SECP256K1 curve encryption not working
We are using ncs 2.4.0, working with a custom project based in matter lock sample.
We were using SECP256R1 curves for encryption, without issues, but we need to move to SECP256K1, and we are getting MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE error when trying to sign a message.
Going deeper I´ve found the function returning error is mbedtls_ecdsa_sign, but AFAIU the implementation is within nrfxlib/nrf_security/src/libmbedcrypto.a
Then I cannot check why it is returning this error
I have already enabled MBEDTLS_ECP_DP_SECP256K1_ENABLED in config file.
Any help will be appreciated.
Hugo
  • Sure
    This is nrf-config.h placed at build/modules/nrfxlib/nrfxlib/nrf_security/src/include/generated/nrf-config.h
     * Copyright (c) 2022 Nordic Semiconductor
    #ifndef LEGACY_CRYPTO_CONFIG_H
    #define LEGACY_CRYPTO_CONFIG_H
     * \file mbedtls_config.h
     * \brief Configuration options (set of defines)
     *  This set of compile-time options may be used to enable
     *  or disable features selectively, and reduce the global
     *  memory footprint.
     *  Copyright The Mbed TLS Contributors
     *  SPDX-License-Identifier: Apache-2.0
     *  Licensed under the Apache License, Version 2.0 (the "License"); you may
     *  not use this file except in compliance with the License.
     *  You may obtain a copy of the License at
     *  http://www.apache.org/licenses/LICENSE-2.0
     *  Unless required by applicable law or agreed to in writing, software
     *  distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
     *  WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
     *  See the License for the specific language governing permissions and
     *  limitations under the License.
     * This is an optional version symbol that enables comatibility handling of
     * config files.
     * It is equal to the #MBEDTLS_VERSION_NUMBER of the Mbed TLS version that
     * introduced the config format we want to be compatible with.
    //#define MBEDTLS_CONFIG_VERSION 0x03000000
     * \name SECTION: System support
     * This section sets system specific settings.
     * \def MBEDTLS_HAVE_ASM
     * The compiler has support for asm().
     * Requires support for asm() in compiler.
     * Used in:
     *      library/aria.c
     *      library/bn_mul.h
     * Required by:
     *      MBEDTLS_AESNI_C
     *      MBEDTLS_PADLOCK_C
     * Comment to disable the use of assembly code.
    #define MBEDTLS_HAVE_ASM
     * \def MBEDTLS_NO_UDBL_DIVISION
     * The platform lacks support for double-width integer division (64-bit
     * division on a 32-bit platform, 128-bit division on a 64-bit platform).
     * Used in:
     *      include/mbedtls/bignum.h
     *      library/bignum.c
     * The bignum code uses double-width division to speed up some operations.
     * Double-width division is often implemented in software that needs to
     * be linked with the program. The presence of a double-width integer
     * type is usually detected automatically through preprocessor macros,
     * but the automatic detection cannot know whether the code needs to
     * and can be linked with an implementation of division for that type.
     * By default division is assumed to be usable if the type is present.
     * Uncomment this option to prevent the use of double-width division.
     * Note that division for the native integer type is always required.
     * Furthermore, a 64-bit type is always required even on a 32-bit
     * platform, but it need not support multiplication or division. In some
     * cases it is also desirable to disable some double-width operations. For
     * example, if double-width division is implemented in software, disabling
     * it can reduce code size in some embedded targets.
    //#define MBEDTLS_NO_UDBL_DIVISION
     * \def MBEDTLS_NO_64BIT_MULTIPLICATION
     * The platform lacks support for 32x32 -> 64-bit multiplication.
     * Used in:
     *      library/poly1305.c
     * Some parts of the library may use multiplication of two unsigned 32-bit
     * operands with a 64-bit result in order to speed up computations. On some
     * platforms, this is not available in hardware and has to be implemented in
     * software, usually in a library provided by the toolchain.
     * Sometimes it is not desirable to have to link to that library. This option
     * removes the dependency of that library on platforms that lack a hardware
     * 64-bit multiplier by embedding a software implementation in Mbed TLS.
     * Note that depending on the compiler, this may decrease performance compared
     * to using the library function provided by the toolchain.
    //#define MBEDTLS_NO_64BIT_MULTIPLICATION
     * \def MBEDTLS_HAVE_SSE2
     * CPU supports SSE2 instruction set.
     * Uncomment if the CPU supports SSE2 (IA-32 specific).
    //#define MBEDTLS_HAVE_SSE2
     * \def MBEDTLS_HAVE_TIME
     * System has time.h and time().
     * The time does not need to be correct, only time differences are used,
     * by contrast with MBEDTLS_HAVE_TIME_DATE
     * Defining MBEDTLS_HAVE_TIME allows you to specify MBEDTLS_PLATFORM_TIME_ALT,
     * MBEDTLS_PLATFORM_TIME_MACRO, MBEDTLS_PLATFORM_TIME_TYPE_MACRO and
     * MBEDTLS_PLATFORM_STD_TIME.
     * Comment if your system does not support time functions
    //#define MBEDTLS_HAVE_TIME
     * \def MBEDTLS_HAVE_TIME_DATE
     * System has time.h, time(), and an implementation for
     * mbedtls_platform_gmtime_r() (see below).
     * The time needs to be correct (not necessarily very accurate, but at least
     * the date should be correct). This is used to verify the validity period of
     * X.509 certificates.
     * Comment if your system does not have a correct clock.
     * \note mbedtls_platform_gmtime_r() is an abstraction in platform_util.h that
     * behaves similarly to the gmtime_r() function from the C standard. Refer to
     * the documentation for mbedtls_platform_gmtime_r() for more information.
     * \note It is possible to configure an implementation for
     * mbedtls_platform_gmtime_r() at compile-time by using the macro
     * MBEDTLS_PLATFORM_GMTIME_R_ALT.
    //#define MBEDTLS_HAVE_TIME_DATE
     * \def MBEDTLS_PLATFORM_MEMORY
     * Enable the memory allocation layer.
     * By default mbed TLS uses the system-provided calloc() and free().
     * This allows different allocators (self-implemented or provided) to be
     * provided to the platform abstraction layer.
     * Enabling MBEDTLS_PLATFORM_MEMORY without the
     * MBEDTLS_PLATFORM_{FREE,CALLOC}_MACROs will provide
     * "mbedtls_platform_set_calloc_free()" allowing you to set an alternative calloc() and
     * free() function pointer at runtime.
     * Enabling MBEDTLS_PLATFORM_MEMORY and specifying
     * MBEDTLS_PLATFORM_{CALLOC,FREE}_MACROs will allow you to specify the
     * alternate function at compile time.
     * Requires: MBEDTLS_PLATFORM_C
     * Enable this layer to allow use of alternative memory allocators.
    #define MBEDTLS_PLATFORM_MEMORY
     * \def MBEDTLS_PLATFORM_NO_STD_FUNCTIONS
     * Do not assign standard functions in the platform layer (e.g. calloc() to
     * MBEDTLS_PLATFORM_STD_CALLOC and printf() to MBEDTLS_PLATFORM_STD_PRINTF)
     * This makes sure there are no linking errors on platforms that do not support
     * these functions. You will HAVE to provide alternatives, either at runtime
     * via the platform_set_xxx() functions or at compile time by setting
     * the MBEDTLS_PLATFORM_STD_XXX defines, or enabling a
     * MBEDTLS_PLATFORM_XXX_MACRO.
     * Uncomment to prevent default assignment of standard functions in the
     * platform layer.
    /* #undef MBEDTLS_PLATFORM_NO_STD_FUNCTIONS */
     * \def MBEDTLS_PLATFORM_EXIT_ALT
     * MBEDTLS_PLATFORM_XXX_ALT: Uncomment a macro to let mbed TLS support the
     * function in the platform abstraction layer.
     * Example: In case you uncomment MBEDTLS_PLATFORM_PRINTF_ALT, mbed TLS will
     * provide a function "mbedtls_platform_set_printf()" that allows you to set an
     * alternative printf function pointer.
     * All these define require MBEDTLS_PLATFORM_C to be defined!
     * \note MBEDTLS_PLATFORM_SNPRINTF_ALT is required on Windows;
     * it will be enabled automatically by check_config.h
     * \warning MBEDTLS_PLATFORM_XXX_ALT cannot be defined at the same time as
     * MBEDTLS_PLATFORM_XXX_MACRO!
     * Requires: MBEDTLS_PLATFORM_TIME_ALT requires MBEDTLS_HAVE_TIME
     * Uncomment a macro to enable alternate implementation of specific base
     * platform function
    /* #undef MBEDTLS_PLATFORM_EXIT_ALT */
    //#define MBEDTLS_PLATFORM_TIME_ALT
    /* #undef MBEDTLS_PLATFORM_FPRINTF_ALT */
    /* #undef MBEDTLS_PLATFORM_PRINTF_ALT */
    /* #undef MBEDTLS_PLATFORM_SNPRINTF_ALT */
    //#define MBEDTLS_PLATFORM_NV_SEED_ALT
    #define MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT
     * \def MBEDTLS_DEPRECATED_WARNING
     * Mark deprecated functions and features so that they generate a warning if
     * used. Functionality deprecated in one version will usually be removed in the
     * next version. You can enable this to help you prepare the transition to a
     * new major version by making sure your code is not using this functionality.
     * This only works with GCC and Clang. With other compilers, you may want to
     * use MBEDTLS_DEPRECATED_REMOVED
     * Uncomment to get warnings on using deprecated functions and features.
    /* #undef MBEDTLS_DEPRECATED_WARNING */
     * \def MBEDTLS_DEPRECATED_REMOVED
     * Remove deprecated functions and features so that they generate an error if
     * Uncomment to get errors on using deprecated functions and features.
    /* #undef MBEDTLS_DEPRECATED_REMOVED */
    /* \} name SECTION: System support */
     * \name SECTION: mbed TLS feature support
     * This section sets support for features that are or are not needed
     * within the modules that are enabled.
     * \def MBEDTLS_TIMING_ALT
     * Uncomment to provide your own alternate implementation for
     * mbedtls_timing_get_timer(), mbedtls_set_alarm(), mbedtls_set/get_delay()
     * Only works if you have MBEDTLS_TIMING_C enabled.
     * You will need to provide a header "timing_alt.h" and an implementation at
     * compile time.
    //#define MBEDTLS_TIMING_ALT
     * \def MBEDTLS_AES_ALT
     * MBEDTLS__MODULE_NAME__ALT: Uncomment a macro to let mbed TLS use your
     * alternate core implementation of a symmetric crypto, an arithmetic or hash
     * module (e.g. platform specific assembly optimized implementations). Keep
     * in mind that the function prototypes should remain the same.
     * This replaces the whole module. If you only want to replace one of the
     * functions, use one of the MBEDTLS__FUNCTION_NAME__ALT flags.
     * Example: In case you uncomment MBEDTLS_AES_ALT, mbed TLS will no longer
     * provide the "struct mbedtls_aes_context" definition and omit the base
     * function declarations and implementations. "aes_alt.h" will be included from
     * "aes.h" to include the new function definitions.
     * Uncomment a macro to enable alternate implementation of the corresponding
     * module.
     * \warning   MD5, DES and SHA-1 are considered weak and their
     *            use constitutes a security risk. If possible, we recommend
     *            avoiding dependencies on them, and considering stronger message
     *            digests and ciphers instead.
    #define MBEDTLS_AES_ALT
    //#define MBEDTLS_ARIA_ALT
    //#define MBEDTLS_CAMELLIA_ALT
    #define MBEDTLS_CCM_ALT
    #define MBEDTLS_CHACHA20_ALT
    #define MBEDTLS_CHACHAPOLY_ALT
    #define MBEDTLS_CMAC_ALT
    //#define MBEDTLS_DES_ALT
    #define MBEDTLS_DHM_ALT
    /* #undef MBEDTLS_ECJPAKE_ALT */
    /* #undef MBEDTLS_GCM_ALT */
    //#define MBEDTLS_NIST_KW_ALT
    //#define MBEDTLS_MD5_ALT
    #define MBEDTLS_POLY1305_ALT
    //#define MBEDTLS_RIPEMD160_ALT
    #define MBEDTLS_RSA_ALT
    #define MBEDTLS_SHA1_ALT
    #define MBEDTLS_SHA256_ALT
    /* #undef MBEDTLS_SHA512_ALT */
     * When replacing the elliptic curve module, pleace consider, that it is
     * implemented with two .c files:
     *      - ecp.c
     *      - ecp_curves.c
     * You can replace them very much like all the other MBEDTLS__MODULE_NAME__ALT
     * macros as described above. The only difference is that you have to make sure
     * that you provide functionality for both .c files.
