TC-CNET-4.10 Test step 11 timeout.
      Our product is about to undergo Matter certification. However, in the testing of TC-CNET-4.10, during the 11th step " ./chip-tool generalcommissioning arm-fail-safe 0 0 1 0", there is a timeout error indicating that the command is not responding. However, when executing it immediately for the second time, it succeeds. This phenomenon is consistently reproducible. Can you provide any guidance on how to resolve this issue? We are anxious to proceed with the product testing.
      I'm urgently looking forward to your reply.
      Jerry.
      22/8/2023
  • Hi Jerry,
    We can confirm that window covering as SED will work on 2.4.0.
    Setting up the test the same as yours will take time and maybe unnecessary as long as we can see debug files collected from your test results.
    Charlie
  • Sharing config in the build directory: build/zephyr/.config will help us to understand the actual configuration of the device. If it is nRF5340 SoC please also ask for the config file from /build/multiprotocol_rpmsg/zephyr/.conf.
    Charlie
  • Setting up the test the same as yours will take time and maybe unnecessary as long as we can see debug files collected from your test results
    Hi Charlie,
    I have tried setting example/window-app as SED and flashed it to 52840dk for testing this case, and the results are exactly the same. If CONFIG_LOG is not enabled, the first attempt fails but the second attempt succeeds. If CONFIG_LOG is enabled, it succeeds in one attempt.
    Here is the demo's build/zephyr/autoconf.h
    #define CONFIG_STATE_LEDS 1
    #define CONFIG_LOG 1
    #define CONFIG_CHIP_APP_LOG_LEVEL 4
    #define CONFIG_LOG_DEFAULT_LEVEL 2
    #define CONFIG_CHIP_LOG_SIZE_OPTIMIZATION 1
    #define CONFIG_PRINTK_SYNC 1
    #define CONFIG_ASSERT 1
    #define CONFIG_HW_STACK_PROTECTION 1
    #define CONFIG_FPU 1
    #define CONFIG_SHELL 1
    #define CONFIG_MAIN_STACK_SIZE 8192
    #define CONFIG_INIT_STACKS 1
    #define CONFIG_NET_IPV6_MLD 1
    #define CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT 14
    #define CONFIG_NET_PKT_RX_COUNT 16
    #define CONFIG_NET_PKT_TX_COUNT 16
    #define CONFIG_NET_BUF_RX_COUNT 80
    #define CONFIG_NET_BUF_TX_COUNT 80
    #define CONFIG_BT 1
    #define CONFIG_BT_PERIPHERAL 1
    #define CONFIG_BT_PERIPHERAL_PREF_MIN_INT 36
    #define CONFIG_BT_PERIPHERAL_PREF_MAX_INT 36
    #define CONFIG_BT_PERIPHERAL_PREF_TIMEOUT 500
    #define CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS 1
    #define CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT 1000
    #define CONFIG_BT_GATT_DYNAMIC_DB 1
    #define CONFIG_BT_DEVICE_NAME_DYNAMIC 1
    #define CONFIG_BT_DEVICE_NAME_MAX 15
    #define CONFIG_BT_MAX_CONN 1
    #define CONFIG_BT_L2CAP_TX_MTU 247
    #define CONFIG_BT_BUF_ACL_RX_SIZE 251
    #define CONFIG_BT_BUF_ACL_TX_SIZE 251
    #define CONFIG_BT_RX_STACK_SIZE 1200
    #define CONFIG_CHIP_NFC_COMMISSIONING 1
    #define CONFIG_CHIP_OTA_REQUESTOR 1
    #define CONFIG_CHIP_QSPI_NOR 1
    #define CONFIG_CHIP_EXTENDED_DISCOVERY 1
    #define CONFIG_NVS_LOOKUP_CACHE 1
    #define CONFIG_NVS_LOOKUP_CACHE_SIZE 512
    #define CONFIG_NET_L2_OPENTHREAD 1
    #define CONFIG_IEEE802154_NRF5_RX_STACK_SIZE 1024
    #define CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE 1120
    #define CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT 6
    #define CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN 900
    #define CONFIG_NET_MAX_ROUTERS 1
    #define CONFIG_NET_MAX_CONN 4
