Network not working when TWT is activated on nrf7002DK
I have an nrf7002DK
using sdk-nrf v2.4.1.
I compiled wifi shell sample
The used ap is netgear WAX214 AX1800.
After connecting to it, I check the wifi status:
> wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: MyWifi6
BSSID: **:**:**:**:**:**
Band: 5GHz
Channel: 44
Security: WPA3-SAE
MFP: Optional
RSSI: -38
Beacon Interval: 100
DTIM: 2
TWT: Supported
All communications are working correctly (ping from 7002DK, ping to 7002DK, tcp from 7002DK).
I activate twt:
>wifi twt setup 0 0 1 1 0 1 1 1 65000 524000
TWT operation TWT setup with dg: 1, flow_id: 1 requested
TWT response: TWT accept
TWT Dialog token: 1
TWT flow ID: 1
TWT negotiation type: TWT individual negotiation
TWT responder: true
TWT implicit: true
TWT announce: true
TWT trigger: true
TWT wake interval: 65024 us
TWT interval: 524000 us
>wifi ps
PS status: Power save enabled
PS mode: Legacy power save
PS listen_interval: 10
PS wake up mode: DTIM
PS timeout: -1 ms
TWT Dialog token: 1
TWT flow ID: 1
TWT responder: false
TWT implicit: true
TWT announce: true
TWT trigger: true
And then no communication are working:
>net ping 192.168.0.1
PING 192.168.0.1
Ping timeout
>net tcp connect 192.168.0.1 80
Connecting from 192.168.1.39:0 to 192.168.0.1:80
TCP connection failed (-116)
[00:08:47.829,925] <err> os: ***** USAGE FAULT *****
[00:08:47.829,956] <err> os:   Illegal use of the EPSR
[00:08:47.829,956] <err> os: r0/a1:  0x20000e18  r1/a2:  0x0008ea08  r2/a3:  0x20007e40
[00:08:47.829,956] <err> os: r3/a4:  0x0008ecf8 r12/ip:  0x20038c20 r14/lr:  0x0000c60f
[00:08:47.829,956] <err> os:  xpsr:  0x60000000
[00:08:47.829,986] <err> os: Faulting instruction address (r15/pc): 0x0008ecf8
[00:08:47.829,986] <err> os: >>> ZEPHYR FATAL ERROR 35: Unknown error on CPU 0
[00:08:47.830,017] <err> os: Current thread: 0x20002868 (tcp_work)
[00:08:47.887,664] <err> coredump: #CD:BEGIN#
[00:08:47.893,432] <err> coredump: #CD:5a4501000300050023000000
[00:08:47.900,726] <err> coredump: #CD:4102004400
[00:08:47.906,829] <err> coredump: #CD:180e002008ea0800407e0020f8ec0800208c03200fc60000f8ec080000000060
[00:08:47.917,633] <err> coredump: #CD:28d0002000000000000000000000000000000000000000000000000000000000
[00:08:47.928,405] <err> coredump: #CD:00000000
[00:08:47.934,326] <err> coredump: #CD:4d01006828002030290020
[00:08:47.941,467] <err> coredump: #CD:e0200020607e0020000000000080f00000000000000000000000000000000000
[00:08:47.952,270] <err> coredump: #CD:000000000000000000000000000000000000000000000000ffffffffffffffff
[00:08:47.963,073] <err> coredump: #CD:00000000000000000000000000000000f0cf002000000000c0280020c0280020
[00:08:47.973,876] <err> coredump: #CD:0001000009910500682800200000000000000000d03200207463705f776f726b
[00:08:47.984,649] <err> coredump: #CD:00000000000000000000000000000000000000000000000000000000a0cc0020
[00:08:47.995,452] <err> coredump: #CD:0004000000000000ec1300200000000000000000000000000000000000000000
[00:08:48.006,256] <err> coredump: #CD:0000000000000000
[00:08:48.012,878] <err> coredump: #CD:4d0100a0cc0020a0d00020
[00:08:48.020,019] <err> coredump: #CD:f0f0f0f0aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.030,822] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.041,595] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.052,398] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.063,201] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.074,005] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.084,808] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.095,581] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.106,384] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.117,187] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.127,990] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.138,793] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.149,597] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.160,400] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.171,203] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:08:48.182,006] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaab032002020310020
