NCS: Writing I2S data to SD card
Hi everybody,
I'm using the nRF Connect SDK v2.4.99 and an nRF5340 DK to write data received via I2S to the SD Card.
My application is based on the SDK's I2S echo sample. Both, the I2S sample and the code for writing to the SD Card are working independently. However, when I combine both into one application, my I2S code fails after very short time with the error message: "Failed to allocate next RX buffer: -12" ("i2s_nrfx.c" in line 205).
I was doing some debugging but I couldn't figure out the problem. I'm posting my main.c below. Since I do not want to use any I2S TX device or buffer, I removed all corresponding code from the I2S echo sample. I would appreciate if anybody could point me towards the bug in my code.
#include <zephyr/kernel.h>
#include <zephyr/drivers/i2s.h>
#include <string.h>
#include <zephyr/device.h>
#include <zephyr/storage/disk_access.h>
#include <zephyr/fs/fs.h>
#include <ff.h>
#include <stdio.h>
LOG_MODULE_REGISTER(main);
 *------------I2S SETTINGS------------
#if DT_NODE_EXISTS(DT_NODELABEL(i2s_rxtx))
#define I2S_RX_NODE  DT_NODELABEL(i2s_rxtx)
#define I2S_TX_NODE  I2S_RX_NODE
#else
#define I2S_RX_NODE  DT_NODELABEL(i2s_rx)
// #define I2S_TX_NODE  DT_NODELABEL(i2s_tx)
#define SAMPLE_FREQUENCY    44100
#define SAMPLE_BIT_WIDTH    32
#define BYTES_PER_SAMPLE    sizeof(int32_t) //4bytes
#define NUMBER_OF_CHANNELS  1
#define SAMPLES_PER_BLOCK   ((SAMPLE_FREQUENCY / 4) * NUMBER_OF_CHANNELS)
#define INITIAL_BLOCKS      2
#define TIMEOUT 1
#define BLOCK_SIZE  (BYTES_PER_SAMPLE * SAMPLES_PER_BLOCK)
#define BLOCK_COUNT (INITIAL_BLOCKS + 2)
K_MEM_SLAB_DEFINE_STATIC(mem_slab, BLOCK_SIZE, BLOCK_COUNT, 4);
 *----------BUTTONS/ISR CONFIG------------
#define SW1_NODE        DT_ALIAS(sw1)
#if DT_NODE_HAS_STATUS(SW1_NODE, okay)
static struct gpio_dt_spec sw1_spec = GPIO_DT_SPEC_GET(SW1_NODE, gpios);
static K_SEM_DEFINE(toggle_transfer, 1, 1); //Sera la variable que activara o no el semaforo, segun el boton sw1
static void sw1_handler(const struct device *dev, struct gpio_callback *cb, uint32_t pins)
	k_sem_give(&toggle_transfer); //Si se apreta el boton, la variable "se activa"
static bool init_interruptions(void)
	int ret;
	static struct gpio_callback sw1_cb_data;
	if (!device_is_ready(sw1_spec.port)) {
		printk("%s is not ready\n", sw1_spec.port->name);
		return false;
	ret = gpio_pin_configure_dt(&sw1_spec, GPIO_INPUT);
	if (ret < 0) {
		printk("Failed to configure %s pin %d: %d\n",
		       sw1_spec.port->name, sw1_spec.pin, ret);
		return false;
	ret = gpio_pin_interrupt_configure_dt(&sw1_spec, GPIO_INT_EDGE_TO_ACTIVE);
	if (ret < 0) {
		printk("Failed to configure interrupt on %s pin %d: %d\n",
		return false;
	gpio_init_callback(&sw1_cb_data, sw1_handler, BIT(sw1_spec.pin));
	gpio_add_callback(sw1_spec.port, &sw1_cb_data);
	printk("Press \"%s\" to stop/restart I2S streams\n", sw1_spec.port->name);
	(void)ret;
	return true;
* ----------------------------------- SD CARD ---------------------------------
#define DISK_DRIVE_NAME "SD"
#define DISK_MOUNT_PT "/"DISK_DRIVE_NAME":"
char file_name[16];
static const char *disk_mount_pt = DISK_MOUNT_PT;
static FATFS fat_fs;
static struct fs_mount_t mp = {
	.type = FS_FATFS,