    #define MBEDTLS_ECP_ALT
     * \def MBEDTLS_SHA256_PROCESS_ALT
     * MBEDTLS__FUNCTION_NAME__ALT: Uncomment a macro to let mbed TLS use you
     * alternate core implementation of symmetric crypto or hash function. Keep in
     * mind that function prototypes should remain the same.
     * This replaces only one function. The header file from mbed TLS is still
     * used, in contrast to the MBEDTLS__MODULE_NAME__ALT flags.
     * Example: In case you uncomment MBEDTLS_SHA256_PROCESS_ALT, mbed TLS will
     * no longer provide the mbedtls_sha1_process() function, but it will still provide
     * the other function (using your mbedtls_sha1_process() function) and the definition
     * of mbedtls_sha1_context, so your implementation of mbedtls_sha1_process must be compatible
     * with this definition.
     * \note If you use the AES_xxx_ALT macros, then it is recommended to also set
     *       MBEDTLS_AES_ROM_TABLES in order to help the linker garbage-collect the AES
     *       tables.
     * function.
     * \warning   MD5, DES and SHA-1 are considered weak and their use
     *            constitutes a security risk. If possible, we recommend avoiding
     *            dependencies on them, and considering stronger message digests
     *            and ciphers instead.
     * \warning   If both MBEDTLS_ECDSA_SIGN_ALT and MBEDTLS_ECDSA_DETERMINISTIC are
     *            enabled, then the deterministic ECDH signature functions pass the
     *            the static HMAC-DRBG as RNG to mbedtls_ecdsa_sign(). Therefore
     *            alternative implementations should use the RNG only for generating
     *            the ephemeral key and nothing else. If this is not possible, then
     *            MBEDTLS_ECDSA_DETERMINISTIC should be disabled and an alternative
     *            implementation should be provided for mbedtls_ecdsa_sign_det_ext().
    //#define MBEDTLS_MD5_PROCESS_ALT
    //#define MBEDTLS_RIPEMD160_PROCESS_ALT
    //#define MBEDTLS_SHA1_PROCESS_ALT
    //#define MBEDTLS_SHA256_PROCESS_ALT
    //#define MBEDTLS_SHA512_PROCESS_ALT
    //#define MBEDTLS_DES_SETKEY_ALT
    //#define MBEDTLS_DES_CRYPT_ECB_ALT
    //#define MBEDTLS_DES3_CRYPT_ECB_ALT
    /* #undef MBEDTLS_AES_SETKEY_ENC_ALT */
    /* #undef MBEDTLS_AES_SETKEY_DEC_ALT */
    /* #undef MBEDTLS_AES_ENCRYPT_ALT */
    /* #undef MBEDTLS_AES_DECRYPT_ALT */
    #define MBEDTLS_ECDH_GEN_PUBLIC_ALT
    #define MBEDTLS_ECDH_COMPUTE_SHARED_ALT
    #define MBEDTLS_ECDSA_VERIFY_ALT
    #define MBEDTLS_ECDSA_SIGN_ALT
    #define MBEDTLS_ECDSA_GENKEY_ALT
     * \def MBEDTLS_ECP_INTERNAL_ALT
     * Expose a part of the internal interface of the Elliptic Curve Point module.
     * MBEDTLS_ECP__FUNCTION_NAME__ALT: Uncomment a macro to let mbed TLS use your
     * alternative core implementation of elliptic curve arithmetic. Keep in mind
     * that function prototypes should remain the same.
     * This partially replaces one function. The header file from mbed TLS is still
     * used, in contrast to the MBEDTLS_ECP_ALT flag. The original implementation
     * is still present and it is used for group structures not supported by the
     * alternative.
     * The original implementation can in addition be removed by setting the
     * MBEDTLS_ECP_NO_FALLBACK option, in which case any function for which the
     * corresponding MBEDTLS_ECP__FUNCTION_NAME__ALT macro is defined will not be
     * able to fallback to curves not supported by the alternative implementation.
     * Any of these options become available by defining MBEDTLS_ECP_INTERNAL_ALT
     * and implementing the following functions:
     *      unsigned char mbedtls_internal_ecp_grp_capable(
     *          const mbedtls_ecp_group *grp )
     *      int  mbedtls_internal_ecp_init( const mbedtls_ecp_group *grp )
     *      void mbedtls_internal_ecp_free( const mbedtls_ecp_group *grp )
     * The mbedtls_internal_ecp_grp_capable function should return 1 if the
     * replacement functions implement arithmetic for the given group and 0
     * otherwise.
     * The functions mbedtls_internal_ecp_init and mbedtls_internal_ecp_free are
     * called before and after each point operation and provide an opportunity to
     * implement optimized set up and tear down instructions.
     * Example: In case you set MBEDTLS_ECP_INTERNAL_ALT and
     * MBEDTLS_ECP_DOUBLE_JAC_ALT, mbed TLS will still provide the ecp_double_jac()
     * function, but will use your mbedtls_internal_ecp_double_jac() if the group
     * for the operation is supported by your implementation (i.e. your
     * mbedtls_internal_ecp_grp_capable() function returns 1 for this group). If the
     * group is not supported by your implementation, then the original mbed TLS
     * implementation of ecp_double_jac() is used instead, unless this fallback
     * behaviour is disabled by setting MBEDTLS_ECP_NO_FALLBACK (in which case
     * ecp_double_jac() will return MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE).
     * The function prototypes and the definition of mbedtls_ecp_group and
     * mbedtls_ecp_point will not change based on MBEDTLS_ECP_INTERNAL_ALT, so your
     * implementation of mbedtls_internal_ecp__function_name__ must be compatible
     * with their definitions.
     * function.
    /* Required for all the functions in this section */
    //#define MBEDTLS_ECP_INTERNAL_ALT
    /* Turn off software fallback for curves not supported in hardware */
    //#define MBEDTLS_ECP_NO_FALLBACK
    /* Support for Weierstrass curves with Jacobi representation */
    //#define MBEDTLS_ECP_RANDOMIZE_JAC_ALT
    //#define MBEDTLS_ECP_ADD_MIXED_ALT
    //#define MBEDTLS_ECP_DOUBLE_JAC_ALT
    //#define MBEDTLS_ECP_NORMALIZE_JAC_MANY_ALT
    //#define MBEDTLS_ECP_NORMALIZE_JAC_ALT
    /* Support for curves with Montgomery arithmetic */
    //#define MBEDTLS_ECP_DOUBLE_ADD_MXZ_ALT
    //#define MBEDTLS_ECP_RANDOMIZE_MXZ_ALT
    //#define MBEDTLS_ECP_NORMALIZE_MXZ_ALT
     * \def MBEDTLS_ENTROPY_HARDWARE_ALT
     * Uncomment this macro to let mbed TLS use your own implementation of a
     * hardware entropy collector.
     * Your function must be called \c mbedtls_hardware_poll(), have the same
     * prototype as declared in library/entropy_poll.h, and accept NULL as first
     * argument.
     * Uncomment to use your own hardware entropy collector.
    #define MBEDTLS_ENTROPY_HARDWARE_ALT
     * \def MBEDTLS_AES_ROM_TABLES
     * Use precomputed AES tables stored in ROM.
     * Uncomment this macro to use precomputed AES tables stored in ROM.
     * Comment this macro to generate AES tables in RAM at runtime.
     * Tradeoff: Using precomputed ROM tables reduces RAM usage by ~8kb
     * (or ~2kb if \c MBEDTLS_AES_FEWER_TABLES is used) and reduces the
     * initialization time before the first AES operation can be performed.
     * It comes at the cost of additional ~8kb ROM use (resp. ~2kb if \c
     * MBEDTLS_AES_FEWER_TABLES below is used), and potentially degraded
     * performance if ROM access is slower than RAM access.
     * This option is independent of \c MBEDTLS_AES_FEWER_TABLES.
    /* #undef MBEDTLS_AES_ROM_TABLES */
     * \def MBEDTLS_AES_FEWER_TABLES
     * Use less ROM/RAM for AES tables.
     * Uncommenting this macro omits 75% of the AES tables from
     * ROM / RAM (depending on the value of \c MBEDTLS_AES_ROM_TABLES)
     * by computing their values on the fly during operations
     * (the tables are entry-wise rotations of one another).
     * Tradeoff: Uncommenting this reduces the RAM / ROM footprint
     * by ~6kb but at the cost of more arithmetic operations during
     * runtime. Specifically, one has to compare 4 accesses within
     * different tables to 4 accesses with additional arithmetic
     * operations within the same table. The performance gain/loss
     * depends on the system and memory details.
     * This option is independent of \c MBEDTLS_AES_ROM_TABLES.
    /* #undef MBEDTLS_AES_FEWER_TABLES */
     * \def MBEDTLS_CAMELLIA_SMALL_MEMORY
     * Use less ROM for the Camellia implementation (saves about 768 bytes).
     * Uncomment this macro to use less memory for Camellia.
    //#define MBEDTLS_CAMELLIA_SMALL_MEMORY
     * \def MBEDTLS_CIPHER_MODE_CBC
     * Enable Cipher Block Chaining mode (CBC) for symmetric ciphers.
    /* #undef MBEDTLS_CIPHER_MODE_CBC */
     * \def MBEDTLS_CIPHER_MODE_CFB
     * Enable Cipher Feedback mode (CFB) for symmetric ciphers.
    /* #undef MBEDTLS_CIPHER_MODE_CFB */
     * \def MBEDTLS_CIPHER_MODE_CTR
     * Enable Counter Block Cipher mode (CTR) for symmetric ciphers.
    #define MBEDTLS_CIPHER_MODE_CTR
     * \def MBEDTLS_CIPHER_MODE_OFB
     * Enable Output Feedback mode (OFB) for symmetric ciphers.
    /* #undef MBEDTLS_CIPHER_MODE_OFB */
     * \def MBEDTLS_CIPHER_MODE_XTS
     * Enable Xor-encrypt-xor with ciphertext stealing mode (XTS) for AES.
    /* #undef MBEDTLS_CIPHER_MODE_XTS */
     * \def MBEDTLS_CIPHER_NULL_CIPHER
     * Enable NULL cipher.
     * Warning: Only do so when you know what you are doing. This allows for
     * encryption or channels without any security!
     * To enable the following ciphersuites:
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_NULL_SHA
     *      MBEDTLS_TLS_ECDH_RSA_WITH_NULL_SHA
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_NULL_SHA
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_NULL_SHA
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_NULL_SHA384
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_NULL_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_NULL_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_NULL_SHA256
     *      MBEDTLS_TLS_RSA_WITH_NULL_SHA256
     *      MBEDTLS_TLS_RSA_WITH_NULL_MD5
     *      MBEDTLS_TLS_RSA_PSK_WITH_NULL_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_NULL_SHA256
     *      MBEDTLS_TLS_PSK_WITH_NULL_SHA384
     *      MBEDTLS_TLS_PSK_WITH_NULL_SHA256
     * Uncomment this macro to enable the NULL cipher and ciphersuites
    //#define MBEDTLS_CIPHER_NULL_CIPHER
     * \def MBEDTLS_CIPHER_PADDING_PKCS7
     * MBEDTLS_CIPHER_PADDING_XXX: Uncomment or comment macros to add support for
     * specific padding modes in the cipher layer with cipher modes that support
     * padding (e.g. CBC)
     * If you disable all padding modes, only full blocks can be used with CBC.
     * Enable padding modes in the cipher layer.
    /* #undef MBEDTLS_CIPHER_PADDING_PKCS7 */
    /* #undef MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS */
    /* #undef MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN */
    /* #undef MBEDTLS_CIPHER_PADDING_ZEROS */
    /** \def MBEDTLS_CTR_DRBG_USE_128_BIT_KEY
     * Uncomment this macro to use a 128-bit key in the CTR_DRBG module.
     * By default, CTR_DRBG uses a 256-bit key.
    #define MBEDTLS_CTR_DRBG_USE_128_BIT_KEY
     * \def MBEDTLS_ECP_DP_SECP192R1_ENABLED
     * MBEDTLS_ECP_XXXX_ENABLED: Enables specific curves within the Elliptic Curve
     * module.  By default all supported curves are enabled.
