Matter Over thread [chip-tool error]
I want to test Matter over Thread, with the Matter: Light Bulb example from nRF Connect. The Border Router and controller are on the same device RPi 3 Model B+.
I've referred https://www.youtube.com/watch?v=9Ar13rMxGIk
The border router is working correctly, and I tested Matter over Thread and Matter binding as explained in the above video.
When I try to do it again, it gives the error which I am not able to solve even after referring to devzone tickets eg  RE: Matter : unable to de-commisioning a device  Matter over Thread Commissioning failed ,  RE: Matter device pairing issue with chip-tool
Environment:
- nRF Connect for Desktop  ncs version 2.4.0
- Chip-Tool (controller) version 2.4.0, compile it from source on Ubuntu 22.04.
- Same RPi 3 Model B+ as Threat Border Router coupled with nRF52840dk as radio co-processor
- nRF5340dk as Light Bulb and nRF5340dk as Light Switch
Matter Light-Bulb logs :
uart:~$ *** Booting Zephyr OS build v3.3.99-ncs1 ***
I: Init CHIP stack
I: 486 [DL]BLE address: D6:D4:2D:E5:96:79
I: 508 [DL]OpenThread started: OK
I: 511 [DL]Setting OpenThread device type to ROUTER
I: 516 [SVR]Subscription persistence not supported
I: 521 [SVR]Server initializing...
I: 524 [TS]Last Known Good Time: 2023-08-07T15:17:34
I: 529 [DMG]AccessControl: initializing
I: 533 [DMG]Examples::AccessControlDelegate::Init
I: 538 [DMG]AccessControl: setting
I: 541 [DMG]DefaultAclStorage: initializing
I: 545 [DMG]DefaultAclStorage: 0 entries loaded
D: 549 [IN]UDP::Init bind&listen port=5540
E: 553 [IN]SO_REUSEPORT failed: 109
D: 556 [IN]UDP::Init bound to port=5540
D: 560 [IN]BLEBase::Init - setting/overriding transport
D: 565 [IN]TransportMgr initialized
D: 570 [DL]Using Thread extended MAC for hostname.
I: 575 [ZCL]Using ZAP configuration...
I: 581 [DMG]AccessControlCluster: initializing
D: 585 [DL]Boot reason: 1
I: 588 [ZCL]Initiating Admin Commissioning cluster.
I: 592 [ZCL]Endpoint 1 On/off already set to new value
I: 598 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
D: 605 [IN]SecureSession[0x20004260]: Allocated Type:1 LSID:58177
D: 611 [DL]CHIPoBLE advertising set to on
I: 615 [DIS]Updating services using commissioning mode 1
E: 620 [DIS]Failed to remove advertised services: 3
D: 625 [DL]Using Thread extended MAC for hostname.
I: 630 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discri        minator=3840/15 cm=1
E: 639 [DIS]Failed to advertise commissionable node: 3
E: 644 [DIS]Failed to finalize service update: 3
I: 648 [DIS]Updating services using commissioning mode 1
E: 653 [DIS]Failed to remove advertised services: 3
D: 658 [DL]Using Thread extended MAC for hostname.
I: 663 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discri        minator=3840/15 cm=1
E: 672 [DIS]Failed to advertise commissionable node: 3
E: 676 [DIS]Failed to finalize service update: 3
I: 681 [DIS]Delaying proxy of operational discovery: missing delegate
I: 687 [IN]CASE Server enabling CASE session setups
D: 692 [IN]SecureSession[0x20004318]: Allocated Type:2 LSID:58178
I: 698 [SVR]Joining Multicast groups
I: 702 [SVR]Server Listening...
I: 704 [DL]Device Configuration:
I: 708 [DL]  Serial Number: 11223344556677889900
I: 712 [DL]  Vendor Id: 65521 (0xFFF1)
I: 716 [DL]  Product Id: 32773 (0x8005)
I: 719 [DL]  Product Name: not-specified
I: 723 [DL]  Hardware Version: 0
I: 726 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 732 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 739 [DL]  Manufacturing Date: (not set)
I: 742 [DL]  Device Type: 65535 (0xFFFF)
I: 747 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 751 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 757 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3        A6FCJ142C00KA0648G00
I: 766 [SVR]Manual pairing code: [34970112332]
I: 772 [DL]CHIP task running
I: 778 [DL]CHIPoBLE advertising started
I: 782 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: 787 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 793 [DL]NFC Tag emulation started
uart:~$ I: 30781 [DL]CHIPoBLE advertising mode changed to slow
I: 30791 [DL]CHIPoBLE advertising started
uart:~$ I: 66444 [DL]BLE connection established (ConnId: 0x00)
I: 66450 [DL]Current number of connections: 1/1
I: 66454 [DL]CHIPoBLE advertising stopped
I: 66458 [DL]NFC Tag emulation stopped
D: 68320 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 68327 [BLE]local and remote recv window sizes = 5
I: 68332 [BLE]selected BTP version 4
I: 68335 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 68410 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 68414 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 68422 [IN]BLE EndPoint 0x2000a810 Connection Complete
I: 68427 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 68544 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 68553 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 68560 [EM]>>> [E:10221r S:0 M:20908917] (U) Msg RX from 0:6BE60A87970DB2B3 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
I: 68573 [EM]<<< [E:10221r S:0 M:59763049] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 68585 [IN](U) Sending msg 59763049 to IP address 'BLE'
D: 68591 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140)
D: 68679 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 68688 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 68695 [EM]>>> [E:10221r S:0 M:20908918] (U) Msg RX from 0:6BE60A87970DB2B3 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
I: 70107 [EM]<<< [E:10221r S:0 M:59763050] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 70119 [IN](U) Sending msg 59763050 to IP address 'BLE'
D: 70124 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
E: 70132 [DL]Long dispatch time: 1443 ms, for event type 16388
D: 70209 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70218 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 70225 [EM]>>> [E:10221r S:0 M:20908919] (U) Msg RX from 0:6BE60A87970DB2B3 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
I: 70237 [EM]<<< [E:10221r S:0 M:59763051] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 70249 [IN](U) Sending msg 59763051 to IP address 'BLE'
D: 70254 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 70263 [SC]SecureSession[0x20004260]: Moving from state 'kEstablishing' --> 'kActive'
D: 70270 [IN]SecureSession[0x20004260]: Activated - Type:1 LSID:58177
D: 70277 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:58177 PSID:9181!
I: 70286 [SVR]Commissioning completed session establishment step
I: 70292 [DIS]Updating services using commissioning mode 0
E: 70297 [DIS]Failed to remove advertised services: 3
D: 70302 [DL]Using Thread extended MAC for hostname.
I: 70307 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 70316 [DIS]Failed to advertise extended commissionable node: 3
D: 70322 [DIS]Scheduling extended discovery timeout in 900s
E: 70328 [DIS]Failed to finalize service update: 3
D: 70332 [DL]CHIPoBLE advertising set to off
I: 70336 [SVR]Device completed Rendezvous process
E: 70341 [DL]Long dispatch time: 123 ms, for event type 16388
D: 70347 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70355 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 70363 [EM]>>> [E:10222r S:58177 M:14390293] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 70374 [IM]Received Read request
I: 70384 [EM]<<< [E:10222r S:58177 M:97649281] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 70394 [IN](S) Sending msg 97649281 on secure session with LSID: 58177
D: 70401 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 70480 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70487 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 70614 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70623 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 70631 [EM]>>> [E:10223r S:58177 M:14390294] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 70643 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 70650 [EM]<<< [E:10223r S:58177 M:97649282] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 70661 [IN](S) Sending msg 97649282 on secure session with LSID: 58177
D: 70668 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 70794 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70803 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 70811 [EM]>>> [E:10224r S:58177 M:14390295] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 70825 [EM]<<< [E:10224r S:58177 M:97649283] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 70837 [IN](S) Sending msg 97649283 on secure session with LSID: 58177
D: 70843 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 70974 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 70983 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 70991 [EM]>>> [E:10225r S:58177 M:14390296] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 71003 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 71012 [EM]<<< [E:10225r S:58177 M:97649284] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 71024 [IN](S) Sending msg 97649284 on secure session with LSID: 58177
D: 71030 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 71155 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71162 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 71335 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71342 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 71425 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71471 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 71479 [EM]>>> [E:10226r S:58177 M:14390297] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 71491 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 71500 [EM]<<< [E:10226r S:58177 M:97649285] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 71512 [IN](S) Sending msg 97649285 on secure session with LSID: 58177
D: 71519 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 71605 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71612 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 71695 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71702 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77)
D: 71784 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71793 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 71801 [EM]>>> [E:10227r S:58177 M:14390298] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 71813 [ZCL]OpCreds: Received an AttestationRequest command
I: 71850 [ZCL]OpCreds: AttestationRequest successful.
I: 71859 [EM]<<< [E:10227r S:58177 M:97649286] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 71870 [IN](S) Sending msg 97649286 on secure session with LSID: 58177
D: 71877 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 71965 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 71972 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 72100 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 72107 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 235)
D: 72279 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 72288 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 72296 [EM]>>> [E:10228r S:58177 M:14390299] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 72308 [ZCL]OpCreds: Received a CSRRequest command
I: 72459 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 72496 [ZCL]OpCreds: CSRRequest successful.
I: 72502 [EM]<<< [E:10228r S:58177 M:97649287] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 72514 [IN](S) Sending msg 97649287 on secure session with LSID: 58177
D: 72520 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
E: 72528 [DL]Long dispatch time: 240 ms, for event type 16388
D: 72640 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 72647 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138)
D: 72730 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 72777 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 72790 [DIS]Updating services using commissioning mode 0
E: 72796 [DIS]Failed to remove advertised services: 3
D: 72800 [DL]Using Thread extended MAC for hostname.
I: 72806 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 72815 [DIS]Failed to advertise extended commissionable node: 3
E: 72821 [DIS]Failed to finalize service update: 3
E: OpenBasicCommissioningWindow() failed
D: 72865 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 72875 [EM]>>> [E:10229r S:58177 M:14390300] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 72887 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 72951 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 72958 [EM]<<< [E:10229r S:58177 M:97649288] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 72969 [IN](S) Sending msg 97649288 on secure session with LSID: 58177
D: 72976 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
E: 72984 [DL]Long dispatch time: 119 ms, for event type 16388
D: 73045 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 73053 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 73137 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 73226 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 73236 [EM]>>> [E:10230r S:58177 M:14390301] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 73248 [ZCL]OpCreds: Received an AddNOC command
I: 73255 [FP]Validating NOC chain
I: 73373 [FP]NOC chain validation successful
I: 73377 [FP]Added new fabric at index: 0x1
I: 73381 [FP]Assigned compressed fabric ID: 0xCEFAD72140B20CDA, node ID: 0x0000000000000001
I: 73390 [TS]Last Known Good Time: 2023-08-07T15:17:34
I: 73395 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00
I: 73401 [TS]Retaining current Last Known Good Time
I: 73413 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
D: 73422 [DL]Using Thread extended MAC for hostname.
