How to reduce the size of an executable file?
I have modified the central_uart example to make the nRF52832 communicate with an ESP32 in MessagePack. After having disabled the logger configuration in the proj.conf file the size of the *.bin file is 225.8 kB which is too large for an nRF52805 (flash of 192 kB). Is there any way to reduce the bin file size?
Below the proj.conf file:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# Enable the BLE stack with GATT Client configuration
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
# Enable the BLE modules from NCS
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_SCAN_ADDRESS_CNT=1
CONFIG_BT_GATT_DM=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_MAX_CONN=1
# This example requires more workqueue stack
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable use of the non-minimal C functionality (stdio.h).
CONFIG_NEWLIB_LIBC=y
# Config logger
CONFIG_LOG=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
CONFIG_BT_DEBUG_LOG=n
CONFIG_BT_GATT_DM_DATA_PRINT=n
CONFIG_ASSERT=y
# Config I2C
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_SHELL=y
CONFIG_I2C_SHELL=y
Marco
  • Hello Hieu and James,
    Thanks for your answers and sorry for my late reply. I have tested your suggestions and they are useful to reduce the size of my software. Unfortunately the size reduction is not enough to make the executable small enough to be flashed in a nRF52805.
    I was having the same problem as msu i.e. the program size has become too big for the flash. So, I switched to using CONFIG_MINIMAL_LIBC=y but I am now getting compiler errors such as undefined reference to function abs(), undefined type time_t...
    Can someone please help?
    Thank you.
    Kind regards
    Mohamed
  • Hello Mohamed,
    Make sure you have the following headers included:
    #include <stdlib.h>
    #include <time.h>
  • Good Morning James,
    Thank you.
    Adding the two header files solved my initial problem. However, the linker is now complaining about undefined reference to sscanf(), rand() and srand().
    Note, I am already #including <stdio.h> and <stdlib.h>.
    The compiler is sending only a warning about sscanf()
    warning: implicit declaration of function 'sscanf' [-Wimplicit-function-declaration]
    It looks like the MINIMAL_LIBC does not include these functions.
    Thank you for your help.
    Mohamed
    1> Linking ‘zephyr_prebuilt.elf’
    1> C:\Zypher\v1.7.0\toolchain\opt/bin/arm-none-eabi-gcc zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=C:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_v149_tuning/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/drivers/adc/libdrivers__adc.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/i2c/libdrivers__i2c.a zephyr/drivers/pwm/libdrivers__pwm.a zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a zephyr/drivers/spi/libdrivers__spi.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/entropy/libdrivers__entropy.a modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -Lc:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v7e-m/nofp -LC:/Sandbox/HomeBeacon_dev_sb/build_nrf52833dk_nrf52833_v149_tuning/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -o zephyr\zephyr_prebuilt.elf
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(debug_console.c.obj): in function `debug_MainMenu':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/debug/debug_console.c:411: undefined reference to `sscanf'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(debug_menu_power.c.obj): in function `debug_PowerMenu':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/debug/debug_menu_power.c:137: undefined reference to `sscanf'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(debug_menu_radio.c.obj): in function `debug_RadioMenu':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/debug/debug_menu_radio.c:184: undefined reference to `sscanf'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(debug_menu_sensors.c.obj): in function `debug_SensorsMenu':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/debug/debug_menu_sensors.c:149: undefined reference to `sscanf'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(link_manager.c.obj): in function `link_GenerateSessionKey':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/link/link_manager.c:972: undefined reference to `rand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(link_message_handler.c.obj): in function `link_ProcessCommand':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/link/link_message_handler.c:347: undefined reference to `rand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/link/link_message_handler.c:387: undefined reference to `rand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(link_message_testing.c.obj): in function `link_Test_Process':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/link/link_message_testing.c:912: undefined reference to `rand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/link/link_message_testing.c:936: undefined reference to `rand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(main.c.obj): in function `main':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/main.c:321: undefined reference to `srand'
    1> c:/zypher/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(utils.c.obj): in function `util_RandFromToCount':
    1> C:\Sandbox\HomeBeacon_dev_sb\build_nrf52833dk_nrf52833_v149_tuning/../src/utils/utils.c:256: undefined reference to `rand'
    1> collect2.exe: error: ld returned 1 exit status
    Build failed
  • Good morning Mohamad,
    For rand() and srand() you need to enable CONFIG_MINIMAL_LIBC_RAND to expose those. Once you have that then having the #include <stdlib.h> should be fine. Unfortunately, the minimal library does not implement the sscanf functionality. I'm not sure of anything equivalent either.
    I just found this lightweight implementation of sscanf that may work? I have not tried it, but would be worth you checking: https://github.com/tusharjois/bscanf