     * Comment macros to disable the curve and functions for it
    /* Short Weierstrass curves (supporting ECP, ECDH, ECDSA) */
    /* #undef MBEDTLS_ECP_DP_SECP192R1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_SECP224R1_ENABLED */
    #define MBEDTLS_ECP_DP_SECP256R1_ENABLED
    /* #undef MBEDTLS_ECP_DP_SECP384R1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_SECP521R1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_SECP192K1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_SECP224K1_ENABLED */
    #define MBEDTLS_ECP_DP_SECP256K1_ENABLED
    /* #undef MBEDTLS_ECP_DP_BP256R1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_BP384R1_ENABLED */
    /* #undef MBEDTLS_ECP_DP_BP512R1_ENABLED */
    /* Montgomery curves (supporting ECP) */
    /* #undef MBEDTLS_ECP_DP_CURVE25519_ENABLED */
    /* #undef MBEDTLS_ECP_DP_CURVE448_ENABLED */
     * \def MBEDTLS_ECP_NIST_OPTIM
     * Enable specific 'modulo p' routines for each NIST prime.
     * Depending on the prime and architecture, makes operations 4 to 8 times
     * faster on the corresponding curve.
     * Comment this macro to disable NIST curves optimisation.
    #define MBEDTLS_ECP_NIST_OPTIM
     * \def MBEDTLS_ECP_RESTARTABLE
     * Enable "non-blocking" ECC operations that can return early and be resumed.
     * This allows various functions to pause by returning
     * #MBEDTLS_ERR_ECP_IN_PROGRESS (or, for functions in the SSL module,
     * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS) and then be called later again in
     * order to further progress and eventually complete their operation. This is
     * controlled through mbedtls_ecp_set_max_ops() which limits the maximum
     * number of ECC operations a function may perform before pausing; see
     * mbedtls_ecp_set_max_ops() for more information.
     * This is useful in non-threaded environments if you want to avoid blocking
     * for too long on ECC (and, hence, X.509 or SSL/TLS) operations.
     * Uncomment this macro to enable restartable ECC computations.
     * \note  This option only works with the default software implementation of
     *        elliptic curve functionality. It is incompatible with
     *        MBEDTLS_ECP_ALT, MBEDTLS_ECDH_XXX_ALT, MBEDTLS_ECDSA_XXX_ALT.
    //#define MBEDTLS_ECP_RESTARTABLE
     * \def MBEDTLS_ECDSA_DETERMINISTIC
     * Enable deterministic ECDSA (RFC 6979).
     * Standard ECDSA is "fragile" in the sense that lack of entropy when signing
     * may result in a compromise of the long-term signing key. This is avoided by
     * the deterministic variant.
     * Requires: MBEDTLS_HMAC_DRBG_C, MBEDTLS_ECDSA_C
     * Comment this macro to disable deterministic ECDSA.
    #define MBEDTLS_ECDSA_DETERMINISTIC
     * \def MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
     * Enable the PSK based ciphersuite modes in SSL / TLS.
     * This enables the following ciphersuites (if other requisites are
     * enabled as well):
     *      MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_PSK_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED
     * Enable the DHE-PSK based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_DHM_C
     * enabled as well):
     *      MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_CAMELLIA_128_CBC_SHA256
     * \warning    Using DHE constitutes a security risk as it
     *             is not possible to validate custom DH parameters.
     *             If possible, it is recommended users should consider
     *             preferring other methods of key exchange.
     *             See dhm.h for more details.
    /* #undef MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED
     * Enable the ECDHE-PSK based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_ECDH_C
     * enabled as well):
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED
     * Enable the RSA-PSK based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
     *           MBEDTLS_X509_CRT_PARSE_C
     * enabled as well):
     *      MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_RSA_ENABLED
     * Enable the RSA-only based ciphersuite modes in SSL / TLS.
     * enabled as well):
     *      MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256
     *      MBEDTLS_TLS_RSA_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256
     *      MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_RSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_RSA_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED
     * Enable the DHE-RSA based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_DHM_C, MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
     * enabled as well):
     *      MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED
     * Enable the ECDHE-RSA based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_ECDH_C, MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
     * enabled as well):
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256
    /* #undef MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
     * Enable the ECDHE-ECDSA based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_ECDH_C, MBEDTLS_ECDSA_C, MBEDTLS_X509_CRT_PARSE_C,
     * enabled as well):
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256
    #define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
     * \def MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED
     * Enable the ECDH-ECDSA based ciphersuite modes in SSL / TLS.
     * enabled as well):
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_GCM_SHA384
    /* #undef MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED
     * Enable the ECDH-RSA based ciphersuite modes in SSL / TLS.
     * Requires: MBEDTLS_ECDH_C, MBEDTLS_RSA_C, MBEDTLS_X509_CRT_PARSE_C
     * enabled as well):
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_GCM_SHA384
    /* #undef MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED */
     * \def MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED
     * Enable the ECJPAKE based ciphersuite modes in SSL / TLS.
     * \warning This is currently experimental. EC J-PAKE support is based on the
     * Thread v1.0.0 specification; incompatible changes to the specification
     * might still happen. For this reason, this is disabled by default.
     * Requires: MBEDTLS_ECJPAKE_C
     *           MBEDTLS_SHA256_C
     *           MBEDTLS_ECP_DP_SECP256R1_ENABLED
     * enabled as well):
     *      MBEDTLS_TLS_ECJPAKE_WITH_AES_128_CCM_8
    #define MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED
     * \def MBEDTLS_PK_PARSE_EC_EXTENDED
     * Enhance support for reading EC keys using variants of SEC1 not allowed by
     * RFC 5915 and RFC 5480.
     * Currently this means parsing the SpecifiedECDomain choice of EC
     * parameters (only known groups are supported, not arbitrary domains, to
     * avoid validation issues).
     * Disable if you only need to support RFC 5915 + 5480 key formats.
    #define MBEDTLS_PK_PARSE_EC_EXTENDED
     * \def MBEDTLS_ERROR_STRERROR_DUMMY
     * Enable a dummy error function to make use of mbedtls_strerror() in
     * third party libraries easier when MBEDTLS_ERROR_C is disabled
     * (no effect when MBEDTLS_ERROR_C is enabled).
     * You can safely disable this if MBEDTLS_ERROR_C is enabled, or if you're
     * not using mbedtls_strerror() or error_strerror() in your application.
     * Disable if you run into name conflicts and want to really remove the
     * mbedtls_strerror()
    #define MBEDTLS_ERROR_STRERROR_DUMMY
     * \def MBEDTLS_GENPRIME
     * Enable the prime-number generation code.
     * Requires: MBEDTLS_BIGNUM_C
    /* #undef MBEDTLS_GENPRIME */
     * \def MBEDTLS_FS_IO
     * Enable functions that use the filesystem.
    //#define MBEDTLS_FS_IO
     * \def MBEDTLS_NO_DEFAULT_ENTROPY_SOURCES
     * Do not add default entropy sources in mbedtls_entropy_init().
     * This is useful to have more control over the added entropy sources in an
     * application.
     * Uncomment this macro to prevent loading of default entropy functions.
    //#define MBEDTLS_NO_DEFAULT_ENTROPY_SOURCES
     * \def MBEDTLS_NO_PLATFORM_ENTROPY
     * Do not use built-in platform entropy functions.
     * This is useful if your platform does not support
     * standards like the /dev/urandom or Windows CryptoAPI.
     * Uncomment this macro to disable the built-in platform entropy functions.
    #define MBEDTLS_NO_PLATFORM_ENTROPY
     * \def MBEDTLS_ENTROPY_FORCE_SHA256
     * Force the entropy accumulator to use a SHA-256 accumulator instead of the
     * default SHA-512 based one (if both are available).
     * Requires: MBEDTLS_SHA256_C
     * On 32-bit systems SHA-256 can be much faster than SHA-512. Use this option
     * if you have performance concerns.
     * This option is only useful if both MBEDTLS_SHA256_C and
     * MBEDTLS_SHA512_C are defined. Otherwise the available hash module is used.
    #define MBEDTLS_ENTROPY_FORCE_SHA256
     * \def MBEDTLS_ENTROPY_NV_SEED
     * Enable the non-volatile (NV) seed file-based entropy source.
     * (Also enables the NV seed read/write functions in the platform layer)
     * This is crucial (if not required) on systems that do not have a
     * cryptographic entropy source (in hardware or kernel) available.
     * Requires: MBEDTLS_ENTROPY_C, MBEDTLS_PLATFORM_C
     * \note The read/write functions that are used by the entropy source are
     *       determined in the platform layer, and can be modified at runtime and/or
     *       compile-time depending on the flags (MBEDTLS_PLATFORM_NV_SEED_*) used.
     * \note If you use the default implementation functions that read a seedfile
     *       with regular fopen(), please make sure you make a seedfile with the
     *       proper name (defined in MBEDTLS_PLATFORM_STD_NV_SEED_FILE) and at
     *       least MBEDTLS_ENTROPY_BLOCK_SIZE bytes in size that can be read from
     *       and written to or you will get an entropy source error! The default
     *       implementation will only use the first MBEDTLS_ENTROPY_BLOCK_SIZE
     *       bytes from the file.
     * \note The entropy collector will write to the seed file before entropy is
     *       given to an external source, to update it.
    //#define MBEDTLS_ENTROPY_NV_SEED
    /* MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER
     * Enable key identifiers that encode a key owner identifier.
     * The owner of a key is identified by a value of type ::mbedtls_key_owner_id_t
     * which is currently hard-coded to be int32_t.
     * Note that this option is meant for internal use only and may be removed
     * without notice. It is incompatible with MBEDTLS_USE_PSA_CRYPTO.
    //#define MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER
     * \def MBEDTLS_MEMORY_DEBUG
     * Enable debugging of buffer allocator memory issues. Automatically prints
     * (to stderr) all (fatal) messages on memory allocation issues. Enables
     * function for 'debug output' of allocated memory.
     * Requires: MBEDTLS_MEMORY_BUFFER_ALLOC_C
     * Uncomment this macro to let the buffer allocator print out error messages.
    //#define MBEDTLS_MEMORY_DEBUG
     * \def MBEDTLS_MEMORY_BACKTRACE
     * Include backtrace information with each allocated block.
     *           GLIBC-compatible backtrace() an backtrace_symbols() support
     * Uncomment this macro to include backtrace information
    //#define MBEDTLS_MEMORY_BACKTRACE
     * \def MBEDTLS_PK_RSA_ALT_SUPPORT
     * Support external private RSA keys (eg from a HSM) in the PK layer.
     * Comment this macro to disable support for external private RSA keys.
    //#define MBEDTLS_PK_RSA_ALT_SUPPORT
     * \def MBEDTLS_PKCS1_V15
     * Enable support for PKCS#1 v1.5 encoding.
     * This enables support for PKCS#1 v1.5 operations.
    /* #undef MBEDTLS_PKCS1_V15 */
     * \def MBEDTLS_PKCS1_V21
     * Enable support for PKCS#1 v2.1 encoding.
     * Requires: MBEDTLS_MD_C, MBEDTLS_RSA_C
     * This enables support for RSAES-OAEP and RSASSA-PSS operations.
    /* #undef MBEDTLS_PKCS1_V21 */
    /** \def MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS
     * Enable support for platform built-in keys. If you enable this feature,
     * you must implement the function mbedtls_psa_platform_get_builtin_key().
     * See the documentation of that function for more information.
     * Built-in keys are typically derived from a hardware unique key or
     * stored in a secure element.
     * Requires: MBEDTLS_PSA_CRYPTO_C.
     * \warning This interface is experimental and may change or be removed
     * without notice.
    //#define MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS
    /** \def MBEDTLS_PSA_CRYPTO_CLIENT
     * Enable support for PSA crypto client.
     * \note This option allows to include the code necessary for a PSA
     *       crypto client when the PSA crypto implementation is not included in
     *       the library (MBEDTLS_PSA_CRYPTO_C disabled). The code included is the
     *       code to set and get PSA key attributes.
     *       The development of PSA drivers partially relying on the library to
     *       fulfill the hardware gaps is another possible usage of this option.
     * without notice.
    /* #undef MBEDTLS_PSA_CRYPTO_CLIENT */
    /** \def MBEDTLS_PSA_CRYPTO_DRIVERS
     * Enable support for the experimental PSA crypto driver interface.
     * without notice.
    //#define MBEDTLS_PSA_CRYPTO_DRIVERS
    /** \def MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG
     * Make the PSA Crypto module use an external random generator provided
     * by a driver, instead of Mbed TLS's entropy and DRBG modules.
     * \note This random generator must deliver random numbers with cryptographic
     *       quality and high performance. It must supply unpredictable numbers
     *       with a uniform distribution. The implementation of this function
     *       is responsible for ensuring that the random generator is seeded
     *       with sufficient entropy. If you have a hardware TRNG which is slow
     *       or delivers non-uniform output, declare it as an entropy source
     *       with mbedtls_entropy_add_source() instead of enabling this option.
