Partition management for multiple peripherals and partitions
Hello everyone,
I'm trying to add an external flash memory to the address range of the main memory. There is already an existing EEPROM, which will be deprecated later, and a Flash memory is added now. Both are connected via SPI. My intention is the following:
  • Leave the EEPROM as it is for now in the configuration
  • Add the flash memory to SPI
  • Define an extended memory space (My intention is to start it at the address 0x90000)
  • Create two partitions for the Flash:
    • Config partition: This needs only be 100 kiB, replacing the functionality of the EEPROM, and will be directly addressed
    • McuBoot swap partition: This will be where the image for the firmware update will be placed. This will be the rest of the memory.
Right now I always get the following warning when building and I'm not sure if I have configured everything correctly:
unit address and first address in 'reg' (0x200090000) don't match for /soc/spi@40004000/flash_at25pe80@2/partitions/partition@0
unit address and first address in 'reg' (0x200090400) don't match for /soc/spi@40004000/flash_at25pe80@2/partitions/partition@1
I have configured my application the following way:
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
Device tree (SPI reg 1 is reserved for another device currently in development, but does not need a partition):
&spi1 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>, <&gpio0 12 GPIO_ACTIVE_LOW>, <&gpio0 13 GPIO_ACTIVE_LOW>; //SIO_11 MCU_0403_A - SPI_CS1
	eeprom_m95040:eeprom_m95040@0 {
		// M95040 is compatible with atmel at25 eeprom driver
		compatible = "atmel,at25";
		reg = <0>;
		size = <DT_SIZE_K(512)>;
		pagesize = <512>;
		address-width = <24>;
		spi-max-frequency = <8000000>;
		timeout = <5>;
	flash_at25pe80:flash_at25pe80@2 {
		compatible = "jedec,spi-nor";
		status = "okay";
		size = < DT_SIZE_M(8) >;
		reg = < 2 >;
		jedec-id = [1f 25 00];
		spi-max-frequency = < 8000000 >;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0xc000 0x32000>;
		slot1_partition: partition@3e000 {
			label = "image-1";
			reg = <0x3e000 0x32000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x70000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x7a000 0x6000>;
&flash_at25pe80 {
	partitions {
		#address-cells = < 2 >;
		#size-cells = < 1 >;
		confflash: partition@0 {
			label = "config";
			reg = < 2 0x90000 0x400 >;
		extflash: partition@1 {
			label = "external-flash";
			reg = < 2 0x90400 0xFFC00 >;
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		nordic,pm-ext-flash = &extflash;
partition.yml
app:
  address: 0x9200
  end_address: 0x42000
  region: flash_primary
  size: 0x38e00 #App size 227.5 KB
mcuboot:
  address: 0x0
  end_address: 0x9000
  placement:
    before:
    - mcuboot_primary
  size: 0x9000 #38 KB MCU Bootloader
mcuboot_pad:
  address: 0x9000
  end_address: 0x9200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x9000
  orig_span: &id001
  - mcuboot_pad
  - app
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x9200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x90000
  device: /soc/spi1/flash_at25pe80@2
  end_address: 0x18FFF
  region: external_flash
  size: 0x100000 #1 MiB / 8 Mbit
nvs_storage:
  address: 0x7b000
  end_address: 0x80000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20020000
  region: sram_primary
I have not defined any custom regions, as the documentation is (in my opinion) abysmal for this with too few examples. But I would gladly be proven otherwise.
The goal is for the config partition to be writable by address, and for McuBoot to use the second partition as an extension, although this may be implemented at a later time.
Sadly I have not found an example where multiple SPI devices are used, one of them a flash device and with addressable partitions, so I don't know where the warning is coming from, as it doesn't show what it expects from me.
Much thanks for any help,
Rico