    #define CONFIG_SHELL_STACK_SIZE 3168
    #define CONFIG_HEAP_MEM_POOL_SIZE 1024
    #define CONFIG_OBERON_BACKEND 1
    #define CONFIG_MBEDTLS_ENABLE_HEAP 1
    #define CONFIG_MBEDTLS_HEAP_SIZE 15360
    #define CONFIG_MBEDTLS_TLS_LIBRARY 1
    #define CONFIG_NRF_SECURITY_ADVANCED 1
    #define CONFIG_MBEDTLS_AES_C 1
    #define CONFIG_MBEDTLS_ECP_C 1
    #define CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED 1
    #define CONFIG_MBEDTLS_CTR_DRBG_C 1
    #define CONFIG_MBEDTLS_CIPHER_MODE_CTR 1
    #define CONFIG_MBEDTLS_ECJPAKE_C 1
    #define CONFIG_MBEDTLS_SHA256_C 1
    #define CONFIG_MBEDTLS_PK_C 1
    #define CONFIG_MBEDTLS_PK_WRITE_C 1
    #define CONFIG_MBEDTLS_X509_CREATE_C 1
    #define CONFIG_MBEDTLS_X509_CSR_WRITE_C 1
    #define CONFIG_PSA_WANT_ALG_SHA_224 1
    #define CONFIG_BT_CTLR_DATA_LENGTH_MAX 251
    #define CONFIG_UPDATEABLE_IMAGE_NUMBER 1
    #define CONFIG_NORDIC_QSPI_NOR 1
    #define CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE 16
    #define CONFIG_GPIO 1
    #define CONFIG_GPIO_INIT_PRIORITY 40
    #define CONFIG_UART_INTERRUPT_DRIVEN 1
    #define CONFIG_NET_IPV6 1
    #define CONFIG_NET_CONFIG_NEED_IPV6 1
    #define CONFIG_SENSOR 1
    #define CONFIG_BT_HCI_VS_EXT 1
    #define CONFIG_BOARD "nrf52840dk_nrf52840"
    #define CONFIG_BT_CTLR 1
    #define CONFIG_SOC "nRF52840_QIAA"
    #define CONFIG_SOC_SERIES "nrf52"
    #define CONFIG_NUM_IRQS 48
    #define CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC 32768
    #define CONFIG_CLOCK_CONTROL_INIT_PRIORITY 30
    #define CONFIG_FLASH_SIZE 1024
    #define CONFIG_FLASH_BASE_ADDRESS 0x0
    #define CONFIG_ICACHE_LINE_SIZE 32
    #define CONFIG_DCACHE_LINE_SIZE 32
    #define CONFIG_PINCTRL 1
    #define CONFIG_ROM_START_OFFSET 0x0
    #define CONFIG_CLOCK_CONTROL 1
    #define CONFIG_SOC_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT 1
    #define CONFIG_PM 1
    #define CONFIG_IEEE802154_NRF5 1
    #define CONFIG_LOG_DOMAIN_NAME ""
    #define CONFIG_NRF_RTC_TIMER 1
    #define CONFIG_SYS_CLOCK_TICKS_PER_SEC 32768
    #define CONFIG_BUILD_OUTPUT_HEX 1
    #define CONFIG_SERIAL_INIT_PRIORITY 55
    #define CONFIG_TINYCRYPT 1
    #define CONFIG_SERIAL 1
    #define CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS ""
    #define CONFIG_MP_MAX_NUM_CPUS 1
    #define CONFIG_PLATFORM_SPECIFIC_INIT 1
    #define CONFIG_HAS_DTS 1
    #define CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED 1
    #define CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED 1
    #define CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED 1
    #define CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED 1
    #define CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_KEYS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_MMIO_SRAM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED 1
    #define CONFIG_DT_HAS_PWM_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED 1
    #define CONFIG_OPENTHREAD_LIBRARY_AVAILABLE 1
    #define CONFIG_NEWLIB_LIBC_NANO 1
    #define CONFIG_NUM_METAIRQ_PRIORITIES 1
    #define CONFIG_LOG_BUFFER_SIZE 4048
    #define CONFIG_OPENTHREAD_MANUAL_START 1
    #define CONFIG_MBEDTLS_SSL_PROTO_DTLS 1
    #define CONFIG_MBEDTLS_ENTROPY_C 1
    #define CONFIG_OPENTHREAD_PING_SENDER 1
    #define CONFIG_NRF_802154_ENCRYPTION 1
    #define CONFIG_IEEE802154_2015 1
    #define CONFIG_NET_PKT_TXTIME 1
    #define CONFIG_NET_PKT_TIMESTAMP 1
    #define CONFIG_OPENTHREAD_PLATFORM_CSL_UNCERT 5
