Porting ncs example code to Fanstel BT840X that has an internal skyworks PA/LNA
I am looking to take example codes for the nrf52840dk and run them on a Fanstel BT840X EV board. I am looking at the central and peripheral coded low data rate firmware but want to achieve a much greater range by using the RF amp and LNA. Can anyone point me to some examples that might demonstrate of give some idea how to do this. I am using NRF connect SDK 2.2.99 with visual studio. I have got the Fanstel BT840X range test code working and I have been able to port the examples for the nrf52840dk to the Fanstel BT840X EV board but cannot get the extended range. Does the code need to control the switching of the PA/LNA as at the moment I have the PA fixed on and LNA off.
  • Hi PSB .config and .dts files
    .config
    CONFIG_GPIO=y
    # CONFIG_KSCAN is not set
    # CONFIG_WIFI is not set
    # CONFIG_SPI is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_WATCHDOG is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_I2C is not set
    # CONFIG_SENSOR is not set
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BOARD="nrf52840dk_nrf52840"
    CONFIG_BT_CTLR=y
    CONFIG_SOC="nRF52840_QIAA"
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_NUM_IRQS=48
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    # CONFIG_RESET is not set
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_PM=y
    # CONFIG_PM_DEVICE is not set
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=2048
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_BT_USER_PHY_UPDATE=y
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_HAS_DTS=y
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GENERIC_FEM_TWO_CTRL_PINS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SKYWORKS_SKY66112_11_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.2.99-dev3/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    # CONFIG_INIT_STACKS is not set
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_LOG_DEFAULT_LEVEL=1
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=1024
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=0
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=2
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_SDC_ADDITIONAL_MEMORY=0
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER is not set
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    CONFIG_BT_GATT_DM=y
    CONFIG_BT_GATT_DM_MAX_ATTRS=35
    # CONFIG_BT_GATT_DM_DATA_PRINT is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
    CONFIG_BT_GATT_DM_LOG_LEVEL_INF=y
    # CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
    CONFIG_BT_GATT_DM_LOG_LEVEL=3
    CONFIG_BT_SCAN=y
    CONFIG_BT_SCAN_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_FILTER_ENABLE=y
    CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
    CONFIG_BT_SCAN_UUID_CNT=1
    CONFIG_BT_SCAN_NAME_CNT=0
    CONFIG_BT_SCAN_SHORT_NAME_CNT=0
    CONFIG_BT_SCAN_ADDRESS_CNT=0
    CONFIG_BT_SCAN_APPEARANCE_CNT=0
    CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=0
    # CONFIG_BT_SCAN_CONN_ATTEMPTS_FILTER is not set
    # CONFIG_BT_SCAN_BLOCKLIST is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
    CONFIG_BT_SCAN_LOG_LEVEL_INF=y
    # CONFIG_BT_SCAN_LOG_LEVEL_DBG is not set
    CONFIG_BT_SCAN_LOG_LEVEL=3
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    CONFIG_BT_NRF_SERVICES=y
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    CONFIG_BT_HRS_CLIENT=y
    CONFIG_BT_HRS_CLIENT_RR_INTERVALS_COUNT=10
    # CONFIG_BT_HRS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HRS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HRS_CLIENT_LOG_LEVEL_WRN is not set
    CONFIG_BT_HRS_CLIENT_LOG_LEVEL_INF=y
    # CONFIG_BT_HRS_CLIENT_LOG_LEVEL_DBG is not set
    CONFIG_BT_HRS_CLIENT_LOG_LEVEL=3
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    CONFIG_BT_L2CAP_TX_MTU=23
    CONFIG_BT_BUF_ACL_TX_SIZE=27
    CONFIG_BT_BUF_ACL_RX_SIZE=27
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=27
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    # CONFIG_BT_PERIPHERAL is not set
    CONFIG_BT_OBSERVER=y
    # CONFIG_BT_BROADCASTER is not set
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    CONFIG_BT_EXT_ADV=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
    # CONFIG_BT_PER_ADV is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    CONFIG_BT_IAS_LOG_LEVEL_INF=y
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL=3
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_VS_EVT is not set
