Issue with multiple HTTPS(TLS) sockets to the same server
Board: nrf7002
nrfConnect SDK 2.4.0 or 2.4.99
IDE: VS code
I’m working on implementing SignalR communication protocol, It uses SSE(Server-Sent Events) communication, so once connected, one socket needs to remain open to receive new data, and we also need to send other messages over an additional socket.
I’m getting a fault when using a second socket, I set it up in the same way as I made the first one. I am modifying the solution found https://devzone.nordicsemi.com/f/nordic-q-a/100826/nrf7002dk-and-tls-sockets--7100-error/433368 to do this. It always faults weather the first socket gets used or not.
Here is the code to create the sockets (changes nslookup to google from my domain):
int sock;
int sock2;
int err;
struct sockaddr_in *sa;
struct addrinfo *rp;
struct sockaddr_in *sa2;
struct addrinfo *rp2;
nslookup("google.com", &rp);
print_addrinfo_results(&rp);
nslookup("google.com", &rp2);
print_addrinfo_results(&rp2);
printk("Connecting to HTTP Server:\n");
// Load in the TLS cert for HTTPS
tls_credential_add(CA_CERTIFICATE_TAG, TLS_CREDENTIAL_CA_CERTIFICATE,
ca_certificate, sizeof(ca_certificate));
// Create Socket
sock = socket(rp->ai_family, rp->ai_socktype, IPPROTO_TLS_1_2); // IPPROTO_TCP //IPPROTO_TLS_1_2
if (sock < 0)
printk("Error creating socket\n");
return (-1);
// TLS settings
sec_tag_t sec_tag_opt[] = {
CA_CERTIFICATE_TAG,
err = setsockopt(sock, SOL_TLS, TLS_SEC_TAG_LIST,
sec_tag_opt, sizeof(sec_tag_opt));
if (err < 0)
LOG_ERR("Failed to set TLS security TAG list. Err: %d", errno);
(void)close(sock);
return -errno;
err = setsockopt(sock, SOL_TLS, TLS_HOSTNAME,
HTTP_HOST, sizeof(HTTP_HOST));
if (err < 0)
LOG_ERR("Failed to set TLS_HOSTNAME option. Err: %d", errno);
(void)close(sock);
return -errno;
// Iterate through until we get a successful connection
for (; rp != NULL; rp = rp->ai_next)
if (rp->ai_addr->sa_family == AF_INET)
// IPv4 Address
sa = (struct sockaddr_in *)rp->ai_addr;
sa->sin_port = htons(443);// this should be 443 (HTTPS port number)
connect(sock, (struct sockaddr *)sa, sizeof(struct sockaddr_in));
if (sock > 0)
// Create Socket 2
sock2 = socket(rp2->ai_family, rp2->ai_socktype, IPPROTO_TLS_1_2); // IPPROTO_TCP //IPPROTO_TLS_1_2
if (sock2 < 0)
return (-1);
sec_tag_t sec_tag_opt2[] = {
CA_CERTIFICATE_TAG,
err = setsockopt(sock2, SOL_TLS, TLS_SEC_TAG_LIST,
sec_tag_opt2, sizeof(sec_tag_opt2));
if (err < 0)
(void)close(sock2);
return -errno;
err = setsockopt(sock2, SOL_TLS, TLS_HOSTNAME,
if (err < 0)
(void)close(sock2);
return -errno;
for (; rp2 != NULL; rp2 = rp2->ai_next)
if (rp2->ai_addr->sa_family == AF_INET)
// IPv4 Address
sa2 = (struct sockaddr_in *)rp2->ai_addr;
sa2->sin_port = htons(443);// this should be 443 (HTTPS port number)
connect(sock2, (struct sockaddr *)sa2, sizeof(struct sockaddr_in));
if (sock2 > 0)
Here is the error log:
<err> os: ***** MPU FAULT *****
[00:00:35.620,819] <err> os: Data Access Violation
[00:00:35.620,819] <err> os: MMFAR Address: 0x0
[00:00:35.620,819] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000000 r2/a3: 0x00000000
[00:00:35.620,849] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000413 r14/lr: 0x00004140
[00:00:35.620,849] <err> os: xpsr: 0x29000000
[00:00:35.620,880] <err> os: Faulting instruction address (r15/pc): 0x0004e620
[00:00:35.620,910] <err> os: >>> ZEPHYR FATAL ERROR 19: Unknown error on CPU 0