I: 73427 [DIS]Advertise operational node CEFAD72140B20CDA-0000000000000001
I: 73434 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 73441 [EM]<<< [E:10230r S:58177 M:97649289] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 73453 [IN](S) Sending msg 97649289 on secure session with LSID: 58177
D: 73460 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
E: 73467 [DL]Long dispatch time: 242 ms, for event type 16388
D: 73585 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 73593 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 73601 [EM]>>> [E:10231r S:58177 M:14390302] (S) Msg RX from 1:FFFFFFFB00000000 [0CDA] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 73616 [EM]<<< [E:10231r S:58177 M:97649290] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 73628 [IN](S) Sending msg 97649290 on secure session with LSID: 58177
D: 73634 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 73720 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 73728 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 73736 [EM]>>> [E:10232r S:58177 M:14390303] (S) Msg RX from 1:FFFFFFFB00000000 [0CDA] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 73748 [FS]GeneralCommissioning: Received ArmFailSafe (76s)
I: 73755 [EM]<<< [E:10232r S:58177 M:97649291] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 73766 [IN](S) Sending msg 97649291 on secure session with LSID: 58177
D: 73773 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 73855 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 73863 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 73871 [EM]>>> [E:10233r S:58177 M:14390304] (S) Msg RX from 1:FFFFFFFB00000000 [0CDA] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 73893 [DL]OpenThread State Changed (Flags: 0x101fc100)
D: 73898 [DL]   Network Name: OpenThread-5a7f
D: 73902 [DL]   PAN Id: 0x5A7F
D: 73905 [DL]   Extended PAN Id: 0x1CEA9DCCAAC89EDC
D: 73910 [DL]   Channel: 16
D: 73913 [DL]   Mesh Prefix: fdaa:96d0:9e1b:6904::/64
D: 73918 [DL]OpenThread State Changed (Flags: 0x1100101d)
D: 73923 [DL]   Device Role: DETACHED
D: 73927 [DL]   Thread Unicast Addresses:
D: 73931 [DL]        fdaa:96d0:9e1b:6904:765f:4f02:b363:438/64 valid
D: 73937 [DL]        fe80::58d0:969a:1fe:ede8/64 valid preferred
I: 75282 [DL]SRP Client was started, detected server: fdaa:96d0:9e1b:6904:0f6a:acb6:d9f3:1763
D: 75291 [DL]OpenThread State Changed (Flags: 0x200012a4)
D: 75296 [DL]   Device Role: CHILD
D: 75299 [DL]   Partition Id: 0x264E277C
D: 75304 [DL]OpenThread State Changed (Flags: 0x00000001)
D: 75309 [DL]   Thread Unicast Addresses:
D: 75313 [DL]        fd8a:1ee1:ee51:1:38ba:7745:f335:aa0b/64 valid preferred
D: 75320 [DL]        fdaa:96d0:9e1b:6904:0:ff:fe00:a405/64 valid rloc
D: 75326 [DL]        fdaa:96d0:9e1b:6904:765f:4f02:b363:438/64 valid
D: 75332 [DL]        fe80::58d0:969a:1fe:ede8/64 valid preferred
I: 75340 [EM]<<< [E:10233r S:58177 M:97649292] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 75351 [IN](S) Sending msg 97649292 on secure session with LSID: 58177
D: 75358 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 75366 [DL]Using Thread extended MAC for hostname.
I: 75370 [DIS]Advertise operational node CEFAD72140B20CDA-0000000000000001
I: 75377 [SVR]Operational advertising enabled
D: 75430 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 76134 [DL]SRP update succeeded
I: 76137 [DIS]Setting operational delegate post init
I: 76145 [SWU]Stopping the watchdog timer
I: 76149 [SWU]Starting the periodic query timer, timeout: 86400 seconds
E: 76156 [SVR]Server initialization complete
I: 76160 [DIS]Updating services using commissioning mode 0
D: 76165 [DL]Using Thread extended MAC for hostname.
I: 76170 [DIS]Advertise operational node CEFAD72140B20CDA-0000000000000001
I: 76177 [DL]advertising srp service: CEFAD72140B20CDA-0000000000000001._matter._tcp
D: 76185 [DL]Using Thread extended MAC for hostname.
I: 76190 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
I: 76199 [DL]advertising srp service: 13A01013B94B964C._matterc._udp
E: 76988 [DL]SRP update error: domain name or RRset is duplicated
D: 78265 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
E: 78830 [DL]SRP update error: domain name or RRset is duplicated
D: 80773 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 80965 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
E: 81922 [DL]SRP update error: domain name or RRset is duplicated
D: 83710 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 85165 [DL]OpenThread State Changed (Flags: 0x00000064)
D: 85171 [DL]   Device Role: ROUTER
D: 86217 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 86455 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
E: 87155 [DL]SRP update error: domain name or RRset is duplicated
D: 88930 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 91438 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 91630 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 91766 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 91774 [EM]>>> [E:10235r S:58177 M:14390305] (S) Msg RX from 1:FFFFFFFB00000000 [0CDA] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 91786 [FS]GeneralCommissioning: Received ArmFailSafe (68s)
I: 91793 [EM]<<< [E:10235r S:58177 M:97649293] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 91804 [IN](S) Sending msg 97649293 on secure session with LSID: 58177
D: 91811 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 91900 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 94646 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
E: 96048 [DL]SRP update error: domain name or RRset is duplicated
D: 97153 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 97301 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 100091 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 102598 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 102791 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 105536 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 108044 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 108236 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 109002 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 109010 [EM]>>> [E:10237r S:58177 M:14390306] (S) Msg RX from 1:FFFFFFFB00000000 [0CDA] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 109022 [FS]GeneralCommissioning: Received ArmFailSafe (103s)
I: 109029 [EM]<<< [E:10237r S:58177 M:97649294] (S) Msg TX to 1:FFFFFFFB00000000 [0CDA] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 109041 [IN](S) Sending msg 97649294 on secure session with LSID: 58177
D: 109047 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 109136 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
E: 111095 [DL]SRP update error: domain name or RRset is duplicated
D: 111881 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 114389 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 114671 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117326 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 119834 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 120116 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122907 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 125414 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 125607 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 128352 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 130859 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 131052 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 133797 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 136304 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 136407 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
E: 136676 [DL]SRP update error: domain name or RRset is duplicated
D: 139242 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 141750 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 141942 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144778 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 147286 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 147703 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 150493 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 153000 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 153103 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 155893 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 158401 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
D: 158593 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 161383 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 161473 [DL]ConnId: 0x00, New CCCD value: 0x0000
D: 161478 [IN]Clearing BLE pending packets.
I: 161482 [BLE]Releasing end point's BLE connection back to application.
I: 161488 [DL]Closing BLE GATT connection (ConnId 00)
I: 161608 [DL]BLE GAP connection terminated (reason 0x16)
I: 161613 [DL]Current number of connections: 0/1
E: 180100 [DL]SRP update error: domain name or RRset is duplicated
I: 212028 [FS]Fail-safe timer expired
E: 212031 [SVR]Failsafe timer expired
D: 212035 [IN]SecureSession[0x20004260]: MarkForEviction Type:1 LSID:58177
I: 212041 [SC]SecureSession[0x20004260]: Moving from state 'kActive' --> 'kPendingEviction'
D: 212050 [IN]SecureSession[0x20004260]: Released - Type:1 LSID:58177
E: 212056 [SVR]Commissioning failed (attempt 1): 32
I: 212060 [DIS]Updating services using commissioning mode 0
D: 212066 [DL]Using Thread extended MAC for hostname.
I: 212071 [DIS]Advertise operational node CEFAD72140B20CDA-0000000000000001
D: 212078 [DL]Using Thread extended MAC for hostname.
I: 212083 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 212093 [ZCL]OpCreds: Got FailSafeTimerExpired
E: 212097 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
D: 212104 [IN]Expiring all sessions for fabric 0x1!!
E: 212109 [FP]Reverting pending fabric data for fabric 0x1
E: 212115 [FP]Warning: metadata not found during delete of fabric 0x1
I: 212126 [FP]Fabric (0x1) deleted.
I: 212129 [ZCL]OpCreds: Fabric index 0x1 was removed
I: 212134 [DIS]Updating services using commissioning mode 0
D: 212139 [DL]Using Thread extended MAC for hostname.
I: 212145 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
I: 212154 [DL]advertising srp service: 13A01013B94B964C._matterc._udp
I: 212161 [DL]removing srp service: CEFAD72140B20CDA-0000000000000001._matter._tcp
I: 212181 [TS]Pending Last Known Good Time: 2023-08-07T15:17:34
I: 212187 [TS]Previous Last Known Good Time: 2023-08-07T15:17:34
I: 212193 [TS]Reverted Last Known Good Time to previous value
E: 212199 [FP]Warning: metadata not found during delete of fabric 0x1
E: 212207 [ZCL]OpCreds: failed to delete fabric at index 1: d8
I: 212213 [NP]Reverting Thread operational dataset
E: 212223 [DL]Long dispatch time: 192 ms, for event type 32782
I: 212228 [FS]Fail-safe cleanly disarmed
D: 212232 [DL]OpenThread State Changed (Flags: 0x11002046)
D: 212237 [DL]   Device Role: DISABLED
D: 212241 [DL]   Thread Unicast Addresses:
D: 212245 [DL]        fd8a:1ee1:ee51:1:38ba:7745:f335:aa0b/64 valid preferred
D: 212252 [DL]OpenThread State Changed (Flags: 0x10000000)
Chip tool error log :
lenovo@lenovo-ThinkPad-L470:~/Downloads$ ./chip-tool-debug pairing ble-thread 1 hex:0e080000000000010000000300001035060004001fffe002081cea9dccaac89edc0708fdaa96d09e1b690405101416c358c6964dcc95d99f3d4d068a93030f4f70656e5468726561642d3561376601025a7f0410fe82415a7b2f71353c3b468190356fde0c0402a0f7f8 20202021 3840
[1691403080.695655][7870:7870] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1691403080.695798][7870:7870] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1691403080.695830][7870:7870] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1691403080.695850][7870:7870] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1691403080.695955][7870:7870] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-vbHOcT)
[1691403080.696120][7870:7870] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1691403080.696133][7870:7870] CHIP:DL: NVS set: chip-counters/reboot-count = 27 (0x1B)
[1691403080.696265][7870:7870] CHIP:DL: Got Ethernet interface: enp0s31f6
[1691403080.696358][7870:7870] CHIP:DL: Found the primary Ethernet interface:enp0s31f6
[1691403080.696460][7870:7870] CHIP:DL: Got WiFi interface: wlp5s0
[1691403080.698000][7870:7870] CHIP:DL: Found the primary WiFi interface:wlp5s0
[1691403080.698021][7870:7870] CHIP:IN: UDP::Init bind&listen port=0
[1691403080.698044][7870:7870] CHIP:IN: UDP::Init bound to port=59227
[1691403080.698049][7870:7870] CHIP:IN: UDP::Init bind&listen port=0
[1691403080.698066][7870:7870] CHIP:IN: UDP::Init bound to port=43359
[1691403080.698070][7870:7870] CHIP:IN: BLEBase::Init - setting/overriding transport
[1691403080.698075][7870:7870] CHIP:IN: TransportMgr initialized
[1691403080.698086][7870:7870] CHIP:FP: Initializing FabricTable from persistent storage
[1691403080.698137][7870:7870] CHIP:TS: Last Known Good Time: 2023-06-01T07:38:45
[1691403080.698280][7870:7870] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xCEFAD72140B20CDA, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1691403080.698764][7870:7870] CHIP:ZCL: Using ZAP configuration...
[1691403080.700414][7870:7870] CHIP:DL: Avahi client registered
[1691403080.700842][7870:7870] CHIP:CTL: System State Initialized...
[1691403080.700892][7870:7870] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1691403080.700905][7870:7870] CHIP:CTL: Setting attestation nonce to random value
[1691403080.700910][7870:7870] CHIP:CTL: Setting CSR nonce to random value
[1691403080.700999][7870:7872] CHIP:DL: CHIP task running
[1691403080.701050][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1691403080.701143][7870:7872] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1691403080.701157][7870:7872] CHIP:CTL: Setting attestation nonce to random value
[1691403080.701163][7870:7872] CHIP:CTL: Setting CSR nonce to random value
[1691403080.705197][7870:7872] CHIP:CTL: Generating NOC
[1691403080.708961][7870:7872] CHIP:FP: Validating NOC chain
[1691403080.723069][7870:7872] CHIP:FP: NOC chain validation successful
[1691403080.723089][7870:7872] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1691403080.723096][7870:7872] CHIP:TS: Last Known Good Time: 2023-06-01T07:38:45
[1691403080.723101][7870:7872] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1691403080.723104][7870:7872] CHIP:TS: Retaining current Last Known Good Time
[1691403080.724161][7870:7872] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1691403080.724569][7870:7872] CHIP:TS: Committing Last Known Good Time to storage: 2023-06-01T07:38:45
[1691403080.724932][7870:7872] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: CEFAD72140B20CDA)
[1691403080.728092][7870:7872] CHIP:CTL: Setting thread operational dataset from parameters
[1691403080.728100][7870:7872] CHIP:CTL: Setting attestation nonce to random value
[1691403080.728107][7870:7872] CHIP:CTL: Setting CSR nonce to random value
[1691403080.728112][7870:7872] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1691403080.729827][7870:7871] CHIP:DL: TRACE: Bus acquired for name C-1ebe
[1691403080.735725][7870:7872] CHIP:DL: PlatformBlueZInit init success
[1691403080.740247][7870:7871] CHIP:BLE: BLE removing known devices.