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG=y
    # CONFIG_BT_DEBUG_NONE is not set
    CONFIG_BT_DEBUG_LOG=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    # CONFIG_BT_DEBUG_HCI_DRIVER is not set
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    CONFIG_BT_RPA_LOG_LEVEL=3
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_AUTO_PHY_UPDATE is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_DEBUG_L2CAP is not set
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    # CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
    # CONFIG_BT_DEBUG_ATT is not set
    CONFIG_BT_ATT_LOG_LEVEL=3
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DEBUG_GATT is not set
    CONFIG_BT_GATT_LOG_LEVEL=3
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Zephyr"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DEBUG_HCI_CORE is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL=3
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DEBUG_CONN is not set
    CONFIG_BT_CONN_LOG_LEVEL=3
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DEBUG_ISO is not set
    CONFIG_BT_ISO_LOG_LEVEL=3
    CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
    CONFIG_BT_KEYS_LOG_LEVEL=3
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    CONFIG_BT_SMP_LOG_LEVEL=3
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    CONFIG_BT_RFCOMM_LOG_LEVEL=3
    CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
    CONFIG_BT_HFP_HF_LOG_LEVEL=3
    CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
    CONFIG_BT_AVDTP_LOG_LEVEL=3
    CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
    CONFIG_BT_A2DP_LOG_LEVEL=3
    CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
    CONFIG_BT_SDP_LOG_LEVEL=3
    CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SDP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DEBUG_SERVICE is not set
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_ESB_LOG_LEVEL_OFF is not set
    # CONFIG_ESB_LOG_LEVEL_ERR is not set
    # CONFIG_ESB_LOG_LEVEL_WRN is not set
    CONFIG_ESB_LOG_LEVEL_INF=y
    # CONFIG_ESB_LOG_LEVEL_DBG is not set
    CONFIG_ESB_LOG_LEVEL=3
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_MQTT_HELPER is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_PPI_TRACE is not set
    # CONFIG_CPU_LOAD is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_ANY_SUPPORT=y
    CONFIG_MPSL_FEM_GENERIC_TWO_CTRL_PINS_SUPPORT=y
    CONFIG_MPSL_FEM_NCS_SUPPORTED_FEM_USED=y
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    CONFIG_MPSL_FEM=y
    CONFIG_MPSL_FEM_SIMPLE_GPIO=y
    # CONFIG_MPSL_FEM_POWER_MODEL is not set
    CONFIG_MPSL_FEM_DEVICE_CONFIG_254=y
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_LOG_LEVEL_INF=y
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_DISABLE_FLASH_PATCH is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CUSTOM_CMD is not set
    CONFIG_DK_LIBRARY=y
    CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
    CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
    # CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set
    # CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set
    # CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set
    CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y
    # CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set
    CONFIG_DK_LIBRARY_LOG_LEVEL=3
    # CONFIG_MODEM_INFO is not set
    CONFIG_MULTITHREADING_LOCK=y
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL=3
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    # CONFIG_MODEM_JWT is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.2.99-dev3/nrf)
    # hostap (C:/ncs/v2.2.99-dev3/modules/lib/hostap)
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (C:/ncs/v2.2.99-dev3/modules/lib/hostap)
    # mcuboot (C:/ncs/v2.2.99-dev3/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.2.99-dev3/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.2.99-dev3/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # end of mbedtls (C:/ncs/v2.2.99-dev3/modules/crypto/mbedtls)
    # trusted-firmware-m (C:/ncs/v2.2.99-dev3/modules/tee/tf-m/trusted-firmware-m)
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v2.2.99-dev3/modules/tee/tf-m/trusted-firmware-m)
    # cjson (C:/ncs/v2.2.99-dev3/modules/lib/cjson)
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.2.99-dev3/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.2.99-dev3/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.2.99-dev3/modules/lib/azure-sdk-for-c)