[00:00:35.620,941] <err> os: Current thread: 0x200049c8 (main)
[00:00:37.542,816] <err> fatal_error: Resetting system
Thanks for your help
  • SNI is enabled, Sorry I forgot to point a few things to www.google.com from azure
    Here is a log of using sock2, crashing trying to go to www.google.com
    When using just sock, It does not crash
    --- 124 messages dropped ---
    [00:03:21.319,244] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0030: cc a9 cc aa c0 2c c0 30 00 9f c0 ad c0 9f c0 24 .....,.0.......$
    --- 4 messages dropped ---
    [00:03:21.319,488] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0040: c0 28 00 6b c0 0a c0 14 00 39 c0 af c0 a3 c0 2b .(.k.....9.....+
    [00:03:21.319,732] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0050: c0 2f 00 9e c0 ac c0 9e c0 23 c0 27 00 67 c0 09 ./.......#.'.g..
    [00:03:21.319,976] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0060: c0 13 00 33 c0 ae c0 a2 00 9d c0 9d 00 3d 00 35 ...3.........=.5
    --- 64 messages dropped ---
    [00:03:21.321,258] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 00b0: 6d 00 0a 00 0c 00 0a 00 1d 00 17 00 18 00 19 00 m...............
    [00:03:21.321,533] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 00c0: 1a 00 0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 ................
    [00:03:21.321,777] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 00d0: 03 04 01 00 0b 00 02 01 00 00 17 00 00 00 23 00 ..............#.
    --- 518 messages dropped ---
    [00:03:21.417,633] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1739: 0x20001ca8: <= parse server hello
    [00:03:21.417,724] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2177: 0x20001ca8: => flush output
    [00:03:21.417,785] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2188: 0x20001ca8: <= flush output
    [00:03:21.653,350] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: dumping 'output record sent to network' (37 bytes)
    [00:03:21.653,594] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0000: 16 03 03 00 20 da e5 e2 c1 eb 4b 98 79 66 83 19 .... .....K.yf..
    --- 116 messages dropped ---
    [00:03:21.653,839] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0010: 7f b8 51 a6 98 14 28 fc 04 b6 59 4d 39 b5 ad 5e ..Q...(...YM9..^
    [00:03:21.654,052] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2886: 0x20001ca8: 0020: 23 12 db a5 f1 #....
    [00:03:21.654,113] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2177: 0x20001ca8: => flush output
    [00:03:21.654,205] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2194: 0x20001ca8: message length: 37, out_left: 37
    [00:03:21.769,409] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1800: 0x20001ca8: dumping 'raw buffer after decryption' (16 bytes)
    [00:03:21.769,653] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1800: 0x20001ca8: 0000: 14 00 00 0c 42 ad cf f6 37 b1 57 89 c5 87 8d c3 ....B...7.W.....
    [00:03:21.769,744] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1928: 0x20001ca8: <= decrypt buf
    [00:03:21.769,836] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3888: 0x20001ca8: dumping 'input payload after decrypt' (16 bytes)
    [00:03:21.770,080] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3888: 0x20001ca8: 0000: 14 00 00 0c 42 ad cf f6 37 b1 57 89 c5 87 8d c3 ....B...7.W.....