	.fs_data = &fat_fs,
bool SD_iniciar(void){
	static const char *disk_pdrv = DISK_DRIVE_NAME;
		uint64_t memory_size_mb;
		uint32_t block_count;
		uint32_t block_size;
		if (disk_access_init(disk_pdrv) != 0) {
			LOG_ERR("Storage init ERROR!");
			return false;
		if (disk_access_ioctl(disk_pdrv, DISK_IOCTL_GET_SECTOR_COUNT, &block_count)) {
			LOG_ERR("Unable to get sector count");
			return false;
		LOG_INF("Block count %u", block_count);
			DISK_IOCTL_GET_SECTOR_SIZE, &block_size)) {
			LOG_ERR("Unable to get sector size");
			return false;
		printk("Sector size %u\n", block_size);
		memory_size_mb = (uint64_t)block_count * block_size;
		printk("Memory Size(MB) %u\n", (uint32_t)(memory_size_mb >> 20));
		return true;
int SD_lsdir(const char *path){
//Pre: Absolute path to list
//Post: -5 on error, listed entries on success. Retorna int num de wavs
	int ret;
	struct fs_dir_t dir;
	static struct fs_dirent entry;
	int count = 0;
	uint8_t exst_wavs = 0;
	fs_dir_t_init(&dir);
	/* Verify fs_opendir() */
	ret = fs_opendir(&dir, path);
	if (ret) {
		printk("Error opening dir %s [%d]\n", path, ret);
		return ret;
	printk("\nListing dir %s ...\n", path);
	while(true) {
		/* Verify fs_readdir() */
		ret = fs_readdir(&dir, &entry);
		/* entry.name[0] == 0 means end-of-dir */
		if (ret || entry.name[0] == 0) {
		if (entry.type == FS_DIR_ENTRY_DIR) {
			printk("[DIR ] %s\n", entry.name);
		} else {
			printk("[FILE] %s (size = %zu)\n",
				entry.name, entry.size);
		if(strstr(entry.name,".WAV") != NULL) exst_wavs++;
		count++;
	printk("Hay %d archivos .WAV", exst_wavs);
	printk(" en un total de %d archivos.\n", count);
	/* Verify fs_closedir() */
	fs_closedir(&dir);
	if (ret == 0) {
		ret = exst_wavs;
	return ret;
int SD_WriteTest(void)
	//#define BUF_SIZE 16128
	#define BUF_SIZE 100 //Para ASCII
	int16_t writebuff[BUF_SIZE];
	int ret;
	struct fs_file_t file;
	fs_file_t_init(&file);
    for (int i = 0; i < BUF_SIZE - 1; i++)
        writebuff[i] = 'A' + (i % 26); // Escribe el abecedario
	writebuff[BUF_SIZE - 1] = '\0'; // El texto debe tener terminación nula
	LOG_INF("Opening file path");
	ret = fs_open(&file, "/SD:/HOLA.txt", FS_O_CREATE | FS_O_WRITE);
	if (ret) {
		LOG_ERR("Error opening file [%d]", ret);
		return 0;
	LOG_INF("Done opening file path");
	if (fs_write(&file, writebuff, BUF_SIZE*sizeof(int16_t)) != BUF_SIZE*sizeof(int16_t))
		LOG_ERR("failed to write buff");
		fs_close(&file);
		return 0;
	LOG_INF("Done writing");
	fs_close(&file);
	return 1;
static void SD_ejecutar(void){
		if(SD_iniciar()){
			mp.mnt_point = disk_mount_pt;
			int ret = fs_mount(&mp);
			if (ret == FR_OK) {
				printk("Disk mounted.\n");
				if (SD_lsdir(disk_mount_pt) == 0) {
					printk("Creando test files.\n");
					ret = SD_WriteTest();
					if (!ret){
						LOG_ERR("failed to write");
					printk("Showing again...\n");
					SD_lsdir(disk_mount_pt);
		else {
			printk("Error mounting disk.\n");
* --------------------------------- I2S AUDIO ---------------------------------
static bool configure_streams(const struct device *i2s_dev_rx,
			    //   const struct device *i2s_dev_tx,
			      const struct i2s_config *config)
	int ret;
	ret = i2s_configure(i2s_dev_rx, I2S_DIR_RX, config);