    # memfault-firmware-sdk (C:/ncs/v2.2.99-dev3/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.2.99-dev3/modules/lib/memfault-firmware-sdk)
    # cirrus-logic (C:/ncs/v2.2.99-dev3/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.2.99-dev3/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.2.99-dev3/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.2.99-dev3/modules/lib/openthread)
    # canopennode (C:/ncs/v2.2.99-dev3/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.2.99-dev3/modules/lib/canopennode)
    # chre (C:/ncs/v2.2.99-dev3/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.2.99-dev3/modules/lib/chre)
    # fatfs (C:/ncs/v2.2.99-dev3/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.2.99-dev3/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.2.99-dev3/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    # CONFIG_NRFX_I2S is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PPI=y
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TIMER3 is not set
    # CONFIG_NRFX_TIMER4 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_USBD is not set
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of nrfx drivers
    # end of hal_nordic (C:/ncs/v2.2.99-dev3/modules/hal/nordic)
    # liblc3 (C:/ncs/v2.2.99-dev3/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (C:/ncs/v2.2.99-dev3/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.2.99-dev3/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.2.99-dev3/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.2.99-dev3/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.2.99-dev3/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.2.99-dev3/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.2.99-dev3/modules/lib/gui/lvgl)
    # lz4 (C:/ncs/v2.2.99-dev3/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.2.99-dev3/modules/lib/lz4)
    # nanopb (C:/ncs/v2.2.99-dev3/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.2.99-dev3/modules/lib/nanopb)
    # picolibc (C:/ncs/v2.2.99-dev3/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.2.99-dev3/modules/lib/picolibc)
    # TraceRecorder (C:/ncs/v2.2.99-dev3/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (C:/ncs/v2.2.99-dev3/modules/debug/TraceRecorder)
    # uoscore-uedhoc (C:/ncs/v2.2.99-dev3/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.2.99-dev3/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.2.99-dev3/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (C:/ncs/v2.2.99-dev3/modules/lib/zcbor)
    # zscilib (C:/ncs/v2.2.99-dev3/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.2.99-dev3/modules/lib/zscilib)
    # nrfxlib (C:/ncs/v2.2.99-dev3/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_CRYPTOCELL_CC310_USABLE=y
    CONFIG_CRYPTOCELL_USABLE=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    # CONFIG_HW_CC3XX_INTERRUPT is not set
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # nrf_security module
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # end of nrf_security module
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.2.99-dev3/nrfxlib)
    # connectedhomeip (C:/ncs/v2.2.99-dev3/modules/lib/matter)
    # CONFIG_CHIP is not set
    # CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.2.99-dev3/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_NN is not set
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCBOR is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    # CONFIG_TINYCRYPT_SHA256 is not set
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF52840DK_NRF52840=y
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    # end of Board Options
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC1701X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    CONFIG_SOC_SERIES_NRF52X=y
    # CONFIG_SOC_SERIES_NRF53X is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_RTC0=y
    CONFIG_HAS_HW_NRF_RTC1=y
    CONFIG_HAS_HW_NRF_RTC2=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TIMER3=y
    CONFIG_HAS_HW_NRF_TIMER4=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_NRF_HW_RTC1_RESERVED=y
    CONFIG_SOC_NRF52840=y
    # CONFIG_SOC_NRF52805_CAAA is not set
    # CONFIG_SOC_NRF52810_QFAA is not set
    # CONFIG_SOC_NRF52811_QFAA is not set
    # CONFIG_SOC_NRF52820_QDAA is not set
    # CONFIG_SOC_NRF52832_CIAA is not set
    # CONFIG_SOC_NRF52832_QFAA is not set
    # CONFIG_SOC_NRF52832_QFAB is not set
    # CONFIG_SOC_NRF52833_QIAA is not set
    CONFIG_SOC_NRF52840_QIAA=y
