ASYNC uart and UART_RX_RDY timeout
I saw some similar question, but none is what I am experiencing.
I notice some weird behavior while testing DMA mode, so I made a simple setup:
I set the DMA buffer to be 100 bytes, and a timeout of 100ms, and a custom callback:
uart_callback_set(dev_uart, app_uart_async_callback, NULL);
uart_rx_enable(dev_uart, uart_double_buffer[0], UART_BUF_SIZE, UART_RX_TIMEOUT_MS);
Then on PC side, i send message of 10 bytes, this is to make sure there is no buffer switch, only timeout from UART_RX_RDY, to avoid any possible mistake with buffer management.
Baudrate is 921600
WHAT DO I EXPECT:
100ms after i sent the message, the callback app_uart_async_callback() get called with event data rx.buf containing my 10 byte message, rx.offset to be 0, and rx.len of 10
If i send another message, the same as above, only difference is the rx.offset is now 10.
And so on until the buffer is full and all the required callback to change buffer get called
WHAT IS HAPPENING:
while sending the message from pc, the callback app_uart_async_callback() get called with event data rx.buf containing ONLY X bytes, rx.offset to be 0, and rx.len of X, where X is between 1 and 10; the TIMEOUT is not respected at all!
What is worse is that i do NOT get a second callback with the remaining data!
Now, at this point, if i send an extra message lets say 1 bytes, the callback is called and all, with rx.len = 1, but as result i see the OLD data that was not served!
MY CONCLUSION:
- according to docs, the TIMEOUT should start at the END of the last bytes, as it is inactivity, this is NOT happening
- even if timeout is counting since the first message is received, ad 921600 baud i should be able to receive 9216 bytes before timeout
- clearly something is wrong in the way the timeout for UART_RX_RDY or the event rx.len is calculated!
- this lead to possibility where data is received, and my application has NO WAY to know it has been
- UART_RX_BUF_REQUEST and RELEASED seems to work properly and get called at the right time, with the correct amount of data in rx.len. SEEMS because due to the delay output, is a bit difficult to notice if data is missing without a proper automated test.
    yes, those differences are desired.
    This is a minimal example to reproduce and debug the issue, i did not want to add anything more than necessary.
    I need to be able to saturate the 921600 baudrate, so i had to get rid of the interrupt implementation and switch to a DMA based. I managed to reach full write speed, but when i started to test the input speed, i notice the test failing and the issue was the weird timing.
    Then i started to remove stuff, thinking it may be some issue with timing or concurrency..
    Until i notice the issue is coming from the callback.
    Note that the data is missing already in the callback event, so even if TX would misbehave, the issue is present; the TX output is just a nice to have
  • I understand. I am sorry for the late reply. I have been trying to clear up my backlog, because I will be out of office for a while.
    Try adding RTT logging to your project, so that you can look into what the functions in the UART_TX_DONE event returns, and whether they work as you expected. I didn't manage to understand the logic flow during my last take on this ticket.
    Check whether bytes_claimed have the correct value when UART_TX_DONE triggers, and whether k_sem_give(&tx_done) is called when it shouldn't be (if bytes_claimed != 0).
    Since I will be out of office, I suggest you create a new ticket for follow up questions. You can refer to this one for background, but please upload your application there, if you changed anything at this point, and try to give a summary of your current status.
    Edvin
  • Hi, long time, new update.
    Im testing with toolchain 2.4.2 and seems better but still some issues.
    Output and code from my test follow.
    First column is time in seconds, if data is send/received and what is sent/received (received data has b'' around them as i print the raw bytes, to see if i get weird non-visible ascii bytes, for example \n is an actual line feed)
    The test send a message every 2 seconds, the nrf is set to 100ms timeout, and send back data immediately.
    1 byte is systematically not reported as received (tested with different length of data, seems always 1 is "lost"), the buffer swap happen correctly at 100 bytes, and all no data is lost.