     * If you enable this option, you must configure the type
     * ::mbedtls_psa_external_random_context_t in psa/crypto_platform.h
     * and define a function called mbedtls_psa_external_get_random()
     * with the following prototype:
     * psa_status_t mbedtls_psa_external_get_random(
     *     mbedtls_psa_external_random_context_t *context,
     *     uint8_t *output, size_t output_size, size_t *output_length);
     * The \c context value is initialized to 0 before the first call.
     * The function must fill the \c output buffer with \p output_size bytes
     * of random data and set \c *output_length to \p output_size.
     * \warning If you enable this option, code that uses the PSA cryptography
     *          interface will not use any of the entropy sources set up for
     *          the entropy module, nor the NV seed that MBEDTLS_ENTROPY_NV_SEED
     *          enables.
     * \note This option is experimental and may be removed without notice.
    /* #undef MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG */
     * \def MBEDTLS_PSA_CRYPTO_SPM
     * When MBEDTLS_PSA_CRYPTO_SPM is defined, the code is built for SPM (Secure
     * Partition Manager) integration which separates the code into two parts: a
     * NSPE (Non-Secure Process Environment) and an SPE (Secure Process
     * Environment).
     * Module:  library/psa_crypto.c
    /* #undef MBEDTLS_PSA_CRYPTO_SPM */
     * \def MBEDTLS_PSA_INJECT_ENTROPY
     * Enable support for entropy injection at first boot. This feature is
     * required on systems that do not have a built-in entropy source (TRNG).
     * This feature is currently not supported on systems that have a built-in
     * entropy source.
     * Requires: MBEDTLS_PSA_CRYPTO_STORAGE_C, MBEDTLS_ENTROPY_NV_SEED
    //#define MBEDTLS_PSA_INJECT_ENTROPY
     * \def MBEDTLS_RSA_NO_CRT
     * Do not use the Chinese Remainder Theorem
     * for the RSA private operation.
     * Uncomment this macro to disable the use of CRT in RSA.
    //#define MBEDTLS_RSA_NO_CRT
     * \def MBEDTLS_SELF_TEST
     * Enable the checkup functions (*_self_test).
    //#define MBEDTLS_SELF_TEST
     * \def MBEDTLS_SHA256_SMALLER
     * Enable an implementation of SHA-256 that has lower ROM footprint but also
     * lower performance.
     * The default implementation is meant to be a reasonnable compromise between
     * performance and size. This version optimizes more aggressively for size at
     * the expense of performance. Eg on Cortex-M4 it reduces the size of
     * mbedtls_sha256_process() from ~2KB to ~0.5KB for a performance hit of about
     * 30%.
     * Uncomment to enable the smaller implementation of SHA256.
    /* #undef MBEDTLS_SHA256_SMALLER */
     * \def MBEDTLS_SHA512_SMALLER
     * Enable an implementation of SHA-512 that has lower ROM footprint but also
     * Uncomment to enable the smaller implementation of SHA512.
    /* #undef MBEDTLS_SHA512_SMALLER */
     * \def MBEDTLS_SSL_ALL_ALERT_MESSAGES
     * Enable sending of alert messages in case of encountered errors as per RFC.
     * If you choose not to send the alert messages, mbed TLS can still communicate
     * with other servers, only debugging of failures is harder.
     * The advantage of not sending alert messages, is that no information is given
     * about reasons for failures thus preventing adversaries of gaining intel.
     * Enable sending of all alert messages
    #define MBEDTLS_SSL_ALL_ALERT_MESSAGES
     * \def MBEDTLS_SSL_DTLS_CONNECTION_ID
     * Enable support for the DTLS Connection ID extension
     * (version draft-ietf-tls-dtls-connection-id-05,
     * https://tools.ietf.org/html/draft-ietf-tls-dtls-connection-id-05)
     * which allows to identify DTLS connections across changes
     * in the underlying transport.
     * Setting this option enables the SSL APIs `mbedtls_ssl_set_cid()`,
     * `mbedtls_ssl_get_peer_cid()` and `mbedtls_ssl_conf_cid()`.
     * See the corresponding documentation for more information.
     * \warning The Connection ID extension is still in draft state.
     *          We make no stability promises for the availability
     *          or the shape of the API controlled by this option.
     * The maximum lengths of outgoing and incoming CIDs can be configured
     * through the options
     * - MBEDTLS_SSL_CID_OUT_LEN_MAX
     * - MBEDTLS_SSL_CID_IN_LEN_MAX.
     * Requires: MBEDTLS_SSL_PROTO_DTLS
     * Uncomment to enable the Connection ID extension.
    /* #undef MBEDTLS_SSL_DTLS_CONNECTION_ID */
     * \def MBEDTLS_SSL_ASYNC_PRIVATE
     * Enable asynchronous external private key operations in SSL. This allows
     * you to configure an SSL connection to call an external cryptographic
     * module to perform private key operations instead of performing the
     * operation inside the library.
    //#define MBEDTLS_SSL_ASYNC_PRIVATE
     * \def MBEDTLS_SSL_CONTEXT_SERIALIZATION
     * Enable serialization of the TLS context structures, through use of the
     * functions mbedtls_ssl_context_save() and mbedtls_ssl_context_load().
     * This pair of functions allows one side of a connection to serialize the
     * context associated with the connection, then free or re-use that context
     * while the serialized state is persisted elsewhere, and finally deserialize
     * that state to a live context for resuming read/write operations on the
     * connection. From a protocol perspective, the state of the connection is
     * unaffected, in particular this is entirely transparent to the peer.
     * Note: this is distinct from TLS session resumption, which is part of the
     * protocol and fully visible by the peer. TLS session resumption enables
     * establishing new connections associated to a saved session with shorter,
     * lighter handshakes, while context serialization is a local optimization in
     * handling a single, potentially long-lived connection.
     * Enabling these APIs makes some SSL structures larger, as 64 extra bytes are
     * saved after the handshake to allow for more efficient serialization, so if
     * you don't need this feature you'll save RAM by disabling it.
     * Comment to disable the context serialization APIs.
    #define MBEDTLS_SSL_CONTEXT_SERIALIZATION
     * \def MBEDTLS_SSL_DEBUG_ALL
     * Enable the debug messages in SSL module for all issues.
     * Debug messages have been disabled in some places to prevent timing
     * attacks due to (unbalanced) debugging function calls.
     * If you need all error reporting you should enable this during debugging,
     * but remove this for production servers that should log as well.
     * Uncomment this macro to report all debug messages on errors introducing
     * a timing side-channel.
    /* #undef MBEDTLS_SSL_DEBUG_ALL */
    /** \def MBEDTLS_SSL_ENCRYPT_THEN_MAC
     * Enable support for Encrypt-then-MAC, RFC 7366.
     * This allows peers that both support it to use a more robust protection for
     * ciphersuites using CBC, providing deep resistance against timing attacks
     * on the padding or underlying cipher.
     * This only affects CBC ciphersuites, and is useless if none is defined.
     * Requires: MBEDTLS_SSL_PROTO_TLS1_2
     * Comment this macro to disable support for Encrypt-then-MAC
    /* #undef MBEDTLS_SSL_ENCRYPT_THEN_MAC */
    /** \def MBEDTLS_SSL_EXTENDED_MASTER_SECRET
     * Enable support for RFC 7627: Session Hash and Extended Master Secret
     * Extension.
     * This was introduced as "the proper fix" to the Triple Handshake familiy of
     * attacks, but it is recommended to always use it (even if you disable
     * renegotiation), since it actually fixes a more fundamental issue in the
     * original SSL/TLS design, and has implications beyond Triple Handshake.
     * Comment this macro to disable support for Extended Master Secret.
    #define MBEDTLS_SSL_EXTENDED_MASTER_SECRET
     * \def MBEDTLS_SSL_KEEP_PEER_CERTIFICATE
     * This option controls the availability of the API mbedtls_ssl_get_peer_cert()
     * giving access to the peer's certificate after completion of the handshake.
     * Unless you need mbedtls_ssl_peer_cert() in your application, it is
     * recommended to disable this option for reduced RAM usage.
     * \note If this option is disabled, mbedtls_ssl_get_peer_cert() is still
     *       defined, but always returns \c NULL.
     * \note This option has no influence on the protection against the
     *       triple handshake attack. Even if it is disabled, Mbed TLS will
     *       still ensure that certificates do not change during renegotiation,
     *       for exaple by keeping a hash of the peer's certificate.
     * Comment this macro to disable storing the peer's certificate
     * after the handshake.
    #define MBEDTLS_SSL_KEEP_PEER_CERTIFICATE
     * \def MBEDTLS_SSL_RENEGOTIATION
     * Enable support for TLS renegotiation.
     * The two main uses of renegotiation are (1) refresh keys on long-lived
     * connections and (2) client authentication after the initial handshake.
     * If you don't need renegotiation, it's probably better to disable it, since
     * it has been associated with security issues in the past and is easy to
     * misuse/misunderstand.
     * Comment this to disable support for renegotiation.
     * \note   Even if this option is disabled, both client and server are aware
     *         of the Renegotiation Indication Extension (RFC 5746) used to
     *         prevent the SSL renegotiation attack (see RFC 5746 Sect. 1).
     *         (See \c mbedtls_ssl_conf_legacy_renegotiation for the
     *          configuration of this extension).
    /* #undef MBEDTLS_SSL_RENEGOTIATION */
     * \def MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
     * Enable support for RFC 6066 max_fragment_length extension in SSL.
     * Comment this macro to disable support for the max_fragment_length extension
    #define MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
     * \def MBEDTLS_SSL_PROTO_TLS1_2
     * Enable support for TLS 1.2 (and DTLS 1.2 if DTLS is enabled).
     * Requires: MBEDTLS_SHA1_C or MBEDTLS_SHA256_C or MBEDTLS_SHA512_C
     *           (Depends on ciphersuites)
     * Comment this macro to disable support for TLS 1.2 / DTLS 1.2
    #define MBEDTLS_SSL_PROTO_TLS1_2
     * \def MBEDTLS_SSL_PROTO_TLS1_3_EXPERIMENTAL
     * This macro is used to selectively enable experimental parts
     * of the code that contribute to the ongoing development of
     * the prototype TLS 1.3 and DTLS 1.3 implementation, and provide
     * no other purpose.
     * \warning TLS 1.3 and DTLS 1.3 aren't yet supported in Mbed TLS,
     *          and no feature exposed through this macro is part of the
     *          public API. In particular, features under the control
     *          of this macro are experimental and don't come with any
     *          stability guarantees.
     * Uncomment this macro to enable experimental and partial
     * functionality specific to TLS 1.3.
    //#define MBEDTLS_SSL_PROTO_TLS1_3_EXPERIMENTAL
     * \def MBEDTLS_SSL_PROTO_DTLS
     * Enable support for DTLS (all available versions).
     * Enable this and MBEDTLS_SSL_PROTO_TLS1_2 to enable DTLS 1.2.
     * Comment this macro to disable support for DTLS
    #define MBEDTLS_SSL_PROTO_DTLS
     * \def MBEDTLS_SSL_ALPN
     * Enable support for RFC 7301 Application Layer Protocol Negotiation.
     * Comment this macro to disable support for ALPN.
    /* #undef MBEDTLS_SSL_ALPN */
     * \def MBEDTLS_SSL_DTLS_ANTI_REPLAY
     * Enable support for the anti-replay mechanism in DTLS.
     * Requires: MBEDTLS_SSL_TLS_C
     *           MBEDTLS_SSL_PROTO_DTLS
     * \warning Disabling this is often a security risk!
     * See mbedtls_ssl_conf_dtls_anti_replay() for details.
     * Comment this to disable anti-replay in DTLS.
    #define MBEDTLS_SSL_DTLS_ANTI_REPLAY
     * \def MBEDTLS_SSL_DTLS_HELLO_VERIFY
     * Enable support for HelloVerifyRequest on DTLS servers.
     * This feature is highly recommended to prevent DTLS servers being used as
     * amplifiers in DoS attacks against other hosts. It should always be enabled
     * unless you know for sure amplification cannot be a problem in the
     * environment in which your server operates.
     * \warning Disabling this can ba a security risk! (see above)
     * Comment this to disable support for HelloVerifyRequest.
    #define MBEDTLS_SSL_DTLS_HELLO_VERIFY
     * \def MBEDTLS_SSL_DTLS_SRTP
     * Enable support for negotiation of DTLS-SRTP (RFC 5764)
     * through the use_srtp extension.
     * \note This feature provides the minimum functionality required
     * to negotiate the use of DTLS-SRTP and to allow the derivation of
     * the associated SRTP packet protection key material.