    CONFIG_SOC_DCDC_NRF52X=y
    CONFIG_SOC_DCDC_NRF52X_HV=y
    CONFIG_GPIO_AS_PINRESET=y
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    CONFIG_SOC_LOG_LEVEL_INF=y
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_CPU_CORTEX_M=y
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_STACK_GUARD=y
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    CONFIG_ARCH_LOG_LEVEL_INF=y
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    CONFIG_MPU_LOG_LEVEL_INF=y
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    CONFIG_KERNEL_LOG_LEVEL_INF=y
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_LORA is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
    CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_RTT_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    # CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    CONFIG_ETH_INIT_PRIORITY=80
    # CONFIG_MDIO is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    CONFIG_UART_LOG_LEVEL_INF=y
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_0_NRF_UARTE=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_ENHANCED_POLL_OUT=y
    CONFIG_NRF_UARTE_PERIPHERAL=y
    # Interrupt Controllers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    CONFIG_INTC_LOG_LEVEL_INF=y
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt Controllers
    # Timer Drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer Drivers
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    CONFIG_ENTROPY_LOG_LEVEL_INF=y
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    CONFIG_GPIO_LOG_LEVEL_INF=y
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    CONFIG_GPIO_NRFX=y
    # CONFIG_FXL6408_LOG_LEVEL_OFF is not set
    # CONFIG_FXL6408_LOG_LEVEL_ERR is not set
    # CONFIG_FXL6408_LOG_LEVEL_WRN is not set
    CONFIG_FXL6408_LOG_LEVEL_INF=y
    # CONFIG_FXL6408_LOG_LEVEL_DBG is not set
    CONFIG_FXL6408_LOG_LEVEL=3
    # CONFIG_SDHC is not set
    # CONFIG_I3C is not set
    # CONFIG_I2S is not set
    # CONFIG_DAI is not set
    # CONFIG_PWM is not set
    # CONFIG_PINMUX is not set
    # CONFIG_ADC is not set
    # CONFIG_DAC is not set
    # CONFIG_W1 is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_IPM is not set
    # CONFIG_FLASH is not set
    # CONFIG_COUNTER is not set
    # CONFIG_DMA is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LED is not set
    # CONFIG_CAN is not set
    # CONFIG_AUDIO is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_HWINFO is not set
    # CONFIG_ESPI is not set
    # CONFIG_PS2 is not set
    # CONFIG_VIDEO is not set
    # CONFIG_EEPROM is not set
    # CONFIG_PECI is not set
    # CONFIG_PECI_INTERRUPT_DRIVEN is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_MEMC is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_EDAC is not set
    # CONFIG_PM_CPU_OPS is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_CACHE is not set
    # CONFIG_SYSCON is not set
    # CONFIG_BBRAM is not set
    # CONFIG_FPGA is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    CONFIG_PINCTRL_LOG_LEVEL_INF=y
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_MBOX is not set
    # CONFIG_MM_DRV is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    CONFIG_USBC_LOG_LEVEL_INF=y
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_FUEL_GAUGE is not set
    # C Library
    CONFIG_SUPPORT_MINIMAL_LIBC=y
    CONFIG_PICOLIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC=y
    # CONFIG_PICOLIBC is not set
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
    CONFIG_MINIMAL_LIBC_MALLOC=y
    CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
    CONFIG_MINIMAL_LIBC_CALLOC=y
    CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
    # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    # CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE is not set
    # CONFIG_MINIMAL_LIBC_RAND is not set
    CONFIG_MINIMAL_LIBC_TIME=y
    # CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # Additional libraries
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_CRC=y
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    CONFIG_SYS_HEAP_SMALL_ONLY=y
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    # CONFIG_SYS_HEAP_AUTO is not set
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_GETOPT is not set
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # Util libraries
    # CONFIG_FNMATCH is not set
    # end of Util libraries
    # CONFIG_SMF is not set
    # end of Additional libraries
