An issue with memory allocation in NRF52832 when working with JSON files
I am using the NRF52832 processor on a custom board to collect data from a sensor and send it to a mobile app using BLE and NUS service in JSON format. However, after a few minutes, the transmission stops due to memory allocation failure.
Here is a piece of my code:
        root_G_P_R=cJSON_CreateObject();
        cJSON_AddItemToObject(root_G_P_R, "info", info_G_P_R=cJSON_CreateObject());
        cJSON *plan_date = cJSON_CreateArray();
        for (int i= 0 ; i<APP_PlanCounter+1;i++)
        cJSON_AddItemToArray(plan_date, cJSON_CreateNumber(APP_PlanDate[i]));
        cJSON *TR = cJSON_CreateArray();
        cJSON_AddItemToArray(TR, cJSON_CreateNumber(APP_TRS[i]));
        cJSON *TRCR = cJSON_CreateArray();
        cJSON_AddItemToArray(TRCR, cJSON_CreateNumber(App_TRCS[i]));
        cJSON_AddItemToObject(root_G_P_R,    "key",            cJSON_CreateString("G_P_R"));
        cJSON_AddItemToObject(info_G_P_R,    "tr",     TR);
        cJSON_AddItemToObject(info_G_P_R,    "trac",     TRCR);
        cJSON_AddNumberToObject(info_G_P_R,  "plan",            plan);
        cJSON_AddNumberToObject(info_G_P_R,    "PT",           App_PT[APP_PlanCounter]);
        cJSON_AddItemToObject(info_G_P_R,    "date",           plan_date);
     if (print_preallocated(root_G_P_R) != 0) {
        cJSON_Delete(root_G_P_R);
        exit(EXIT_FAILURE);
and in the case of print_preallocated:
  static int print_preallocated(cJSON *root)
    char *out = NULL;
    char *buf = NULL;
    char *buf_fail = NULL;
    uint16_t len = 0;
    size_t len_fail = 0;
    out = cJSON_Print(root);
    len = strlen(out) + 5;
    buf = (char*)malloc(len);
    if (buf == NULL)
        printf("Failed to allocate memory.\n");
        exit(1);
    len_fail = strlen(out);
    buf_fail = (char*)malloc(len_fail);
    if (buf_fail == NULL)
        exit(1);
     ble_nus_data_send(&m_nus, (uint8_t *)out , &len, m_conn_handle);
    free(out);
    free(buf_fail);
    free(buf);
    return 0;
I have read in a thread that applying cJSON_Init() to the main would be helpful, but when I added this function, the JSON parse data process failed:
cJSON_Parse(received_data) --> cJSON_ParseWithOpts --> cJSON_New_Item --> cJSON_malloc
I suspect that there is something wrong with memory allocation. Could you please help me with this problem? Is there any configuration or consideration that I should have taken but missed out on?
 Thank you for your assistance.
  • Hi Håkon,
    Which compiler are you using? is alloc used in other functions of your firmware?
    I'm currently using Segger Embedded Studio as IDE and GCC as the compiler. As for the second question, alloc is only utilized within the cJSON code and not elsewhere.
    I appreciate your response.
    ZaQa
    Looking at it again I found one place where the memory is free'd:
    ZaQa said:
    allocated address : 20005b5c
    allocated address : 20005b1c
    allocated address : 20005b8c
    This is the only place where you actually free the allocated memory, thus the HEAP goes up again. You need to adjust your heap size and/or handle your timing accordingly.
    Try to print + when alloc'ing, and - when free'ing memory to see how often one occurs vs. the other.
    Håkon
    I tried it again, but this time I increased the heap size to 16KB. However, I obtained the same result:
    allocated address : 2000955c
    allocated address : 2000949c
    allocated address : 2000945c
    allocated address : 2000934c
    allocated address : 2000930c
    allocated address : 200092dc
    allocated address : 2000920c
    allocated address : 200091dc
    allocated address : 2000915c
    allocated address : 2000910c
    allocated address : 2000908c
    allocated address : 2000904c
    allocated address : 2000901c
    allocated address : 20008fcc
    allocated address : 20008f1c
    allocated address : 20008eec
    allocated address : 20008edc
    allocated address : 20008eac
    allocated address : 20008e7c
    allocated address : 20008e6c
    allocated address : 20008e3c
    allocated address : 20008dbc
    allocated address : 20008d7c
    allocated address : 20008d0c
    allocated address : 20008c8c
    allocated address : 20008c2c
    allocated address : 20008bfc
    allocated address : 20008bec
    allocated address : 20008bbc
    allocated address : 20008b3c
    allocated address : 20008aec
    allocated address : 20008adc
    allocated address : 20008acc
    allocated address : 20008abc
    allocated address : 20008aac
    allocated address : 20008a9c
    allocated address : 20008a8c
    allocated address : 20008a7c
    allocated address : 20008a6c
    allocated address : 20008a5c
    allocated address : 20008a4c
    allocated address : 200089cc
    allocated address : 2000898c
    allocated address : 2000895c
    allocated address : 2000892c
    allocated address : 2000891c
    allocated address : 200088ec
    allocated address : 200088bc
    allocated address : 2000889c
    allocated address : 2000888c
    allocated address : 2000887c
    allocated address : 2000886c
    allocated address : 2000885c
    allocated address : 2000884c
    allocated address : 2000883c
    allocated address : 2000882c
    allocated address : 2000881c
    allocated address : 2000880c
    allocated address : 200087fc
    allocated address : 200087ec
    allocated address : 2000879c
    allocated address : 200086ec
    allocated address : 2000861c
    allocated address : 2000852c
    allocated address : 200084bc
    allocated address : 200083cc
    allocated address : 2000837c
    allocated address : 200082fc
    allocated address : 200082bc
    allocated address : 2000823c