[1691403080.740863][7870:7871] CHIP:BLE: BLE initiating scan.
[1691403080.860396][7870:7872] CHIP:DL: Long dispatch time: 133 ms, for event type 2
[1691403080.869867][7870:7871] CHIP:BLE: Device 4E:30:D0:20:6D:9E does not look like a CHIP device.
[1691403080.873693][7870:7871] CHIP:BLE: Device 39:32:16:2C:07:FB does not look like a CHIP device.
[1691403080.883155][7870:7871] CHIP:BLE: New device scanned: F4:10:CB:75:55:F1
[1691403080.883183][7870:7871] CHIP:BLE: Device discriminator match. Attempting to connect.
[1691403081.051609][7870:7871] CHIP:DL: ConnectDevice complete
[1691403082.571903][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0001
[1691403082.571922][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571931][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0001
[1691403082.571937][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571944][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0001
[1691403082.571949][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571961][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571967][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571977][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571983][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.571994][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.572000][7870:7871] CHIP:DL: Char1 /org/bluez/hci0/dev_F4_10_CB_75_55_F1/service0010
[1691403082.572009][7870:7871] CHIP:DL: New BLE connection 0x7f942c056c60, device F4:10:CB:75:55:F1, path /org/bluez/hci0/dev_F4_10_CB_75_55_F1
[1691403082.572049][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1691403082.572063][7870:7872] CHIP:DIS: Closing all BLE connections
[1691403082.572092][7870:7872] CHIP:IN: BleConnectionComplete: endPoint 0x55a38d3403c0
[1691403082.572209][7870:7872] CHIP:IN: SecureSession[0x7f94240095a0]: Allocated Type:1 LSID:15906
[1691403082.572220][7870:7872] CHIP:SC: Assigned local session key ID 15906
[1691403082.572247][7870:7872] CHIP:EM: <<< [E:58373i S:0 M:166617635] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1691403082.572263][7870:7872] CHIP:IN: (U) Sending msg 166617635 to IP address 'BLE'
[1691403082.572274][7870:7872] CHIP:IN: Message appended to BLE send queue
[1691403082.572282][7870:7872] CHIP:SC: Sent PBKDF param request
[1691403082.894145][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403082.985283][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1691403082.985320][7870:7872] CHIP:BLE: subscribe complete, ep = 0x55a38d3403c0
[1691403082.986166][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403082.986289][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403082.986319][7870:7872] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1691403082.986338][7870:7872] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1691403082.986352][7870:7872] CHIP:BLE: local and remote recv window size = 5
[1691403082.986603][7870:7872] CHIP:IN: BLE EndPoint 0x55a38d3403c0 Connection Complete
[1691403083.074387][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403083.121299][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403083.121472][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403083.121565][7870:7872] CHIP:EM: >>> [E:58373i S:0 M:198850083] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1691403083.121595][7870:7872] CHIP:EM: Found matching exchange: 58373i, Delegate: 0x7f942400c180
[1691403083.121627][7870:7872] CHIP:SC: Received PBKDF param response
[1691403083.121662][7870:7872] CHIP:SC: Peer assigned session ID 22955
[1691403083.121689][7870:7872] CHIP:SC: Found MRP parameters in the message
[1691403083.152744][7870:7872] CHIP:EM: <<< [E:58373i S:0 M:166617636] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1691403083.152770][7870:7872] CHIP:IN: (U) Sending msg 166617636 to IP address 'BLE'
[1691403083.152922][7870:7872] CHIP:SC: Sent spake2p msg1
[1691403083.209023][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403084.650790][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403084.650965][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403084.651043][7870:7872] CHIP:EM: >>> [E:58373i S:0 M:198850084] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1691403084.651069][7870:7872] CHIP:EM: Found matching exchange: 58373i, Delegate: 0x7f942400c180
[1691403084.651101][7870:7872] CHIP:SC: Received spake2p msg2
[1691403084.667719][7870:7872] CHIP:EM: <<< [E:58373i S:0 M:166617637] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1691403084.667761][7870:7872] CHIP:IN: (U) Sending msg 166617637 to IP address 'BLE'
[1691403084.667930][7870:7872] CHIP:SC: Sent spake2p msg3
[1691403084.739650][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403084.784817][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403084.784907][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403084.784996][7870:7872] CHIP:EM: >>> [E:58373i S:0 M:198850085] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1691403084.785030][7870:7872] CHIP:EM: Found matching exchange: 58373i, Delegate: 0x7f942400c180
[1691403084.785120][7870:7872] CHIP:SC: SecureSession[0x7f94240095a0]: Moving from state 'kEstablishing' --> 'kActive'
[1691403084.785139][7870:7872] CHIP:IN: SecureSession[0x7f94240095a0]: Activated - Type:1 LSID:15906
[1691403084.785157][7870:7872] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:15906 PSID:22955!
[1691403084.785179][7870:7872] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1691403084.785195][7870:7872] CHIP:TOO: Pairing Success
[1691403084.785209][7870:7872] CHIP:TOO: PASE establishment successful
[1691403084.785225][7870:7872] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1691403084.785242][7870:7872] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1691403084.785255][7870:7872] CHIP:CTL: Sending request for commissioning information
[1691403084.785283][7870:7872] CHIP:DMG: SendReadRequest ReadClient[0x7f9424025430]: Sending Read Request
[1691403084.785366][7870:7872] CHIP:EM: <<< [E:58374i S:15906 M:216097734] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1691403084.785392][7870:7872] CHIP:IN: (S) Sending msg 216097734 on secure session with LSID: 15906
[1691403084.785637][7870:7872] CHIP:DMG: MoveToState ReadClient[0x7f9424025430]: Moving to [AwaitingIn]
[1691403084.874445][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403084.921894][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403084.922077][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.009616][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.009709][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.009796][7870:7872] CHIP:EM: >>> [E:58374i S:15906 M:122858322] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1691403085.009821][7870:7872] CHIP:EM: Found matching exchange: 58374i, Delegate: 0x7f9424025440
[1691403085.009905][7870:7872] CHIP:DMG: ReportDataMessage =
[1691403085.009925][7870:7872] CHIP:DMG: {
[1691403085.009946][7870:7872] CHIP:DMG: 	AttributeReportIBs =
[1691403085.009974][7870:7872] CHIP:DMG: 	[
[1691403085.009986][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.010007][7870:7872] CHIP:DMG: 		{
[1691403085.010022][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.010038][7870:7872] CHIP:DMG: 			{
[1691403085.010054][7870:7872] CHIP:DMG: 				DataVersion = 0xddc765d8,
[1691403085.010069][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.010084][7870:7872] CHIP:DMG: 				{
[1691403085.010100][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.010117][7870:7872] CHIP:DMG: 					Cluster = 0x31,
[1691403085.010136][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0003,
[1691403085.010156][7870:7872] CHIP:DMG: 				}
[1691403085.010169][7870:7872] CHIP:DMG:
[1691403085.010182][7870:7872] CHIP:DMG: 				Data = 20,
[1691403085.010193][7870:7872] CHIP:DMG: 			},
[1691403085.010216][7870:7872] CHIP:DMG:
[1691403085.010230][7870:7872] CHIP:DMG: 		},
[1691403085.010261][7870:7872] CHIP:DMG:
[1691403085.010275][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.010300][7870:7872] CHIP:DMG: 		{
[1691403085.010314][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.010333][7870:7872] CHIP:DMG: 			{
[1691403085.010350][7870:7872] CHIP:DMG: 				DataVersion = 0x9b61c295,
[1691403085.010366][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.010385][7870:7872] CHIP:DMG: 				{
[1691403085.010404][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.010423][7870:7872] CHIP:DMG: 					Cluster = 0x28,
[1691403085.010441][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0004,
[1691403085.010458][7870:7872] CHIP:DMG: 				}
[1691403085.010480][7870:7872] CHIP:DMG:
[1691403085.010499][7870:7872] CHIP:DMG: 				Data = 32773,
[1691403085.010514][7870:7872] CHIP:DMG: 			},
[1691403085.010537][7870:7872] CHIP:DMG:
[1691403085.010550][7870:7872] CHIP:DMG: 		},
[1691403085.010581][7870:7872] CHIP:DMG:
[1691403085.010595][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.010619][7870:7872] CHIP:DMG: 		{
[1691403085.010633][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.010652][7870:7872] CHIP:DMG: 			{
[1691403085.010669][7870:7872] CHIP:DMG: 				DataVersion = 0x9b61c295,
[1691403085.010686][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.010705][7870:7872] CHIP:DMG: 				{
[1691403085.010723][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.010742][7870:7872] CHIP:DMG: 					Cluster = 0x28,
[1691403085.010761][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0002,
[1691403085.010777][7870:7872] CHIP:DMG: 				}
[1691403085.010798][7870:7872] CHIP:DMG:
[1691403085.010816][7870:7872] CHIP:DMG: 				Data = 65521,
[1691403085.010832][7870:7872] CHIP:DMG: 			},
[1691403085.010855][7870:7872] CHIP:DMG:
[1691403085.010871][7870:7872] CHIP:DMG: 		},
[1691403085.010901][7870:7872] CHIP:DMG:
[1691403085.010914][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.010939][7870:7872] CHIP:DMG: 		{
[1691403085.010953][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.010971][7870:7872] CHIP:DMG: 			{
[1691403085.010989][7870:7872] CHIP:DMG: 				DataVersion = 0xfd19fde9,
[1691403085.011005][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.011024][7870:7872] CHIP:DMG: 				{
[1691403085.011042][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.011061][7870:7872] CHIP:DMG: 					Cluster = 0x30,
[1691403085.011079][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0003,
[1691403085.011095][7870:7872] CHIP:DMG: 				}
[1691403085.011117][7870:7872] CHIP:DMG:
[1691403085.011135][7870:7872] CHIP:DMG: 				Data = 0,
[1691403085.011151][7870:7872] CHIP:DMG: 			},
[1691403085.011174][7870:7872] CHIP:DMG:
[1691403085.011188][7870:7872] CHIP:DMG: 		},
[1691403085.011218][7870:7872] CHIP:DMG:
[1691403085.011231][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.011256][7870:7872] CHIP:DMG: 		{
[1691403085.011270][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.011288][7870:7872] CHIP:DMG: 			{
[1691403085.011306][7870:7872] CHIP:DMG: 				DataVersion = 0xfd19fde9,
[1691403085.011323][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.011340][7870:7872] CHIP:DMG: 				{
[1691403085.011354][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.011369][7870:7872] CHIP:DMG: 					Cluster = 0x30,
[1691403085.011384][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0002,
[1691403085.011398][7870:7872] CHIP:DMG: 				}
[1691403085.011414][7870:7872] CHIP:DMG:
[1691403085.011429][7870:7872] CHIP:DMG: 				Data = 0,
[1691403085.011442][7870:7872] CHIP:DMG: 			},
[1691403085.011460][7870:7872] CHIP:DMG:
[1691403085.011472][7870:7872] CHIP:DMG: 		},
[1691403085.011498][7870:7872] CHIP:DMG:
[1691403085.011510][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.011531][7870:7872] CHIP:DMG: 		{
[1691403085.011543][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.011556][7870:7872] CHIP:DMG: 			{
[1691403085.011570][7870:7872] CHIP:DMG: 				DataVersion = 0xfd19fde9,
[1691403085.011584][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.011598][7870:7872] CHIP:DMG: 				{
[1691403085.011617][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.011637][7870:7872] CHIP:DMG: 					Cluster = 0x30,
[1691403085.011656][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0001,
[1691403085.011673][7870:7872] CHIP:DMG: 				}
[1691403085.011695][7870:7872] CHIP:DMG:
[1691403085.011710][7870:7872] CHIP:DMG: 				Data =
[1691403085.011729][7870:7872] CHIP:DMG: 				{
[1691403085.011770][7870:7872] CHIP:DMG: 					0x0 = 60,
[1691403085.011790][7870:7872] CHIP:DMG: 					0x1 = 900,
[1691403085.011808][7870:7872] CHIP:DMG: 				},
[1691403085.011826][7870:7872] CHIP:DMG: 			},
[1691403085.011850][7870:7872] CHIP:DMG:
[1691403085.011864][7870:7872] CHIP:DMG: 		},
[1691403085.011896][7870:7872] CHIP:DMG:
[1691403085.011909][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.011934][7870:7872] CHIP:DMG: 		{
[1691403085.011948][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.011966][7870:7872] CHIP:DMG: 			{
[1691403085.011984][7870:7872] CHIP:DMG: 				DataVersion = 0xfd19fde9,
[1691403085.012001][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.012020][7870:7872] CHIP:DMG: 				{
[1691403085.012037][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.012057][7870:7872] CHIP:DMG: 					Cluster = 0x30,
[1691403085.012075][7870:7872] CHIP:DMG: 					Attribute = 0x0000_0000,
[1691403085.012091][7870:7872] CHIP:DMG: 				}
[1691403085.012113][7870:7872] CHIP:DMG:
[1691403085.012131][7870:7872] CHIP:DMG: 				Data = 0,
[1691403085.012147][7870:7872] CHIP:DMG: 			},
[1691403085.012170][7870:7872] CHIP:DMG:
[1691403085.012197][7870:7872] CHIP:DMG: 		},
[1691403085.012226][7870:7872] CHIP:DMG:
[1691403085.012238][7870:7872] CHIP:DMG: 		AttributeReportIB =
[1691403085.012261][7870:7872] CHIP:DMG: 		{
[1691403085.012274][7870:7872] CHIP:DMG: 			AttributeDataIB =
[1691403085.012291][7870:7872] CHIP:DMG: 			{
[1691403085.012307][7870:7872] CHIP:DMG: 				DataVersion = 0xddc765d8,
[1691403085.012323][7870:7872] CHIP:DMG: 				AttributePathIB =
[1691403085.012342][7870:7872] CHIP:DMG: 				{
[1691403085.012359][7870:7872] CHIP:DMG: 					Endpoint = 0x0,
[1691403085.012376][7870:7872] CHIP:DMG: 					Cluster = 0x31,
[1691403085.012394][7870:7872] CHIP:DMG: 					Attribute = 0x0000_FFFC,
[1691403085.012409][7870:7872] CHIP:DMG: 				}
