DFU BLE bootloader doesn't seem to work
I am trying to implement the smp_svr example as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html.
I have successfully built and flashed the MCU bootloader. (to a nRF52840dk)
I have successfully built, the mcumgr.
I have successfully built, signed, and flashed the smp_svr.
At this point I looked at my nRF_CONNECT_FOR_MOBILE scanner but I do not see the device.
I modified the smp_svr bluetooth.c as follows:
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID128_ALL,
0x84, 0xaa, 0x60, 0x74, 0x52, 0x8a, 0x8b, 0x86,
0xd3, 0x4c, 0xb7, 0x1d, 0x1d, 0xdc, 0x53, 0x8d),
BT_DATA(BT_DATA_NAME_COMPLETE, "Zephyr_DFU", 8),
This I did because I was unsure what the default advertising name was.
I then rebuilt, resigned, and re-flashed.
I still did not see the the device on my scanner.
When I attempt to flash with mcumgr It doesn't connect.
sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' echo hello
hello
Error: Failed to connect to peer after 10s
and
sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='ZephyrDFU' echo hello
This suggests to me the smp_svr program isn't working correctly.
I'm not sure where to go with this, any suggestions?
Jerry
  • Hi Jerry,
    When in doubt , just try both ;)
    Just kidding, you should use the one at slot 1 : 582ef2530f15968c39513443f312418a0179dac2050b1146bd727467df042564
    The original image will always at slot 0. It's the image that will run at boot (after MCUBoot). When you do test, image at slot 1 will be temporarily copied to slot 0 and revert back after rest.
    When you do confirm the image at slot 1 will overwrite the one at slot 0 and run at next boot.
  • Hi Hung,
    Ok this is what I did:
    (.venv) jerry@Ubuntu:~/zephyrproject$ sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload ~/MyApps/blinky/build_dk/zephyr/app_update.bin
     23.03 KiB / 23.03 KiB [====================================================================================================================] 100.00% 10.43 KiB/s 2s
    Done
    (.venv) jerry@Ubuntu:~/zephyrproject$ sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image list
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
        flags: active confirmed
        hash: ea9c889031e33c8c9c500e00e8ed94454f536368c499c186688f323a48f973b4
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags:
        hash: 582ef2530f15968c39513443f312418a0179dac2050b1146bd727467df042564
    Split status: N/A (0)
    (.venv) jerry@Ubuntu:~/zephyrproject$ sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image test 582ef2530f15968c39513443f312418a0179dac2050b1146bd727467df042564  + a reset
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags: pending
    (.venv) jerry@Ubuntu:~/zephyrproject$ sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image confirm 582ef2530f15968c39513443f312418a0179dac2050b1146bd727467df042564  + a reset
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags: pending
    My blinky application does not run.
    I have reset the device with vscode: it doesn't run.
    I have reset the device with the reset button: it does not run.
    I have removed power and applied power: it does not run.
    I am sure I have switched images because my smp_svr is no longer manifest.
    Maybe I have not properly prepared my blinky application?
    Jerry
  • Hi again,
    Have you built the blinky with MCUBoot added ? The image should be configured so that it can run on slot 0
    My suggestion is to do an update with the same smp_svr image, just change something like advertising name, or blink another LED but still the same smp_svr application.
  • Hi Hung,
    I apologize, it is working: I must have had too much coffee and not enough sleep.
    I have just one other question if I may abuse you further:
    My understanding of how this works is as follows:
    Any application that I want to update from time to time over BLE will necessarily have to include the equivalent of the smp_svr code; is that correct?
    Jerry
  • Hi Jerry,
    Yes SMP_SVR is integrated into your application automatically when you enable those configuration you find in the smp_svr (both prj.conf and the overlay_bt.conf)