     * In particular, the SRTP packet protection itself, as well as the
     * demultiplexing of RTP and DTLS packets at the datagram layer
     * (see Section 5 of RFC 5764), are not handled by this feature.
     * Instead, after successful completion of a handshake negotiating
     * the use of DTLS-SRTP, the extended key exporter API
     * mbedtls_ssl_conf_export_keys_cb() should be used to implement
     * the key exporter described in Section 4.2 of RFC 5764 and RFC 5705
     * (this is implemented in the SSL example programs).
     * The resulting key should then be passed to an SRTP stack.
     * Setting this option enables the runtime API
     * mbedtls_ssl_conf_dtls_srtp_protection_profiles()
     * through which the supported DTLS-SRTP protection
     * profiles can be configured. You must call this API at
     * runtime if you wish to negotiate the use of DTLS-SRTP.
     * Uncomment this to enable support for use_srtp extension.
    /* #undef MBEDTLS_SSL_DTLS_SRTP */
     * \def MBEDTLS_SSL_DTLS_CLIENT_PORT_REUSE
     * Enable server-side support for clients that reconnect from the same port.
     * Some clients unexpectedly close the connection and try to reconnect using the
     * same source port. This needs special support from the server to handle the
     * new connection securely, as described in section 4.2.8 of RFC 6347. This
     * flag enables that support.
     * Requires: MBEDTLS_SSL_DTLS_HELLO_VERIFY
     * Comment this to disable support for clients reusing the source port.
    /* #undef MBEDTLS_SSL_DTLS_CLIENT_PORT_REUSE */
     * \def MBEDTLS_SSL_SESSION_TICKETS
     * Enable support for RFC 5077 session tickets in SSL.
     * Client-side, provides full support for session tickets (maintenance of a
     * session store remains the responsibility of the application, though).
     * Server-side, you also need to provide callbacks for writing and parsing
     * tickets, including authenticated encryption and key management. Example
     * callbacks are provided by MBEDTLS_SSL_TICKET_C.
     * Comment this macro to disable support for SSL session tickets
    /* #undef MBEDTLS_SSL_SESSION_TICKETS */
     * \def MBEDTLS_SSL_EXPORT_KEYS
     * Enable support for exporting key block and master secret.
     * This is required for certain users of TLS, e.g. EAP-TLS.
     * Comment this macro to disable support for key export
    #define MBEDTLS_SSL_EXPORT_KEYS
     * \def MBEDTLS_SSL_SERVER_NAME_INDICATION
     * Enable support for RFC 6066 server name indication (SNI) in SSL.
     * Requires: MBEDTLS_X509_CRT_PARSE_C
     * Comment this macro to disable support for server name indication in SSL
    /* #undef MBEDTLS_SSL_SERVER_NAME_INDICATION */
     * \def MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH
     * When this option is enabled, the SSL buffer will be resized automatically
     * based on the negotiated maximum fragment length in each direction.
     * Requires: MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
    //#define MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH
     * \def MBEDTLS_TEST_CONSTANT_FLOW_MEMSAN
     * Enable testing of the constant-flow nature of some sensitive functions with
     * clang's MemorySanitizer. This causes some existing tests to also test
     * this non-functional property of the code under test.
     * This setting requires compiling with clang -fsanitize=memory. The test
     * suites can then be run normally.
     * \warning This macro is only used for extended testing; it is not considered
     * part of the library's API, so it may change or disappear at any time.
     * Uncomment to enable testing of the constant-flow nature of selected code.
    //#define MBEDTLS_TEST_CONSTANT_FLOW_MEMSAN
     * \def MBEDTLS_TEST_CONSTANT_FLOW_VALGRIND
     * valgrind's memcheck tool. This causes some existing tests to also test
     * This setting requires valgrind headers for building, and is only useful for
     * testing if the tests suites are run with valgrind's memcheck. This can be
     * done for an individual test suite with 'valgrind ./test_suite_xxx', or when
     * using CMake, this can be done for all test suites with 'make memcheck'.
    //#define MBEDTLS_TEST_CONSTANT_FLOW_VALGRIND
     * \def MBEDTLS_TEST_HOOKS
     * Enable features for invasive testing such as introspection functions and
     * hooks for fault injection. This enables additional unit tests.
     * Merely enabling this feature should not change the behavior of the product.
     * It only adds new code, and new branching points where the default behavior
     * is the same as when this feature is disabled.
     * However, this feature increases the attack surface: there is an added
     * risk of vulnerabilities, and more gadgets that can make exploits easier.
     * Therefore this feature must never be enabled in production.
     * See `docs/architecture/testing/mbed-crypto-invasive-testing.md` for more
     * information.
     * Uncomment to enable invasive tests.
    //#define MBEDTLS_TEST_HOOKS
     * \def MBEDTLS_THREADING_ALT
     * Provide your own alternate threading implementation.
     * Requires: MBEDTLS_THREADING_C
     * Uncomment this to allow your own alternate threading implementation.
    #define MBEDTLS_THREADING_ALT
     * \def MBEDTLS_THREADING_PTHREAD
     * Enable the pthread wrapper layer for the threading layer.
     * Uncomment this to enable pthread mutexes.
    //#define MBEDTLS_THREADING_PTHREAD
     * \def MBEDTLS_USE_PSA_CRYPTO
     * Make the X.509 and TLS library use PSA for cryptographic operations, and
     * enable new APIs for using keys handled by PSA Crypto.
     * \note Development of this option is currently in progress, and parts of Mbed
     * TLS's X.509 and TLS modules are not ported to PSA yet. However, these parts
     * will still continue to work as usual, so enabling this option should not
     * break backwards compatibility.
     * \warning The PSA Crypto API is in beta stage. While you're welcome to
     * experiment using it, incompatible API changes are still possible, and some
     * parts may not have reached the same quality as the rest of Mbed TLS yet.
     * \warning This option enables new Mbed TLS APIs that are dependent on the
     * PSA Crypto API, so can't come with the same stability guarantees as the
     * rest of the Mbed TLS APIs. You're welcome to experiment with them, but for
     * now, access to these APIs is opt-in (via enabling the present option), in
     * order to clearly differentiate them from the stable Mbed TLS APIs.
     * Uncomment this to enable internal use of PSA Crypto and new associated APIs.
    /* #undef MBEDTLS_USE_PSA_CRYPTO */
     * \def MBEDTLS_PSA_CRYPTO_CONFIG
     * This setting allows support for cryptographic mechanisms through the PSA
     * API to be configured separately from support through the mbedtls API.
     * Uncomment this to enable use of PSA Crypto configuration settings which
     * can be found in include/psa/crypto_config.h.
     * This feature is still experimental and is not ready for production since
     * it is not completed.
    //#define MBEDTLS_PSA_CRYPTO_CONFIG
     * \def MBEDTLS_VERSION_FEATURES
     * Allow run-time checking of compile-time enabled features. Thus allowing users
     * to check at run-time if the library is for instance compiled with threading
     * support via mbedtls_version_check_feature().
     * Requires: MBEDTLS_VERSION_C
     * Comment this to disable run-time checking and save ROM space
    #define MBEDTLS_VERSION_FEATURES
     * \def MBEDTLS_X509_TRUSTED_CERTIFICATE_CALLBACK
     * If set, this enables the X.509 API `mbedtls_x509_crt_verify_with_ca_cb()`
     * and the SSL API `mbedtls_ssl_conf_ca_cb()` which allow users to configure
     * the set of trusted certificates through a callback instead of a linked
     * list.
     * This is useful for example in environments where a large number of trusted
     * certificates is present and storing them in a linked list isn't efficient
     * enough, or when the set of trusted certificates changes frequently.
     * See the documentation of `mbedtls_x509_crt_verify_with_ca_cb()` and
     * `mbedtls_ssl_conf_ca_cb()` for more information.
     * Uncomment to enable trusted certificate callbacks.
    //#define MBEDTLS_X509_TRUSTED_CERTIFICATE_CALLBACK
     * \def MBEDTLS_X509_REMOVE_INFO
     * Disable mbedtls_x509_*_info() and related APIs.
     * Uncomment to omit mbedtls_x509_*_info(), as well as mbedtls_debug_print_crt()
     * and other functions/constants only used by these functions, thus reducing
     * the code footprint by several KB.
    #define MBEDTLS_X509_REMOVE_INFO
     * \def MBEDTLS_X509_RSASSA_PSS_SUPPORT
     * Enable parsing and verification of X.509 certificates, CRLs and CSRS
     * signed with RSASSA-PSS (aka PKCS#1 v2.1).
     * Comment this macro to disallow using RSASSA-PSS in certificates.
    /* #undef MBEDTLS_X509_RSASSA_PSS_SUPPORT */
    /* \} name SECTION: mbed TLS feature support */
     * \name SECTION: mbed TLS modules
     * This section enables or disables entire modules in mbed TLS
     * \def MBEDTLS_AESNI_C
     * Enable AES-NI support on x86-64.
     * Module:  library/aesni.c
     * Caller:  library/aes.c
     * Requires: MBEDTLS_HAVE_ASM
     * This modules adds support for the AES-NI instructions on x86-64
    //#define MBEDTLS_AESNI_C
     * \def MBEDTLS_AES_C
     * Enable the AES block cipher.
     * Module:  library/aes.c
     * Caller:  library/cipher.c
     *          library/pem.c
     *          library/ctr_drbg.c
     * This module enables the following ciphersuites (if other requisites are
     * enabled as well):
     * PEM_PARSE uses AES for decrypting encrypted keys.
    #define MBEDTLS_AES_C
     * \def MBEDTLS_ASN1_PARSE_C
     * Enable the generic ASN1 parser.
     * Module:  library/asn1.c
     * Caller:  library/x509.c
     *          library/dhm.c
     *          library/pkcs12.c
     *          library/pkcs5.c
     *          library/pkparse.c
    #define MBEDTLS_ASN1_PARSE_C
     * \def MBEDTLS_ASN1_WRITE_C
     * Enable the generic ASN1 writer.
     * Module:  library/asn1write.c
     * Caller:  library/ecdsa.c
     *          library/pkwrite.c
     *          library/x509_create.c
     *          library/x509write_crt.c
     *          library/x509write_csr.c
    #define MBEDTLS_ASN1_WRITE_C
     * \def MBEDTLS_BASE64_C
     * Enable the Base64 module.
     * Module:  library/base64.c
     * Caller:  library/pem.c
     * This module is required for PEM support (required by X.509).
    #define MBEDTLS_BASE64_C
     * \def MBEDTLS_BIGNUM_C
     * Enable the multi-precision integer library.
     * Module:  library/bignum.c
     * Caller:  library/dhm.c
     *          library/ecp.c
     *          library/ecdsa.c
     *          library/rsa.c
     *          library/rsa_alt_helpers.c
     *          library/ssl_tls.c
     * This module is required for RSA, DHM and ECC (ECDH, ECDSA) support.
    #define MBEDTLS_BIGNUM_C
     * \def MBEDTLS_CAMELLIA_C
     * Enable the Camellia block cipher.
     * Module:  library/camellia.c
     * enabled as well):
    /* #undef MBEDTLS_CAMELLIA_C */
     * \def MBEDTLS_ARIA_C
     * Enable the ARIA block cipher.
     * Module:  library/aria.c
     * enabled as well):
     *      MBEDTLS_TLS_RSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_RSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_DHE_RSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_RSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_RSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_RSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_PSK_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_PSK_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_RSA_PSK_WITH_ARIA_256_CBC_SHA384
     *      MBEDTLS_TLS_PSK_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_PSK_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_DHE_PSK_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_DHE_PSK_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_RSA_PSK_WITH_ARIA_128_GCM_SHA256
     *      MBEDTLS_TLS_RSA_PSK_WITH_ARIA_256_GCM_SHA384
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_ARIA_128_CBC_SHA256
     *      MBEDTLS_TLS_ECDHE_PSK_WITH_ARIA_256_CBC_SHA384
    /* #undef MBEDTLS_ARIA_C */
     * \def MBEDTLS_CCM_C
     * Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher.
     * Module:  library/ccm.c
     * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C
     * This module enables the AES-CCM ciphersuites, if other requisites are
     * enabled as well.
    #define MBEDTLS_CCM_C
     * \def MBEDTLS_CHACHA20_C
     * Enable the ChaCha20 stream cipher.
     * Module:  library/chacha20.c
    /* #undef MBEDTLS_CHACHA20_C */
     * \def MBEDTLS_CHACHAPOLY_C
     * Enable the ChaCha20-Poly1305 AEAD algorithm.
     * Module:  library/chachapoly.c
     * This module requires: MBEDTLS_CHACHA20_C, MBEDTLS_POLY1305_C
    /* #undef MBEDTLS_CHACHAPOLY_C */
     * \def MBEDTLS_CIPHER_C
     * Enable the generic cipher layer.
