Trying to perform OTA to a nRF52840 device via nRF9160 LTE connection
Dear All,
What I need is to be able to perform a DFU on a nRF52840 device that has a UART connection to nRF9160 device that can download the bin file for the nRF52840 device.
I have seen that there are 3 main threads on the topic:
https://devzone.nordicsemi.com/f/nordic-q-a/90110/send-dfu-image-between-two-nrf5340
https://devzone.nordicsemi.com/f/nordic-q-a/79779/firmware-update-ota-of-nrf9160-by-ble-nrf52840-and-update-nrf52840-by-fota-of-nrf9160/330275
 RE: Perform NRF52840 OTA over the NRF9160 and UART
From what I gather from the posts above, there was a pull-request at some point that is now closed that was doing exactly what I am looking for.
I have tried to implement the changes described on this pull request and tried to compile initially a very basic project for the nRF52840.
At the very start of the build process, I am getting this error:
 Found assembler: C:/zephyr-sdk-0.15.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
usage: zcbor.py [-h] [--version] -c CDDL [--default-max-qty DEFAULT_MAX_QTY]
                [--no-prelude] [-v]
                {code,convert} ...
zcbor.py: error: the following arguments are required: -c/--cddl
CMake Error at C:/ncs/nrf/subsys/dfu/dfu_target/src/dfu_target_uart_cddl/CMakeLists.txt:19 (execute_process):
  execute_process failed command indexes:
    1: "Child return code: 2"
←[91mFATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-DWEST_PYTHON=C:\Python311\python.exe' '-BC:\Users\Desktop\nRF52\build' -GNinja -DBOARD=nrf52840dk_nrf52840 -DSIGNED=Signed '-SC:\Users\Desktop\nRF52'
←[0m
Any ideas what do I need to do in order to fix this and move on with allowing the application to compile?
I am using NCS v2.1.0 running on Windows
  • Dear Sigurd,
    Thanks a lot for your response and assistance.
    I figured out the issue I had with editing your sample for the serial recovery dfu.
    In order to have the MCUboot use the same pinout as the overlay for the main application, I had to copy this overlay inside the child_image/mcuboot/boards directory and then that part worked like a charm.
    What I did next is to create a .bin file and use it to DFU the nRF52840. For now I am using the default MCUboot key, to test with.
    The next step towards my goal is to download the .bin file. Using the sample found in ncs\nrf\samples\nrf9160\download it becomes straight forward to download my file.
    In the sample there is the download callback that I have simplified to make it look like this:
    static int callback(const struct download_client_evt* event)
        static size_t downloaded;
        static size_t file_size;
        uint32_t speed;
        int64_t ms_elapsed;
        if (downloaded == 0) {
            download_client_file_size_get(&downloader, &file_size);
            downloaded += STARTING_OFFSET;
        switch (event->id) {
            case DOWNLOAD_CLIENT_EVT_FRAGMENT:
                downloaded += event->fragment.len;
                smp_frag_upload(event->fragment.buf, event->fragment.len);
                return 0;
            case DOWNLOAD_CLIENT_EVT_DONE:
                ms_elapsed = k_uptime_delta(&ref_time);
                speed = ((float)file_size / ms_elapsed) * MSEC_PER_SEC;
                printk("\nDownload completed in %lld ms @ %d bytes per sec, total %d bytes\n", ms_elapsed, speed, downloaded);
                lte_lc_power_off();
                printk("Bye\n");
                return 0;
            case DOWNLOAD_CLIENT_EVT_ERROR:
                if ((socket_retries_left)) {
                    printk("Download socket error: %d. %d retries left...\r\n", event->error, socket_retries_left);
                    socket_retries_left--;
                    /* Fall through and return 0 below to tell
                     * download_client to retry
                    return 0;
                else {
                    printk("Error %d during download\n", event->error);
                    lte_lc_power_off();
                    /* Stop download */}
                    return -1;
        return 0;
    In there, as you can see there is the smp_frag_upload that I am trying to implement in order to send the data received directly via uart to the nRF52 device:
    static void smp_frag_upload(void* buf, size_t len)
        struct mgmt_hdr image_list_header;
        struct net_buf* nb;
        uint8_t data[2048 + 1]; // One more byte, to store '/0'
        memcpy(data, buf, MIN((sizeof(data) - 1), len));
        data[MIN((sizeof(data) - 1), len) + 1] = '\0';
        static int offset = 0x0000C000; // Start of slot0 partition of the nRF52840
        nb = smp_packet_alloc();
        zcbor_state_t zs[CBOR_ENCODER_STATE_NUM];
        size_t tailroom = net_buf_tailroom(nb);
        printk("NUM of bytes: %u\r\n", tailroom);
        zcbor_new_encode_state(zs, ARRAY_SIZE(zs), nb->data + sizeof(struct mgmt_hdr), tailroom, 0);