[1691403085.012429][7870:7872] CHIP:DMG:
[1691403085.012447][7870:7872] CHIP:DMG: 				Data = 2,
[1691403085.012460][7870:7872] CHIP:DMG: 			},
[1691403085.012482][7870:7872] CHIP:DMG:
[1691403085.012494][7870:7872] CHIP:DMG: 		},
[1691403085.012516][7870:7872] CHIP:DMG:
[1691403085.012528][7870:7872] CHIP:DMG: 	],
[1691403085.012591][7870:7872] CHIP:DMG:
[1691403085.012605][7870:7872] CHIP:DMG: 	SuppressResponse = true,
[1691403085.012620][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403085.012634][7870:7872] CHIP:DMG: }
[1691403085.013469][7870:7872] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1691403085.013516][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1691403085.013533][7870:7872] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1691403085.013548][7870:7872] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1691403085.013562][7870:7872] CHIP:CTL: Arming failsafe (60 seconds)
[1691403085.013597][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403085.013614][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403085.013662][7870:7872] CHIP:EM: <<< [E:58375i S:15906 M:216097735] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403085.013686][7870:7872] CHIP:IN: (S) Sending msg 216097735 on secure session with LSID: 15906
[1691403085.013902][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403085.099716][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403085.145278][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.145381][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.145488][7870:7872] CHIP:EM: >>> [E:58375i S:15906 M:122858323] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403085.145518][7870:7872] CHIP:EM: Found matching exchange: 58375i, Delegate: 0x7f942c02f6a8
[1691403085.145550][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403085.145588][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403085.145601][7870:7872] CHIP:DMG: {
[1691403085.145619][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403085.145635][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403085.145662][7870:7872] CHIP:DMG: 	[
[1691403085.145675][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403085.145702][7870:7872] CHIP:DMG: 		{
[1691403085.145716][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403085.145734][7870:7872] CHIP:DMG: 			{
[1691403085.145750][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403085.145770][7870:7872] CHIP:DMG: 				{
[1691403085.145789][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403085.145807][7870:7872] CHIP:DMG: 					ClusterId = 0x30,
[1691403085.145825][7870:7872] CHIP:DMG: 					CommandId = 0x1,
[1691403085.145841][7870:7872] CHIP:DMG: 				},
[1691403085.145862][7870:7872] CHIP:DMG:
[1691403085.145877][7870:7872] CHIP:DMG: 				CommandFields =
[1691403085.145896][7870:7872] CHIP:DMG: 				{
[1691403085.145915][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403085.145935][7870:7872] CHIP:DMG: 					0x1 = "" (0 chars),
[1691403085.145952][7870:7872] CHIP:DMG: 				},
[1691403085.145968][7870:7872] CHIP:DMG: 			},
[1691403085.145988][7870:7872] CHIP:DMG:
[1691403085.145999][7870:7872] CHIP:DMG: 		},
[1691403085.146018][7870:7872] CHIP:DMG:
[1691403085.146030][7870:7872] CHIP:DMG: 	],
[1691403085.146050][7870:7872] CHIP:DMG:
[1691403085.146062][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403085.146073][7870:7872] CHIP:DMG: },
[1691403085.146140][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1691403085.146189][7870:7872] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1691403085.146214][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1691403085.146227][7870:7872] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1691403085.146247][7870:7872] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1691403085.146262][7870:7872] CHIP:CTL: Setting Regulatory Config
[1691403085.146272][7870:7872] CHIP:CTL: Device does not support configurable regulatory location
[1691403085.146316][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403085.146352][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403085.146415][7870:7872] CHIP:EM: <<< [E:58376i S:15906 M:216097736] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403085.146446][7870:7872] CHIP:IN: (S) Sending msg 216097736 on secure session with LSID: 15906
[1691403085.146724][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403085.146774][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403085.234188][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403085.325510][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.325600][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.325706][7870:7872] CHIP:EM: >>> [E:58376i S:15906 M:122858324] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403085.325735][7870:7872] CHIP:EM: Found matching exchange: 58376i, Delegate: 0x7f9424008898
[1691403085.325768][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403085.325805][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403085.325819][7870:7872] CHIP:DMG: {
[1691403085.325834][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403085.325849][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403085.325876][7870:7872] CHIP:DMG: 	[
[1691403085.325888][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403085.325930][7870:7872] CHIP:DMG: 		{
[1691403085.325946][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403085.325961][7870:7872] CHIP:DMG: 			{
[1691403085.325972][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403085.325985][7870:7872] CHIP:DMG: 				{
[1691403085.325998][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403085.326011][7870:7872] CHIP:DMG: 					ClusterId = 0x30,
[1691403085.326024][7870:7872] CHIP:DMG: 					CommandId = 0x3,
[1691403085.326036][7870:7872] CHIP:DMG: 				},
[1691403085.326049][7870:7872] CHIP:DMG:
[1691403085.326061][7870:7872] CHIP:DMG: 				CommandFields =
[1691403085.326082][7870:7872] CHIP:DMG: 				{
[1691403085.326101][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403085.326116][7870:7872] CHIP:DMG: 					0x1 = "" (0 chars),
[1691403085.326129][7870:7872] CHIP:DMG: 				},
[1691403085.326140][7870:7872] CHIP:DMG: 			},
[1691403085.326156][7870:7872] CHIP:DMG:
[1691403085.326166][7870:7872] CHIP:DMG: 		},
[1691403085.326182][7870:7872] CHIP:DMG:
[1691403085.326192][7870:7872] CHIP:DMG: 	],
[1691403085.326208][7870:7872] CHIP:DMG:
[1691403085.326219][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403085.326228][7870:7872] CHIP:DMG: },
[1691403085.326273][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1691403085.326311][7870:7872] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1691403085.326328][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1691403085.326348][7870:7872] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1691403085.326369][7870:7872] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1691403085.326382][7870:7872] CHIP:CTL: Sending request for PAI certificate
[1691403085.326397][7870:7872] CHIP:CTL: Sending Certificate Chain request to 0x7f942400c130 device
[1691403085.326439][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403085.326471][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403085.326525][7870:7872] CHIP:EM: <<< [E:58377i S:15906 M:216097737] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403085.326553][7870:7872] CHIP:IN: (S) Sending msg 216097737 on secure session with LSID: 15906
[1691403085.326801][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403085.326855][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403085.413966][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403085.461570][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.461726][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.551992][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.552171][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.640601][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.640779][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.640886][7870:7872] CHIP:EM: >>> [E:58377i S:15906 M:122858325] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403085.640916][7870:7872] CHIP:EM: Found matching exchange: 58377i, Delegate: 0x7f942c02f6a8
[1691403085.640945][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403085.640976][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403085.640990][7870:7872] CHIP:DMG: {
[1691403085.641002][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403085.641017][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403085.641043][7870:7872] CHIP:DMG: 	[
[1691403085.641060][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403085.641081][7870:7872] CHIP:DMG: 		{
[1691403085.641092][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403085.641104][7870:7872] CHIP:DMG: 			{
[1691403085.641115][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403085.641128][7870:7872] CHIP:DMG: 				{
[1691403085.641141][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403085.641154][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403085.641166][7870:7872] CHIP:DMG: 					CommandId = 0x3,
[1691403085.641178][7870:7872] CHIP:DMG: 				},
[1691403085.641192][7870:7872] CHIP:DMG:
[1691403085.641203][7870:7872] CHIP:DMG: 				CommandFields =
[1691403085.641216][7870:7872] CHIP:DMG: 				{
[1691403085.641229][7870:7872] CHIP:DMG: 					0x0 = [
[1691403085.641319][7870:7872] CHIP:DMG: 							0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1691403085.641383][7870:7872] CHIP:DMG: 					] (463 bytes)
[1691403085.641405][7870:7872] CHIP:DMG: 				},
[1691403085.641423][7870:7872] CHIP:DMG: 			},
[1691403085.641449][7870:7872] CHIP:DMG:
[1691403085.641463][7870:7872] CHIP:DMG: 		},
[1691403085.641490][7870:7872] CHIP:DMG:
[1691403085.641504][7870:7872] CHIP:DMG: 	],
[1691403085.641531][7870:7872] CHIP:DMG:
[1691403085.641546][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403085.641562][7870:7872] CHIP:DMG: },
[1691403085.641623][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1691403085.641647][7870:7872] CHIP:CTL: Received certificate chain from the device
[1691403085.641669][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1691403085.641687][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1691403085.641708][7870:7872] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1691403085.641721][7870:7872] CHIP:CTL: Sending request for DAC certificate
[1691403085.641735][7870:7872] CHIP:CTL: Sending Certificate Chain request to 0x7f942400c130 device
[1691403085.641779][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403085.641798][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403085.641862][7870:7872] CHIP:EM: <<< [E:58378i S:15906 M:216097738] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403085.641888][7870:7872] CHIP:IN: (S) Sending msg 216097738 on secure session with LSID: 15906
[1691403085.642105][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403085.642167][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403085.729673][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403085.777133][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.777305][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.868276][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.868451][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.955710][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403085.955874][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403085.955992][7870:7872] CHIP:EM: >>> [E:58378i S:15906 M:122858326] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403085.956016][7870:7872] CHIP:EM: Found matching exchange: 58378i, Delegate: 0x7f942c057968
[1691403085.956047][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403085.956087][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403085.956102][7870:7872] CHIP:DMG: {
[1691403085.956120][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403085.956137][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403085.956165][7870:7872] CHIP:DMG: 	[
[1691403085.956180][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403085.956207][7870:7872] CHIP:DMG: 		{
[1691403085.956222][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403085.956242][7870:7872] CHIP:DMG: 			{
[1691403085.956272][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403085.956287][7870:7872] CHIP:DMG: 				{
[1691403085.956302][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403085.956317][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403085.956331][7870:7872] CHIP:DMG: 					CommandId = 0x3,
[1691403085.956345][7870:7872] CHIP:DMG: 				},
[1691403085.956362][7870:7872] CHIP:DMG:
[1691403085.956375][7870:7872] CHIP:DMG: 				CommandFields =
[1691403085.956389][7870:7872] CHIP:DMG: 				{
[1691403085.956404][7870:7872] CHIP:DMG: 					0x0 = [
[1691403085.956565][7870:7872] CHIP:DMG: 							0x30, 0x82, 0x01, 0xe8, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x6f, 0xdc, 0xb6, 0xed, 0x06, 0xf3, 0x58, 0xf9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x35, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x7e, 0xf2, 0xf1, 0x08, 0x2b, 0x2a, 0x56, 0x4a, 0x05, 0x44, 0xc0, 0xa6, 0x13, 0xd2, 0x1b, 0x15, 0x75, 0x00, 0x55, 0x2d, 0x03, 0x5f, 0x23, 0x02, 0x25, 0x2f, 0xce, 0xe8, 0x1d, 0x6e, 0xc6, 0x74, 0x17, 0x34, 0x18, 0xa9, 0x4a, 0x88, 0xdb, 0x
[1691403085.956626][7870:7872] CHIP:DMG: 					] (492 bytes)
[1691403085.956641][7870:7872] CHIP:DMG: 				},
[1691403085.956653][7870:7872] CHIP:DMG: 			},
[1691403085.956672][7870:7872] CHIP:DMG:
[1691403085.956683][7870:7872] CHIP:DMG: 		},
[1691403085.956702][7870:7872] CHIP:DMG:
[1691403085.956713][7870:7872] CHIP:DMG: 	],
[1691403085.956733][7870:7872] CHIP:DMG:
[1691403085.956745][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403085.956760][7870:7872] CHIP:DMG: },
[1691403085.956817][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1691403085.956839][7870:7872] CHIP:CTL: Received certificate chain from the device
[1691403085.956859][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1691403085.956874][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1691403085.956893][7870:7872] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1691403085.956905][7870:7872] CHIP:CTL: Sending Attestation Request to the device.