    # Sub Systems and OS Services
    CONFIG_BT=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    CONFIG_BT_LOG_LEVEL_INF=y
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER is not set
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    CONFIG_BT_CTLR_AD_DATA_BACKUP=y
    # CONFIG_BT_CTLR_HCI_ADV_HANDLE_MAPPING is not set
    CONFIG_BT_CTLR_DUP_FILTER_LEN=16
    CONFIG_BT_CTLR_DUP_FILTER_ADV_SET_MAX=1
    CONFIG_BT_CTLR_RX_BUFFERS=1
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=22
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # BLE Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    # CONFIG_BT_CTLR_CONN_RSSI is not set
    # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
    # CONFIG_BT_CTLR_PRIVACY is not set
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_PHY_CODED=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_ADV_EXT_RX_PDU_LEN_MAX=255
    CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=31
    # CONFIG_BT_CTLR_SYNC_PERIODIC is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_CTLR_TEST is not set
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_COMPANY_ID=0x05F1
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPLUSPLUS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_MSG_INFO=y
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    CONFIG_DEBUG_THREAD_INFO=y
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Logging
    CONFIG_LOG=y
    # CONFIG_LOG_MODE_DEFERRED is not set
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    CONFIG_LOG_MODE_MINIMAL=y
    # CONFIG_LOG_FRONTEND is not set
    CONFIG_LOG_DEFAULT_MINIMAL=y
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # end of Processing
    # Misc
    CONFIG_LOG_USE_VLA=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # end of Misc
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    # CONFIG_DSP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_MCUMGR is not set
    # CONFIG_HAWKBIT is not set
    # CONFIG_UPDATEHUB is not set
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    CONFIG_NET_BUF_LOG_LEVEL_INF=y
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Portability
    # end of Portability
    # Power Management
    # CONFIG_PM_LOG_LEVEL_OFF is not set
    # CONFIG_PM_LOG_LEVEL_ERR is not set
    # CONFIG_PM_LOG_LEVEL_WRN is not set
    CONFIG_PM_LOG_LEVEL_INF=y
    # CONFIG_PM_LOG_LEVEL_DBG is not set
    CONFIG_PM_LOG_LEVEL=3
    # CONFIG_PM_S2RAM is not set
    CONFIG_PM_POLICY_DEFAULT=y
    # CONFIG_PM_POLICY_CUSTOM is not set
    # end of Power Management
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_SD_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_IMG_MANAGER is not set
    # Random Number Generators
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
    CONFIG_XOSHIRO_RANDOM_GENERATOR=y
    CONFIG_CSPRING_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_SETTINGS is not set
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_RTIO is not set
    # CONFIG_ZBUS is not set
    # end of Sub Systems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_15=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_NATIVE_APPLICATION is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # CONFIG_NO_OPTIMIZATIONS is not set
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    CONFIG_FORTIFY_SOURCE_NONE=y
    # CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_DISASSEMBLY=y
    # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    # CONFIG_LEGACY_INCLUDE_PATH is not set
    zephyr.dts
    /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic nRF52840 DK NRF52840";
    	compatible = "nordic,nrf52840-dk-nrf52840";
    	chosen {
    		zephyr,entropy = &cryptocell;
    		zephyr,flash-controller = &flash_controller;
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,ieee802154 = &ieee802154;
    	aliases {
    		led1 = &led1;
    		led3 = &led3;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led1 = &led1;
    		mcuboot-button0 = &button0;
    		mcuboot-led1 = &led1;
    		watchdog0 = &wdt0;
    		led0 = &led0;
    		led2 = &led2;
    	soc {
    		compatible = "nordic,nRF52840-QIAA", "nordic,nRF52840", "nordic,nRF52", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v7m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv7m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		ficr: ficr@10000000 {
    			compatible = "nordic,nrf-ficr";
    			reg = < 0x10000000 0x1000 >;
    			status = "okay";
    		uicr: uicr@10001000 {
    			compatible = "nordic,nrf-uicr";