	if (ret < 0) {
		printk("Failed to configure RX stream: %d\n", ret);
		return false;
	return true;
static bool prepare_transfer(const struct device *i2s_dev_rx, const struct device *i2s_dev_tx)
	int ret;
	for (int i = 0; i < INITIAL_BLOCKS; ++i) {
		void *mem_block;
		ret = k_mem_slab_alloc(&mem_slab, &mem_block, K_NO_WAIT);
		if (ret < 0) {
			printk("Failed to allocate TX block %d: %d\n", i, ret);
			return false;
		memset(mem_block, 0, BLOCK_SIZE);
		ret = i2s_write(i2s_dev_tx, mem_block, BLOCK_SIZE);
		if (ret < 0) {
			printk("Failed to write block %d: %d\n", i, ret);
			return false;
	return true;
static bool trigger_command(const struct device *i2s_dev_rx, enum i2s_trigger_cmd cmd)
	int ret;
	ret = i2s_trigger(i2s_dev_rx, I2S_DIR_RX, cmd);
	if (ret < 0) {
		printk("Failed to trigger command %d on RX: %d\n", cmd, ret);
		return false;
	return true;
* ----------------------------------- MAIN ------------------------------------
	const struct device *const i2s_dev_rx = DEVICE_DT_GET(I2S_RX_NODE);
	// const struct device *const i2s_dev_tx = DEVICE_DT_GET(I2S_TX_NODE);
	struct i2s_config config;
	printk("SD_I2S program\n");
	SD_ejecutar();
	if (!device_is_ready(i2s_dev_rx)) {
		printk("%s is not ready\n", i2s_dev_rx->name);
		return 0;
	config.word_size = SAMPLE_BIT_WIDTH;
	config.channels = NUMBER_OF_CHANNELS;
	config.format = I2S_FMT_DATA_FORMAT_I2S;
	config.options = I2S_OPT_BIT_CLK_MASTER | I2S_OPT_FRAME_CLK_MASTER;
	config.frame_clk_freq = SAMPLE_FREQUENCY;
	config.mem_slab = &mem_slab;
	config.block_size = BLOCK_SIZE;
	config.timeout = TIMEOUT;
	if (!configure_streams(i2s_dev_rx, &config)) {
		return 0;
	int i = 1; //Para la generacion de archivos
	for (;;) {
		k_sem_take(&toggle_transfer, K_FOREVER); //Solo avanza si la variable toggle se activa (cuando se toca el boton)
		char filename[30];
		sprintf(&filename, "/SD:/audio%d.txt", i); //Para que sea nombre archivo iterativo
		int ret = fs_open(&file, filename, FS_O_CREATE | FS_O_WRITE);
		if (ret) {
			return 0;
		printk("Streams started\n");
		if (!init_interruptions()) {
			return 0;
		if (!trigger_command(i2s_dev_rx, I2S_TRIGGER_START)) {
			return 0;
		while (k_sem_take(&toggle_transfer, K_NO_WAIT) != 0) { //Solo en el caso que se active la variable sale del bucle, PERO NO ESPERA a que sea activado
			void *mem_block;
			size_t block_size;
			ret = i2s_read(i2s_dev_rx, &mem_block, &block_size);
			if (ret < 0) {
				printk("Failed to read data: %d\n", ret);
				return 0;
			ret = fs_write(&file, mem_block, block_size);
			if (ret < 0) {
				printk("Failed to write data in sd card: %d\n", ret);
		if (!trigger_command(i2s_dev_rx, I2S_TRIGGER_DROP)) {
			return 0;
		printk("Stream stopped\n");
		printk("File named \"audio%d.txt\" successfully created\n", i);
		fs_close(&file);
		i++;//contador
    Your combined main.c file is working fine in v2.4.1\nrf\samples\peripheral\sd_i2s_def\src\main.c
    What do you mean by "combined"? Overall I understand I simply can't delete the parts of i2s_write() because I need it for starting the i2s TX state machine?
    I've been through the files you sent via screenshots. Is there a way by editing those files that we can delete the i2s_write() sections?
