_25_MS);break;
			case '7':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(40, UNIT_1_25_MS);break;
			case '8':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(45, UNIT_1_25_MS);break;
			case '9':m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(60, UNIT_1_25_MS);break;
				m_conn_param.max_conn_interval = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL, UNIT_1_25_MS);
		scan_init(false);
		return;
	if (*(p_data + sizeof(AT_COLA) - 1) == '?')
		printf("OK+Get:%d\r\n", m_conn_param.slave_latency);
		uint32_t latency;
		int result;
		uint8_t buffer[4] = {0,0,0,0};
		memcpy(buffer, (p_data + sizeof(AT_COLA) - 1), data_len - sizeof(AT_COLA) + 1);
		result = sscanf((const char *)buffer, "%d", &latency);
		if ((latency <= BLE_GAP_CP_SLAVE_LATENCY_MAX) && (result == 1))
			m_conn_param.slave_latency = latency;
			scan_init(false);
			printf("OK+Set:%d\r\n", m_conn_param.slave_latency);
	int8_t timeout;
	uint8_t param = *(p_data + sizeof(AT_COSU) - 1);
		return;
	if (param == '?')
		switch (m_conn_param.conn_sup_timeout)
			case (uint16_t)MSEC_TO_UNITS(100, UNIT_10_MS):timeout = 0;break;
			case (uint16_t)MSEC_TO_UNITS(1000, UNIT_10_MS):timeout = 1;break;
			case (uint16_t)MSEC_TO_UNITS(2000, UNIT_10_MS):timeout = 2;break;
			case (uint16_t)MSEC_TO_UNITS(3000, UNIT_10_MS):timeout = 3;break;
			case (uint16_t)MSEC_TO_UNITS(4000, UNIT_10_MS):timeout = 4;break;
			case (uint16_t)MSEC_TO_UNITS(5000, UNIT_10_MS):timeout = 5;break;
			case (uint16_t)MSEC_TO_UNITS(6000, UNIT_10_MS):timeout = 6;break;
			default:timeout = -1;break;
		printf("OK+Get:%d\r\n", timeout);
	else if ((param >= '0') && (param <= '6'))
		if (param == '0')
			m_conn_param.conn_sup_timeout = (uint16_t)MSEC_TO_UNITS(100, UNIT_10_MS);
		else if((param >= '1') && (param <= '6'))
			m_conn_param.conn_sup_timeout = (uint16_t)MSEC_TO_UNITS((param-'0')*1000, UNIT_10_MS);
		scan_init(false);
		printf("OK+Set:%d\r\n", param - '0');
	uint32_t channel;
	uint32_t address[6];
	int result;
	if (data_len < (sizeof(AT_CONN"0:010203040506") - 1))
		goto flag_error;
	//extract
	result = sscanf((const char *)p_data, "AT+CONN%d:%02X%02X%02X%02X%02X%02X",
																&channel,
																&address[0],
																&address[1],
																&address[2],
																&address[3],
																&address[4],
																&address[5]);
	if (result != 7)
		goto flag_error;
	if (channel == 0)
		curr_conn_param.channel = 0;
	else if (channel == 1)
		curr_conn_param.channel = 1;
		goto flag_error;
	curr_conn_param.filter_address[0] = address[0];
	curr_conn_param.filter_address[1] = address[1];
	curr_conn_param.filter_address[2] = address[2];
	curr_conn_param.filter_address[3] = address[3];
	curr_conn_param.filter_address[4] = address[4];
	curr_conn_param.filter_address[5] = address[5];
	if (m_ble_nus_c[curr_conn_param.channel].conn_handle != BLE_CONN_HANDLE_INVALID)
		goto flag_error;