    			reg = < 0x10001000 0x1000 >;
    			status = "okay";
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x40000 >;
    		clock: clock@40000000 {
    			compatible = "nordic,nrf-clock";
    			reg = < 0x40000000 0x1000 >;
    			interrupts = < 0x0 0x1 >;
    			status = "okay";
    		power: power@40000000 {
    			compatible = "nordic,nrf-power";
    			status = "okay";
    		radio: radio@40001000 {
    			compatible = "nordic,nrf-radio";
    			reg = < 0x40001000 0x1000 >;
    			interrupts = < 0x1 0x1 >;
    			status = "okay";
    			ieee802154-supported;
    			ble-2mbps-supported;
    			ble-coded-phy-supported;
    			tx-high-power-supported;
    			ieee802154: ieee802154 {
    				compatible = "nordic,nrf-ieee802154";
    				status = "okay";
    		uart0: uart@40002000 {
    			reg = < 0x40002000 0x1000 >;
    			interrupts = < 0x2 0x1 >;
    			status = "okay";
    			current-speed = < 0x1c200 >;
    			pinctrl-0 = < &uart0_default >;
    			pinctrl-1 = < &uart0_sleep >;
    		nfct: nfct@40005000 {
    			compatible = "nordic,nrf-nfct";
    			reg = < 0x40005000 0x1000 >;
    			interrupts = < 0x5 0x1 >;
    		gpiote: gpiote@40006000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x40006000 0x1000 >;
    			interrupts = < 0x6 0x5 >;
    			status = "okay";
    		timer0: timer@40008000 {
    			compatible = "nordic,nrf-timer";
    			status = "okay";
    			reg = < 0x40008000 0x1000 >;
    			cc-num = < 0x4 >;
    			interrupts = < 0x8 0x1 >;
    			prescaler = < 0x0 >;
    		timer1: timer@40009000 {
    			status = "okay";
    			reg = < 0x40009000 0x1000 >;
    			cc-num = < 0x4 >;
    			interrupts = < 0x9 0x1 >;
    		timer2: timer@4000a000 {
    			status = "okay";
    			reg = < 0x4000a000 0x1000 >;
    			cc-num = < 0x4 >;
    			interrupts = < 0xa 0x1 >;
    			phandle = < 0x4 >;
    		rtc0: rtc@4000b000 {
    			compatible = "nordic,nrf-rtc";
    			reg = < 0x4000b000 0x1000 >;
    			cc-num = < 0x3 >;
    			interrupts = < 0xb 0x1 >;
    			status = "okay";
    			clock-frequency = < 0x8000 >;
    			prescaler = < 0x1 >;
    		temp: temp@4000c000 {
    			compatible = "nordic,nrf-temp";
    			reg = < 0x4000c000 0x1000 >;
    			interrupts = < 0xc 0x1 >;
    			status = "okay";
    		rng: random@4000d000 {
    			compatible = "nordic,nrf-rng";
    			reg = < 0x4000d000 0x1000 >;
    			interrupts = < 0xd 0x1 >;
    			status = "okay";
    		ecb: ecb@4000e000 {
    			compatible = "nordic,nrf-ecb";
    			reg = < 0x4000e000 0x1000 >;
    			interrupts = < 0xe 0x1 >;
    			status = "okay";
    		ccm: ccm@4000f000 {
    			compatible = "nordic,nrf-ccm";
    			reg = < 0x4000f000 0x1000 >;
    			interrupts = < 0xf 0x1 >;
    			length-field-length-8-bits;
    			status = "okay";
    		wdt: wdt0: watchdog@40010000 {
    			compatible = "nordic,nrf-wdt";
    			reg = < 0x40010000 0x1000 >;
    			interrupts = < 0x10 0x1 >;
    			status = "okay";
    		rtc1: rtc@40011000 {
    			reg = < 0x40011000 0x1000 >;
    			cc-num = < 0x4 >;
    			interrupts = < 0x11 0x1 >;
    			status = "okay";
    		qdec: qdec0: qdec@40012000 {
    			compatible = "nordic,nrf-qdec";
    			reg = < 0x40012000 0x1000 >;
    			interrupts = < 0x12 0x1 >;
    		comp: comparator@40013000 {
    			compatible = "nordic,nrf-comp";
    			reg = < 0x40013000 0x1000 >;
    			interrupts = < 0x13 0x1 >;
    			#io-channel-cells = < 0x1 >;
    		egu0: swi0: egu@40014000 {
    			compatible = "nordic,nrf-egu", "nordic,nrf-swi";
    			reg = < 0x40014000 0x1000 >;
    			interrupts = < 0x14 0x1 >;
    			status = "okay";
    		egu1: swi1: egu@40015000 {
    			reg = < 0x40015000 0x1000 >;
    			interrupts = < 0x15 0x1 >;
    			status = "okay";
    		egu2: swi2: egu@40016000 {
    			reg = < 0x40016000 0x1000 >;
    			interrupts = < 0x16 0x1 >;
    			status = "okay";
    		egu3: swi3: egu@40017000 {
    			reg = < 0x40017000 0x1000 >;
    			interrupts = < 0x17 0x1 >;
    			status = "okay";
    		egu4: swi4: egu@40018000 {
    			reg = < 0x40018000 0x1000 >;
    			interrupts = < 0x18 0x1 >;
    			status = "okay";
    		egu5: swi5: egu@40019000 {
    			reg = < 0x40019000 0x1000 >;
    			interrupts = < 0x19 0x1 >;
    			status = "okay";
    		timer3: timer@4001a000 {
    			status = "okay";
    			reg = < 0x4001a000 0x1000 >;
    			cc-num = < 0x6 >;
    			interrupts = < 0x1a 0x1 >;
    		timer4: timer@4001b000 {
    			status = "okay";
    			reg = < 0x4001b000 0x1000 >;
    			cc-num = < 0x6 >;
    			interrupts = < 0x1b 0x1 >;
    		pwm0: pwm@4001c000 {
