nrf_gpio_read_pin doesn't seem to be working
I am trying to read if an input is 0 or 1 but for some reason it takes the first one its offered and then it does not change anymore.
   nrf_gpio_cfg_output(24);
   nrf_gpio_cfg_input(26, NRF_GPIO_PIN_NOPULL);
   for(;;)
      if(nrf_gpio_pin_read(26) == 1)
         nrf_gpio_pin_toggle(24);
I've also tried to read the input into a variable like this in a while/for loop:
int value = nrf_gpio_pin_read(26);
But for some reason it keeps sticking to either the first value I stored in it or the direction of the pull up/down. I'm a bit at a loss at what to try as the problem seems wierd. I have tried multiple DKs and pins to ensure it wasn't faulty hardware.
EDIT: What i want to be able to do is make something happen depending on if the input is high or low at the moment I read this. It is connected to a comparator that puts either a digital 1 or 0 value on the pin I am using as input.
EDIT: After I thought it worked last time with the code that uses a button and led on the DK I gave the comperator another go but it starts acting up again that it sets the nrf_gpio_pin_read only once in a while/for loop. When I use the code below in combination with an external comperator and I hook the comperator up to a PSU it waits for the condition while(nrf_gpio_pin_read(26) > 0) once afterwards even if I lower the voltage so this is no longer true the blinky light remains.
nrf_gpio_cfg_output(21);
	nrf_gpio_pin_write(21, 0);
	nrf_delay_ms(5000);
	for(;;)
			nrf_gpio_pin_toggle(21);
			nrf_delay_ms(500);
  • What is the supply voltage (VDD)? In the last code snipped of your updated post you do not configure the input pin (26) as a input, and if you do not, nrf_gpio_pin_read() will not return a valid value. Note that in general you would want do do this differently, using GPIOTE so that you get events instead of polling the pin. For a real product that makes much more sense.
  • The VDD is 3.3V and I forgot to post the pin declaration as I declared the IO above main. In the final product the GPIOTE/PPI will be used to handle this but at the moment I am prototyping hardware and found it strange that some pins do not work as input on two boards and some pins do and was unable to find why in the product specifications or other documents.
  • What do you mean you declared it above main? Is it called somewhere? Can you post the complete code?
  • Does the updated code you have compile without warnings? It is not legal to put statements outside a function body. Move your calls to nrf_gpio_cfg_output() and nrf_gpio_cfg_input() inside main(), and see if that solves the problem.
  • Made a mistake while updating the code it was actually in the main code but wasn't at my computer while typing but as I can get the nrf_gpio_pin_read() to work on other pins than the one I was using originally I recon the question is resolved as the problem does not seem to be with the function but rather with the pins I was using. If more problems show up around these pins i'll create a new question. Thank you for your time and help.