     * Module:  library/cipher.c
     * Caller:  library/ssl_tls.c
     * Uncomment to enable generic cipher wrappers.
    #define MBEDTLS_CIPHER_C
     * \def MBEDTLS_CMAC_C
     * Enable the CMAC (Cipher-based Message Authentication Code) mode for block
     * ciphers.
     * \note When #MBEDTLS_CMAC_ALT is active, meaning that the underlying
     *       implementation of the CMAC algorithm is provided by an alternate
     *       implementation, that alternate implementation may opt to not support
     *       AES-192 or 3DES as underlying block ciphers for the CMAC operation.
     * Module:  library/cmac.c
     * Requires: MBEDTLS_AES_C or MBEDTLS_DES_C
    #define MBEDTLS_CMAC_C
     * \def MBEDTLS_CTR_DRBG_C
     * Enable the CTR_DRBG AES-based random generator.
     * The CTR_DRBG generator uses AES-256 by default.
     * To use AES-128 instead, enable \c MBEDTLS_CTR_DRBG_USE_128_BIT_KEY above.
     * \note To achieve a 256-bit security strength with CTR_DRBG,
     *       you must use AES-256 *and* use sufficient entropy.
     *       See ctr_drbg.h for more details.
     * Module:  library/ctr_drbg.c
     * Caller:
     * This module provides the CTR_DRBG AES random number generator.
    #define MBEDTLS_CTR_DRBG_C
     * \def MBEDTLS_DEBUG_C
     * Enable the debug functions.
     * Module:  library/debug.c
     * Caller:  library/ssl_cli.c
     *          library/ssl_srv.c
     *          library/ssl_tls.c
     * This module provides debugging functions.
    /* #undef MBEDTLS_DEBUG_C */
     * \def MBEDTLS_DES_C
     * Enable the DES block cipher.
     * Module:  library/des.c
     *          library/cipher.c
     * PEM_PARSE uses DES/3DES for decrypting encrypted keys.
     * \warning   DES is considered a weak cipher and its use constitutes a
     *            security risk. We recommend considering stronger ciphers instead.
     * \def MBEDTLS_DHM_C
     * Enable the Diffie-Hellman-Merkle module.
     * Module:  library/dhm.c
     *          library/ssl_srv.c
     * This module is used by the following key exchanges:
     *      DHE-RSA, DHE-PSK
    /* #undef MBEDTLS_DHM_C */
     * \def MBEDTLS_ECDH_C
     * Enable the elliptic curve Diffie-Hellman library.
     * Module:  library/ecdh.c
     *          library/ssl_srv.c
     *      ECDHE-ECDSA, ECDHE-RSA, DHE-PSK
     * Requires: MBEDTLS_ECP_C
     * \def MBEDTLS_ECDSA_C
     * Enable the elliptic curve DSA library.
     * Module:  library/ecdsa.c
     * Caller:
     *      ECDHE-ECDSA
     * Requires: MBEDTLS_ECP_C, MBEDTLS_ASN1_WRITE_C, MBEDTLS_ASN1_PARSE_C,
     *           and at least one MBEDTLS_ECP_DP_XXX_ENABLED for a
     *           short Weierstrass curve.
    #define MBEDTLS_ECDSA_C
     * \def MBEDTLS_ECJPAKE_C
     * Enable the elliptic curve J-PAKE library.
     * \note EC J-PAKE support is based on the Thread v1.0.0 specification.
     *       It has not been reviewed for compliance with newer standards such as
     *       Thread v1.1 or RFC 8236.
     * Module:  library/ecjpake.c
     * Caller:
     *      ECJPAKE
     * Requires: MBEDTLS_ECP_C, MBEDTLS_MD_C
    #define MBEDTLS_ECJPAKE_C
     * \def MBEDTLS_ECP_C
     * Enable the elliptic curve over GF(p) library.
     * Module:  library/ecp.c
     * Caller:  library/ecdh.c
     *          library/ecdsa.c
     *          library/ecjpake.c
     * Requires: MBEDTLS_BIGNUM_C and at least one MBEDTLS_ECP_DP_XXX_ENABLED
    #define MBEDTLS_ECP_C
     * \def MBEDTLS_ENTROPY_C
     * Enable the platform-specific entropy code.
     * Module:  library/entropy.c
     * Caller:
     * Requires: MBEDTLS_SHA512_C or MBEDTLS_SHA256_C
     * This module provides a generic entropy pool
    #define MBEDTLS_ENTROPY_C
     * \def MBEDTLS_ERROR_C
     * Enable error code to error string conversion.
     * Module:  library/error.c
     * Caller:
     * This module enables mbedtls_strerror().
    /* #undef MBEDTLS_ERROR_C */
     * \def MBEDTLS_GCM_C
     * Enable the Galois/Counter Mode (GCM).
     * Module:  library/gcm.c
     * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C or MBEDTLS_ARIA_C
     * This module enables the AES-GCM and CAMELLIA-GCM ciphersuites, if other
     * requisites are enabled as well.
    /* #undef MBEDTLS_GCM_C */
     * \def MBEDTLS_HKDF_C
     * Enable the HKDF algorithm (RFC 5869).
     * Module:  library/hkdf.c
     * Caller:
     * This module adds support for the Hashed Message Authentication Code
     * (HMAC)-based key derivation function (HKDF).
    #define MBEDTLS_HKDF_C
     * \def MBEDTLS_HMAC_DRBG_C
     * Enable the HMAC_DRBG random generator.
     * Module:  library/hmac_drbg.c
     * Caller:
     * Uncomment to enable the HMAC_DRBG random number geerator.
    #define MBEDTLS_HMAC_DRBG_C
     * \def MBEDTLS_NIST_KW_C
     * Enable the Key Wrapping mode for 128-bit block ciphers,
     * as defined in NIST SP 800-38F. Only KW and KWP modes
     * are supported. At the moment, only AES is approved by NIST.
     * Module:  library/nist_kw.c
     * Requires: MBEDTLS_AES_C and MBEDTLS_CIPHER_C
    //#define MBEDTLS_NIST_KW_C
     * \def MBEDTLS_MD_C
     * Enable the generic message digest layer.
     * Module:  library/md.c
     * Caller:
     * Uncomment to enable generic message digest wrappers.
    #define MBEDTLS_MD_C
     * \def MBEDTLS_MD5_C
     * Enable the MD5 hash algorithm.
     * Module:  library/md5.c
     * Caller:  library/md.c
     *          library/pem.c
     *          library/ssl_tls.c
     * This module is required for TLS 1.2 depending on the handshake parameters.
     * Further, it is used for checking MD5-signed certificates, and for PBKDF1
     * when decrypting PEM-encoded encrypted keys.
     * \warning   MD5 is considered a weak message digest and its use constitutes a
     *            security risk. If possible, we recommend avoiding dependencies on
     *            it, and considering stronger message digests instead.
    /* #undef MBEDTLS_MD5_C */
     * \def MBEDTLS_MEMORY_BUFFER_ALLOC_C
     * Enable the buffer allocator implementation that makes use of a (stack)
     * based buffer to 'allocate' dynamic memory. (replaces calloc() and free()
     * calls)
     * Module:  library/memory_buffer_alloc.c
     * Requires: MBEDTLS_PLATFORM_C
     *           MBEDTLS_PLATFORM_MEMORY (to use it within mbed TLS)
     * Enable this module to enable the buffer memory allocator.
    #define MBEDTLS_MEMORY_BUFFER_ALLOC_C
     * \def MBEDTLS_NET_C
     * Enable the TCP and UDP over IPv6/IPv4 networking routines.
     * \note This module only works on POSIX/Unix (including Linux, BSD and OS X)
     * and Windows. For other platforms, you'll want to disable it, and write your
     * own networking callbacks to be passed to \c mbedtls_ssl_set_bio().
     * \note See also our Knowledge Base article about porting to a new
     * environment:
     * https://tls.mbed.org/kb/how-to/how-do-i-port-mbed-tls-to-a-new-environment-OS
     * Module:  library/net_sockets.c
     * This module provides networking routines.
    //#define MBEDTLS_NET_C
     * \def MBEDTLS_OID_C
     * Enable the OID database.
     * Module:  library/oid.c
     * Caller:  library/asn1write.c
     *          library/pkcs5.c
     *          library/pkparse.c
     *          library/pkwrite.c
     *          library/rsa.c
     *          library/x509.c
     *          library/x509_crl.c
     *          library/x509_crt.c
     *          library/x509_csr.c
     * This modules translates between OIDs and internal values.
    #define MBEDTLS_OID_C
     * \def MBEDTLS_PADLOCK_C
     * Enable VIA Padlock support on x86.
     * Module:  library/padlock.c
     * This modules adds support for the VIA PadLock on x86.
    //#define MBEDTLS_PADLOCK_C
     * \def MBEDTLS_PEM_PARSE_C
     * Enable PEM decoding / parsing.
     * Module:  library/pem.c
     *          library/pkparse.c
     * Requires: MBEDTLS_BASE64_C
     * This modules adds support for decoding / parsing PEM files.
    #define MBEDTLS_PEM_PARSE_C
     * \def MBEDTLS_PEM_WRITE_C
     * Enable PEM encoding / writing.
     * Caller:  library/pkwrite.c
     * This modules adds support for encoding / writing PEM files.
    #define MBEDTLS_PEM_WRITE_C
     * \def MBEDTLS_PK_C
     * Enable the generic public (asymetric) key layer.
     * Module:  library/pk.c
     *          library/ssl_cli.c
     *          library/ssl_srv.c
     * Requires: MBEDTLS_RSA_C or MBEDTLS_ECP_C
     * Uncomment to enable generic public key wrappers.
    #define MBEDTLS_PK_C
     * \def MBEDTLS_PK_PARSE_C
     * Enable the generic public (asymetric) key parser.
     * Module:  library/pkparse.c
     * Caller:  library/x509_crt.c
     * Requires: MBEDTLS_PK_C
     * Uncomment to enable generic public key parse functions.
    #define MBEDTLS_PK_PARSE_C
     * \def MBEDTLS_PK_WRITE_C
     * Enable the generic public (asymetric) key writer.
     * Module:  library/pkwrite.c
     * Caller:  library/x509write.c
     * Uncomment to enable generic public key write functions.
    #define MBEDTLS_PK_WRITE_C
     * \def MBEDTLS_PKCS5_C
     * Enable PKCS#5 functions.
     * Module:  library/pkcs5.c
     * This module adds support for the PKCS#5 functions.
    #define MBEDTLS_PKCS5_C
     * \def MBEDTLS_PKCS12_C
     * Enable PKCS#12 PBE functions.
     * Adds algorithms for parsing PKCS#8 encrypted private keys
     * Module:  library/pkcs12.c
     * Caller:  library/pkparse.c
     * Requires: MBEDTLS_ASN1_PARSE_C, MBEDTLS_CIPHER_C, MBEDTLS_MD_C
     * This module enables PKCS#12 functions.
    //#define MBEDTLS_PKCS12_C
     * \def MBEDTLS_PLATFORM_C
     * Enable the platform abstraction layer that allows you to re-assign
     * functions like calloc(), free(), snprintf(), printf(), fprintf(), exit().
     * Enabling MBEDTLS_PLATFORM_C enables to use of MBEDTLS_PLATFORM_XXX_ALT
     * or MBEDTLS_PLATFORM_XXX_MACRO directives, allowing the functions mentioned
     * above to be specified at runtime or compile time respectively.
     * \note This abstraction layer must be enabled on Windows (including MSYS2)
     * as other module rely on it for a fixed snprintf implementation.
     * Module:  library/platform.c
     * Caller:  Most other .c files
     * This module enables abstraction of common (libc) functions.
    #define MBEDTLS_PLATFORM_C
     * \def MBEDTLS_POLY1305_C
     * Enable the Poly1305 MAC algorithm.
     * Module:  library/poly1305.c
     * Caller:  library/chachapoly.c
    /* #undef MBEDTLS_POLY1305_C */
     * Enable the Platform Security Architecture cryptography API.
     * \warning The PSA Crypto API is still beta status. While you're welcome to
     * Requires: either MBEDTLS_CTR_DRBG_C and MBEDTLS_ENTROPY_C,
     *           or MBEDTLS_HMAC_DRBG_C and MBEDTLS_ENTROPY_C,
     *           or MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG.
     * \def MBEDTLS_PSA_CRYPTO_SE_C
     * Enable secure element support in the Platform Security Architecture
     * cryptography API.
     * \warning This feature is not yet suitable for production. It is provided
     *          for API evaluation and testing purposes only.