	// connecting target
	printf("OK+CONN%dA\r\n", curr_conn_param.channel); //report connecting
	scan_init(true);
	scan_start();
	return;
	flag_error:
	uint8_t channel;
	if (data_len < (sizeof(AT_CONC"0") - 1))
		goto flag_error;
	if (*(p_data + 7) == '0')
		channel = 0;
	else if(*(p_data + 7) == '1')
		channel = 1;
		goto flag_error;
	if (m_ble_nus_c[channel].conn_handle == BLE_CONN_HANDLE_INVALID)
		printf("OK+CON0\r\n");
		printf("OK+CON1:%02X%02X%02X%02X%02X%02X\r\n",
			m_ble_nus_c[channel].addr.addr[0],
			m_ble_nus_c[channel].addr.addr[1],
			m_ble_nus_c[channel].addr.addr[2],
			m_ble_nus_c[channel].addr.addr[3],
			m_ble_nus_c[channel].addr.addr[4],
			m_ble_nus_c[channel].addr.addr[5]);
	flag_error:
	uint8_t channel;
	if (data_len < (sizeof(AT_DISC"0") - 1))
		goto flag_error;
		channel = 0;
		channel = 1;
		goto flag_error;
		goto flag_error;
	err_code = sd_ble_gap_disconnect(m_ble_nus_c[channel].conn_handle,
		goto flag_error;
	printf("OK+DISC%d\r\n", channel);
	flag_error:
	uint32_t channel;
	uint32_t length;
	int result;
	uint8_t *p_send_data;
	uint8_t counter = 0;
	uint32_t ret_val;
	if (data_len < (sizeof(AT_DATA"0:0:") - 1))
		goto flag_error;
	result = sscanf((const char *)p_data, "AT+DATA%d:%d:", &channel, &length);
	NRF_LOG_INFO("sscanf result:%d, channel:%d, length:%d\r\n", result, channel, length);
	p_send_data = p_data + sizeof("AT+DATA0:") - 1;
	while ((*p_send_data++ != ':') && (++counter <= length));
    do
        ret_val = ble_nus_c_string_send(&m_ble_nus_c[channel], p_send_data, length);
        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
    } while (ret_val == NRF_ERROR_RESOURCES);
	flag_error:
	printf("OK+Get:%s\r\n", VERSION_STRING_APP);
	uart_puts("OK\r\n", sizeof("OK\r\n")-1);
 * Copyright (c) 2012 - 2021, Nordic Semiconductor ASA
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_NUS_C)
#include <stdlib.h>
#include "ble.h"
#include "ble_gattc.h"
#include "ble_srv_common.h"
#define NRF_LOG_MODULE_NAME ble_nus_c
NRF_LOG_MODULE_REGISTER();
/**@brief Function for intercepting the errors of GATTC and the BLE GATT Queue.
 * @param[in] nrf_error   Error code.
 * @param[in] p_ctx       Parameter from the event handler.
 * @param[in] conn_handle Connection handle.
static void gatt_error_handler(uint32_t   nrf_error,
                               void     * p_ctx,
                               uint16_t   conn_handle)
    ble_nus_c_t * p_ble_nus_c = (ble_nus_c_t *)p_ctx;
    NRF_LOG_DEBUG("A GATT Client error has occurred on conn_handle: 0X%X", conn_handle);
    if (p_ble_nus_c->error_handler != NULL)
        p_ble_nus_c->error_handler(nrf_error);
void ble_nus_c_on_db_disc_evt(ble_nus_c_t * p_ble_nus_c, ble_db_discovery_evt_t * p_evt)
    ble_nus_c_evt_t nus_c_evt;
    memset(&nus_c_evt,0,sizeof(ble_nus_c_evt_t));
    ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
    // Check if the NUS was discovered.