    [00:03:21.770,202] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3088: 0x20001ca8: handshake message: msglen = 16, type = 20, hslen = 16
    [00:03:21.770,263] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4076: 0x20001ca8: <= read record
    [00:03:21.770,355] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7890: 0x20001ca8: <= parse finished
    [00:03:21.770,416] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2177: 0x20001ca8: => flush output
    [00:03:21.770,507] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2188: 0x20001ca8: <= flush output
    [00:03:21.770,599] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3709: 0x20001ca8: client state: MBEDTLS_SSL_FLUSH_BUFFERS
    [00:03:21.770,660] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3756: 0x20001ca8: handshake: done
    [00:03:21.770,751] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2177: 0x20001ca8: => flush output
    [00:03:21.770,812] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2188: 0x20001ca8: <= flush output
    [00:03:21.770,904] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3709: 0x20001ca8: client state: MBEDTLS_SSL_HANDSHAKE_WRAPUP
    [00:03:21.770,996] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7642: 0x20001ca8: => handshake wrapup
    [00:03:21.771,057] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7615: 0x20001ca8: => handshake wrapup: final free
    [00:03:21.771,484] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7635: 0x20001ca8: <= handshake wrapup: final free
    [00:03:21.771,575] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7700: 0x20001ca8: <= handshake wrapup
    [00:03:21.771,636] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3801: 0x20001ca8: <= handshake
    [00:03:21.771,697] <dbg> net_sock_tls: tls_alloc: (main): Allocated TLS context, 0x20002110
    [00:03:21.771,942] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x20006340, fd=10
    [00:03:25.327,117] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:25.941,528] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:30.550,201] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:30.857,391] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:31.370,574] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:31.373,840] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:31.386,199] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:31.416,717] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:31.417,083] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x200062a0, pkt=(nil), st=0, user_data=(nil)
    [00:03:31.417,114] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Marked socket 0x200062a0 as peer-closed
    [00:03:31.475,067] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:31.676,147] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:32.290,405] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:33.417,022] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:37.205,749] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:37.410,675] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:39.049,011] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:39.969,848] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:40.075,653] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:40.080,627] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:40.380,706] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    Trying sock2: 9
    [00:03:44.066,284] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578bc, st=0, user_data=(nil)
    [00:03:46.114,654] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x20006160, pkt=0x200578fc, st=0, user_data=(nil)
    [00:03:46.772,796] <err> os: ***** MPU FAULT *****
    [00:03:46.772,827] <err> os: Data Access Violation
    [00:03:46.772,827] <err> os: MMFAR Address: 0x0
    [00:03:46.772,857] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000000 r2/a3: 0x00000000
    [00:03:46.772,857] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000413 r14/lr: 0x00004140
    [00:03:46.772,857] <err> os: xpsr: 0x29000000
    [00:03:46.772,888] <err> os: Faulting instruction address (r15/pc): 0x0004ddf8
    [00:03:46.772,918] <err> os: >>> ZEPHYR FATAL ERROR 19: Unknown error on CPU 0
    [00:03:46.772,949] <err> os: Current thread: 0x20004900 (main)
    [00:03:46.847,869] <err> coredump: #CD:BEGIN#
    [00:03:46.855,804] <err> coredump: #CD:5a4501000300050013000000