[00:08:48.192,779] <err> coredump: #CD:00000000d99305002031002001000000607e0020f19405006828002068280020
[00:08:48.203,582] <err> coredump: #CD:44100020d79605006828002017a208000000000000ed00e0407e002000000000
[00:08:48.214,385] <err> coredump: #CD:c1000000640c09000200000000000000ffffffff208c0320640c090044cf0020
[00:08:48.225,189] <err> coredump: #CD:02000000e0350020640c0900e1fc060044cf0020020000001c00000025fd0600
[00:08:48.235,992] <err> coredump: #CD:44cf0020020000001c00000080ef080003fd0600c43500200f4809008f0a0700
[00:08:48.246,795] <err> coredump: #CD:0200000002000000140c09000a0000001d05070000000000ffffffffb50a0700
[00:08:48.257,598] <err> coredump: #CD:af0a070015050700140c09005b050700becf00201c000000140c090047590000
[00:08:48.268,402] <err> coredump: #CD:becf0020c0cf00200d48090048d0002074000000000000008000016400000000
[00:08:48.279,174] <err> coredump: #CD:000000000000000000000000010000009294070119950700b032002020310020
[00:08:48.289,978] <err> coredump: #CD:00000000d99305002031002001000000607e0020f19405006828002068280020
[00:08:48.300,781] <err> coredump: #CD:68440020d79605006828002017a208000000000000ed00e0407e002000000000
[00:08:48.311,584] <err> coredump: #CD:208c032023970500e4c400000000006168440020c38d05006844002000000000
[00:08:48.322,357] <err> coredump: #CD:68440020878e0500180e002008ea0800407e0020f8ec0800208c03200fc60000
[00:08:48.333,160] <err> coredump: #CD:f8ec08000000006000000000197007008cffffff0000000064ae032001000000
[00:08:48.343,963] <err> coredump: #CD:3cae032095700700ccae0320682800200000000093910500ffffffffffffffff
[00:08:48.354,736] <err> coredump: #CD:0000000068280020099105000000000000000000f7bc060000000000aaaaaaaa
[00:08:48.365,539] <err> coredump: #CD:END#
[00:08:48.371,093] <err> fatal_error: Resetting system
The last valid stack trace is https://github.com/nrfconnect/sdk-zephyr/blob/28a3fca7da5cfb3b72f1a874b3b7fa62f713ab3d/subsys/net/ip/tcp.c#L503.
After some minutes of twt activated, the 7002DK disappear from connected device in the AP webui. If I desactivate twt, the 7002DK realise it is disconnected, and reconnect:
>wifi twt teardown_all
TWT operation TWT teardown all flows
Disconnected
[00:18:21.978,485] <inf> wpa_supp: wlan0: CTRL-EVENT-DISCONNECTED bssid=**:**:**:**:**:** reason=2 locally_generated=1
[00:18:22.004,547] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Connected
[00:18:27.160,644] <inf> wpa_supp: wlan0: SME: Trying to authenticate with **:**:**:**:**:** (SSID='MyWifi6' freq=5220 MHz)
[00:18:27.171,997] <inf> wifi_nrf: wifi_nrf_wpa_supp_authenticate:Authentication request sent successfully
[00:18:27.739,959] <inf> wpa_supp: wlan0: SME: Trying to authenticate with **:**:**:**:**:** (SSID='MyWifi6' freq=5220 MHz)
[00:18:27.747,985] <inf> wifi_nrf: wifi_nrf_wpa_supp_authenticate:Authentication request sent successfully
[00:18:27.754,455] <inf> wpa_supp: wlan0: Trying to associate with **:**:**:**:**:** (SSID='MyWifi6' freq=5220 MHz)
[00:18:27.760,681] <inf> wifi_nrf: wifi_nrf_wpa_supp_associate: Association request sent successfully
[00:18:27.773,681] <inf> wpa_supp: wlan0: Associated with **:**:**:**:**:**
[00:18:27.773,773] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:18:27.799,011] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with **:**:**:**:**:** [PTK=CCMP GTK=CCMP]
[00:18:27.799,133] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to **:**:**:**:**:** completed [id=0 id_str=]
[00:18:27.835,144] <inf> net_dhcpv4: Received: 192.168.1.39
Do you have an idea of what is happening? I have nothing to capture wifi communications.