        zs->constant_state->stop_on_error = true;
        zcbor_map_start_encode(zs, 20);
        zcbor_tstr_put_lit(zs, "image");
        zcbor_int64_put(zs, 0);
        zcbor_tstr_put_lit(zs, "data");
        zcbor_bstr_put_lit(zs, data);
        zcbor_tstr_put_lit(zs, "len");
        zcbor_uint64_put(zs, (uint64_t)len);
        zcbor_tstr_put_lit(zs, "off");
        zcbor_uint64_put(zs, offset);
        zcbor_tstr_put_lit(zs, "sha");
        zcbor_bstr_put_lit(zs, "12345");
        zcbor_tstr_put_lit(zs, "upgrade");
        zcbor_bool_put(zs, false);
        zcbor_map_end_encode(zs, 20);
        if (!zcbor_check_error(zs)) {
            printk("Failed to encode SMP test packet, err: %d\n", zcbor_pop_error(zs));
            goto end;
        offset += len;
        image_list_header.nh_op = MGMT_OP_WRITE;
        image_list_header.nh_flags = 0;
        image_list_header.nh_len = zs->payload_mut - nb->data - MGMT_HDR_SIZE;
        image_list_header.nh_group = MGMT_GROUP_ID_IMAGE;
        image_list_header.nh_seq = 0;
        image_list_header.nh_id = IMG_MGMT_ID_UPLOAD;
        mgmt_hton_hdr(&image_list_header);
        nb->len = zs->payload_mut - nb->data;
        memcpy(nb->data, &image_list_header, sizeof(image_list_header));
        int err = uart_mcumgr_send(nb->data, nb->len);
        if (err) {
            printk("upload2: uart_mcumgr_send failed with %d\n", err);
            goto end;
    end:
        net_buf_unref(nb);
    In my case I am receiving the data in chunks of 2048 bytes, so, following the idea in your sample I am declaring a buffer at the size of the chunk plus 1 that is set to '0'.
    In the board files, I see that the slot0 particion starts at 0xC000 for the nRF52840, so I am sending that as the offset of the first chunk and for each subsequent chunk I am incrementing the value with the number of bytes already received.
    In my prj.conf I have set this configuration to make sure that the buffer is sufficiently large to contain the data of the fragment.
    CONFIG_MCUMGR_BUF_SIZE=2200
    In my custom board configuration I have set this:
    chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart1;
    In the dtsi this is what I have:
    &pinctrl {
        uart1_default: uart1_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 1)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, 0)>;
    			bias-pull-up;
    	uart1_sleep: uart1_sleep {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 1)>,
    			low-power-enable;
    So bringing this sample together, I do see the data downloading properly, but the application run by the nRF52840 does not change.
    Is there any step that I am missing here?
    When you build with MCUboot enabled, these binaries are automatically generated for you and lives inside build/zephyr.
    The one for this is called build/zephyr/app_update.bin. See MCUboot output build files for more info.
    Were you able to perform Serial Recovery DFU from a computer to test this?
    Makes sense to me.
    Steps seem logical to me.
    Do you get any errors from the mcumgr code?
    Is it possible for you to probe the UART lines using either a analyzator or oscilloscope to verify if data is being transferred?
    If the file was being transferred but wrong, we would not see the old app still on the nRF52840, instead it would fail at boot. So we can assume that something went wrong so that the file was never transferred.
    I have finally manage to update my nRF52 device using your code as a starting point, so I would like to thank you for your assistance.
    I have one more question regarding the process.
    In the case of the having the DFU running through the application and not in the bootloader of the nRF52, it seems that the mcumgr uart is occupied and it is not capable of receiving UART data apart from the DFU data. Is that correct? Is there anyway around it, like registering the uart for MCUMGR when needed and un-registering it later on?
    On the serial recovery mode, what I am observing is that if I send a new image signed with the wrong key, the image gets applied on the nRF52, but it will not run leaving the device in the bootloader. Is there a way to check that the image is valid before applying it?
    Again, thanks a lot for your assistance.
  • Hi Ioannis,
    Sigurd is on vacation and I will take over the ticket.
    I haven't tested but I believe it's only possible to share UART between MCUMGR with Shell/Console.
    You can have a look at this ticket: Sharing UART between DFU & APP
    If you look at the \zephyr\samples\subsys\mgmt\mcumgr\smp_svr sample you can find overlay-serial-console.conf you can find the configuration to share between MCUMGR and CONSOLE.
    Serial recovery mode use only one bank to receive the new image, this mean it will overwrite the old image to receive new image. So it will result in what you experience, the device is "brick" until it get a correct image.