    [00:03:46.865,264] <err> coredump: #CD:4102004400
    [00:03:46.873,535] <err> coredump: #CD:000000000000000000000000000000001304000040410000f8dd040000000029
    [00:03:46.886,535] <err> coredump: #CD:9836022000000000000000000000000000000000000000000000000000000000
    [00:03:46.899,475] <err> coredump: #CD:00000000
    [00:03:46.907,562] <err> coredump: #CD:4d010000490020c8490020
    [00:03:46.916,870] <err> coredump: #CD:383a002088810120000000000180000000000000000000000000000000000000
    [00:03:46.929,870] <err> coredump: #CD:03040a0000000000000000000000000000800200e76271000000000068810120
    [00:03:46.942,840] <err> coredump: #CD:0000000000000000ffffffffffffffff50370220000000005849002058490020
    [00:03:46.955,841] <err> coredump: #CD:00010000bdb00400000000000000000000000000000000006d61696e00000000
    [00:03:46.968,811] <err> coredump: #CD:00000000000000000000000000000000000000000000000002000000e0270220
    [00:03:46.981,781] <err> coredump: #CD:0010000000000000fc0d00200000000000000000000000000000000000000000
    [00:03:46.994,750] <err> coredump: #CD:00000000f5ffffff
    [00:03:47.003,540] <err> coredump: #CD:4d0100e0270220e0370220
    [00:03:47.012,847] <err> coredump: #CD:f0f0f0f0aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.025,817] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.038,787] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.051,788] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.064,758] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.077,728] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.090,698] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.103,668] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.116,668] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.129,638] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.142,608] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.155,609] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.168,579] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.181,549] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.194,549] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.207,519] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.220,520] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.233,489] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.246,490] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.259,460] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.272,430] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.285,430] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.298,400] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.311,401] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.324,371] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.337,371] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.350,341] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.363,342] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.376,312] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.389,312] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.402,282] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.415,252] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.428,253] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.441,223] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.454,193] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.467,193] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.480,163] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.493,133] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.506,134] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.519,104] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.532,104] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.545,074] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [00:03:47.558,044] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa102f022024000000
    [00:03:47.571,014] <err> coredump: #CD:240000009df90400aaaaaaaaaaaaaaaaaaaaaaaa06000000c831022002000000
    [00:03:47.583,984] <err> coredump: #CD:fcffffff942f02200200000000000000040000006f070500aaaaaaaaaaaaaaaa
    [00:03:47.596,984] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa000000003c2e022004000000aaaaaaaa
    [00:03:47.609,954] <err> coredump: #CD:30000020102f0220866d0c00000000001000000000000000902f022049000000
