How to reduce the size of an executable file?
I have modified the central_uart example to make the nRF52832 communicate with an ESP32 in MessagePack. After having disabled the logger configuration in the proj.conf file the size of the *.bin file is 225.8 kB which is too large for an nRF52805 (flash of 192 kB). Is there any way to reduce the bin file size?
Below the proj.conf file:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# Enable the BLE stack with GATT Client configuration
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
# Enable the BLE modules from NCS
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_SCAN_ADDRESS_CNT=1
CONFIG_BT_GATT_DM=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_MAX_CONN=1
# This example requires more workqueue stack
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable use of the non-minimal C functionality (stdio.h).
CONFIG_NEWLIB_LIBC=y
# Config logger
CONFIG_LOG=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
CONFIG_BT_DEBUG_LOG=n
CONFIG_BT_GATT_DM_DATA_PRINT=n
CONFIG_ASSERT=y
# Config I2C
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_SHELL=y
CONFIG_I2C_SHELL=y
Marco
  • Good Morning James,
    I thought I ought to let you know how it all unfolded ...
    It was a silly mistake from my part when I switched from using sscanf() to strtol().  I was calling strtol() with the wrong number of parameters and I was ignoring the compiler warning "Implicit definition of function...". Once I fixed this the problem disappeared.
    long strtol(const char *nptr)
    instead of
    long strtol(const char *nptr, char **endptr, register int base)
    In fact, I am now using atoi() because it is more appropriate in my case.
    Morale: Get rid of all warnings first!
    Thank you for your help. Have a great day!
    Kind regards
    Mohamed
  • Oh, awesome! So glad to hear you got it going and thank you for letting me know. We have a joke around here about, "So what was the problem?"... "The software was only doing what I told it to do, so it wasn't behaving correctly... stupid thing, it should have known better" lol.
    Have a great day too.