     * Module:  library/psa_crypto_se.c
     * Requires: MBEDTLS_PSA_CRYPTO_C, MBEDTLS_PSA_CRYPTO_STORAGE_C
    //#define MBEDTLS_PSA_CRYPTO_SE_C
     * \def MBEDTLS_PSA_CRYPTO_STORAGE_C
     * Enable the Platform Security Architecture persistent key storage.
     * Module:  library/psa_crypto_storage.c
     *           either MBEDTLS_PSA_ITS_FILE_C or a native implementation of
     *           the PSA ITS interface
    /* #undef MBEDTLS_PSA_CRYPTO_STORAGE_C */
     * \def MBEDTLS_PSA_ITS_FILE_C
     * Enable the emulation of the Platform Security Architecture
     * Internal Trusted Storage (PSA ITS) over files.
     * Module:  library/psa_its_file.c
     * Requires: MBEDTLS_FS_IO
    //#define MBEDTLS_PSA_ITS_FILE_C
     * \def MBEDTLS_RIPEMD160_C
     * Enable the RIPEMD-160 hash algorithm.
     * Module:  library/ripemd160.c
    /* #undef MBEDTLS_RIPEMD160_C */
     * \def MBEDTLS_RSA_C
     * Enable the RSA public-key cryptosystem.
     * Module:  library/rsa.c
     *          library/ssl_srv.c
     *          library/ssl_tls.c
     *          library/x509.c
     *      RSA, DHE-RSA, ECDHE-RSA, RSA-PSK
     * Requires: MBEDTLS_BIGNUM_C, MBEDTLS_OID_C
    /* #undef MBEDTLS_RSA_C */
     * \def MBEDTLS_SHA1_C
     * Enable the SHA1 cryptographic hash algorithm.
     * Module:  library/sha1.c
     *          library/ssl_cli.c
     *          library/ssl_srv.c
     *          library/ssl_tls.c
     * This module is required for TLS 1.2 depending on the handshake parameters,
     * and for SHA1-signed certificates.
     * \warning   SHA-1 is considered a weak message digest and its use constitutes
     *            a security risk. If possible, we recommend avoiding dependencies
     *            on it, and considering stronger message digests instead.
    /* #undef MBEDTLS_SHA1_C */
     * \def MBEDTLS_SHA224_C
     * Enable the SHA-224 cryptographic hash algorithm.
     * Requires: MBEDTLS_SHA256_C. The library does not currently support enabling
     *           SHA-224 without SHA-256.
     * Module:  library/sha256.c
     *          library/ssl_cookie.c
     * This module adds support for SHA-224.
    #define MBEDTLS_SHA224_C
     * \def MBEDTLS_SHA256_C
     * Enable the SHA-256 cryptographic hash algorithm.
     * Requires: MBEDTLS_SHA224_C. The library does not currently support enabling
     *           SHA-256 without SHA-224.
     * Caller:  library/entropy.c
     *          library/md.c
     *          library/ssl_cli.c
     *          library/ssl_srv.c
     *          library/ssl_tls.c
     * This module adds support for SHA-256.
     * This module is required for the SSL/TLS 1.2 PRF function.
    #define MBEDTLS_SHA256_C
     * \def MBEDTLS_SHA384_C
     * Enable the SHA-384 cryptographic hash algorithm.
     * Module:  library/sha512.c
     *          library/ssl_cli.c
     *          library/ssl_srv.c
     * Comment to disable SHA-384
    /* #undef MBEDTLS_SHA384_C */
     * \def MBEDTLS_SHA512_C
     * Enable SHA-512 cryptographic hash algorithms.
     *          library/md.c
     *          library/ssl_tls.c
     * This module adds support for SHA-512.
    /* #undef MBEDTLS_SHA512_C */
     * \def MBEDTLS_SSL_CACHE_C
     * Enable simple SSL cache implementation.
     * Module:  library/ssl_cache.c
     * Caller:
     * Requires: MBEDTLS_SSL_CACHE_C
    /* #undef MBEDTLS_SSL_CACHE_C */
     * \def MBEDTLS_SSL_COOKIE_C
     * Enable basic implementation of DTLS cookies for hello verification.
     * Module:  library/ssl_cookie.c
     * Caller:
    #define MBEDTLS_SSL_COOKIE_C
     * \def MBEDTLS_SSL_TICKET_C
     * Enable an implementation of TLS server-side callbacks for session tickets.
     * Module:  library/ssl_ticket.c
     * Caller:
     * Requires: MBEDTLS_CIPHER_C
    /* #undef MBEDTLS_SSL_TICKET_C */
     * \def MBEDTLS_SSL_CLI_C
     * Enable the SSL/TLS client code.
     * Module:  library/ssl_cli.c
     * Caller:
     * This module is required for SSL/TLS client support.
    #define MBEDTLS_SSL_CLI_C
     * \def MBEDTLS_SSL_SRV_C
     * Enable the SSL/TLS server code.
     * Module:  library/ssl_srv.c
     * Caller:
     * This module is required for SSL/TLS server support.
    #define MBEDTLS_SSL_SRV_C
     * \def MBEDTLS_SSL_TLS_C
     * Enable the generic SSL/TLS code.
     * Module:  library/ssl_tls.c
     *          library/ssl_srv.c
     * Requires: MBEDTLS_CIPHER_C, MBEDTLS_MD_C
     *           and at least one of the MBEDTLS_SSL_PROTO_XXX defines
     * This module is required for SSL/TLS.
    #define MBEDTLS_SSL_TLS_C
     * \def MBEDTLS_THREADING_C
     * Enable the threading abstraction layer.
     * By default mbed TLS assumes it is used in a non-threaded environment or that
     * contexts are not shared between threads. If you do intend to use contexts
     * between threads, you will need to enable this layer to prevent race
     * conditions. See also our Knowledge Base article about threading:
     * https://tls.mbed.org/kb/development/thread-safety-and-multi-threading
     * Module:  library/threading.c
     * This allows different threading implementations (self-implemented or
     * provided).
     * You will have to enable either MBEDTLS_THREADING_ALT or
     * MBEDTLS_THREADING_PTHREAD.
     * Enable this layer to allow use of mutexes within mbed TLS
    #define MBEDTLS_THREADING_C
     * \def MBEDTLS_TIMING_C
     * Enable the semi-portable timing interface.
     * \note The provided implementation only works on POSIX/Unix (including Linux,
     * BSD and OS X) and Windows. On other platforms, you can either disable that
     * module and provide your own implementations of the callbacks needed by
     * \c mbedtls_ssl_set_timer_cb() for DTLS, or leave it enabled and provide
     * your own implementation of the whole module by setting
     * \c MBEDTLS_TIMING_ALT in the current file.
     * environment:
     * Module:  library/timing.c
    //#define MBEDTLS_TIMING_C
     * \def MBEDTLS_VERSION_C
     * Enable run-time version information.
     * Module:  library/version.c
     * This module provides run-time version information.
    #define MBEDTLS_VERSION_C
     * \def MBEDTLS_X509_USE_C
     * Enable X.509 core for using certificates.
     * Module:  library/x509.c
     * Caller:  library/x509_crl.c
     * Requires: MBEDTLS_ASN1_PARSE_C, MBEDTLS_BIGNUM_C, MBEDTLS_OID_C,
     *           MBEDTLS_PK_PARSE_C
     * This module is required for the X.509 parsing modules.
    #define MBEDTLS_X509_USE_C
     * \def MBEDTLS_X509_CRT_PARSE_C
     * Enable X.509 certificate parsing.
     * Module:  library/x509_crt.c
     *          library/ssl_srv.c
     *          library/ssl_tls.c
     * Requires: MBEDTLS_X509_USE_C
     * This module is required for X.509 certificate parsing.
    #define MBEDTLS_X509_CRT_PARSE_C
     * \def MBEDTLS_X509_CRL_PARSE_C
     * Enable X.509 CRL parsing.
     * Module:  library/x509_crl.c
     * This module is required for X.509 CRL parsing.
    #define MBEDTLS_X509_CRL_PARSE_C
     * \def MBEDTLS_X509_CSR_PARSE_C
     * Enable X.509 Certificate Signing Request (CSR) parsing.
     * Module:  library/x509_csr.c
     * Caller:  library/x509_crt_write.c
     * This module is used for reading X.509 certificate request.
    #define MBEDTLS_X509_CSR_PARSE_C
     * \def MBEDTLS_X509_CREATE_C
     * Enable X.509 core for creating certificates.
     * Module:  library/x509_create.c
     * Requires: MBEDTLS_BIGNUM_C, MBEDTLS_OID_C, MBEDTLS_PK_WRITE_C
     * This module is the basis for creating X.509 certificates and CSRs.
    #define MBEDTLS_X509_CREATE_C
     * \def MBEDTLS_X509_CRT_WRITE_C
     * Enable creating X.509 certificates.
     * Module:  library/x509_crt_write.c
     * Requires: MBEDTLS_X509_CREATE_C
     * This module is required for X.509 certificate creation.
    /* #undef MBEDTLS_X509_CRT_WRITE_C */
     * \def MBEDTLS_X509_CSR_WRITE_C
     * Enable creating X.509 Certificate Signing Requests (CSR).
     * Module:  library/x509_csr_write.c
     * This module is required for X.509 certificate request writing.
    #define MBEDTLS_X509_CSR_WRITE_C
    /* \} name SECTION: mbed TLS modules */
     * \name SECTION: Module configuration options
     * This section allows for the setting of module specific sizes and
     * configuration options. The default values are already present in the
     * relevant header files and should suffice for the regular use cases.
     * Our advice is to enable options and change their values here
     * only if you have a good reason and know the consequences.
     * Please check the respective header file for documentation on these
     * parameters (to prevent duplicate documentation).
    /* MPI / BIGNUM options */
    #define MBEDTLS_MPI_WINDOW_SIZE       6 /**< Maximum window size used. */
    #define MBEDTLS_MPI_MAX_SIZE          256 /**< Maximum number of bytes for usable MPIs. */
    /* CTR_DRBG options */
    //#define MBEDTLS_CTR_DRBG_ENTROPY_LEN               48 /**< Amount of entropy used per seed by default (48 with SHA-512, 32 with SHA-256) */
    /*!  Maximal reseed counter - indicates maximal number of
    requests allowed between reseeds; according to NIST 800-90
    it is (2^48 - 1), our restriction is :  (int - 0xFFFF - 0xF).*/
    #define MBEDTLS_CTR_DRBG_RESEED_INTERVAL            0xFFF0 /**< Interval before reseed is performed by default */
    //#define MBEDTLS_CTR_DRBG_MAX_INPUT                256 /**< Maximum number of additional input bytes */
    //#define MBEDTLS_CTR_DRBG_MAX_REQUEST             1024 /**< Maximum number of requested bytes per call */
    //#define MBEDTLS_CTR_DRBG_MAX_SEED_INPUT           384 /**< Maximum size of (re)seed buffer */
    /* HMAC_DRBG options */
    //#define MBEDTLS_HMAC_DRBG_RESEED_INTERVAL   10000 /**< Interval before reseed is performed by default */
    //#define MBEDTLS_HMAC_DRBG_MAX_INPUT           256 /**< Maximum number of additional input bytes */
    //#define MBEDTLS_HMAC_DRBG_MAX_REQUEST        1024 /**< Maximum number of requested bytes per call */
    //#define MBEDTLS_HMAC_DRBG_MAX_SEED_INPUT      384 /**< Maximum size of (re)seed buffer */
    /* ECP options */
    /* #undef MBEDTLS_ECP_WINDOW_SIZE */
    /* #undef MBEDTLS_ECP_FIXED_POINT_OPTIM */
    /* Entropy options */
    #define MBEDTLS_ENTROPY_MAX_SOURCES             1 /**< Maximum number of sources supported */
    #define MBEDTLS_ENTROPY_MAX_GATHER                   144 /**< Maximum amount requested from entropy sources */
    //#define MBEDTLS_ENTROPY_MIN_HARDWARE               32 /**< Default minimum number of bytes required for the hardware entropy source mbedtls_hardware_poll() before entropy is released */
    /* Memory buffer allocator options */
    //#define MBEDTLS_MEMORY_ALIGN_MULTIPLE      4 /**< Align on multiples of this value */
    /* Platform options */
    //#define MBEDTLS_PLATFORM_STD_MEM_HDR   <stdlib.h> /**< Header to include if MBEDTLS_PLATFORM_NO_STD_FUNCTIONS is defined. Don't define if no header is needed. */
    //#define MBEDTLS_PLATFORM_STD_CALLOC        calloc /**< Default allocator to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_FREE            free /**< Default free to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_EXIT            exit /**< Default exit to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_TIME            time /**< Default time to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
    //#define MBEDTLS_PLATFORM_STD_FPRINTF      fprintf /**< Default fprintf to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_PRINTF        printf /**< Default printf to use, can be undefined */
    /* Note: your snprintf must correctly zero-terminate the buffer! */
    //#define MBEDTLS_PLATFORM_STD_SNPRINTF    snprintf /**< Default snprintf to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_EXIT_SUCCESS       0 /**< Default exit value to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_EXIT_FAILURE       1 /**< Default exit value to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_NV_SEED_READ   mbedtls_platform_std_nv_seed_read /**< Default nv_seed_read function to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_NV_SEED_WRITE  mbedtls_platform_std_nv_seed_write /**< Default nv_seed_write function to use, can be undefined */
    //#define MBEDTLS_PLATFORM_STD_NV_SEED_FILE  "seedfile" /**< Seed file to read/write with default implementation */
    /* To Use Function Macros MBEDTLS_PLATFORM_C must be enabled */
    /* MBEDTLS_PLATFORM_XXX_MACRO and MBEDTLS_PLATFORM_XXX_ALT cannot both be defined */
    //#define MBEDTLS_PLATFORM_CALLOC_MACRO        calloc /**< Default allocator macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_FREE_MACRO            free /**< Default free macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_EXIT_MACRO            exit /**< Default exit macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_TIME_MACRO            time /**< Default time macro to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
    //#define MBEDTLS_PLATFORM_TIME_TYPE_MACRO       time_t /**< Default time macro to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
    //#define MBEDTLS_PLATFORM_FPRINTF_MACRO      fprintf /**< Default fprintf macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_PRINTF_MACRO        printf /**< Default printf macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_SNPRINTF_MACRO    snprintf /**< Default snprintf macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_VSNPRINTF_MACRO    vsnprintf /**< Default vsnprintf macro to use, can be undefined */
    //#define MBEDTLS_PLATFORM_NV_SEED_READ_MACRO   mbedtls_platform_std_nv_seed_read /**< Default nv_seed_read function to use, can be undefined */
    //#define MBEDTLS_PLATFORM_NV_SEED_WRITE_MACRO  mbedtls_platform_std_nv_seed_write /**< Default nv_seed_write function to use, can be undefined */
    /* PSA options */
     * Use HMAC_DRBG with the specified hash algorithm for HMAC_DRBG for the
     * PSA crypto subsystem.