    [00:03:47.622,924] <err> coredump: #CD:490000009df90400230000009df90400000000004b0000006832022002000000
    [00:03:47.635,894] <err> coredump: #CD:b82f022049000000490000009df90400490000006f070500040000004b000000
    [00:03:47.648,895] <err> coredump: #CD:9032022002000000e02f02202d0000002d0000009df90400490000006f070500
    [00:03:47.661,865] <err> coredump: #CD:300000202f0000009c32022002000000d3ffffff643002200200000000000000
    [00:03:47.674,835] <err> coredump: #CD:2d0000006f07050030000020b82f0220866d0c00000000005500000000000000
    [00:03:47.687,805] <err> coredump: #CD:000000000c2f02202d0000000000000030000020e02f0220866d0c0000000000
    [00:03:47.700,775] <err> coredump: #CD:39000000000000005c3002207300000068300220450000007030022049000000
    [00:03:47.713,745] <err> coredump: #CD:490000009df904004500000047000000403302204b0000004833022002000000
    [00:03:47.726,715] <err> coredump: #CD:b7fffffff43002200200000000000000490000006f0705004c33022011000000
    [00:03:47.739,685] <err> coredump: #CD:5433022002000000f1ffffff1c31022002000000000000000f0000006f070500
    [00:03:47.752,685] <err> coredump: #CD:3000002070300220866d0c0000000000550000000000000000000000c42f0220
    [00:03:47.765,655] <err> coredump: #CD:0f000000000000003000002098300220866d0c00000000001b00000000000000
    [00:03:47.778,625] <err> coredump: #CD:1431022073000000000000000000000000000000000000000000000000000000
    [00:03:47.791,595] <err> coredump: #CD:0100000058fc0a004031022049000000490000009df904000000000040000000
    [00:03:47.804,565] <err> coredump: #CD:f43002204b0000001834022002000000b7ffffffc43102200200000000000000
    [00:03:47.817,565] <err> coredump: #CD:490000006f0705001c3102205c3002207d1008006df507009031022036000000
    [00:03:47.830,535] <err> coredump: #CD:360000009df90400490000000000000030000020380000004c34022002000000
    [00:03:47.843,505] <err> coredump: #CD:caffffff143202200200000000000000360000006f0705000000000000000000
    [00:03:47.856,475] <err> coredump: #CD:0000000000000000e031022020000000200000009df90400f031022014000000
    [00:03:47.869,476] <err> coredump: #CD:140000009df904009c34022002000000e0ffffff16000000ac34022002000000
    [00:03:47.882,446] <err> coredump: #CD:ecffffff743202200200000000000000140000006f070500f0ffffff2d000000
    [00:03:47.895,416] <err> coredump: #CD:000000000c310220200000000f000000e434022002000000f3ffffffac320220
    [00:03:47.908,416] <err> coredump: #CD:02000000000000000d0000006f07050020000000000000006c32022073000000
    [00:03:47.921,386] <err> coredump: #CD:000000000000000000000000543102200d000000000000003000002028320220
    [00:03:47.934,356] <err> coredump: #CD:866d0c00000000001900000000000000a4320220730000000000000000000000
    [00:03:47.947,357] <err> coredump: #CD:000000000000000000000000000000000100000058fc0a00b4690c0000000000
    [00:03:47.960,327] <err> coredump: #CD:0000000000000000000000006df50700743202203a0000007d100800735d0000
    [00:03:47.973,297] <err> coredump: #CD:02000000000000001800000030780000b43102206ca30a00ac320220ec310220
    [00:03:47.986,267] <err> coredump: #CD:7d1008006df50700ac320220330000007d100800735d00000200000000000000
    [00:03:47.999,237] <err> coredump: #CD:180000001c000000ec3102206ca30a007d100800000000006032022001000000
    [00:03:48.012,207] <err> coredump: #CD:840c00200500000006000002840c002000000000000000000100000005000000
    [00:03:48.025,177] <err> coredump: #CD:0000000000000000840c002006010000000000001e000000840c00208f080800
    [00:03:48.038,146] <err> coredump: #CD:ff010000840c0020b8190020770c0800b8190020b8190020b8190020650f0800
    [00:03:48.051,116] <err> coredump: #CD:db0e08002172000080660000cf1008001c000000f00c00200000000071750000
    [00:03:48.064,086] <err> coredump: #CD:0a0000001432022004000000ac320220ffffffff1a00ffffffffffff00000000
    [00:03:48.077,056] <err> coredump: #CD:0000000000000000c532022080320220ac320220d90e00008032022084910c00
    [00:03:48.090,026] <err> coredump: #CD:ffffffffffffffffffffffff0dec000071e900000300000084910c00141e0000
    [00:03:48.102,996] <err> coredump: #CD:060000026ca30a0084910c00d90e000018000000ac3202200002030561383a20
    [00:03:48.115,966] <err> coredump: #CD:000203050600000271e900000200000084910c00d90e0000ac32022015a10500
    [00:03:48.128,936] <err> coredump: #CD:ac32022061383a20636c6965307832303030316361383a203c3d2068616e6473
    [00:03:48.141,906] <err> coredump: #CD:68616b650a00ffffffffffffffffffff9c330220771805001300000000000000