  • I think the start_transfer() in the i2s_nrfx.c is not designed to simply comment out the i2s_write function in main. Since it seems to think that if it is not set to read operation then it is automatically a write(tx) operation. Let me see if I can modify it to accomodate your use case of having just rx and no operation (from the current state machine that thinks if it is not rx, then it is tx operation)
  • Actually it turned to be simple than that.
    in main.c
    I2S_DIR_BOTH direction in both
    configure_streams()->
    i2s_configure and trigger_command()->i2s_trigger to
    I2S_DIR_RX, so that no TX buffers are expected in any transactions.
    This should help you to make the i2s driver work only on RX buffers.
    I did the changes you mentioned but this error pops up:
    <err> i2s_nrfx: Failed to allocate next RX buffer: -12
    Here is the main file with the changes:
    /*DESCRIPCION: Lee los datos que se reciben del microfono por I2S y los guarda inmediatamente a la tarjeta SD,
    creando un wav header apropiado para cada archivo. Los archivos se generaran por cada grabacion realizada,
    enumerados por orden creciente "AUDIOxx.WAV", y el archivo creado mas recientemente tendra el num mas grande.
    El LED1 se encendera cada vez que se este grabando. Cada grabacion se iniciara y se parara apretando el button2,
    al iniciarse el programa estará a la espera a que aprete el boton (no inicia la grabacion automaticamente).
     DESCRIPTION: This program reads data received from the microphone via I2S and immediately saves it to the SD card,
    creating an appropriate WAV header for each file. The files will be generated for each recording made,
    numbered in ascending order as "AUDIOxx.WAV," and the most recently created file will have the largest number.
    LED1 will turn on each time recording is in progress. Each recording will start and stop by pressing button2.
    At the start of the program, it will wait for the user to press the button (it will not start recording automatically).
    #include <string.h>
    #include <ff.h>
    #include <stdio.h>
    #else
    #define SAMPLES_PER_BLOCK   8192//((SAMPLE_FREQUENCY / 4) * NUMBER_OF_CHANNELS) //Mejor punto de equilibrio entre SD y I2S
    #define TIMEOUT 2000	//Tiempo de espera para recibir datos del buffer (porque la funcion es blocante)
     *--------WAV FILE HEADER CONFIG----------
    #define SUBCHUNK1SIZE (16) //tamano tipico del subchunk1 para el formato PCM (Pulse-Code Modulation), que es un formato de audio sin compresión.
    #define AUDIO_FORMAT (1) /*For PCM*/
    #define BLOCK_ALIGN (NUMBER_OF_CHANNELS * (SAMPLE_BIT_WIDTH / 8))
    //https:// ccrma.stanford.edu/courses/422/projects/WaveFormat/
    typedef struct wavfile_header_s {
      char ChunkID[4];   	/*  4   */// 0 - 3   -> "RIFF"
      int32_t ChunkSize; 	/*  4   */// 4 - 7   -> size of the file in bytes
      char Format[4];    	/*  4   */// 8 - 11  -> File type header, "WAVE"
      char Subchunk1ID[4];   /*  4   */// 12 - 15 -> "fmt "
      int32_t Subchunk1Size; /*  4   */// 16 - 19 -> Length of format data                         16
      int16_t AudioFormat;   /*  2   */// 20 - 21 -> type of format, pcm is                        1
      int16_t NumChannels;   /*  2   */// 22 - 23 -> number of channels                            2
      int32_t SampleRate;    /*  4   */// 24 - 27 -> sample rate,                                  32 kHz
      int32_t ByteRate;      /*  4   */// 28 - 31 -> sample rate x bps x channels                  19200
      int16_t BlockAlign;    /*  2   */// 32 - 33 -> bps * channels                                4
      int16_t BitsPerSample; /*  2   */// 34 - 35 -> bits per sample				               16
      char Subchunk2ID[4];  		   // 36 - 39 -> "data"
      int32_t Subchunk2Size;		   // 40 - 43 -> size of the data section
    } wavfile_header_t;
    wavfile_header_t wav_header;
    void write_PCM_header() {