[1691403085.956920][7870:7872] CHIP:CTL: Sending Attestation request to 0x7f942400c130 device
[1691403085.956959][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403085.956977][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403085.957029][7870:7872] CHIP:EM: <<< [E:58379i S:15906 M:216097739] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403085.957055][7870:7872] CHIP:IN: (S) Sending msg 216097739 on secure session with LSID: 15906
[1691403085.957336][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403085.957360][7870:7872] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1691403085.957403][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403086.089459][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403086.181978][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403086.182090][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403086.317593][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403086.317778][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403086.407109][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403086.407247][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403086.407372][7870:7872] CHIP:EM: >>> [E:58379i S:15906 M:122858327] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403086.407398][7870:7872] CHIP:EM: Found matching exchange: 58379i, Delegate: 0x7f942c057d58
[1691403086.407430][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403086.407469][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403086.407484][7870:7872] CHIP:DMG: {
[1691403086.407503][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403086.407519][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403086.407547][7870:7872] CHIP:DMG: 	[
[1691403086.407561][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403086.407587][7870:7872] CHIP:DMG: 		{
[1691403086.407602][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403086.407617][7870:7872] CHIP:DMG: 			{
[1691403086.407631][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403086.407648][7870:7872] CHIP:DMG: 				{
[1691403086.407664][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403086.407680][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403086.407695][7870:7872] CHIP:DMG: 					CommandId = 0x1,
[1691403086.407710][7870:7872] CHIP:DMG: 				},
[1691403086.407728][7870:7872] CHIP:DMG:
[1691403086.407742][7870:7872] CHIP:DMG: 				CommandFields =
[1691403086.407785][7870:7872] CHIP:DMG: 				{
[1691403086.407804][7870:7872] CHIP:DMG: 					0x0 = [
[1691403086.408010][7870:7872] CHIP:DMG: 							0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1691403086.408093][7870:7872] CHIP:DMG: 					] (583 bytes)
[1691403086.408113][7870:7872] CHIP:DMG: 					0x1 = [
[1691403086.408175][7870:7872] CHIP:DMG: 							0x61, 0x0a, 0xec, 0x5a, 0xd0, 0x18, 0x4d, 0x19, 0xf1, 0x1a, 0x4e, 0x5d, 0x43, 0x75, 0x18, 0xa8, 0x66, 0xd4, 0x77, 0xab, 0xe4, 0xfe, 0xb3, 0x27, 0xc7, 0x58, 0x97, 0x36, 0xf3, 0x57, 0x31, 0xc4, 0x03, 0xd7, 0xb0, 0x54, 0x06, 0x26, 0x81, 0xaf, 0x06, 0x6b, 0xfe, 0x77, 0x1b, 0x9a, 0xb3, 0xf4, 0xe0, 0x41, 0xe5, 0xa8, 0x3f, 0x00, 0x17, 0xad, 0xda, 0xf8, 0x37, 0x72, 0xd6, 0x8d, 0xb4, 0x65,
[1691403086.408204][7870:7872] CHIP:DMG: 					] (64 bytes)
[1691403086.408226][7870:7872] CHIP:DMG: 				},
[1691403086.408242][7870:7872] CHIP:DMG: 			},
[1691403086.408268][7870:7872] CHIP:DMG:
[1691403086.408283][7870:7872] CHIP:DMG: 		},
[1691403086.408310][7870:7872] CHIP:DMG:
[1691403086.408323][7870:7872] CHIP:DMG: 	],
[1691403086.408351][7870:7872] CHIP:DMG:
[1691403086.408366][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403086.408381][7870:7872] CHIP:DMG: },
[1691403086.408447][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1691403086.408473][7870:7872] CHIP:CTL: Received Attestation Information from the device
[1691403086.408493][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1691403086.408510][7870:7872] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
[1691403086.408533][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1691403086.408552][7870:7872] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1691403086.408566][7870:7872] CHIP:CTL: Verifying attestation
[1691403086.427087][7870:7872] CHIP:CR: mbedTLS error: ERROR - Generic error
[1691403086.457052][7870:7872] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
[1691403086.457071][7870:7872] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
[1691403086.457080][7870:7872] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
[1691403086.457091][7870:7872] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
[1691403086.457097][7870:7872] CHIP:CTL: Sending CSR request to 0x7f942400c130 device
[1691403086.457124][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403086.457134][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403086.457169][7870:7872] CHIP:EM: <<< [E:58380i S:15906 M:216097740] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403086.457181][7870:7872] CHIP:IN: (S) Sending msg 216097740 on secure session with LSID: 15906
[1691403086.457329][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403086.457342][7870:7872] CHIP:CTL: Sent CSR request, waiting for the CSR
[1691403086.457364][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403086.539681][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.006584][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403087.006779][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403087.080840][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403087.081008][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403087.081117][7870:7872] CHIP:EM: >>> [E:58380i S:15906 M:122858328] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403087.081147][7870:7872] CHIP:EM: Found matching exchange: 58380i, Delegate: 0x7f942c057188
[1691403087.081183][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403087.081219][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403087.081233][7870:7872] CHIP:DMG: {
[1691403087.081251][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403087.081267][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403087.081297][7870:7872] CHIP:DMG: 	[
[1691403087.081311][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403087.081339][7870:7872] CHIP:DMG: 		{
[1691403087.081354][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403087.081376][7870:7872] CHIP:DMG: 			{
[1691403087.081392][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403087.081413][7870:7872] CHIP:DMG: 				{
[1691403087.081434][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403087.081454][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403087.081473][7870:7872] CHIP:DMG: 					CommandId = 0x5,
[1691403087.081490][7870:7872] CHIP:DMG: 				},
[1691403087.081513][7870:7872] CHIP:DMG:
[1691403087.081530][7870:7872] CHIP:DMG: 				CommandFields =
[1691403087.081551][7870:7872] CHIP:DMG: 				{
[1691403087.081570][7870:7872] CHIP:DMG: 					0x0 = [
[1691403087.081720][7870:7872] CHIP:DMG: 							0x15, 0x30, 0x01, 0xce, 0x30, 0x81, 0xcb, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x8a, 0x2d, 0xcf, 0xb2, 0x84, 0xaa, 0x56, 0xcb, 0xe2, 0x72, 0xe6, 0xc7, 0x98, 0xb1, 0xde, 0xf5, 0xd3, 0xbc, 0xc9, 0x61, 0x2f, 0x50, 0xe8, 0xcd, 0x95, 0x2f, 0x5d, 0x79, 0xbd, 0x49, 0x73, 0xad, 0xcf, 0x3a, 0x9a, 0xb0, 0xf1, 0x2f, 0x4d, 0xe2, 0xa6, 0xd5, 0x87, 0xee, 0x06, 0x11, 0x93, 0xbb, 0x4d, 0xfa, 0x85, 0x2e, 0x00, 0x57, 0x3a, 0xcc, 0xde, 0x19, 0x2c, 0x22, 0x77, 0x73, 0x46, 0x28, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x49, 0x00, 0x30, 0x46, 0x02, 0x21, 0x00, 0xfa, 0x2d, 0xb0, 0xfa, 0xf3, 0xd6, 0x29, 0x15, 0x2f, 0xea, 0xa2, 0x91, 0x8b, 0xe4, 0x08, 0xdb, 0xb9, 0x1f, 0xd3, 0xe8, 0x9b, 0x3b, 0xef, 0xef, 0x69, 0x7e, 0xe3, 0x06, 0x1c, 0x44, 0xee, 0xdf, 0x02, 0x21, 0x00, 0x9a, 0xf1, 0x79, 0xff, 0xce, 0x78, 0xa7, 0xd3, 0x8b, 0x88, 0x24, 0x72, 0x00, 0xa3, 0xb1, 0x68, 0x37, 0x39, 0xd2, 0x8f, 0xb7, 0x61, 0x06, 0x12, 0xfb, 0xa4, 0x3d, 0x7a, 0x48, 0x8f, 0xe7, 0x28, 0x30, 0x02, 0x20, 0x17, 0x05, 0xf0, 0xd3, 0xee, 0xa9, 0x0a, 0x10, 0xa1, 0x17, 0xa4, 0x37, 0x86, 0x06, 0x6a, 0x84, 0x60, 0x47, 0xf5, 0xcf, 0x73, 0xc9, 0x9f, 0xa4, 0xee, 0x44, 0x05, 0x5a, 0x9a, 0xdb, 0xc1, 0xd2, 0x18,
[1691403087.081785][7870:7872] CHIP:DMG: 					] (246 bytes)
[1691403087.081806][7870:7872] CHIP:DMG: 					0x1 = [
[1691403087.081857][7870:7872] CHIP:DMG: 							0x5f, 0x19, 0xd6, 0x7f, 0xe9, 0x28, 0x73, 0x41, 0x12, 0x51, 0x4d, 0x75, 0x68, 0x4f, 0xf6, 0x68, 0x55, 0xe8, 0x00, 0x7f, 0xca, 0x03, 0x27, 0x72, 0xe4, 0xfd, 0x38, 0x98, 0xac, 0xc5, 0xaf, 0x08, 0x2d, 0x6d, 0x50, 0x4b, 0x68, 0x07, 0xfc, 0x86, 0x63, 0x70, 0x2e, 0x96, 0x17, 0xab, 0x80, 0x12, 0x71, 0xa9, 0x32, 0x86, 0xfb, 0x4c, 0x67, 0xca, 0x1f, 0xae, 0x19, 0x0a, 0x61, 0x3e, 0xf4, 0x32,
[1691403087.081878][7870:7872] CHIP:DMG: 					] (64 bytes)
[1691403087.081894][7870:7872] CHIP:DMG: 				},
[1691403087.081908][7870:7872] CHIP:DMG: 			},
[1691403087.081929][7870:7872] CHIP:DMG:
[1691403087.081942][7870:7872] CHIP:DMG: 		},
[1691403087.081962][7870:7872] CHIP:DMG:
[1691403087.081975][7870:7872] CHIP:DMG: 	],
[1691403087.081997][7870:7872] CHIP:DMG:
[1691403087.082010][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403087.082022][7870:7872] CHIP:DMG: },
[1691403087.082080][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
[1691403087.082103][7870:7872] CHIP:CTL: Received certificate signing request from the device
[1691403087.082123][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
[1691403087.082136][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
[1691403087.082153][7870:7872] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
[1691403087.097671][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
[1691403087.097698][7870:7872] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
[1691403087.097712][7870:7872] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
[1691403087.097721][7870:7872] CHIP:CTL: Getting certificate chain for the device from the issuer
[1691403087.097759][7870:7872] CHIP:CTL: Verifying Certificate Signing Request
[1691403087.112089][7870:7872] CHIP:CTL: Generating NOC
[1691403087.116983][7870:7872] CHIP:CTL: Providing certificate chain to the commissioner
[1691403087.117005][7870:7872] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
[1691403087.117018][7870:7872] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
[1691403087.117086][7870:7872] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
[1691403087.117096][7870:7872] CHIP:CTL: Sending root certificate to the device
[1691403087.117126][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403087.117136][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403087.117178][7870:7872] CHIP:EM: <<< [E:58381i S:15906 M:216097741] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403087.117192][7870:7872] CHIP:IN: (S) Sending msg 216097741 on secure session with LSID: 15906
[1691403087.117386][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403087.117399][7870:7872] CHIP:CTL: Sent root certificate to the device
[1691403087.117525][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403087.168958][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.259154][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.350723][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403087.350899][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403087.351002][7870:7872] CHIP:EM: >>> [E:58381i S:15906 M:122858329] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403087.351027][7870:7872] CHIP:EM: Found matching exchange: 58381i, Delegate: 0x7f942c057d58
[1691403087.351059][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403087.351098][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403087.351112][7870:7872] CHIP:DMG: {
[1691403087.351125][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403087.351137][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403087.351157][7870:7872] CHIP:DMG: 	[
[1691403087.351171][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403087.351191][7870:7872] CHIP:DMG: 		{
[1691403087.351203][7870:7872] CHIP:DMG: 			CommandStatusIB =
[1691403087.351221][7870:7872] CHIP:DMG: 			{
[1691403087.351236][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403087.351253][7870:7872] CHIP:DMG: 				{
[1691403087.351270][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403087.351286][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403087.351302][7870:7872] CHIP:DMG: 					CommandId = 0xb,
[1691403087.351318][7870:7872] CHIP:DMG: 				},
[1691403087.351338][7870:7872] CHIP:DMG:
[1691403087.351353][7870:7872] CHIP:DMG: 				StatusIB =
[1691403087.351370][7870:7872] CHIP:DMG: 				{
[1691403087.351386][7870:7872] CHIP:DMG: 					status = 0x00 (SUCCESS),
[1691403087.351401][7870:7872] CHIP:DMG: 				},
[1691403087.351418][7870:7872] CHIP:DMG:
[1691403087.351433][7870:7872] CHIP:DMG: 			},
[1691403087.351452][7870:7872] CHIP:DMG:
[1691403087.351466][7870:7872] CHIP:DMG: 		},
[1691403087.351487][7870:7872] CHIP:DMG:
[1691403087.351500][7870:7872] CHIP:DMG: 	],
[1691403087.351522][7870:7872] CHIP:DMG:
[1691403087.351536][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403087.351550][7870:7872] CHIP:DMG: },
[1691403087.351602][7870:7872] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
