Running CAN-BUS Sample with different shield (NRF52840DK & Seeed CAN BUS Shield V2.0)
Hi All,
Im very new to this how firmware space and would love some help.
Currently i have a NRF52840 DK Board with a Seeed Canbus shield. (CAN-BUS Shield V2.0 | Seeed Studio Wiki)
From what i have read is very similar to the DFROBOT CanBus Shield. (Only changing the default pinout for the CS from D10 to D9)
- I have been able to succesfully comple and flash the firmware but i get the following error :
Error starting CAN controller [-5]
I have tried modifying the dfrobot_can_bus_v2_0.overlay to make it work with my seeed shield.  (changing the CS-GPIOS to 15 (D9) instead of 16 (D10).
The error remains the same, and i dont really know how to get a little bit more information to progress on this.
Im trying to run this sample: zephyr/samples/drivers/can/counter at main · zephyrproject-rtos/zephyr (github.com)
    Thanks a lot for your help. Indeed i didnt think that would a good idea as well.
    In the mean time i have ordered one of the two shields that are specified on the sample. (the keys one).
    and ill report back if that one works as intended and its a restriction of the Seeed one given the voltage lines or if something else is up.
    Thanks for the help.
  • Hi Efrain
    Sounds good, I will wait for your report then. I am guessing you will have more success with the supported shields.
    Good luck Slight smile
    Best regards
    Torbjørn
  • Hi!
    So i got my new shield. i got the Keystudio_ks0411. - KS0411 keyestudio CAN-BUS Shield - Keyestudio Wiki
    But... im getting exactly the same answer than the Seeed shield.
    uart:~$ Error starting CAN control--- 334 messages dropped ---
    [00:00:00.528,076] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    --- 78 messages dropped ---
    [00:00:00.528,259] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20004438 - rx_bufs 0x20004440 - 1
    [00:00:00.528,289] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20004448 (2), current_rx 0x20004458 (2), tx buf/len 0x20004434/2, rx buf/len (nil)/2
    [00:00:00.528,350] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/1
    [00:00:00.528,381] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x2000447f/1
    [00:00:00.528,411] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.528,442] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0
    [00:00:00.528,472] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.528,625] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20004438 - rx_bufs 0x20004440 - 1
    [00:00:00.528,656] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20004448 (2), current_rx 0x20004458 (2), tx buf/len 0x20004434/2, rx buf/len (nil)/2
    [00:00:00.528,717] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/1
    [00:00:00.528,747] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x2000447f/1
    [00:00:00.528,778] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.528,808] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0
    [00:00:00.528,839] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.529,022] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20004438 - rx_bufs 0x20004440 - 1
    [00:00:00.529,052] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20004448 (2), current_rx 0x20004458 (2), tx buf/len 0x20004434/2, rx buf/len (nil)/2
    [00:00:00.529,113] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/1
    [00:00:00.529,144] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x2000447f/1
    [00:00:00.529,174] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.529,205] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0
    [00:00:00.529,235] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.529,266] <err> can_mcp2515: Timeout trying to set MCP2515 operation mode
    [00:00:00.529,296] <err> can_mcp2515: Failed to set the mode [-5]
  • Hi Efrain
    If there is no working communication between the nRF device and the MCP2515 it makes sense that the log output would be the same. It seems the new shield is also using 5V supply.
    I think it is hard to debug this further without the ability to scope the SPI lines, and some way of adjusting the supply voltage on the CAN shield in order to be compatible with the nRF device.
    Like I said I am happy to order a shield and do some testing on my own, but this will take some time.
    Best regards
    Torbjørn
  • hI Torbjørn
    I think it could be awsome if you get a can shield (please le me know which one so that i can order the same :) ).