    			compatible = "nordic,nrf-pwm";
    			reg = < 0x4001c000 0x1000 >;
    			interrupts = < 0x1c 0x1 >;
    			#pwm-cells = < 0x3 >;
    			phandle = < 0x7 >;
    		pdm0: pdm@4001d000 {
    			compatible = "nordic,nrf-pdm";
    			reg = < 0x4001d000 0x1000 >;
    			interrupts = < 0x1d 0x1 >;
    		acl: acl@4001e000 {
    			compatible = "nordic,nrf-acl";
    			reg = < 0x4001e000 0x1000 >;
    			status = "okay";
    		flash_controller: flash-controller@4001e000 {
    			compatible = "nordic,nrf52-flash-controller";
    			partial-erase;
    			flash0: flash@0 {
    				compatible = "soc-nv-flash";
    				erase-block-size = < 0x1000 >;
    				write-block-size = < 0x4 >;
    				reg = < 0x0 0x100000 >;
    				partitions {
    					boot_partition: partition@0 {
    						label = "mcuboot";
    						reg = < 0x0 0xc000 >;
    					slot0_partition: partition@c000 {
    						label = "image-0";
    						reg = < 0xc000 0x67000 >;
    					slot1_partition: partition@73000 {
    						label = "image-1";
    						reg = < 0x73000 0x67000 >;
    					scratch_partition: partition@da000 {
    						label = "image-scratch";
    						reg = < 0xda000 0x1e000 >;
    					storage_partition: partition@f8000 {
    						label = "storage";
    						reg = < 0xf8000 0x8000 >;
    		ppi: ppi@4001f000 {
    			compatible = "nordic,nrf-ppi";
    			reg = < 0x4001f000 0x1000 >;
    			status = "okay";
    		mwu: mwu@40020000 {
    			compatible = "nordic,nrf-mwu";
    			reg = < 0x40020000 0x1000 >;
    			status = "okay";
    		pwm1: pwm@40021000 {
    			reg = < 0x40021000 0x1000 >;
    			interrupts = < 0x21 0x1 >;
    		pwm2: pwm@40022000 {
    			reg = < 0x40022000 0x1000 >;
    			interrupts = < 0x22 0x1 >;
    		rtc2: rtc@40024000 {
    			reg = < 0x40024000 0x1000 >;
    			cc-num = < 0x4 >;
    			interrupts = < 0x24 0x1 >;
    			status = "okay";
    		i2s0: i2s@40025000 {
    			compatible = "nordic,nrf-i2s";
    			#size-cells = < 0x0 >;
    			reg = < 0x40025000 0x1000 >;
    			interrupts = < 0x25 0x1 >;
    		usbd: zephyr_udc0: usbd@40027000 {
    			compatible = "nordic,nrf-usbd";
    			reg = < 0x40027000 0x1000 >;
    			interrupts = < 0x27 0x1 >;
    			num-bidir-endpoints = < 0x1 >;
    			num-in-endpoints = < 0x7 >;
    			num-out-endpoints = < 0x7 >;
    			num-isoin-endpoints = < 0x1 >;
    			num-isoout-endpoints = < 0x1 >;
    			status = "okay";
    		pwm3: pwm@4002d000 {
    			reg = < 0x4002d000 0x1000 >;
    			interrupts = < 0x2d 0x1 >;
    		gpio0: gpio@50000000 {
    			compatible = "nordic,nrf-gpio";
    			gpio-controller;
    			reg = < 0x50000000 0x200 0x50000500 0x300 >;
    			#gpio-cells = < 0x2 >;
    			status = "okay";
    			port = < 0x0 >;
    			phandle = < 0x5 >;
    		gpio1: gpio@50000300 {
    			gpio-controller;
    			reg = < 0x50000300 0x200 0x50000800 0x300 >;
    			ngpios = < 0x10 >;
    			status = "okay";
    			port = < 0x1 >;
    			phandle = < 0x6 >;
    		cryptocell: crypto@5002a000 {
    			compatible = "nordic,nrf-cc310";
    			reg = < 0x5002a000 0x1000 >;
    			status = "okay";
    			cryptocell310: crypto@5002b000 {
    				compatible = "arm,cryptocell-310";
    				reg = < 0x5002b000 0x1000 >;
    				interrupts = < 0x2a 0x1 >;
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl";
    		uart0_default: uart0_default {
    			phandle = < 0x2 >;
    			group1 {
    				psels = < 0x22 >, < 0x20005 >;
    			group2 {
    				psels = < 0x10021 >, < 0x30007 >;
    				bias-pull-up;
    		uart0_sleep: uart0_sleep {
    			phandle = < 0x3 >;
    			group1 {
    				psels = < 0x22 >, < 0x10021 >, < 0x20005 >, < 0x30007 >;
    				low-power-enable;
    		uart1_default: uart1_default {
    			group1 {
    				psels = < 0x10021 >;
    				bias-pull-up;
    			group2 {
    				psels = < 0x22 >;
    		uart1_sleep: uart1_sleep {
    			group1 {
    				psels = < 0x10021 >, < 0x22 >;
    				low-power-enable;
    		i2c0_default: i2c0_default {
    			group1 {
    				psels = < 0xc001a >, < 0xb001b >;
    		i2c0_sleep: i2c0_sleep {
    			group1 {
    				low-power-enable;
    		i2c1_default: i2c1_default {
    			group1 {
    				psels = < 0xc001e >, < 0xb001f >;
    		i2c1_sleep: i2c1_sleep {
    			group1 {
    				low-power-enable;
    		pwm0_default: pwm0_default {
    		pwm0_sleep: pwm0_sleep {
    		spi0_default: spi0_default {
    			group1 {
    				psels = < 0x4001b >, < 0x5001a >, < 0x6001d >;
    		spi0_sleep: spi0_sleep {
    			group1 {
    				low-power-enable;
    		spi1_default: spi1_default {