[1691403087.351623][7870:7872] CHIP:CTL: Device confirmed that it has received the root certificate
[1691403087.351644][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
[1691403087.351658][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
[1691403087.351678][7870:7872] CHIP:CTL: Performing next commissioning step 'SendNOC'
[1691403087.351725][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403087.351775][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403087.351851][7870:7872] CHIP:EM: <<< [E:58382i S:15906 M:216097742] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403087.351887][7870:7872] CHIP:IN: (S) Sending msg 216097742 on secure session with LSID: 15906
[1691403087.352241][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403087.352270][7870:7872] CHIP:CTL: Sent operational certificate to the device
[1691403087.352322][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403087.439718][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.529431][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.619250][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.861547][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403087.861717][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403087.861837][7870:7872] CHIP:EM: >>> [E:58382i S:15906 M:122858330] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403087.861860][7870:7872] CHIP:EM: Found matching exchange: 58382i, Delegate: 0x7f942c057188
[1691403087.861891][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403087.861932][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403087.861953][7870:7872] CHIP:DMG: {
[1691403087.861970][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403087.861987][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403087.862015][7870:7872] CHIP:DMG: 	[
[1691403087.862029][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403087.862051][7870:7872] CHIP:DMG: 		{
[1691403087.862063][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403087.862076][7870:7872] CHIP:DMG: 			{
[1691403087.862087][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403087.862101][7870:7872] CHIP:DMG: 				{
[1691403087.862121][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403087.862148][7870:7872] CHIP:DMG: 					ClusterId = 0x3e,
[1691403087.862168][7870:7872] CHIP:DMG: 					CommandId = 0x8,
[1691403087.862187][7870:7872] CHIP:DMG: 				},
[1691403087.862213][7870:7872] CHIP:DMG:
[1691403087.862229][7870:7872] CHIP:DMG: 				CommandFields =
[1691403087.862250][7870:7872] CHIP:DMG: 				{
[1691403087.862272][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403087.862299][7870:7872] CHIP:DMG: 					0x1 = 1,
[1691403087.862322][7870:7872] CHIP:DMG: 				},
[1691403087.862339][7870:7872] CHIP:DMG: 			},
[1691403087.862364][7870:7872] CHIP:DMG:
[1691403087.862379][7870:7872] CHIP:DMG: 		},
[1691403087.862406][7870:7872] CHIP:DMG:
[1691403087.862420][7870:7872] CHIP:DMG: 	],
[1691403087.862448][7870:7872] CHIP:DMG:
[1691403087.862463][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403087.862478][7870:7872] CHIP:DMG: },
[1691403087.862549][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
[1691403087.862575][7870:7872] CHIP:CTL: Device returned status 0 on receiving the NOC
[1691403087.862590][7870:7872] CHIP:CTL: Operational credentials provisioned on device 0x7f942400c130
[1691403087.862605][7870:7872] CHIP:TOO: Secure Pairing Success
[1691403087.862624][7870:7872] CHIP:TOO: CASE establishment successful
[1691403087.862648][7870:7872] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
[1691403087.862663][7870:7872] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1691403087.862674][7870:7872] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
[1691403087.862688][7870:7872] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
[1691403087.862742][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403087.862772][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403087.862845][7870:7872] CHIP:EM: <<< [E:58383i S:15906 M:216097743] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403087.862874][7870:7872] CHIP:IN: (S) Sending msg 216097743 on secure session with LSID: 15906
[1691403087.863134][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403087.863195][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403087.979055][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403087.980724][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403087.980905][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403087.981021][7870:7872] CHIP:EM: >>> [E:58383i S:15906 M:122858331] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403087.981055][7870:7872] CHIP:EM: Found matching exchange: 58383i, Delegate: 0x7f942c057d58
[1691403087.981084][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403087.981115][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403087.981126][7870:7872] CHIP:DMG: {
[1691403087.981137][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403087.981148][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403087.981164][7870:7872] CHIP:DMG: 	[
[1691403087.981174][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403087.981190][7870:7872] CHIP:DMG: 		{
[1691403087.981201][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403087.981214][7870:7872] CHIP:DMG: 			{
[1691403087.981224][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403087.981241][7870:7872] CHIP:DMG: 				{
[1691403087.981263][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403087.981283][7870:7872] CHIP:DMG: 					ClusterId = 0x31,
[1691403087.981304][7870:7872] CHIP:DMG: 					CommandId = 0x5,
[1691403087.981323][7870:7872] CHIP:DMG: 				},
[1691403087.981347][7870:7872] CHIP:DMG:
[1691403087.981363][7870:7872] CHIP:DMG: 				CommandFields =
[1691403087.981384][7870:7872] CHIP:DMG: 				{
[1691403087.981404][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403087.981426][7870:7872] CHIP:DMG: 					0x2 = 0,
[1691403087.981446][7870:7872] CHIP:DMG: 				},
[1691403087.981462][7870:7872] CHIP:DMG: 			},
[1691403087.981489][7870:7872] CHIP:DMG:
[1691403087.981503][7870:7872] CHIP:DMG: 		},
[1691403087.981530][7870:7872] CHIP:DMG:
[1691403087.981544][7870:7872] CHIP:DMG: 	],
[1691403087.981571][7870:7872] CHIP:DMG:
[1691403087.981586][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403087.981601][7870:7872] CHIP:DMG: },
[1691403087.981664][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
[1691403087.981754][7870:7872] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
[1691403087.981776][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
[1691403087.981793][7870:7872] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'FailsafeBeforeThreadEnable'
[1691403087.981814][7870:7872] CHIP:CTL: Performing next commissioning step 'FailsafeBeforeThreadEnable'
[1691403087.981840][7870:7872] CHIP:CTL: Arming failsafe (76 seconds)
[1691403087.981880][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403087.981899][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403087.981955][7870:7872] CHIP:EM: <<< [E:58384i S:15906 M:216097744] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403087.981981][7870:7872] CHIP:IN: (S) Sending msg 216097744 on secure session with LSID: 15906
[1691403087.982243][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403087.982305][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403088.069641][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403088.115552][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403088.115660][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403088.115801][7870:7872] CHIP:EM: >>> [E:58384i S:15906 M:122858332] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403088.115829][7870:7872] CHIP:EM: Found matching exchange: 58384i, Delegate: 0x7f942c057188
[1691403088.115877][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403088.115924][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403088.115939][7870:7872] CHIP:DMG: {
[1691403088.115957][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403088.115974][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403088.116009][7870:7872] CHIP:DMG: 	[
[1691403088.116023][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403088.116052][7870:7872] CHIP:DMG: 		{
[1691403088.116065][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403088.116087][7870:7872] CHIP:DMG: 			{
[1691403088.116104][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403088.116125][7870:7872] CHIP:DMG: 				{
[1691403088.116146][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403088.116169][7870:7872] CHIP:DMG: 					ClusterId = 0x30,
[1691403088.116191][7870:7872] CHIP:DMG: 					CommandId = 0x1,
[1691403088.116210][7870:7872] CHIP:DMG: 				},
[1691403088.116234][7870:7872] CHIP:DMG:
[1691403088.116252][7870:7872] CHIP:DMG: 				CommandFields =
[1691403088.116274][7870:7872] CHIP:DMG: 				{
[1691403088.116296][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403088.116319][7870:7872] CHIP:DMG: 					0x1 = "" (0 chars),
[1691403088.116340][7870:7872] CHIP:DMG: 				},
[1691403088.116358][7870:7872] CHIP:DMG: 			},
[1691403088.116386][7870:7872] CHIP:DMG:
[1691403088.116401][7870:7872] CHIP:DMG: 		},
[1691403088.116429][7870:7872] CHIP:DMG:
[1691403088.116443][7870:7872] CHIP:DMG: 	],
[1691403088.116471][7870:7872] CHIP:DMG:
[1691403088.116486][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403088.116501][7870:7872] CHIP:DMG: },
[1691403088.116564][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1691403088.116591][7870:7872] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1691403088.116612][7870:7872] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
[1691403088.116626][7870:7872] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
[1691403088.116647][7870:7872] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
[1691403088.116691][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403088.116712][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403088.116768][7870:7872] CHIP:EM: <<< [E:58385i S:15906 M:216097745] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403088.116795][7870:7872] CHIP:IN: (S) Sending msg 216097745 on secure session with LSID: 15906
[1691403088.117034][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403088.117088][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403088.204543][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403089.330590][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403089.330709][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403089.330814][7870:7872] CHIP:EM: >>> [E:58385i S:15906 M:122858333] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403089.330844][7870:7872] CHIP:EM: Found matching exchange: 58385i, Delegate: 0x7f942c057d58
[1691403089.330869][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403089.330907][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403089.330922][7870:7872] CHIP:DMG: {
[1691403089.330938][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403089.330954][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403089.330980][7870:7872] CHIP:DMG: 	[
[1691403089.330995][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403089.331021][7870:7872] CHIP:DMG: 		{
[1691403089.331036][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403089.331056][7870:7872] CHIP:DMG: 			{
[1691403089.331072][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403089.331098][7870:7872] CHIP:DMG: 				{
[1691403089.331118][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403089.331137][7870:7872] CHIP:DMG: 					ClusterId = 0x31,
[1691403089.331157][7870:7872] CHIP:DMG: 					CommandId = 0x7,
[1691403089.331174][7870:7872] CHIP:DMG: 				},
[1691403089.331194][7870:7872] CHIP:DMG:
[1691403089.331210][7870:7872] CHIP:DMG: 				CommandFields =
[1691403089.331228][7870:7872] CHIP:DMG: 				{
[1691403089.331250][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403089.331269][7870:7872] CHIP:DMG: 					0x2 = NULL
[1691403089.331294][7870:7872] CHIP:DMG: 				},
[1691403089.331310][7870:7872] CHIP:DMG: 			},
[1691403089.331334][7870:7872] CHIP:DMG:
[1691403089.331349][7870:7872] CHIP:DMG: 		},
[1691403089.331374][7870:7872] CHIP:DMG:
[1691403089.331388][7870:7872] CHIP:DMG: 	],
[1691403089.331413][7870:7872] CHIP:DMG:
[1691403089.331428][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403089.331443][7870:7872] CHIP:DMG: },
[1691403089.331508][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
[1691403089.331533][7870:7872] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
[1691403089.331554][7870:7872] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
[1691403089.331571][7870:7872] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
[1691403089.331590][7870:7872] CHIP:CTL: Performing next commissioning step 'FindOperational'
[1691403089.331604][7870:7872] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000001]
[1691403089.331620][7870:7872] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
[1691403089.331644][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
[1691403089.331664][7870:7872] CHIP:DIS: Resolving CEFAD72140B20CDA:0000000000000001 ...
