I have a nrf51-DK, SDK 9.0, S110, dual-bank bootloader that supports both serial and ble protocols, developed using GCC/Eclipse. I'm able to flash my app/bootloader/softdevice using JLink through Eclipse as well as update my app via OTA. Now I need to be able to update the app via serial reflash. I use nRF Toolbox to do the OTA. Is there a similar app capable of performing serial reflash of my app? I see the format of the data and the handshake back and forth described here - infocenter.nordicsemi.com/index.jsp. Is there a tool/script available that implements this, or do I need to write this myself?
UPDATE: It looks like nrfutil is the program I need to do a serial reflash of my app. However, I'm having issues getting it to work. Here is what I'm sending:
nrfutil.exe dfu serial --package C:\Firmware\strobe\build\obj_strobe\strobe.zip --port 11 --flowcontrol --baudrate 38400
And here is what I get back:
Upgrading target on 11 with DFU package C:\Firmware\strobe\build\obj_strobe\stro be.zip. Flow control is enabled. [------------------------------------] 0%
Failed to upgrade target. Error is: Serial port could not be opened on 11. Reaso n: could not open port u'11': WindowsError(2, 'The system cannot find the file s pecified.')
Possible causes:
- bootloader, SoftDevice or application on target does not match the requirement s in the DFU package.
- baud rate or flow control is not the same as in the target bootloader.
- target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
C:\Program Files (x86)\Nordic Semiconductor\nRFgo Studio>
I have first put by dev kit into serial bootloader mode upon reset - I have LED3 lit.
From Windows Device Manager, I can see that Com11 is the correct port:
The package file, strobe.zip, is the same file I use to program the device OTA, which works correctly. I generated it using the following: "c:\Program Files (x86)\Nordic Semiconductor\nRFgo Studio"nrfutil dfu genpkg strobe.zip --application strobe.hex --application-version 0xffff --dev-revision 0xffff --dev-type 0xffff --sd-req 0xfffe
Any ideas what I might be doing wrong? Thanks!