    [00:03:48.154,876] <err> coredump: #CD:cc3602208c330220000000000000000001000000a43302200000000000000000
    [00:03:48.167,846] <err> coredump: #CD:3000002068340220f4950c00000000000c000000000000000437022000000000
    [00:03:48.180,847] <err> coredump: #CD:00000000000000000100000058fc0a0000000000000000000100000058fc0a00
    [00:03:48.193,817] <err> coredump: #CD:0000000000000000000000000000000000000000dc9a0c006433022000000000
    [00:03:48.206,787] <err> coredump: #CD:000000002c9b0c001300000035ea04007c330220000000000000000064ac0c00
    [00:03:48.219,757] <err> coredump: #CD:8c3302200000000000000000d0950c009c3302200000000000000000f4950c00
    [00:03:48.232,727] <err> coredump: #CD:0c000000000031360000000030000020100c000088820c0003000000ffffffff
    [00:03:48.245,697] <err> coredump: #CD:ffffffffffffffffffffffff896405008134022000000000ca0100000802ffff
    [00:03:48.258,697] <err> coredump: #CD:4c34022030000020ec0f000088820c0002000000ffffffffffffffff30000020
    [00:03:48.271,667] <err> coredump: #CD:d31d000084910c000300000030000020141e000084910c0003000000ffffffff
    [00:03:48.284,667] <err> coredump: #CD:ffffffffffffffffffffffff89640500bf340220ff010000ec0100000802ffff
    [00:03:48.297,637] <err> coredump: #CD:ac34022030000020d90e000084910c0002000000ffffffffffffffffffffffff
    [00:03:48.310,638] <err> coredump: #CD:ffffffff89640500f0340220ff010000f30100000802ffffe4340220ff010000
    [00:03:48.323,608] <err> coredump: #CD:84910c0003000000a81c0020141e000084910c0003000000ffffffff85a10500
    [00:03:48.336,578] <err> coredump: #CD:ac34022068616b65207772613c3d2068616e647368616b65207772617075700a
    [00:03:48.349,548] <err> coredump: #CD:d80e0020000000003c0c0020cbb80400000f00200000000040350220cbb80400
    [00:03:48.362,518] <err> coredump: #CD:d80e0020000000003c0c0020cbb80400000f00200000000060350220cbb80400
    [00:03:48.375,488] <err> coredump: #CD:cc84012000000000603502209be700007de7000085aa07000050845075ba0700
    [00:03:48.388,488] <err> coredump: #CD:8035022000000000d80e0020000000003c0c0020cc8401201000000068350220
    [00:03:48.401,458] <err> coredump: #CD:a03502200000000048850120100c002004000000d7ef07001000000068350220
    [00:03:48.414,428] <err> coredump: #CD:ac84012000ba0700ac8401206bb460d3956e385583ef07006bb460d305e10700
    [00:03:48.427,398] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000000000000
    [00:03:48.440,368] <err> coredump: #CD:705e00200000000070360220cbb80400ac84012000000000600e002000000000
    [00:03:48.453,369] <err> coredump: #CD:06000000cbb804000000000000000000060000005f760100600e002000000000
    [00:03:48.466,339] <err> coredump: #CD:40970520cbb8040000000000dc36022040970520a376010040630020a5780100
    [00:03:48.479,309] <err> coredump: #CD:bb010000688f000000800100040000004c360220000000006c360220dc360220
    [00:03:48.492,309] <err> coredump: #CD:8f6800000000000000800100c1ac070000000000736808000000000004000000
    [00:03:48.505,279] <err> coredump: #CD:0400000005a2080044970520040000003460002040630020bc82052040630020
    [00:03:48.518,249] <err> coredump: #CD:bc82052001bb000040970520dc3602208f6800000000000000800100a5c00100
    [00:03:48.531,219] <err> coredump: #CD:bb010000688f00004063002075c1010040630020846300200000000000000000
    [00:03:48.544,189] <err> coredump: #CD:00000000000000001304000040410000f8dd040000000029b021002000000000
    [00:03:48.557,189] <err> coredump: #CD:4d410000fb150a00b021002000000000cc6f0a0069190a000000000010210020
    [00:03:48.570,159] <err> coredump: #CD:10210020b1190a0000000000fb2d080000000000008fffff1021002095340800
    [00:03:48.583,129] <err> coredump: #CD:ffffffffffffffff0000000028000000cc6f0a00102100205536080000000000
    [00:03:48.596,130] <err> coredump: #CD:ffffffff45360800000000006d360800000000000000000000800200a31e0800
    [00:03:48.609,100] <err> coredump: #CD:0000000000000000448e0a003854002000000000cc6f0a001900000098370220
    [00:03:48.622,070] <err> coredump: #CD:0080020023f407000000000000000000090000005f3800001900000098370220
    [00:03:48.635,040] <err> coredump: #CD:0080020007000000090000006f5000000f000000ff020a0001000000c8930520
    [00:03:48.648,010] <err> coredump: #CD:2097052001000000010000000400000100000000bdb004000000000000000000
    [00:03:48.660,980] <err> coredump: #CD:00000000ffffffffffffffffddb0040000000000b9f707000000000033f20000
    [00:03:48.673,919] <err> coredump: #CD:END#
    [00:03:48.681,640] <err> os: Halting system
    Possibly a null pointer being executed.
