Cannot able to communicate with external target
I am trying to flash one external module which is actually a BLE having (NRF52832) and I am using NRF52832 Development board. By doing all the necessary connections and using the DC power supply and setting the current and voltage to 11mA and 3.7V respectively. While running I am getting this error
Connecting ‘J-Link’ using ‘USB’
Loaded /Applications/SEGGER Embedded Studio for ARM 7.22/bin/libjlinkarm.dylib
Firmware Version: J-Link OB-nRF5340-NordicSemi compiled Nov 7 2022 16:22:01
DLL Version: 7.88c
Hardware Version: V1.00
Target Voltage: 3.300
Device "NRF52832_XXAA" selected.
Current Speed: 2000 kHz
InitTarget() start
InitTarget() end - Took 102ms
Failed to attach to CPU. Trying connect under reset.
InitTarget() start
InitTarget() end - Took 106ms
Failed to connect to target.
Please help me. What steps do I need to follow now. I am getting stucked
    after adjusting the SWD speed to 125 kHz and running the code nrfjprog --recover -f nrf52 -c 125 I got this
    C:\Users\admin>nrfjprog --recover -f nrf52 -c 125
    ERROR: Unable to connect to a debugger.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    and after flashing the program
    Current Speed: 125 kHz
    InitTarget() start
    InitTarget() end - Took 136ms
    InitTarget() start
    and I am also attaching the log file. Please have a look
    C:\Users\admin>nrfjprog --recover -f nrf52 -c 125 --log
    ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    C:\Users\admin>
    please suggest.
    Kind regards
    Kushagra
    Can you attach the .log file?
    Do all your devices behave like this?
    Given that the debugger provides generic errors, it can indicate a hardware-wise connection problem between the debugger and the nRF.
    Håkon
  • I am kinda facing the same problem, what was the reason for your problem ?
    This thread is quite old. Could you create a separate ticket on your issue?
    And be sure to attach logs showing your problem.
    Håkon