    Now with that said i have made some "progress"
    Since there was soo much code in the "sample" i cut it down to a simpler one:
    //Pretty standar code to recieve frames and send an OBD2 CanFrame
     * Copyright (c)
    #include <zephyr/drivers/can.h>
    LOG_MODULE_REGISTER(main);
    void tx_callback(const struct device *dev, int error, void *user_data)
    	char *sender = (char *)user_data;
    	if (error != 0) {
    		LOG_ERR("Sending failed [%d] - Sender: %s", error, sender);
    int send_function(const struct device *can_dev)
    	struct can_frame frame = {.flags = 0, .id = 0x7df, .dlc = 8, .data = {0x02, 0x01, 0x0c}};
    	// frame.data[0] = 1;
    	// frame.data[1] = 2;
    	return can_send(can_dev, &frame, K_MSEC(2000), tx_callback, "Sender 1");
    void rx_callback_function(const struct device *dev, struct can_frame *frame, void *user_data)
    	LOG_INF("ID: 0x%x\n", frame->id);
    	printk("Received CAN frame\nSender: %s\n", sender);
    	printk("ID: 0x%x\n", frame->id);
    	printk("DLC: %d\n", frame->dlc);
    	printk("Data: ");
    	printk("0x%x ", frame->data[0]);
    	printk("0x%x ", frame->data[1]);
    	printk("0x%x ", frame->data[2]);
    	printk("0x%x ", frame->data[3]);
    	printk("0x%x ", frame->data[4]);
    	printk("0x%x ", frame->data[5]);
    	printk("0x%x ", frame->data[6]);
    	printk("0x%x ", frame->data[7]);
    	printk("\n");
    	LOG_INF("CanBus-OBD2 samplev11");
    	int ret;
    	k_sleep(K_MSEC(8000));
    	const struct device *const can_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_canbus));
    	LOG_INF("Asserting device ready.");
    	if (!device_is_ready(can_dev)) {
    		LOG_ERR("CAN: Device %s not ready.", can_dev->name);
    		return 0;
    	LOG_INF("CAN: Device %s ready.", can_dev->name);
    	LOG_INF("Enabling MODE NORMAL.");
    	ret = can_set_mode(can_dev, CAN_MODE_NORMAL);
    	if (ret != 0) {
    		LOG_ERR("Error setting CAN mode [%d]", ret);
    		return 0;
    	LOG_INF("MODE NORMAL Enabled.");
    	LOG_INF("Trying to set bitrate.");
    	ret = can_set_bitrate(can_dev, 500000);
    	if (ret != 0) {
    		LOG_ERR("Error setting CAN bitrate [%d]", ret);
    		return 0;
    	LOG_INF("Set bitrate.");
    	LOG_INF("Trying to start CAN.");
    	ret = can_stop(can_dev);
    	if (ret != 0) {
    		LOG_ERR("Error stop CAN controller [%d]", ret);
    		// return 0;
    	LOG_INF("CAN stopped [%d]", ret);
    	LOG_INF("Trying to start can.");
    	ret = can_start(can_dev);
    	if (ret != 0) {
    		LOG_ERR("Error starting CAN controller [%d]", ret);
    		return 0;
    	LOG_INF("CAN started");
    	const struct can_filter my_filter = {
    		.flags = CAN_FILTER_DATA, .id = 0x7E8, .mask = CAN_STD_ID_MASK};
    	int filter_id;
    	char *callback_arg = "Callback argument";
    	filter_id = can_add_rx_filter(can_dev, rx_callback_function, callback_arg, &my_filter);
    	if (filter_id < 0) {
    		LOG_ERR("Unable to add rx filter [%d]", filter_id);
    	printk("Filter ID: %d\n", filter_id);
    	while (1) {
    		LOG_INF("Waiting for CAN frame");
    		k_sleep(K_MSEC(1000));
    		LOG_INF("Sending CAN frame");
    		ret = send_function(can_dev);
    		if (ret != 0) {
    			LOG_ERR("Sending failed [%d]", ret);
    		} else {
    			LOG_INF("CAN frame sent");
    Now (both Shields The "seeed" and the "keystudio" seem to "boot up"
    And i get the following log:
    [00:00:00.251,617] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000aca8 - rx_bufs (nil) - 1
    [00:00:00.251,617] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac9c (1), current_rx (nil) (0), tx buf/len 0x2000ac98/1, rx buf/len (nil)/0
    [00:00:00.251,678] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.251,708] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.251,800] <dbg> can_mcp2515: mcp2515_init: Presc: 4, BS1: 7, BS2: 2
    [00:00:00.251,800] <dbg> can_mcp2515: mcp2515_init: Sample-point err : 0
    [00:00:00.252,044] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac48 - rx_bufs (nil) - 1
    [00:00:00.252,075] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac50 (2), current_rx (nil) (0), tx buf/len 0x2000ac40/2, rx buf/len (nil)/0
    [00:00:00.252,136] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x2000ac44/4
    [00:00:00.252,197] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.252,197] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.252,227] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac30 - rx_bufs (nil) - 1
    [00:00:00.252,258] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac28 (1), current_rx (nil) (0), tx buf/len 0x2000ac24/4, rx buf/len (nil)/0
    [00:00:00.252,319] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.252,349] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:00.252,380] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac30 - rx_bufs (nil) - 1
    [00:00:00.252,410] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac28 (1), current_rx (nil) (0), tx buf/len 0x2000ac24/4, rx buf/len (nil)/0
    [00:00:00.252,471] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:00.252,471] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    *** Booting Zephyr OS build v3.3.99-ncs1 ***
    [00:00:00.252,563] <inf> main: CanBus-OBD2 samplev11
    [00:00:08.252,624] <inf> main: Asserting device ready.
