Cannot store a key in the psa key storage (err -134)
I am attempting to store a pre-generated key in the psa key store using the psa API. I have taken the nrf->samples->crypto->hmac and nrf->samples->crypto->persistent_key_usage samples as a base for my implementation.
In my prj.conf file I declare:
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
CONFIG_PSA_NATIVE_ITS=y
And I try to store the key using the following code:
    psa_status_t status;
    psa_key_attributes_t key_attributes = PSA_KEY_ATTRIBUTES_INIT;
    psa_key_id_t  key_id;
    status = psa_crypto_init();
    if(status)
        LOG_ERR("psa_crypto_init failed - status %d", status);
    psa_set_key_lifetime(&key_attributes, PSA_KEY_LIFETIME_PERSISTENT);
    psa_set_key_id(&key_attributes, HMAC_KEY_TAG);
    psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_SIGN_HASH);
    psa_set_key_algorithm(&key_attributes, PSA_ALG_HMAC(PSA_ALG_SHA_256));
    psa_set_key_type(&key_attributes, PSA_KEY_TYPE_HMAC);
    psa_set_key_bits(&key_attributes, (strlen(key) * 8));
    status = psa_import_key(&key_attributes, key, strlen(key), &key_id);
    if(status)
        LOG_ERR("psa_import_key failed - status %d", status);
Unfortunately the call to psa_import_key fails with the return status -134 - suggesting that the operation or some parameter is not supported.
I use the same configuration as in the samples, BUT the CONFIG_PSA_NATIVE_ITS configuration shows a warning that a dependency is missing: !BUILD_WITH_TFM. Which is because I am building for the _ns target of my custom board definition (based on an nrf9160 board sample from the SDK), which has TFM enabled by default.
How would I go about making this work in combination with TFM?
Target: nrf9160 (ns)
SDK version: 2.4.0
Bonus question:
I want this key to have the same lifetime as the device. With the PSA_KEY_PERSISTENCE_READ_ONLY option, will the key be preserved on firmware updates? If not, how do I get the key to be more persistent?
Edit:
I didn’t notice this before, as there is no warning issued for this. Although I have configured CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y (seems to also be a dependency for key storage) in my prj.conf file, it is somehow set to n in the build.
For the Mbed TLS implementation I use the Nordic provided security backend library, and have the “Generate mbed TLS config files option enabled” (no custom Mbed TLS config file)
  • Hi Stefan,
    It seems I set the configuration to:
    CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    In combination with the code snippet in my original post.
    For us the tfm_secure partition is also >200kB. I have not looked into decreasing the size for this partition because "It works! Don't touch it!".
  • Hi luc_eac,
    thank you for your reply.
    Mmmh, if you want to build a real world application (which means you have to support FOTA) and you need more features than included in CONFIG_TFM_PROFILE_TYPE_MINIMAL, then the space left for the actual application gets pretty tiny... If you don't have an external Flash available (as it is expected in the Nordic provided applications).