    	//Pre: --
    	//Post: configura el struct wav_header para la reproduccion de audio
    	//Configurar a sus necesidades
        wav_header.ChunkID[0] = 'R';
        wav_header.ChunkID[1] = 'I';
        wav_header.ChunkID[2] = 'F';
        wav_header.ChunkID[3] = 'F';
        wav_header.ChunkSize = 0;//chunk_size; // (Size of the overall file - 8), to be filled at the end of record
        wav_header.Format[0] = 'W';
        wav_header.Format[1] = 'A';
        wav_header.Format[2] = 'V';
        wav_header.Format[3] = 'E';
        wav_header.Subchunk1ID[0] = 'f';
        wav_header.Subchunk1ID[1] = 'm';
        wav_header.Subchunk1ID[2] = 't';
        wav_header.Subchunk1ID[3] = ' ';
        wav_header.Subchunk1Size = SUBCHUNK1SIZE;
        wav_header.AudioFormat = AUDIO_FORMAT;
        wav_header.NumChannels = NUMBER_OF_CHANNELS;
        wav_header.SampleRate = SAMPLE_FREQUENCY;
        wav_header.ByteRate = SAMPLE_FREQUENCY*BYTES_PER_SAMPLE*NUMBER_OF_CHANNELS;
        wav_header.BlockAlign = BLOCK_ALIGN;
        wav_header.BitsPerSample = SAMPLE_BIT_WIDTH;
        wav_header.Subchunk2ID[0] = 'd';
        wav_header.Subchunk2ID[1] = 'a';
        wav_header.Subchunk2ID[2] = 't';
        wav_header.Subchunk2ID[3] = 'a';
        wav_header.Subchunk2Size = 0; // Size of the file - 44
    	//Lo actualizo antes de cerrar el archivo
     *---------------BUTTONS/LED--------------
    #define LED0_NODE DT_ALIAS(led0)
    static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
    static bool led_starter(void){
    	//Pre: pin del led correcto
    	//Post: inicializa el led y lo deja listo para su uso
    	if (!gpio_is_ready_dt(&led)) {
    		return false;
    	if (gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE) < 0) {
    		return false;
    	if(gpio_pin_set(led.port,led.pin,1)!=0){
    		return false;
    	return true;
    static K_SEM_DEFINE(toggle_transfer, 0, 1); //Sera la variable que activara o no el semaforo, segun el boton sw1
    // Inicialmente, el semáforo está en estado bloqueado (0)
    static bool init_interruptions(void){
    	//Pre:--
    	//Post: inicializa las interrupciones
    		return false;
    	int ret = gpio_pin_configure_dt(&sw1_spec, GPIO_INPUT);
    	if (ret < 0) {
    		return false;
    	if (ret < 0) {
    		return false;
    	printk("Press \"%s\" to start/stop I2S streams\n", sw1_spec.port->name);
    	(void)ret;
    	return true;
    uint16_t audio_counter = 0; // Will contain the number of the last audio%.wav file stored in the sd_card
    	.type = FS_FATFS,
    	.fs_data = &fat_fs,
    	//Pre: tarjeta insertada
    	//Post: inicia la tarjeta. Retorna falso si hay algun error.
    			return false;
    			return false;
    			return false;
    		return true;
    //Post: retorna -5 si hay error, sino retorna el total de wav files del directorio
    //Actualiza la variable audio_counter al numero mas alto de AUDIOxx.WAV que hay en el path
    	int ret;
    	int count = 0;
    	uint16_t exst_wavs = 0;
    	if (ret) {
    		return ret;
    	while(true) {
    		else {
    				count++;
    		if(strstr(entry.name,"AUDIO") != NULL){
    			exst_wavs++;
    			char* name = entry.name;
    			uint16_t num = 0;
    			int i = 5;//AUDIO = 5 char
    			while (name[i] != '.'){
    				num = num*((i-5)*10)+(int)(name[i]-'0');
    				i++;
    			if(num>audio_counter) audio_counter = num;
    			//me aseguro que sea el numero mas alto en caso que no esten ordenados por nombre
    	printk("%u AUDIOxx.WAV files were found out of %zu files.\n", exst_wavs, count);
    	fs_closedir(&dir);
    	if (ret == 0) {
    		ret = exst_wavs;
    	return ret;
    //Post: ejecuta las funciones para inicializar la tarjeta
    		if(SD_iniciar()){
    			if (ret == FR_OK) {
    		else {
    	int ret;
    	/*if (i2s_dev_rx == i2s_dev_tx) {
    		if (ret == 0) {
    			return true;
    		/* -ENOSYS means that the RX and TX streams need to be
    		 * configured separately.
