NRF52840 dongle 10 button USB HID with zephyr
Goodday
 I thought this could be good learning curve to get started with Zephyr. Im having some problems with the GPIO.  If I rewrite this code for  3 buttons with  PORT1 (pin 1.10 pin 1.13 and pin 1.15) the code works. But it does not work on PORT 0 with 10 buttons. I presume it may be something with the DTS file that may be configuring the ports for other purposes (SPI/UART/I2C) etc.
1. How do I use PORT 0 in zephyr instead of port 1.
2. is there anything I need to reconfigure in the DTS file to make it work.
Any help appreciated as always
 * Copyright (c) 2016 Open-RnD Sp. z o.o.
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/util.h>
#include <inttypes.h>
#define SLEEP_TIME_MS	1
 * Get button configuration from the devicetree sw0 alias. This is mandatory.
#define SW0_NODE	DT_ALIAS(sw0)
#if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios,
							      {0});
static struct gpio_callback button0_cb_data;
static struct gpio_callback button1_cb_data;
static struct gpio_callback button2_cb_data;
static struct gpio_callback button3_cb_data;
static struct gpio_callback button4_cb_data;
static struct gpio_callback button5_cb_data;
static struct gpio_callback button6_cb_data;
static struct gpio_callback button7_cb_data;
static struct gpio_callback button8_cb_data;
static struct gpio_callback button9_cb_data;
static struct gpio_callback button10_cb_data;
#define BUT_PIN1 13 //port 0
#define BUT_PIN2 15 //port 0
#define BUT_PIN3 17 //port 0
#define BUT_PIN4 20 //port 0
#define BUT_PIN5 24 //port 0
#define BUT_PIN6 02 //port 0
#define BUT_PIN7 9 //port 0
#define BUT_PIN8 10 //port 0
#define BUT_PIN9 29  //port 0
#define BUT_PIN10 31  //port 0
 * The led0 devicetree alias is optional. If present, we'll use it
 * to turn on the LED whenever the button is pressed.
static struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(DT_ALIAS(led0), gpios,
						     {0});
void button_pressed(const struct device *dev, struct gpio_callback *cb,
		    uint32_t pins)
	uint32_t bit_to_pin = 0;
	for (int i = 0; i < 32; i++) {
		if ((pins >> i) == 1) {
			bit_to_pin = i;
	printk("Button %d pressed at %" PRIu32 "\n", bit_to_pin, k_cycle_get_32());
	static bool val;
	val = !val;
	gpio_pin_set_dt(&led, val);
void main(void)
	int ret;
	if (!device_is_ready(button.port)) {
		printk("Error: button device %s is not ready\n",
		       button.port->name);
		return;
	ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
	if (ret != 0) {
		printk("Error %d: failed to configure %s pin %d\n",
		       ret, button.port->name, button.pin);
		return;
	ret = gpio_pin_interrupt_configure_dt(&button, GPIO_INT_EDGE_TO_ACTIVE);
	if (ret != 0) {
		printk("Error %d: failed to configure interrupt on %s pin %d\n",
		return;
	ret = gpio_pin_configure(button.port, BUT_PIN1, GPIO_INPUT | GPIO_PULL_UP);
	printk("ret %d\n", ret);
	ret = gpio_pin_configure(button.port, BUT_PIN2, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN3, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN4, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN5, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN6, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN7, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN8, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN9, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_configure(button.port, BUT_PIN10, GPIO_INPUT | GPIO_PULL_UP);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN1, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN2, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN3, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN4, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN5, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN6, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN7, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN8, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN9, GPIO_INT_EDGE_BOTH);
	ret = gpio_pin_interrupt_configure(button.port, BUT_PIN10, GPIO_INT_EDGE_BOTH);
	gpio_init_callback(&button1_cb_data, button_pressed, BIT(BUT_PIN1));
	ret = gpio_add_callback(button.port, &button1_cb_data);
	gpio_init_callback(&button2_cb_data, button_pressed, BIT(BUT_PIN2));
	ret = gpio_add_callback(button.port, &button2_cb_data);
	gpio_init_callback(&button3_cb_data, button_pressed, BIT(BUT_PIN3));
	ret = gpio_add_callback(button.port, &button3_cb_data);
	gpio_init_callback(&button4_cb_data, button_pressed, BIT(BUT_PIN4));
	ret = gpio_add_callback(button.port, &button4_cb_data);
	gpio_init_callback(&button5_cb_data, button_pressed, BIT(BUT_PIN5));
	ret = gpio_add_callback(button.port, &button5_cb_data);
	gpio_init_callback(&button6_cb_data, button_pressed, BIT(BUT_PIN6));
	ret = gpio_add_callback(button.port, &button6_cb_data);
	gpio_init_callback(&button7_cb_data, button_pressed, BIT(BUT_PIN7));
	ret = gpio_add_callback(button.port, &button7_cb_data);
	gpio_init_callback(&button8_cb_data, button_pressed, BIT(BUT_PIN8));
	ret = gpio_add_callback(button.port, &button8_cb_data);
	gpio_init_callback(&button9_cb_data, button_pressed, BIT(BUT_PIN9));
	ret = gpio_add_callback(button.port, &button9_cb_data);
	gpio_init_callback(&button10_cb_data, button_pressed, BIT(BUT_PIN10));
	ret = gpio_add_callback(button.port, &button10_cb_data);
	gpio_init_callback(&button0_cb_data, button_pressed, BIT(button.pin));
	gpio_add_callback(button.port, &button0_cb_data);
	printk("Set up button at %s pin %d\n", button.port->name, button.pin);
	if (led.port && !device_is_ready(led.port)) {
		printk("Error %d: LED device %s is not ready; ignoring it\n",
		       ret, led.port->name);
		led.port = NULL;
	if (led.port) {
		ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT);
		if (ret != 0) {
			printk("Error %d: failed to configure LED device %s pin %d\n",
			       ret, led.port->name, led.pin);
			led.port = NULL;
		} else {
			printk("Set up LED at %s pin %d\n", led.port->name, led.pin);
	printk("Press the button\n");