     * If this option is unset:
     * - If CTR_DRBG is available, the PSA subsystem uses it rather than HMAC_DRBG.
     * - Otherwise, the PSA subsystem uses HMAC_DRBG with either
     *   #MBEDTLS_MD_SHA512 or #MBEDTLS_MD_SHA256 based on availability and
     *   on unspecified heuristics.
    //#define MBEDTLS_PSA_HMAC_DRBG_MD_TYPE MBEDTLS_MD_SHA256
    /** \def MBEDTLS_PSA_KEY_SLOT_COUNT
     * Restrict the PSA library to supporting a maximum amount of simultaneously
     * loaded keys. A loaded key is a key stored by the PSA Crypto core as a
     * volatile key, or a persistent key which is loaded temporarily by the
     * library as part of a crypto operation in flight.
     * If this option is unset, the library will fall back to a default value of
     * 32 keys.
    //#define MBEDTLS_PSA_KEY_SLOT_COUNT 32
    /* SSL Cache options */
    //#define MBEDTLS_SSL_CACHE_DEFAULT_TIMEOUT       86400 /**< 1 day  */
    //#define MBEDTLS_SSL_CACHE_DEFAULT_MAX_ENTRIES      50 /**< Maximum entries in cache */
    /* SSL options */
    /** \def MBEDTLS_SSL_IN_CONTENT_LEN
     * Maximum length (in bytes) of incoming plaintext fragments.
     * This determines the size of the incoming TLS I/O buffer in such a way
     * that it is capable of holding the specified amount of plaintext data,
     * regardless of the protection mechanism used.
     * \note When using a value less than the default of 16KB on the client, it is
     *       recommended to use the Maximum Fragment Length (MFL) extension to
     *       inform the server about this limitation. On the server, there
     *       is no supported, standardized way of informing the client about
     *       restriction on the maximum size of incoming messages, and unless
     *       the limitation has been communicated by other means, it is recommended
     *       to only change the outgoing buffer size #MBEDTLS_SSL_OUT_CONTENT_LEN
     *       while keeping the default value of 16KB for the incoming buffer.
     * Uncomment to set the maximum plaintext size of the incoming I/O buffer.
    #define MBEDTLS_SSL_IN_CONTENT_LEN              900
    /** \def MBEDTLS_SSL_CID_IN_LEN_MAX
     * The maximum length of CIDs used for incoming DTLS messages.
    //#define MBEDTLS_SSL_CID_IN_LEN_MAX 32
    /** \def MBEDTLS_SSL_CID_OUT_LEN_MAX
     * The maximum length of CIDs used for outgoing DTLS messages.
    //#define MBEDTLS_SSL_CID_OUT_LEN_MAX 32
    /** \def MBEDTLS_SSL_CID_TLS1_3_PADDING_GRANULARITY
     * This option controls the use of record plaintext padding
     * in TLS 1.3 and when using the Connection ID extension in DTLS 1.2.
     * The padding will always be chosen so that the length of the
     * padded plaintext is a multiple of the value of this option.
     * Note: A value of \c 1 means that no padding will be used
     *       for outgoing records.
     * Note: On systems lacking division instructions,
     *       a power of two should be preferred.
    //#define MBEDTLS_SSL_CID_TLS1_3_PADDING_GRANULARITY 16
    /** \def MBEDTLS_SSL_OUT_CONTENT_LEN
     * Maximum length (in bytes) of outgoing plaintext fragments.
     * This determines the size of the outgoing TLS I/O buffer in such a way
     * It is possible to save RAM by setting a smaller outward buffer, while keeping
     * the default inward 16384 byte buffer to conform to the TLS specification.
     * The minimum required outward buffer size is determined by the handshake
     * protocol's usage. Handshaking will fail if the outward buffer is too small.
     * The specific size requirement depends on the configured ciphers and any
     * certificate data which is sent during the handshake.
     * Uncomment to set the maximum plaintext size of the outgoing I/O buffer.
    #define MBEDTLS_SSL_OUT_CONTENT_LEN             900
    /** \def MBEDTLS_SSL_DTLS_MAX_BUFFERING
     * Maximum number of heap-allocated bytes for the purpose of
     * DTLS handshake message reassembly and future message buffering.
     * This should be at least 9/8 * MBEDTLSSL_IN_CONTENT_LEN
     * to account for a reassembled handshake message of maximum size,
     * together with its reassembly bitmap.
     * A value of 2 * MBEDTLS_SSL_IN_CONTENT_LEN (32768 by default)
     * should be sufficient for all practical situations as it allows
     * to reassembly a large handshake message (such as a certificate)
     * while buffering multiple smaller handshake messages.
    //#define MBEDTLS_SSL_DTLS_MAX_BUFFERING             32768
    //#define MBEDTLS_PSK_MAX_LEN               32 /**< Max size of TLS pre-shared keys, in bytes (default 256 bits) */
    //#define MBEDTLS_SSL_COOKIE_TIMEOUT        60 /**< Default expiration delay of DTLS cookies, in seconds if HAVE_TIME, or in number of cookies issued */
     * Complete list of ciphersuites to use, in order of preference.
     * \warning No dependency checking is done on that field! This option can only
     * be used to restrict the set of available ciphersuites. It is your
     * responsibility to make sure the needed modules are active.
     * Use this to save a few hundred bytes of ROM (default ordering of all
     * available ciphersuites) and a few to a few hundred bytes of RAM.
     * The value below is only an example, not the default.
    /* #undef MBEDTLS_SSL_CIPHERSUITES */
    /* X509 options */
    //#define MBEDTLS_X509_MAX_INTERMEDIATE_CA   8   /**< Maximum number of intermediate CAs in a verification chain. */
    //#define MBEDTLS_X509_MAX_FILE_PATH_LEN     512 /**< Maximum length of a path/filename string in bytes including the null terminator character ('\0'). */
     * Uncomment the macro to let mbed TLS use your alternate implementation of
     * mbedtls_platform_zeroize(). This replaces the default implementation in
     * platform_util.c.
     * mbedtls_platform_zeroize() is a widely used function across the library to
     * zero a block of memory. The implementation is expected to be secure in the
     * sense that it has been written to prevent the compiler from removing calls
     * to mbedtls_platform_zeroize() as part of redundant code elimination
     * optimizations. However, it is difficult to guarantee that calls to
     * mbedtls_platform_zeroize() will not be optimized by the compiler as older
     * versions of the C language standards do not provide a secure implementation
     * of memset(). Therefore, MBEDTLS_PLATFORM_ZEROIZE_ALT enables users to
     * configure their own implementation of mbedtls_platform_zeroize(), for
     * example by using directives specific to their compiler, features from newer
     * C standards (e.g using memset_s() in C11) or calling a secure memset() from
     * their system (e.g explicit_bzero() in BSD).
    #define MBEDTLS_PLATFORM_ZEROIZE_ALT
     * Uncomment the macro to let Mbed TLS use your alternate implementation of
     * mbedtls_platform_gmtime_r(). This replaces the default implementation in
     * platform_util.c.
     * gmtime() is not a thread-safe function as defined in the C standard. The
     * library will try to use safer implementations of this function, such as
     * gmtime_r() when available. However, if Mbed TLS cannot identify the target
     * system, the implementation of mbedtls_platform_gmtime_r() will default to
     * using the standard gmtime(). In this case, calls from the library to
     * gmtime() will be guarded by the global mutex mbedtls_threading_gmtime_mutex
     * if MBEDTLS_THREADING_C is enabled. We recommend that calls from outside the
     * library are also guarded with this mutex to avoid race conditions. However,
     * if the macro MBEDTLS_PLATFORM_GMTIME_R_ALT is defined, Mbed TLS will
     * unconditionally use the implementation for mbedtls_platform_gmtime_r()
     * supplied at compile time.
    //#define MBEDTLS_PLATFORM_GMTIME_R_ALT
     * Enable the verified implementations of ECDH primitives from Project Everest
     * (currently only Curve25519). This feature changes the layout of ECDH
     * contexts and therefore is a compatibility break for applications that access
     * fields of a mbedtls_ecdh_context structure directly. See also
     * MBEDTLS_ECDH_LEGACY_CONTEXT in include/mbedtls/ecdh.h.
    //#define MBEDTLS_ECDH_VARIANT_EVEREST_ENABLED
    #if defined(CONFIG_MBEDTLS_OPENTHREAD_OPTIMIZATIONS_ENABLED)
    #define MBEDTLS_MPI_WINDOW_SIZE            1 /**< Maximum windows size used. */
    #define MBEDTLS_MPI_MAX_SIZE              32 /**< Maximum number of bytes for usable MPIs. */
    #define MBEDTLS_ECP_WINDOW_SIZE            2 /**< Maximum window size used */
    #define MBEDTLS_ECP_FIXED_POINT_OPTIM      0 /**< Enable fixed-point speed-up */
    /* \} name SECTION: Customisation configuration options */
    #endif /* LEGACY_CRYPTO_CONFIG_H */
    build/modules/nrfxlib/nrfxlib/nrf_security/src/include/generated/nrf-config-user.h is an empty file
     * Copyright (c) 2021 Nordic Semiconductor
    /* This file is intentionally empty.*/
    I have asked my colleagues to have a look at the nrf-config.h file which you provided.
    Since I will be out of the office for next 2 weeks, you could either wait till I return or if your issue needs urgent attention, you could open a new ticket in which you would refer to this one.
    Dejan
  • Hey, Hugo.Dev.
    In your .config file I can see that CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG is not set (line 66).
    Can you try to figure out why, and see if you can turn it on?
    Best Regards,
    Magne
  • Hi Magne.
    Thanks for your reply.
    I think the reason of this macro not set is in config/nrfconnect/chip-module/Kconfig.defaults
    config MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG
        default n
    As I have explained, I started from the matter lock sample and only enabled these macros in conf file:
    CONFIG_OBERON_BACKEND=n
    CONFIG_NRF_OBERON=n
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_CC3XX_BACKEND=y
    Now, after your message I have added this line:
    CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y
    But now it is not compiling with undefined reference to `mbedtls_entropy_init' error.
    I dont know if there is another dependency I am missing.
  • Hi Magne, pls confirm if you will keep answering within this ticket or I should open a new one as Dejan suggested.
    Thanks
