MPSL assert error 112, 2134 when trying to advertise
I am trying to set up my application to advertise on the BLE and am having issues with some asserts I am seeing.
The error I am getting is shown here in my serial console:
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF52x (0x0002)
I: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
I: Identity: E4:40:49:3C:12:84 (random)
I: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
I: LMP: version 5.4 (0x0d) subver 0x1077
Bluetooth initialized
E: MPSL ASSERT: 112, 2097
E: ***** HARD FAULT *****
E:   Fault escalation (see below)
E: ARCH_EXCEPT with reason 3
E: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000000
E: r3/a4:  0x200058bd r12/ip:  0x00000000 r14/lr:  0x00022b1f
E:  xpsr:  0x61000018
E: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
E: s[ 4]:  0x00000002  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
E: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
E: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0xffffffff  s[15]:  0x00000000
E: fpscr:  0x0df9bb2d
E: Faulting instruction address (r15/pc): 0x00022b2a
E: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
E: Fault during interrupt handling
E: Current thread: 0x20002728 (sysworkq)
What am I doing wrong here?
I looked at this ticket to see if it would help. It indicated the HFCLK may not have been started, but when I put the code in place to test the startup time it never exits the while loop. Maybe this is indicative of a custom hardware issue with that crystal? I did put in the code at the end (a call to mpsl_clock_hfclk_request), but that never calls the clock_started_cb unless I am debugging and slowly stepping through the code.
 MPSL ASSERT: 112, 2134 if using multiple BLE communication
Thanks for the support!
  • Hi Jon
    Sounds like the issue is hardware related then.
    I agree that investigating the clocks would be a natural first step.
    If it is the HF clock that is the problem it must be pretty serious, possibly the HF crystal is not able to start at all.
    If you are using external LF crystal this could also be the culprit, as this clock is used for the timing of various stack events.
    I think we should start by doing a proper hardware schematic and layout review, and see if we can spot any issues in your design.
    I recommend that you open a new ticket on this to keep the discussion separate, and make sure it gets handled by one of the hardware experts (hardware reviews is not my forte). You can link to this case for context.
    Best regards
    Torbjørn
  • After doing more testing, this would only happen rarely. I believe we had a few configuration issues that helped eliminate the errors, but our underlying issue was a missing decoupling capacitor on DEC4, causing all sorts of noise and instability on the internal LDO. We added a cap to ground on that pin and now everything is working just fine.
    Jon
  • Hi Jon
    Great to hear that you found the issue, I will consider the case closed then Slight smile
    Best regards
    Torbjørn
