lte_ble_gateway fails with NCS 2.2 and thingy:91 rev 1.6.0
Hi!
I am building an application that is based on the lte_ble_gateway which works perfectly on the nrf9160dk. However, it does not work on the thingy:91.
The error is also present in the unmodified lte_ble_gateway sample, so it should be easy to reproduce.
I am trying to run lte_ble_gateway to a thingy:91 rev 1.6.0, but get the following error message when running the application:
** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.487,274] <inf> lte_ble_gw: LTE Sensor Gateway sample started
[00:00:00.487,426] <inf> lte_ble_gw: Initializing Bluetooth..
[00:00:00.504,943] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:329
k_sem_take failed with err -11
[00:00:10.497,924] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000002
[00:00:10.497,955] <err> os: r3/a4: 0x2000e168 r12/ip: 0x20016e78 r14/lr: 0x000223b3
[00:00:10.497,955] <err> os: xpsr: 0x41000000
[00:00:10.497,985] <err> os: Faulting instruction address (r15/pc): 0x000223be
[00:00:10.498,016] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:10.498,046] <err> os: Current thread: 0x2000eea0 (unknown)
[00:00:10.720,733] <err> fatal_error: Resetting system
Output from nrf52840:
*** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.000,671] <inf> sdc_hci_driver: SoftDevice Controller build revision:
6d 90 41 2a 38 e8 ad 17 29 a5 03 38 39 27 d7 85 |m.A*8... )..89'..
1f 85 d8 e1 |....
[00:00:00.001,312] <inf> bt_hci_raw: Bluetooth enabled in RAW mode
[00:00:01.001,373] <wrn> lpuart: Tx timeout
[00:00:02.002,166] <wrn> lpuart: Tx timeout
[00:00:03.002,990] <wrn> lpuart: Tx timeout
[00:00:04.003,814] <wrn> lpuart: Tx timeout
[00:00:05.004,638] <wrn> lpuart: Tx timeout
[00:00:06.005,462] <wrn> lpuart: Tx timeout
1f 85 d8 e1 |....
I build lte_ble_gateway with the command:
west build --board [email protected]
and hci_lpuart:
I have managed to get the sample working for the nrf9160DK earlier (Where I had to build with west build --board [email protected] for hci_lpuart and [email protected] for lte_ble_gateway)
I have looked at this post, but it is not an option to downgrade to NCS 1.9.X: devzone.nordicsemi.com/.../382953
Additionally, it is really tidious to debug as the flashing process fails 70% of the time and the nrf9160dk disappears from discovered devices, which means that I must reboot my computer. Any tips on this would also be greatly appreciated.
Thanks in advance for your help.
    I updated the SDK to 2.5.99 which seemed to do the trick.
    Now I have a new issue regarding the thingy refusing to establish LTE connection (it worked yesterday, but stopped working after updating the modem FW). But I assume that is for another ticket.
    Thanks for your support.
    -Jonathan
  • Hi Jonathan,
    It may be a good idea to try with v2.5.0 instead. The main branch is continuously updated and may not always be stable. If you continue to experience issues with your LTE connection, I recommend creating a new support ticket.
    Vidar
    I also use a Thingy91 and I'm trying to test the Bluetooth.
    I have the same setup (ncs V2.5.1), 'hci_lpuart' sample on the nrf52840 and 'lte_ble_gateway' on the nrf9160 (NS).
    My nRF9160 logs:
    *** Booting nRF Connect SDK v2.5.1 ***
    [00:00:00.257,415] \033[0m<inf> lte_ble_gw: LTE Sensor Gateway sample started\033[0m
    [00:00:00.257,568] \033[0m<inf> lte_ble_gw: Initializing Bluetooth..\033[0m
    [00:00:00.271,148] \033[1;33m<wrn> lpuart: req pin low when expected high\033[0m
    [00:00:00.271,270] \033[1;31m<err> lpuart: Empty receiver state:4\033[0m
    [00:00:00.502,441] \033[0m<inf> lte_ble_gw: Establishing LTE link (this may take some time) ...\033[0m
    [00:00:01.363,311] \033[1;31m<err> lpuart: Empty receiver state:4\033[0m
    ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:338
    	command opcode 0x0c03 timeout with err -11
    [00:00:10.268,066] \033[1;31m<err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002\033[0m
    [00:00:10.268,066] \033[1;31m<err> os: r3/a4:  0x2000d298 r12/ip:  0x00000010 r14/lr:  0x0002049d\033[0m
    [00:00:10.268,096] \033[1;31m<err> os:  xpsr:  0x41000000\033[0m
    [00:00:10.268,096] \033[1;31m<err> os: Faulting instruction address (r15/pc): 0x000204a8\033[0m
    [00:00:10.268,157] \033[1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0\033[0m
    [00:00:10.268,188] \033[1;31m<err> os: Current thread: 0x2000f7b8 (unknown)\033[0m
    [00:00:10.490,264] \033[1;31m<err> fatal_error: Resetting system\033[0m
    and my nRF52840 logs:
    [00:00:00.726,226] \033[0m<inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                c5 93 ba a9 14 4d 8d 05  30 4e 9b 92 d7 71 1e e8 |.....M.. 0N...q..
                                                aa 02 50 3c                                      |..P<             \033[0m
    [00:00:00.726,593] \033[0m<inf> bt_hci_raw: Bluetooth enabled in RAW mode\033[0m
    [00:00:01.726,623] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    [00:00:02.727,478] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    [00:00:03.728,302] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    [00:00:04.729,125] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    [00:00:05.729,949] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    [00:00:06.730,773] \033[1;33m<wrn> lpuart: Tx timeout\033[0m
    What's wrong with my configuration?
    I didn't change anything in these samples, I just copied, compiled and flashed.
    Dorian
  • Try adding
    CONFIG_GPIO_AS_PINRESET=y
    to boards/thingy91_nrf52840.conf
