Option for better throughput with BLE multi-link/multi-role
Hello everyone,
I’m trying to concurrently transmit data from two separate BLE devices to a smartphone. After reading several posts and other resources, the following are two different configurations that I probably use. I have several questions regarding these configurations before going to implement:
  1. Each BLE peripheral device has 1 or 2 biosensors and I wanted to send it continuously, say 32 bytes with minimum sampling rate of 250 samples/second. For both configurations, are they able to send that amount of data with that data rate to smartphone’s app without any data loss?
  2. I saw an example of Configuration 1 demonstrated at Nordic youtube video and it has a sample code using phone app to turn on/off LED from the peripheral devices. However, I’m not sure if it has high throughput or not. Between the two configurations, which one is easier to implement?
  3. Looking at the config #2, seems it will be more on the phone app to be able to connect, and then collect data from two BLE peripheral devices. Any suggestions/ comments if it’s more doable and flexible to work?