    if (    (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
        &&  (p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_NUS_SERVICE)
        &&  (p_evt->params.discovered_db.srv_uuid.type == p_ble_nus_c->uuid_type))
        for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
            switch (p_chars[i].characteristic.uuid.uuid)
                case BLE_UUID_NUS_RX_CHARACTERISTIC:
                    nus_c_evt.handles.nus_rx_handle = p_chars[i].characteristic.handle_value;
                    p_ble_nus_c->write_cmd = p_chars[i].characteristic.char_props.write_wo_resp;
                case BLE_UUID_NUS_TX_CHARACTERISTIC:
                    nus_c_evt.handles.nus_tx_handle = p_chars[i].characteristic.handle_value;
                    nus_c_evt.handles.nus_tx_cccd_handle = p_chars[i].cccd_handle;
        if (p_ble_nus_c->evt_handler != NULL)
            nus_c_evt.conn_handle = p_evt->conn_handle;
            nus_c_evt.evt_type    = BLE_NUS_C_EVT_DISCOVERY_COMPLETE;
            p_ble_nus_c->evt_handler(p_ble_nus_c, &nus_c_evt);
/**@brief     Function for handling Handle Value Notification received from the SoftDevice.
 * @details   This function uses the Handle Value Notification received from the SoftDevice
 *            and checks if it is a notification of the NUS TX characteristic from the peer.
 *            If it is, this function decodes the data and sends it to the application.
 * @param[in] p_ble_nus_c Pointer to the NUS Client structure.
 * @param[in] p_ble_evt   Pointer to the BLE event received.
static void on_hvx(ble_nus_c_t * p_ble_nus_c, ble_evt_t const * p_ble_evt)
    // HVX can only occur from client sending.
    if (   (p_ble_nus_c->handles.nus_tx_handle != BLE_GATT_HANDLE_INVALID)
        && (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_nus_c->handles.nus_tx_handle)
        && (p_ble_nus_c->evt_handler != NULL))
        ble_nus_c_evt_t ble_nus_c_evt;
        ble_nus_c_evt.evt_type = BLE_NUS_C_EVT_NUS_TX_EVT;
        ble_nus_c_evt.p_data   = (uint8_t *)p_ble_evt->evt.gattc_evt.params.hvx.data;
        ble_nus_c_evt.data_len = p_ble_evt->evt.gattc_evt.params.hvx.len;
        p_ble_nus_c->evt_handler(p_ble_nus_c, &ble_nus_c_evt);
        NRF_LOG_DEBUG("Client sending data.");
uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)
    uint32_t      err_code;
    ble_uuid_t    uart_uuid;
    ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;
    VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
    VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
    VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init->p_gatt_queue);
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
    VERIFY_SUCCESS(err_code);
    uart_uuid.type = p_ble_nus_c->uuid_type;
    uart_uuid.uuid = BLE_UUID_NUS_SERVICE;
    p_ble_nus_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
    p_ble_nus_c->evt_handler           = p_ble_nus_c_init->evt_handler;
    p_ble_nus_c->error_handler         = p_ble_nus_c_init->error_handler;
    p_ble_nus_c->handles.nus_tx_handle = BLE_GATT_HANDLE_INVALID;
    p_ble_nus_c->handles.nus_rx_handle = BLE_GATT_HANDLE_INVALID;
    p_ble_nus_c->p_gatt_queue          = p_ble_nus_c_init->p_gatt_queue;
    return ble_db_discovery_evt_register(&uart_uuid);
void ble_nus_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    ble_nus_c_t * p_ble_nus_c = (ble_nus_c_t *)p_context;
    if ((p_ble_nus_c == NULL) || (p_ble_evt == NULL))
        return;
    if ( (p_ble_nus_c->conn_handle == BLE_CONN_HANDLE_INVALID)
       ||(p_ble_nus_c->conn_handle != p_ble_evt->evt.gap_evt.conn_handle)
        return;
        case BLE_GATTC_EVT_HVX:
            on_hvx(p_ble_nus_c, p_ble_evt);
            if (p_ble_evt->evt.gap_evt.conn_handle == p_ble_nus_c->conn_handle
                    && p_ble_nus_c->evt_handler != NULL)
                nus_c_evt.evt_type = BLE_NUS_C_EVT_DISCONNECTED;
            // No implementation needed.