    		if (ret != -ENOSYS) {
    			printk("Failed to configure streams: %d\n", ret);
    			return false;
    	if (ret < 0) {
    		return false;
    	/*ret = i2s_configure(i2s_dev_tx, I2S_DIR_TX, config);
    	if (ret < 0) {
    		printk("Failed to configure TX stream: %d\n", ret);
    		return false;
    	return true;
    static bool prepare_transfer(const struct device *i2s_dev_tx)
    	int ret;
    		void *mem_block;
    		if (ret < 0) {
    			return false;
    		if (ret < 0) {
    			return false;
    	return true;
    	int ret;
    		ret = i2s_trigger(i2s_dev_rx, I2S_DIR_BOTH, cmd);
    		if (ret == 0) {
    			return true;
    		/* -ENOSYS means that commands for the RX and TX streams need
    		 * to be triggered separately.
    			printk("Failed to trigger command %d: %d\n", cmd, ret);
    			return false;
    	if (ret < 0) {
    		return false;
    	/*ret = i2s_trigger(i2s_dev_tx, I2S_DIR_TX, cmd);
    	if (ret < 0) {
    		printk("Failed to trigger command %d on TX: %d\n", cmd, ret);
    		return false;
    	return true;*/
    	SD_ejecutar();
    		return 0;
    	if (i2s_dev_rx != i2s_dev_tx && !device_is_ready(i2s_dev_tx)) {
    		printk("%s is not ready\n", i2s_dev_tx->name);
    		return 0;
    	if (!configure_streams(i2s_dev_rx, i2s_dev_tx, &config)) {
    		return 0;
    		return 0;
    	for (;;) {
    		char filename[30];
    		sprintf(&filename, "/SD:/audio%d.wav", audio_counter+1); //Para que sea nombre archivo iterativo
    		if (ret) {
    			return 0;
    		printk("New file created: %s\n", filename);
    		write_PCM_header();
    		ret = fs_write(&file, &wav_header, sizeof(wav_header));
        	if (ret<0) {
            	printk("Write wav header failed with error %d", ret);
    		if(!led_starter()){
    			return 0;
    		/*if (!prepare_transfer(i2s_dev_tx)) {
    			return 0;
    		if (!trigger_command(i2s_dev_rx, i2s_dev_tx, I2S_TRIGGER_START)) {
    			return 0;
    		printk("WAV header set, starting streams\n");
    			void *mem_block;
    			if (ret != 0) {
    			/*ret = i2s_write(i2s_dev_tx, mem_block, block_size);
    			if (ret != 0) {
    				printk("Failed to write data: %d\n", ret);
    			if (ret < 0) {
    		if (!trigger_command(i2s_dev_rx, i2s_dev_tx, I2S_TRIGGER_DROP)) {
    			return 0;
    		LOG_INF ("Streams stopped\n");
    		gpio_pin_set(led.port,led.pin,0);
    		k_msleep(10); //10 ms delay
    		//----WAV HEADER TOTAL BYTES EDIT---
    		ret = fs_tell(&file); //retorna la posicion actual del puntero
        	if (ret<0) {
            	printk("Error al obtener el tamaño del archivo\n");
    		printk("Tamano del archivo \"%s\" : %zu bytes\n", filename, ret);
    		uint32_t total_size = ret;
    		uint32_t chunky = total_size - 8;
    		ret = fs_seek(&file, 4, FS_SEEK_SET);
       		if (ret < 0) {
          		printk("Seek failed. \n");
    	    ret = fs_write(&file, &chunky, sizeof(chunky)); //subchunk1
        	if (ret < 0) {
          		printk("Header rewriting 2 failed.\n");
    		chunky = total_size;
        	ret = fs_seek(&file, 40, FS_SEEK_SET);//Para cambiar el total de bytes (subchunk2)
        	if (ret < 0) {
        	if (ret < 0) {
    		//-------FINAL DEL ARCHIVO--------
    		fs_close(&file);
  • You are never freeing the block you read from i2s_read.  In the sample code the block is passed to i2s_write which will free it when it is done with it.  Since you no longer call i2s_write, the block leaks.  You just need to call  k_mem_slab_free(&mem_slab, mem_block);  after you call fs_write