    1697713032.61: sent: 0123456789
    1697713032.811: recv: b'INF: got 9 bytes\nDATA: -012345678-\n'
    1697713034.618: sent: 0123456789
    1697713034.818: recv: b'INF: got 9 bytes\nDATA: -901234567-\n'
    1697713036.624: sent: 0123456789
    1697713036.825: recv: b'INF: got 9 bytes\nDATA: -890123456-\n'
    1697713038.631: sent: 0123456789
    1697713038.832: recv: b'INF: got 9 bytes\nDATA: -789012345-\n'
    1697713040.638: sent: 0123456789
    1697713040.839: recv: b'INF: got 9 bytes\nDATA: -678901234-\n'
    1697713042.645: sent: 0123456789
    1697713042.846: recv: b'INF: got 9 bytes\nDATA: -567890123-\n'
    1697713044.652: sent: 0123456789
    1697713044.853: recv: b'INF: got 9 bytes\nDATA: -456789012-\n'
    1697713046.66: sent: 0123456789
    1697713046.861: recv: b'INF: got 9 bytes\nDATA: -345678901-\n'
    1697713048.667: sent: 0123456789
    1697713048.868: recv: b'INF: got 9 bytes\nDATA: -234567890-\n'
    1697713050.674: sent: 0123456789
    1697713050.774: recv: b'INF: detected end of buffer for 19 bytes\nDATA: -1234567890123456789-\n'
    1697713052.681: sent: 0123456789
    1697713052.882: recv: b'INF: got 9 bytes\nDATA: -012345678-\n'
    1697713054.688: sent: 0123456789
    1697713054.889: recv: b'INF: got 9 bytes\nDATA: -901234567-\n'
    Code python:
    import serial
    import time
    last_write = time.time()
    with serial.Serial('/dev/ttyACM0', 921600, timeout=0.1) as ser:
     while True:
     x = ser.read(100) # read one byte
     if len(x):
     print(f"{round(time.time(), 3)}: recv: {x}")
     if time.time() - last_write >= 2:
     msg = "0123456789ABCDEFGHILMNOPQRSTUVZ"
     print(f"{round(time.time(), 3)}: sent: {msg}")
     ser.write(msg.encode("ascii"))
    print("failed to open serial")
    Code NRF:
    #include <zephyr/types.h>
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/uart.h>
    #include <zephyr/usb/usb_device.h>
    #include <zephyr/device.h>
    #include <soc.h>
    #include <stdio.h>
    #define LOG_MODULE_NAME peripheral_uart
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    uint8_t uart_buffer_rx[100];
    volatile size_t uart_buffer_written = 0;
    volatile size_t uart_buffer_completed = 0;
    volatile bool disabled = true;
    static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
    const int32_t UART_RX_TIMEOUT_US = 1000 * 100; // 100 millisecond timeout
    void app_uart_async_callback(const struct device *uart_dev, struct uart_event *evt, void *user_data) {
     switch (evt->type) {
     case UART_TX_DONE:
     // do nothing
     case UART_RX_RDY:
     uart_buffer_written += evt->data.rx.len;
     case UART_RX_BUF_REQUEST:
     //assign same buffer; basically this is now a circular buffer
     uart_rx_buf_rsp(uart, uart_buffer_rx, sizeof(uart_buffer_rx));
     uart_buffer_completed++;
     case UART_RX_BUF_RELEASED:
     case UART_RX_DISABLED:
     disabled = true;
    static int uart_init(void) {
     int err = 0;
     struct uart_config serial_config;
     uart_config_get(uart, &serial_config);
     uart_configure(uart, &serial_config);
     if (!device_is_ready(uart)) {
     return -ENODEV;
     err |= uart_callback_set(uart, app_uart_async_callback, NULL);
     err |= uart_rx_enable(uart, uart_buffer_rx, sizeof(uart_buffer_rx), UART_RX_TIMEOUT_US);
     disabled = false;
     return err;
    void log(const char *msg, ...) {
     static char s[1000];
     va_list argptr;
     va_start(argptr, msg);
     size_t len = vsnprintf(s, sizeof(s), msg, argptr);
     va_end(argptr);
     uart_tx(uart, s, len, SYS_FOREVER_MS);
     k_sleep(K_MSEC(1)); //92 char
    void error(void) {
     while (true) {
     /* Spin for ever */
     k_sleep(K_MSEC(1000));
    int main(void) {
     int err = 0;
     err = uart_init();
     if (err) {
     log("ERR: uart_init");
     error();
     log("started!");
     size_t last_uart_buffer_written = uart_buffer_written;
     size_t last_uart_buffer_completed = uart_buffer_completed;
     for (;;) {
     if (disabled){
     if (err == 0)
     disabled = false;
     log("ERR: Serial re-enabled");
     size_t number_of_oveflow = uart_buffer_completed - last_uart_buffer_completed;
     switch (number_of_oveflow){
     log("ERR: TOO MANY OVERFLOW FOR %d TIMES", number_of_oveflow);
     // we want to fallthrough to read whatever we got
     case 1:
     // now we print remaining buffer
     size_t remaining_data = sizeof(uart_buffer_rx) - last_uart_buffer_written;
     log("INF: detected end of buffer for %d bytes\n", remaining_data);
     log("DATA: -%.*s-\n", remaining_data, uart_buffer_rx+last_uart_buffer_written);
     // now reset buffer counters
     last_uart_buffer_completed += number_of_oveflow;
     last_uart_buffer_written = 0;
     // we want to fallthrough to read the initial data
     case 0:
     size_t available = uart_buffer_written - last_uart_buffer_written;
     if (!available){
     log("INF: got %d bytes\n", available);
     log("DATA: -%.*s-\n", available, uart_buffer_rx+last_uart_buffer_written);
     last_uart_buffer_written += available;
     k_sleep(K_MSEC(10));
    Edvin is our of office so the case has been re-assigned. We will look into it and get back to you. Please let us know if you have had any updates on your end in the meantime.
    Br,
    Einar
    From your log it seems that the single byte is not lost, as it is included at the start of the following message.
    Could you try debugging and check where this byte is when the RX RDY event is triggered in your event handler? Check the contents of the RX buffer and whether data.rx.len matches the number of bytes in the RX buffer. A logic trace on the UART lines could also be insightful.