[1691403089.332412][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403089.332779][7870:7872] CHIP:DL: Avahi resolve found
[1691403089.332817][7870:7872] CHIP:DIS: Node ID resolved for CEFAD72140B20CDA:0000000000000001
[1691403089.332845][7870:7872] CHIP:DIS: 	Hostname: 127E39564B673908
[1691403089.332864][7870:7872] CHIP:DIS: 	IP Address #1: fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7
[1691403089.332875][7870:7872] CHIP:DIS: 	Port: 5540
[1691403089.332887][7870:7872] CHIP:DIS: 	Mrp Interval idle: 1000 ms
[1691403089.332900][7870:7872] CHIP:DIS: 	Mrp Interval active: 1000 ms
[1691403089.332912][7870:7872] CHIP:DIS: 	TCP Supported: 0
[1691403089.333107][7870:7872] CHIP:DIS: Lookup clearing interface for non LL address
[1691403089.333150][7870:7872] CHIP:DIS: UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7%wlp5s0]:5540: new best score: 4
[1691403089.333163][7870:7872] CHIP:DIS: Checking node lookup status after 1 ms
[1691403089.333175][7870:7872] CHIP:DIS: Keeping DNSSD lookup active
[1691403089.532304][7870:7872] CHIP:DIS: Checking node lookup status after 201 ms
[1691403089.532357][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540 while in state 2
[1691403089.532378][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
[1691403089.532440][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Allocated Type:2 LSID:15907
[1691403089.532505][7870:7872] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
[1691403089.540340][7870:7872] CHIP:EM: <<< [E:58386i S:0 M:166617638] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
[1691403089.540400][7870:7872] CHIP:IN: (U) Sending msg 166617638 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403089.540486][7870:7872] CHIP:SC: Sent Sigma1 msg
[1691403089.540500][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
[1691403090.803873][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617638 on exchange 58386i Send Cnt 1
[1691403090.803923][7870:7872] CHIP:IN: (U) Sending msg 166617638 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403090.861150][7870:7872] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
[1691403091.894189][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403092.050497][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617638 on exchange 58386i Send Cnt 2
[1691403092.050560][7870:7872] CHIP:IN: (U) Sending msg 166617638 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403094.099605][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617638 on exchange 58386i Send Cnt 3
[1691403094.099672][7870:7872] CHIP:IN: (U) Sending msg 166617638 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403094.453325][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403094.453410][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403097.159149][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403097.400545][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617638 on exchange 58386i Send Cnt 4
[1691403097.400601][7870:7872] CHIP:IN: (U) Sending msg 166617638 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403099.717736][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403099.717922][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403102.012114][7870:7872] CHIP:EM: Failed to Send CHIP MessageCounter:166617638 on exchange 58386i sendCount: 4 max retries: 4
[1691403102.469157][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403105.029819][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403105.029932][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403105.628685][7870:7872] CHIP:SC: CASESession timed out while waiting for a response from the peer. Current state was 1
[1691403105.628729][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Released - Type:2 LSID:15907
[1691403105.628761][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
[1691403105.628790][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
[1691403105.628820][7870:7872] CHIP:DIS: OperationalSessionSetup:attempts done: 1, attempts left: 2, retry delay 1s, status src/system/SystemLayerImplSelect.cpp:167: Success
[1691403105.628830][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 6
[1691403105.628860][7870:7872] CHIP:CTL: Session establishment failed for <0000000000000001, 1>, error: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 8 seconds
[1691403105.628885][7870:7872] CHIP:CTL: Arming failsafe (68 seconds)
[1691403105.628932][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403105.628951][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403105.629013][7870:7872] CHIP:EM: <<< [E:58387i S:15906 M:216097746] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403105.629037][7870:7872] CHIP:IN: (S) Sending msg 216097746 on secure session with LSID: 15906
[1691403105.629287][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403105.710078][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403105.755846][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403105.756027][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403105.756128][7870:7872] CHIP:EM: >>> [E:58387i S:15906 M:122858334] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403105.756153][7870:7872] CHIP:EM: Found matching exchange: 58387i, Delegate: 0x7f942c057188
[1691403105.756176][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403105.756216][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403105.756229][7870:7872] CHIP:DMG: {
[1691403105.756240][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403105.756250][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403105.756267][7870:7872] CHIP:DMG: 	[
[1691403105.756276][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403105.756292][7870:7872] CHIP:DMG: 		{
[1691403105.756302][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403105.756314][7870:7872] CHIP:DMG: 			{
[1691403105.756324][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403105.756336][7870:7872] CHIP:DMG: 				{
[1691403105.756348][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403105.756369][7870:7872] CHIP:DMG: 					ClusterId = 0x30,
[1691403105.756388][7870:7872] CHIP:DMG: 					CommandId = 0x1,
[1691403105.756407][7870:7872] CHIP:DMG: 				},
[1691403105.756428][7870:7872] CHIP:DMG:
[1691403105.756445][7870:7872] CHIP:DMG: 				CommandFields =
[1691403105.756464][7870:7872] CHIP:DMG: 				{
[1691403105.756493][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403105.756515][7870:7872] CHIP:DMG: 					0x1 = "" (0 chars),
[1691403105.756532][7870:7872] CHIP:DMG: 				},
[1691403105.756544][7870:7872] CHIP:DMG: 			},
[1691403105.756567][7870:7872] CHIP:DMG:
[1691403105.756580][7870:7872] CHIP:DMG: 		},
[1691403105.756602][7870:7872] CHIP:DMG:
[1691403105.756615][7870:7872] CHIP:DMG: 	],
[1691403105.756639][7870:7872] CHIP:DMG:
[1691403105.756652][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403105.756664][7870:7872] CHIP:DMG: },
[1691403105.756725][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1691403105.756751][7870:7872] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
[1691403105.756781][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403106.629799][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 6 --> 2
[1691403106.629835][7870:7872] CHIP:DIS: Resolving CEFAD72140B20CDA:0000000000000001 ...
[1691403106.631114][7870:7872] CHIP:DL: Avahi resolve found
[1691403106.631156][7870:7872] CHIP:DIS: Node ID resolved for CEFAD72140B20CDA:0000000000000001
[1691403106.631166][7870:7872] CHIP:DIS: 	Hostname: 127E39564B673908
[1691403106.631177][7870:7872] CHIP:DIS: 	IP Address #1: fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7
[1691403106.631185][7870:7872] CHIP:DIS: 	Port: 5540
[1691403106.631193][7870:7872] CHIP:DIS: 	Mrp Interval idle: 1000 ms
[1691403106.631202][7870:7872] CHIP:DIS: 	Mrp Interval active: 1000 ms
[1691403106.631211][7870:7872] CHIP:DIS: 	TCP Supported: 0
[1691403106.631411][7870:7872] CHIP:DIS: Lookup clearing interface for non LL address
[1691403106.631456][7870:7872] CHIP:DIS: UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7%wlp5s0]:5540: new best score: 4
[1691403106.631469][7870:7872] CHIP:DIS: Checking node lookup status after 2 ms
[1691403106.631483][7870:7872] CHIP:DIS: Keeping DNSSD lookup active
[1691403106.830766][7870:7872] CHIP:DIS: Checking node lookup status after 201 ms
[1691403106.830817][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540 while in state 2
[1691403106.830839][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
[1691403106.830889][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Allocated Type:2 LSID:15908
[1691403106.830916][7870:7872] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
[1691403106.838442][7870:7872] CHIP:EM: <<< [E:58388i S:0 M:166617639] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
[1691403106.838480][7870:7872] CHIP:IN: (U) Sending msg 166617639 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403106.838572][7870:7872] CHIP:SC: Sent Sigma1 msg
[1691403106.838587][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
[1691403108.016007][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617639 on exchange 58388i Send Cnt 1
[1691403108.016064][7870:7872] CHIP:IN: (U) Sending msg 166617639 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403108.319259][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403109.308314][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617639 on exchange 58388i Send Cnt 2
[1691403109.308364][7870:7872] CHIP:IN: (U) Sending msg 166617639 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403110.877949][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403110.878078][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403111.364268][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617639 on exchange 58388i Send Cnt 3
[1691403111.364323][7870:7872] CHIP:IN: (U) Sending msg 166617639 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403113.584371][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403114.351265][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617639 on exchange 58388i Send Cnt 4
[1691403114.351312][7870:7872] CHIP:IN: (U) Sending msg 166617639 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403116.141775][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403116.141923][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403118.849486][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403119.882682][7870:7872] CHIP:EM: Failed to Send CHIP MessageCounter:166617639 on exchange 58388i sendCount: 4 max retries: 4
[1691403121.409785][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403121.409958][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403122.927666][7870:7872] CHIP:SC: CASESession timed out while waiting for a response from the peer. Current state was 1
[1691403122.927707][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Released - Type:2 LSID:15908
[1691403122.927744][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
[1691403122.927794][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
[1691403122.927833][7870:7872] CHIP:DIS: OperationalSessionSetup:attempts done: 2, attempts left: 1, retry delay 36s, status src/system/SystemLayerImplSelect.cpp:167: Success
[1691403122.927849][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 1 --> 6
[1691403122.927876][7870:7872] CHIP:CTL: Session establishment failed for <0000000000000001, 1>, error: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 43 seconds
[1691403122.927898][7870:7872] CHIP:CTL: Arming failsafe (103 seconds)
[1691403122.927964][7870:7872] CHIP:DMG: ICR moving to [AddingComm]
[1691403122.927987][7870:7872] CHIP:DMG: ICR moving to [AddedComma]
[1691403122.928058][7870:7872] CHIP:EM: <<< [E:58389i S:15906 M:216097747] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1691403122.928093][7870:7872] CHIP:IN: (S) Sending msg 216097747 on secure session with LSID: 15906
[1691403122.928393][7870:7872] CHIP:DMG: ICR moving to [CommandSen]
[1691403122.989612][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403123.035598][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403123.035808][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403123.035926][7870:7872] CHIP:EM: >>> [E:58389i S:15906 M:122858335] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1691403123.035962][7870:7872] CHIP:EM: Found matching exchange: 58389i, Delegate: 0x7f942c057188
[1691403123.035994][7870:7872] CHIP:DMG: ICR moving to [ResponseRe]
[1691403123.036036][7870:7872] CHIP:DMG: InvokeResponseMessage =
[1691403123.036050][7870:7872] CHIP:DMG: {
[1691403123.036067][7870:7872] CHIP:DMG: 	suppressResponse = false,
[1691403123.036088][7870:7872] CHIP:DMG: 	InvokeResponseIBs =
[1691403123.036118][7870:7872] CHIP:DMG: 	[
[1691403123.036131][7870:7872] CHIP:DMG: 		InvokeResponseIB =
[1691403123.036159][7870:7872] CHIP:DMG: 		{
[1691403123.036173][7870:7872] CHIP:DMG: 			CommandDataIB =
[1691403123.036193][7870:7872] CHIP:DMG: 			{
[1691403123.036209][7870:7872] CHIP:DMG: 				CommandPathIB =
[1691403123.036231][7870:7872] CHIP:DMG: 				{
[1691403123.036250][7870:7872] CHIP:DMG: 					EndpointId = 0x0,
[1691403123.036271][7870:7872] CHIP:DMG: 					ClusterId = 0x30,
[1691403123.036291][7870:7872] CHIP:DMG: 					CommandId = 0x1,
[1691403123.036306][7870:7872] CHIP:DMG: 				},
[1691403123.036324][7870:7872] CHIP:DMG:
[1691403123.036339][7870:7872] CHIP:DMG: 				CommandFields =
[1691403123.036355][7870:7872] CHIP:DMG: 				{
[1691403123.036376][7870:7872] CHIP:DMG: 					0x0 = 0,
[1691403123.036395][7870:7872] CHIP:DMG: 					0x1 = "" (0 chars),
[1691403123.036411][7870:7872] CHIP:DMG: 				},
[1691403123.036425][7870:7872] CHIP:DMG: 			},
[1691403123.036446][7870:7872] CHIP:DMG:
[1691403123.036459][7870:7872] CHIP:DMG: 		},
[1691403123.036479][7870:7872] CHIP:DMG:
[1691403123.036492][7870:7872] CHIP:DMG: 	],
[1691403123.036513][7870:7872] CHIP:DMG:
[1691403123.036526][7870:7872] CHIP:DMG: 	InteractionModelRevision = 1
[1691403123.036538][7870:7872] CHIP:DMG: },
[1691403123.036596][7870:7872] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1691403123.036620][7870:7872] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
[1691403123.036653][7870:7872] CHIP:DMG: ICR moving to [AwaitingDe]
[1691403125.599308][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403128.161938][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403128.162110][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403128.580896][7870:7871] CHIP:DL: Got IP address on interface: wlp5s0 IP: 192.168.7.165
[1691403128.581477][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 32770
[1691403128.788655][7870:7871] CHIP:DL: Got IP address on interface: wlp5s0 IP: 192.168.7.165
[1691403128.788765][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 32770
[1691403130.865106][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403133.422103][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403133.422202][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403136.129798][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403138.690179][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403138.690264][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403141.394584][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403143.953602][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403143.953759][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403146.705003][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403149.221947][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403149.222076][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403151.924728][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403154.481664][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403154.481825][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403157.189677][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403158.928277][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 6 --> 2
[1691403158.928314][7870:7872] CHIP:DIS: Resolving CEFAD72140B20CDA:0000000000000001 ...
