Unable to change Bluetooth name with Zephyr
I'm trying to change Bluetooth name at runtime using Zephyr on the nRF700-DK. So for now I have a name defined with CONFIG_BT_DEVICE_NAME in my prj.conf that I tried to override using the following code (based on this ticket ). Unfortunately, my device always appears with the old name. Is something missing in my prj.conf file ?
static const struct bt_data sd[] =
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, MY_SERVICE_UUID),
static struct bt_data ad[] =
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR), BT_LE_ADV_OPT_USE_NAME ),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static void bt_ready(int err)
	if (err)
		printk("BLE init failed with error code %d\n", err);
		return;
	//Configure connection callbacks
	bt_conn_cb_register(&conn_callbacks);
	//Initialize services
	err = hc_bt_nus_init();
	if(err){
		printk("Failed to init NUS service (err:%d)\n", err);
		return;
	err = hc_ble_identity_init();
	if(err){
		printk("Failed to init Identity service (err:%d)\n", err);
		return;
	bt_set_name(BLE_NAME);
	bt_le_adv_update_data(ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	//Start advertising
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
	if (err)
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
	k_sem_give(&ble_init_ok);
int hc_bt_init(){
    int err = 0;
    err = bt_enable(bt_ready);
    if (err)
		printk("BLE initialization failed\n");
		printk("Error is %d\n", err);
	err = k_sem_take(&ble_init_ok, K_MSEC(500));
    if (!err)
		printk("Bluetooth initialized\n");
	} else
		printk("BLE initialization did not complete in time\n");
	return err;
prj.conf :
CONFIG_NEWLIB_LIBC=y
#Global attroibutes
CONFIG_GPIO=y
#SPI attributes
CONFIG_SPI=y
#PWM attributes
CONFIG_NRFX_PWM0=y
#BLE attributes
CONFIG_BT=y
CONFIG_BT_NUS=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="My_Device"
CONFIG_BT_DEVICE_APPEARANCE=962
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=30
#Tests
Thank you,
Best regards