    			group1 {
    				psels = < 0x4001f >, < 0x5001e >, < 0x60028 >;
    		spi1_sleep: spi1_sleep {
    			group1 {
    				low-power-enable;
    		spi2_default: spi2_default {
    			group1 {
    				psels = < 0x40013 >, < 0x50014 >, < 0x60015 >;
    		spi2_sleep: spi2_sleep {
    			group1 {
    				low-power-enable;
    		qspi_default: qspi_default {
    			group1 {
    				psels = < 0x1d0013 >, < 0x1f0014 >, < 0x200015 >, < 0x210016 >, < 0x220017 >, < 0x1e0011 >;
    		qspi_sleep: qspi_sleep {
    			group1 {
    				psels = < 0x1d0013 >, < 0x1f0014 >, < 0x200015 >, < 0x210016 >, < 0x220017 >;
    				low-power-enable;
    			group2 {
    				psels = < 0x1e0011 >;
    				low-power-enable;
    				bias-pull-up;
    		spi3_default: spi3_default {
    			group1 {
    				psels = < 0x4002f >, < 0x6002e >, < 0x5002d >;
    		spi3_sleep: spi3_sleep {
    			group1 {
    				low-power-enable;
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy";
    		status = "okay";
    	cpus {
    		cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m4f";
    			reg = < 0x0 >;
    			itm: itm@e0000000 {
    				compatible = "arm,armv7m-itm";
    				reg = < 0xe0000000 0x1000 >;
    				swo-ref-frequency = < 0x1e84800 >;
    	sw_pwm: sw-pwm {
    		compatible = "nordic,nrf-sw-pwm";
    		generator = < &timer2 >;
    		clock-prescaler = < 0x0 >;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = < &gpio0 0x8 0x0 >;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = < &gpio1 0x0 0x1 >;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = < &gpio0 0x6 0x0 >;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = < &gpio0 0xd 0x1 >;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = < &pwm0 0x0 0x1312d00 0x1 >;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = < &gpio0 0xb 0x11 >;
    			label = "Push button switch 0";
    		button1: button_1 {
    			gpios = < &gpio0 0xe 0x11 >;
    			label = "Push button switch 1";
    		button2: button_2 {
    			gpios = < &gpio0 0xf 0x11 >;
    			label = "Push button switch 2";
    		button3: button_3 {
    			gpios = < &gpio0 0x10 0x11 >;
    			label = "Push button switch 3";
    	nrf_radio_fem: skyFem {
    		compatible = "skyworks,sky66112-11", "generic-fem-two-ctrl-pins";
    		ctx-gpios = < &gpio0 0x11 0x0 >;
    		crx-gpios = < &gpio0 0x13 0x0 >;
    		tx-gain-db = < 0x16 >;
    Try to update the overlay as
        nrf_radio_fem: my_fem {
            ctx-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
            crx-gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
            cps-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
            chl-gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
    &radio {
        fem = <&nrf_radio_fem>;
    The deviation of distance measurements must be expected to increase with distance, as there will be more interference from more sources the further away you get. The range you'll be able to achieve and the quality of the signal is mostly dependent on the environment you're deploying the devices, and testing should be done in open environments to get reliable test results.
    -Amanda H.
  • Hi, I applied the changes you suggested but still no change in current consumption. When I load the Fanstel supplied BT840X hex file for BT range testing I get peaks of current consumption of around 250mA. I only get a consumption of around 35mA with my code.
  • I can force the PA on by setting the GPIO and I do get the 250mA consumption but as this forces the PA on it does not go to receive mode with the LNA so the link only has minimal range. When I alter the PA and LNA pins to something I can scope I do not see the pins toggling which is what I think I should expect.
    The MPSL fem driver can control a skyworks fem, but it only controls the CTX and CRX pins. The CPS and CHL must be handled manually by the application. I assume you want 20dBm output power, for this, you need to set the CHL pin high and the CPS pin low.  The fem driver will automatically set the output power from the SoC to get the desired final output power(after the PA), the default will be 0dBm, so the output power of the SoC will be turned down so that the final output power is 0dBm. To change this you need to change the config:
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=20
    There is also an issue in 2.3.0 and older that causes the output power to not be set correctly when in a connection. Please update to at least 2.4.0 as the issue has been fixed in this version.
    -Amanda H.
