#include <zephyr/kernel.h> #include <zephyr/drivers/spi.h> #include <stdio.h> #include <string.h> #include <nrfx.h> #include <nrfx_spim.h> #include <nrfx_gpiote.h> #include <nrfx_dppi.h> /* Define your SPI frequency and timing parameters */ #define SPI_FREQUENCY 26000000 // 26 MHz #define COMMAND_RATE 10000 // Desired command rate: 10 kHz /* Define your SPI command and data variables */ #define COMMAND_SIZE 32 // Command size: 32 bits #define CONVERSION_COMMAND 0x12345678 // Example conversion command #define SETUP_COMMANDS {0xe0ff0000, 0x80200000, 0x80210000, 0x8026ffff, 0x6a000000, 0x800000c7, 0x8001051a, 0x80020000,0x80030080, 0x80040016, 0x80050017, 0x800600a8, 0x8007000a, 0x8008ffff, 0xa00a0000, 0xa00cffff, 0x802200e2, 0x802300aa, 0x80240080, 0x80254f00, 0xa02a0000, 0xa02c0000,0xa02e0000,0xa0300000,0x8020aaaa, 0x802100ff, 0xe0ff0000} void main(void) { const struct device *spi_dev; //const struct device *cs_dev; int rc; spi_dev = DEVICE_DT_GET(DT_NODELABEL(spi4)); //cs_dev = device_get_binding(DT_GPIO_LABEL(DT_ALIAS(cs_gpios), gpios)); // Configure SPI device settings struct spi_config spi_cfg = { .frequency = SPI_FREQUENCY, .operation = SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB | SPI_WORD_SET(32), .slave = 0, //.cs = DT_GPIO_PIN(DT_ALIAS(cs_gpios), gpios), }; // Set the active level of the chip select line //gpio_pin_configure(cs_dev, CS_PIN, GPIO_OUTPUT_ACTIVE | CS_ACTIVE_LEVEL); if (!device_is_ready(spi_dev)) { printk("%s: device not ready.\n", spi_dev->name); return; } printk("\n%s SPI command generation\n", spi_dev->name); printk("=============================\n"); rc = spi_transceive(spi_dev, &spi_cfg, NULL, NULL); // Calculate the delay needed between commands to achieve the desired rate k_timeout_t command_delay = K_MSEC(1000 / COMMAND_RATE); while (1) { // Generate SPI command and send it uint8_t tx_buf[4] = { (CONVERSION_COMMAND >> 24) & 0xFF, (CONVERSION_COMMAND >> 16) & 0xFF, (CONVERSION_COMMAND >> 8) & 0xFF, CONVERSION_COMMAND & 0xFF }; uint8_t rx_buf[4] = { 0 }; spi_cfg.frequency = SPI_FREQUENCY; spi_cfg.operation = SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB | SPI_WORD_SET(32); spi_cfg.slave = 0; struct spi_buf tx_bufs[] = { { .buf = tx_buf, .len = sizeof(tx_buf) } }; struct spi_buf rx_bufs[] = { { .buf = rx_buf, .len = sizeof(rx_buf) } }; struct spi_buf_set txrx_bufs = { .buffers = { tx_bufs, rx_bufs }, .count = ARRAY_SIZE(tx_bufs) + ARRAY_SIZE(rx_bufs) }; //rc = spi_transceive(spi_dev, &spi_cfg, &txrx_bufs, &txrx_bufs); //rc = spi_transceive(spi_dev, &spi_cfg, tx_bufs, rx_bufs); rc = spi_write(spi_dev, &spi_cfg, tx_bufs); if (rc != 0) { printk("SPI command transmission failed! Error: %d\n", rc); } // Wait for the desired delay before sending the next command k_sleep(command_delay); } }
I am able to build and flash to my board but the issue comes during debugging. I get a code of -22 after calling spi_transceive and I notice that my spi_dev is optimized out. I am a beginner when it comes to Nordic boards and this software is very new to me as well. I don't know how much I need to do in terms of SPI setup using zephyr as from what I can tell everything else is fine except for these things. Let me know if there are any resources that could help as well.