    [00:00:08.252,685] <inf> main: CAN: Device can@0 ready.
    [00:00:08.252,685] <inf> main: Enabling MODE NORMAL.
    [00:00:08.252,716] <inf> main: MODE NORMAL Enabled.
    [00:00:08.252,716] <inf> main: Trying to set bitrate.
    [00:00:08.252,746] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac60 - rx_bufs (nil) - 1
    [00:00:08.252,777] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac68 (2), current_rx (nil) (0), tx buf/len 0x2000ac58/2, rx buf/len (nil)/0
    [00:00:08.252,838] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x2000ac5c/4
    [00:00:08.252,899] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:08.252,899] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:08.252,960] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac48 - rx_bufs (nil) - 1
    [00:00:08.252,990] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac40 (1), current_rx (nil) (0), tx buf/len 0x2000ac3c/4, rx buf/len (nil)/0
    [00:00:08.253,051] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:08.253,051] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:08.253,082] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac48 - rx_bufs (nil) - 1
    [00:00:08.253,112] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac40 (1), current_rx (nil) (0), tx buf/len 0x2000ac3c/4, rx buf/len (nil)/0
    [00:00:08.253,173] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:08.253,204] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:08.253,234] <inf> main: Set bitrate.
    [00:00:08.253,234] <inf> main: Trying to start CAN.
    [00:00:08.253,265] <err> main: Error stop CAN controller [-120]
    [00:00:08.253,265] <inf> main: CAN stopped [-120]
    [00:00:08.253,295] <inf> main: Trying to start can.
    [00:00:08.253,295] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac50 - rx_bufs (nil) - 1
    [00:00:08.253,326] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac48 (1), current_rx (nil) (0), tx buf/len 0x2000ac44/4, rx buf/len (nil)/0
    [00:00:08.253,387] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:08.253,417] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:08.253,448] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac20 - rx_bufs 0x2000ac28 - 1
    [00:00:08.253,479] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac30 (2), current_rx 0x2000ac40 (2), tx buf/len 0x2000ac1c/2, rx buf/len (nil)/2
    [00:00:08.253,509] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/1
    [00:00:08.253,540] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x2000ac67/1
    [00:00:08.253,570] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:08.253,570] <dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0
    [00:00:08.253,601] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:08.253,631] <inf> main: CAN started
    Filter ID: 0
    [00:00:08.253,662] <inf> main: Waiting for CAN frame
    [00:00:09.253,753] <inf> main: Sending CAN frame
    [00:00:09.253,814] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac40 - rx_bufs (nil) - 1
    [00:00:09.253,814] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac58 (2), current_rx (nil) (0), tx buf/len 0x2000ac3c/1, rx buf/len (nil)/0
    [00:00:09.253,875] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x2000ac48/13
    [00:00:09.254,028] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:09.254,028] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:09.254,089] <dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x2000ac58 - rx_bufs (nil) - 1
    [00:00:09.254,089] <dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x2000ac40 (1), current_rx (nil) (0), tx buf/len 0x2000ac3c/1, rx buf/len (nil)/0
    [00:00:09.254,150] <dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0
    [00:00:09.254,180] <dbg> spi_nrfx_spim: finish_transaction: Transaction finished with status 0
    [00:00:09.254,211] <inf> main: CAN frame sent
    [00:00:09.254,211] <inf> main: Waiting for CAN frame
    [00:00:10.254,302] <inf> main: Sending CAN frame
    [00:00:12.254,425] <err> main: Sending failed [-11]
    [00:00:12.254,455] <inf> main: Waiting for CAN frame
    [00:00:13.254,608] <inf> main: Sending CAN frame
    [00:00:15.254,699] <err> main: Sending failed [-11]
    [00:00:15.254,730] <inf> main: Waiting for CAN frame
    [00:00:16.254,882] <inf> main: Sending CAN frame
    [00:00:18.254,974] <err> main: Sending failed [-11]
    Any ideas?