    allocated address : 2000818c
    allocated address : 2000810c
    allocated address : 200080cc
    allocated address : 20007ffc
    allocated address : 20007fac
    allocated address : 20007f6c
    allocated address : 20007f3c
    allocated address : 20007f0c
    allocated address : 20007edc
    allocated address : 20007e9c
    allocated address : 20007e4c
    allocated address : 20007dac
    allocated address : 20007d4c
    allocated address : 20007cfc
    allocated address : 20007ccc
    allocated address : 20007c4c
    allocated address : 20007c1c
    allocated address : 20007b9c
    allocated address : 20007a7c
    allocated address : 20007a4c
    allocated address : 200079bc
    allocated address : 2000797c
    allocated address : 2000791c
    allocated address : 200078bc
    allocated address : 200077ec
    allocated address : 200077bc
    allocated address : 200077ac
    allocated address : 2000779c
    allocated address : 2000777c
    allocated address : 200076dc
    allocated address : 2000767c
    allocated address : 2000764c
    allocated address : 2000761c
    allocated address : 2000757c
    allocated address : 2000754c
    allocated address : 200074ec
    allocated address : 2000747c
    allocated address : 2000742c
    allocated address : 200073ac
    allocated address : 2000736c
    allocated address : 2000733c
    allocated address : 2000730c
    allocated address : 200072dc
    allocated address : 200072ac
    allocated address : 2000727c
    allocated address : 2000724c
    allocated address : 2000721c
    allocated address : 2000714c
    allocated address : 2000705c
    allocated address : 20006fbc
    allocated address : 20006f0c
    allocated address : 20006e4c
    allocated address : 20006e1c
    allocated address : 20006d3c
    allocated address : 20006d2c
    allocated address : 20006d1c
    allocated address : 20006d0c
    allocated address : 20006cbc
    allocated address : 20006bfc
    allocated address : 20006b3c
    allocated address : 20006afc
    allocated address : 20006aec
    allocated address : 20006adc
    allocated address : 20006acc
    allocated address : 20006abc
    allocated address : 20006aac
    allocated address : 20006a9c
    allocated address : 20006a8c
    allocated address : 20006a7c
    allocated address : 20006a6c
    allocated address : 20006a5c
    allocated address : 20006a4c
    allocated address : 200069ac
    allocated address : 2000691c
    allocated address : 200068ec
    allocated address : 200068cc
    allocated address : 2000683c
    allocated address : 200067dc
    allocated address : 200067bc
    allocated address : 2000678c
    allocated address : 2000673c
    allocated address : 2000670c
    allocated address : 2000668c
    allocated address : 200065fc
    allocated address : 200065cc
    allocated address : 2000656c
    allocated address : 200064cc
    allocated address : 2000646c
    allocated address : 2000643c
    allocated address : 2000640c
    allocated address : 2000639c
    allocated address : 2000634c
    allocated address : 200062fc
    allocated address : 200062cc
    allocated address : 2000629c
    allocated address : 2000623c
    allocated address : 200061ec
    allocated address : 2000617c
    allocated address : 2000615c
    allocated address : 200060ec
    allocated address : 2000608c
    allocated address : 2000603c
    allocated address : 2000601c
    allocated address : 20005ffc
    allocated address : 20005fdc
    allocated address : 20005fbc
    allocated address : 20005f9c
    allocated address : 20005f6c
    allocated address : 20005f4c
    allocated address : 20005f1c
    allocated address : 20005efc
    allocated address : 20005edc
    allocated address : 20005eac
    allocated address : 20005e8c
    allocated address : 20005e6c
    allocated address : 20005e5c
    allocated address : 20005e3c
    allocated address : 20005ddc
    allocated address : 20005d8c
    allocated address : 20005d2c
    allocated address : 20005d0c
    allocated address : 20005cdc
    allocated address : 20005c3c
    allocated address : 20005c0c
    allocated address : 20005bac
    allocated address : 20005b4c
    allocated address : 20005aec
    allocated address : 2000596c
    allocated address : 20005a2c
    allocated address : 200059ec
    allocated address : 0
    Finally, for the first and last time allocated address goes up from 2000596c to 20005a2c and then decreases to 0.
    Is it possible to clear the entire heap and start anew, perhaps when the allocated address reaches 0?
    I'm unsure how to ensure the allocated memory has been freed since the free() function doesn't return any value to confirm its success. Do you have any suggestions on how to address this issue?
    Thank you for your time.
  • For instance: for each malloc, print a "+", and for each free call, print a "-".
    That list shows your firmware is leaking memory, try switching to static allocation for everything else except cJSON_* calls.
    Also, I would recommend that you add some waiting logic (wait for the callback with evt BLE_GATTS_EVT_HVN_TX_COMPLETE) after the ble_nus_data_send() call, as this is a non-blocking function.
    Håkon
  • Hi Håkon,
    I have been addressing this problem since then and I am pleased to report that it has been resolved successfully. Based on your previous comments, I have made changes to the memory allocation and replaced all the static cJSON calls with dynamic memory allocation. The memory leakage issue has been eliminated, and everything is functioning correctly.
    Thank you very much for taking the time to guide me. I truly appreciate your patience.
    Warmest regards,
    ZaQa