[1691403158.929602][7870:7872] CHIP:DL: Avahi resolve found
[1691403158.929654][7870:7872] CHIP:DIS: Node ID resolved for CEFAD72140B20CDA:0000000000000001
[1691403158.929671][7870:7872] CHIP:DIS: 	Hostname: 127E39564B673908
[1691403158.929691][7870:7872] CHIP:DIS: 	IP Address #1: fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7
[1691403158.929703][7870:7872] CHIP:DIS: 	Port: 5540
[1691403158.929716][7870:7872] CHIP:DIS: 	Mrp Interval idle: 1000 ms
[1691403158.929730][7870:7872] CHIP:DIS: 	Mrp Interval active: 1000 ms
[1691403158.929746][7870:7872] CHIP:DIS: 	TCP Supported: 0
[1691403158.929926][7870:7872] CHIP:DIS: Lookup clearing interface for non LL address
[1691403158.929970][7870:7872] CHIP:DIS: UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7%wlp5s0]:5540: new best score: 4
[1691403158.929984][7870:7872] CHIP:DIS: Checking node lookup status after 1 ms
[1691403158.929998][7870:7872] CHIP:DIS: Keeping DNSSD lookup active
[1691403159.128923][7870:7872] CHIP:DIS: Checking node lookup status after 200 ms
[1691403159.128980][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540 while in state 2
[1691403159.129006][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
[1691403159.129061][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Allocated Type:2 LSID:15909
[1691403159.129093][7870:7872] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000001
[1691403159.135600][7870:7872] CHIP:EM: <<< [E:58390i S:0 M:166617640] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
[1691403159.135624][7870:7872] CHIP:IN: (U) Sending msg 166617640 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403159.135679][7870:7872] CHIP:SC: Sent Sigma1 msg
[1691403159.135687][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
[1691403159.749403][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403159.749607][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403160.465477][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617640 on exchange 58390i Send Cnt 1
[1691403160.465529][7870:7872] CHIP:IN: (U) Sending msg 166617640 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403161.642886][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617640 on exchange 58390i Send Cnt 2
[1691403161.642949][7870:7872] CHIP:IN: (U) Sending msg 166617640 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403162.500317][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403163.522782][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617640 on exchange 58390i Send Cnt 3
[1691403163.522827][7870:7872] CHIP:IN: (U) Sending msg 166617640 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403165.013984][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403165.014165][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403166.699874][7870:7872] CHIP:EM: Retransmitting MessageCounter:166617640 on exchange 58390i Send Cnt 4
[1691403166.699919][7870:7872] CHIP:IN: (U) Sending msg 166617640 to IP address 'UDP:[fd8a:1ee1:ee51:1:88c8:90a5:f389:9ac7]:5540'
[1691403167.720303][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403170.277544][7870:7871] CHIP:DL: Indication received, conn = 0x7f942c056c60
[1691403170.277655][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1691403171.420308][7870:7872] CHIP:EM: Failed to Send CHIP MessageCounter:166617640 on exchange 58390i sendCount: 4 max retries: 4
[1691403172.984995][7870:7872] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1691403175.225420][7870:7872] CHIP:SC: CASESession timed out while waiting for a response from the peer. Current state was 1
[1691403175.225468][7870:7872] CHIP:IN: SecureSession[0x7f94240176b0]: Released - Type:2 LSID:15909
[1691403175.225513][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
[1691403175.225539][7870:7872] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
[1691403175.225570][7870:7872] CHIP:CTL: Device connection failed. Error src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout
[1691403175.225606][7870:7872] CHIP:CTL: Error on commissioning step 'FindOperational': 'src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout'
[1691403175.225631][7870:7872] CHIP:CTL: Failed to perform commissioning step 20
[1691403175.225655][7870:7872] CHIP:CTL: Going from commissioning step 'FindOperational' with lastErr = 'src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout' -> 'Cleanup'
[1691403175.225686][7870:7872] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout'
[1691403175.225711][7870:7872] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1691403175.225740][7870:7872] CHIP:TOO: Device commissioning Failure: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout
[1691403175.225992][7870:7870] CHIP:CTL: Shutting down the commissioner
[1691403175.226015][7870:7870] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1691403175.226024][7870:7870] CHIP:DIS: Closing all BLE connections
[1691403175.226035][7870:7870] CHIP:IN: Clearing BLE pending packets.
[1691403175.226251][7870:7870] CHIP:BLE: Auto-closing end point's BLE connection.
[1691403175.226274][7870:7870] CHIP:DL: Closing BLE GATT connection (con 0x7f942c056c60)
[1691403175.226389][7870:7871] CHIP:DL: BluezDisconnect peer=F4:10:CB:75:55:F1
[1691403175.371432][7870:7870] CHIP:IN: SecureSession[0x7f94240095a0]: MarkForEviction Type:1 LSID:15906
[1691403175.371467][7870:7870] CHIP:SC: SecureSession[0x7f94240095a0]: Moving from state 'kActive' --> 'kPendingEviction'
[1691403175.371495][7870:7870] CHIP:IN: SecureSession[0x7f94240095a0]: Released - Type:1 LSID:15906
[1691403175.371516][7870:7870] CHIP:CTL: Shutting down the controller
[1691403175.371531][7870:7870] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1691403175.371542][7870:7870] CHIP:FP: Forgetting fabric 0x1
[1691403175.371561][7870:7870] CHIP:TS: Pending Last Known Good Time: 2023-06-01T07:38:45
[1691403175.371696][7870:7870] CHIP:TS: Previous Last Known Good Time: 2023-06-01T07:38:45
[1691403175.371716][7870:7870] CHIP:TS: Reverted Last Known Good Time to previous value
[1691403175.371739][7870:7870] CHIP:CTL: Shutting down the commissioner
[1691403175.371778][7870:7870] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1691403175.371792][7870:7870] CHIP:CTL: Shutting down the controller
[1691403175.371804][7870:7870] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1691403175.372028][7870:7871] CHIP:DL: Bluez disconnected
[1691403175.372053][7870:7871] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1691403175.372908][7870:7870] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1691403175.372971][7870:7870] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1691403175.373010][7870:7870] CHIP:FP: Shutting down FabricTable
[1691403175.373037][7870:7870] CHIP:TS: Pending Last Known Good Time: 2023-06-01T07:38:45
[1691403175.373150][7870:7870] CHIP:TS: Previous Last Known Good Time: 2023-06-01T07:38:45
[1691403175.373163][7870:7870] CHIP:TS: Reverted Last Known Good Time to previous value
[1691403175.373357][7870:7870] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-mcUdZA)
[1691403175.373759][7870:7870] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1691403175.373803][7870:7870] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1691403175.373819][7870:7870] CHIP:DL: Inet Layer shutdown
[1691403175.373831][7870:7870] CHIP:DL: BLE shutdown
[1691403175.374584][7870:7870] CHIP:DL: System Layer shutdown
[1691403175.374869][7870:7870] CHIP:TOO: Run command failure: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout
lenovo@lenovo-ThinkPad-L470:~/Downloads$ 7f94240095a0]: Moving from state 'kActive' --> 'kPendingEviction'
[1691403175.374869][7870:7870] CHIP:TOO: Run command failure: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout7f94240095a0]: Moving from state 'kActive' --> 'kPendingEviction'
I've tried
1. Factory reset the nRF 5340dk board
2. Reboot the Border Router
3. Try to unpair the node device in Chip-tool (it gave error : retry resolve)
Still, the error is not resolved
Am I missing something?
Need Help
  • Yes, while testing Matter over Thread the network and devices were up and running.
    After that when I try to set up it again (ie flashing nRF5340 as matter light bulb and then chip tool pairing) the issue arises.
  • Can you describe the following:
    Which commands do you use to
    1. Flash the device?
    2. Factory reset the device?
    Andreas
  • 1. For Flashing:  nRF Connect with VS Code -> Build and Flash Matter:Light bulb sample
     2. For Factory reset:
    Method 1: In the Windows command prompt using
    $nrfjprog --eraseall
    $nrfjprog --recover
    Method 2: Using nRF connect for Desktop -> Programmer tool -> Selecting device and erase all
    Method 3: After flashing and connecting to Putty Port used the following command for factory reset
    $matter device factoryreset
    $ot factoryreset
    Note:
    1. For Factory reset I've followed one method at a time (ie factory reset the device using method 1 and flash the sample then try the chip-tool command)
    2. For flashing, I've created a new build and flashed the device
    Noted, thank you for clarifying.
    I suspect that the device may still be provisioned on the network. Are you able to list all devices that are on
    1. The Thread network
    2. All visible Matter devices
    If you find your devices still being on the Thread network, you should be able to commission them to the Matter network over IP using ./chip-tool pairing onnetwork <node_id> <pin_code>
    In addition, do you have any luck with trying to commission the devices with new node IDs?
    Andreas
    I didn't understand this
    I've already tried the chip-tool command like ./chip-tool pairing onnetwork <node_id> <pin_code>   to commission devices to matter network over IPAlso, I've tried to commission the devices with new node IDs.
    I've tried all the possible solutions provided by you and devzone tickets to commission the device but failed.
    Is there any other solution that will help to commission the device?
    What about logs? Did you find anything?
