Decoupling capacitor values for nRF52
I have read your guide for Power Supply Capacitor Selection: https://infocenter.nordicsemi.com/pdf/nwp_030.pdf
and the product datasheet v1.7 for the nRF52840 which were both quite helpful. I see that the recommended capacitor value for VDD and VDDH are 4.7uF and the product datasheet recommends a 100nF for DEC1.
I am a bit confused to see a "maximum" value listed for a decoupling capacitor.
1. What constraint drives the maximum value of the decoupling capacitors for the nRF52?
2. As long as the capacitors exceed the minimum values, deliver <50 mV AC rms at 1 kHz, sufficiently block DC, and provide all of those over the operating temperature range, is there any reason why we could not use a 10uF capacitor for each VDDH and VDD and a 1uF capacitor for DEC1?  Is there some other reason why these capacitor values would not work properly if used?
Thank you,
James
  • Hi James,
    The "safe range" or the "nominal values for operation" are what is recommended by us, i.e. the 100nF (with a tolerance of +/-10%). We always recommend to NOT CHANGE the cap value, but you are free to test it just that we will not guarantee the performance.
    Also, we cannot share further specific details regarding the design, other than what is available in the P.S and documentation.
    -Priyanka