/**@brief Function for creating a message for writing to the CCCD. */
static uint32_t cccd_configure(ble_nus_c_t * p_ble_nus_c, bool notification_enable)
    nrf_ble_gq_req_t cccd_req;
    uint8_t          cccd[BLE_CCCD_VALUE_LEN];
    uint16_t         cccd_val = notification_enable ? BLE_GATT_HVX_NOTIFICATION : 0;
    memset(&cccd_req, 0, sizeof(nrf_ble_gq_req_t));
    cccd[0] = LSB_16(cccd_val);
    cccd[1] = MSB_16(cccd_val);
    cccd_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
    cccd_req.error_handler.cb            = gatt_error_handler;
    cccd_req.error_handler.p_ctx         = p_ble_nus_c;
    cccd_req.params.gattc_write.handle   = p_ble_nus_c->handles.nus_tx_cccd_handle;
    cccd_req.params.gattc_write.len      = BLE_CCCD_VALUE_LEN;
    cccd_req.params.gattc_write.offset   = 0;
    cccd_req.params.gattc_write.p_value  = cccd;
    cccd_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
    cccd_req.params.gattc_write.flags    = BLE_GATT_EXEC_WRITE_FLAG_PREPARED_WRITE;
    return nrf_ble_gq_item_add(p_ble_nus_c->p_gatt_queue, &cccd_req, p_ble_nus_c->conn_handle);
uint32_t ble_nus_c_tx_notif_enable(ble_nus_c_t * p_ble_nus_c)
       ||(p_ble_nus_c->handles.nus_tx_cccd_handle == BLE_GATT_HANDLE_INVALID)
    return cccd_configure(p_ble_nus_c, true);
uint32_t ble_nus_c_string_send(ble_nus_c_t * p_ble_nus_c, uint8_t * p_string, uint16_t length)
    nrf_ble_gq_req_t write_req;
    memset(&write_req, 0, sizeof(nrf_ble_gq_req_t));
    if (length > BLE_NUS_MAX_DATA_LEN)
        NRF_LOG_WARNING("Content too long.");
        return NRF_ERROR_INVALID_PARAM;
    if (p_ble_nus_c->conn_handle == BLE_CONN_HANDLE_INVALID)
        NRF_LOG_WARNING("Connection handle invalid.");
    write_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
    write_req.error_handler.cb            = gatt_error_handler;
    write_req.error_handler.p_ctx         = p_ble_nus_c;
    write_req.params.gattc_write.handle   = p_ble_nus_c->handles.nus_rx_handle;
    write_req.params.gattc_write.len      = length;
    write_req.params.gattc_write.offset   = 0;
    write_req.params.gattc_write.p_value  = p_string;
    write_req.params.gattc_write.write_op = (p_ble_nus_c->write_cmd)?(BLE_GATT_OP_WRITE_CMD):(BLE_GATT_OP_WRITE_REQ);
    write_req.params.gattc_write.flags    = BLE_GATT_EXEC_WRITE_FLAG_PREPARED_WRITE;
    return nrf_ble_gq_item_add(p_ble_nus_c->p_gatt_queue, &write_req, p_ble_nus_c->conn_handle);
uint32_t ble_nus_c_handles_assign(ble_nus_c_t               * p_ble_nus,
                                  uint16_t                    conn_handle,
                                  ble_nus_c_handles_t const * p_peer_handles)
    VERIFY_PARAM_NOT_NULL(p_ble_nus);
    p_ble_nus->conn_handle = conn_handle;
    if (p_peer_handles != NULL)
        p_ble_nus->handles.nus_tx_cccd_handle = p_peer_handles->nus_tx_cccd_handle;
        p_ble_nus->handles.nus_tx_handle      = p_peer_handles->nus_tx_handle;
        p_ble_nus->handles.nus_rx_handle      = p_peer_handles->nus_rx_handle;
    return nrf_ble_gq_conn_handle_register(p_ble_nus->p_gatt_queue, conn_handle);
#endif // NRF_MODULE_ENABLED(BLE_NUS_C)