    addr2line can help here, to find where the faulting instruction was called from:
    arm-zephyr-eabi-addr2line -e build-folder/zephyr/zephyr.elf 0x4ddf8
    Possibly the LR can be resolved as well, ie. 0x4140.
    Also, since you're using coredump, you can load this into gdb:
    https://docs.zephyrproject.org/latest/services/debugging/coredump.html
    It is hard to see what has happened here, as there's missing logs etc. Can you elaborate on when the fault occurs in the context of when the second socket is used?
    Ie. where were you in the second connection procedure when this fault happens?
    Are you running this line twice? If yes, you must check if it is already present before adding it.
    What is your main stack size set to? I would recommend setting it high (15-20k area) in case you're overflowing it.
    Håkon
  • It is hard to see what has happened here, as there's missing logs etc. Can you elaborate on when the fault occurs in the context of when the second socket is used?
    It looks like it crashes when it goes to make the request, here is the function I call to make the request. I think it is in the Send call
    void https_get_goog(int sock)
    	const char *request = "GET / HTTP/1.1\r\n"
    						   "Host: www.google.com\r\n\r\n";
    	send(sock, request, strlen(request), 0);
    	while (1) {
    		int len = recv(sock, response, sizeof(response) - 1, 0);
    		if (len < 0) {
    			printk("Error reading response\n");
    			return 0;
    		if (len == 0) {
    			printf("GOOGLE Response: none\n");
    		response[len] = 0;
    		printk("Response: %s\n", response);
    		return 0;
    For some reason I was not able to get any useful information from GDB, there was no backtrace, Also when looking at the lines, it did not give me one 0x4ddf8.
    0x4140, Was a print statement for the WiFi status in the cmd_wifi_status callback
    LOG_INF("SSID: %-32s", status.ssid);
    That line is only being called once
  • I highly suspect that there's a thread/buffer that overflows.
    There's several buffers that is setup as well as contexts in the NET_* space.
    Did the zephyr.map file show which object/function is located at this address?
    Thank you for confirming.
    I have seen some stack related issues when trying to reproduce your scenario. Here's a sample based on the https_client sample, which, quite crudely, opens two TLS sockets towards google.com:
    0385.https_client_two_TLS_connections.zip
    What was the crucial config at my end was "CONFIG_NET_MAX_CONN=6". Without this, the connect() would return with an err on the second socket.
    Output:
    Looking up google.com
    Resolved 142.250.74.78 (AF_INET)
    FD: 0
    Connecting to google.com:443
    Sent 60 bytes
    Received 809 bytes
    >        HTTP/1.1 301 Moved Permanently
    Finished with socket fd=7
    FD: 1
    Sent 60 bytes
    Received 809 bytes
    Finished with socket fd=9
    Clean up
    My apologies for the prj.conf being a bit all over the place (I wanted to update you before my workday ends), I upped most stacks to a relatively high value to ensure no MPU faults.
    Håkon
  • This solution appears to work when WiFi gets connected, however a lot of the time it is not, I am seeing this in the logs, where it fails to connect to Wifi.
    [00:00:01.637,359] <inf> app: Registering IPv4 events
    [00:00:05.637,481] <err> app: Connecting to Wi-Fi failed. error: -1
    [00:00:05.637,512] <inf> app: Wait for Wi-fi connection
    The other issues I see is the body of the response coming back has been stripped out, I thought this was due to terminating the string at \r\n\r\n , but I removed that and still does not appear to be getting anything other than just the header data.