    #define CONFIG_IEEE802154_NRF5_DELAY_TRX_ACC 20
    #define CONFIG_IEEE802154_CSL_ENDPOINT 1
    #define CONFIG_OPENTHREAD_CSL_RECEIVE_TIME_AHEAD 5000
    #define CONFIG_OPENTHREAD_CSL_MIN_RECEIVE_ON 300
    #define CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY 1
    #define CONFIG_WARN_EXPERIMENTAL 1
    #define CONFIG_PRIVILEGED_STACK_SIZE 1024
    #define CONFIG_BT_BUF_CMD_TX_COUNT 2
    #define CONFIG_ENTROPY_GENERATOR 1
    #define CONFIG_INIT_ARCH_HW_AT_BOOT 1
    #define CONFIG_LINKER_LAST_SECTION_ID 1
    #define CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE 4096
    #define CONFIG_PM_PARTITION_SIZE_PROVISION 0x1000
    #define CONFIG_PM_PARTITION_SIZE_B0_IMAGE 0x8000
    #define CONFIG_SB_VALIDATION_INFO_MAGIC 0x86518483
    #define CONFIG_SB_VALIDATION_POINTER_MAGIC 0x6919b47e
    #define CONFIG_SB_VALIDATION_INFO_CRYPTO_ID 1
    #define CONFIG_SB_VALIDATION_INFO_VERSION 2
    #define CONFIG_SB_VALIDATION_METADATA_OFFSET 0
    #define CONFIG_SB_VALIDATE_FW_SIGNATURE 1
    #define CONFIG_BT_LL_SOFTDEVICE 1
    #define CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB 1
    #define CONFIG_BT_HCI_TX_STACK_SIZE 1536
    #define CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT 1
    #define CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT 7500
    #define CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT 3
    #define CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT 2
    #define CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT 3
    #define CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT 2
    #define CONFIG_BT_CTLR_SDC_RX_PRIO 6
    #define CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL 1
    #define CONFIG_BT_BROADCASTER 1
    #define CONFIG_BT_CONN 1
    #define CONFIG_BT_PHY_UPDATE 1
    #define CONFIG_BT_DATA_LEN_UPDATE 1
    #define CONFIG_BT_IAS_LOG_LEVEL_INF 1
    #define CONFIG_BT_IAS_LOG_LEVEL 3
    #define CONFIG_BT_BUF_ACL_TX_COUNT 3
    #define CONFIG_BT_BUF_ACL_RX_COUNT 6
    #define CONFIG_BT_BUF_EVT_RX_SIZE 68
    #define CONFIG_BT_BUF_EVT_RX_COUNT 10
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE 43
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT 3
    #define CONFIG_BT_BUF_CMD_TX_SIZE 65
    #define CONFIG_BT_HAS_HCI_VS 1
    #define CONFIG_BT_HCI_VS 1
    #define CONFIG_BT_ASSERT 1
    #define CONFIG_BT_ASSERT_VERBOSE 1
    #define CONFIG_BT_DEBUG_NONE 1
    #define CONFIG_BT_LONG_WQ 1
    #define CONFIG_BT_LONG_WQ_STACK_SIZE 1300
    #define CONFIG_BT_LONG_WQ_PRIO 10
    #define CONFIG_BT_HCI_HOST 1
    #define CONFIG_BT_HCI_TX_PRIO 7
    #define CONFIG_BT_HCI_RESERVE 0
    #define CONFIG_BT_RECV_WORKQ_BT 1
    #define CONFIG_BT_RX_PRIO 8
    #define CONFIG_BT_DRIVER_RX_HIGH_PRIO 6
    #define CONFIG_BT_LIM_ADV_TIMEOUT 30
    #define CONFIG_BT_CONN_TX_MAX 3
    #define CONFIG_BT_AUTO_PHY_UPDATE 1
    #define CONFIG_BT_AUTO_DATA_LEN_UPDATE 1
    #define CONFIG_BT_L2CAP_TX_BUF_COUNT 3
    #define CONFIG_BT_L2CAP_TX_FRAG_COUNT 2
    #define CONFIG_BT_ATT_ENFORCE_FLOW 1
    #define CONFIG_BT_ATT_PREPARE_COUNT 0
    #define CONFIG_BT_GATT_SERVICE_CHANGED 1
    #define CONFIG_BT_GATT_CACHING 1
    #define CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION 1
    #define CONFIG_BT_GATT_READ_MULTIPLE 1
    #define CONFIG_BT_GATT_READ_MULT_VAR_LEN 1
    #define CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS 1
    #define CONFIG_BT_PERIPHERAL_PREF_LATENCY 0
    #define CONFIG_BT_MAX_PAIRED 0
    #define CONFIG_BT_CREATE_CONN_TIMEOUT 3
    #define CONFIG_BT_DEVICE_NAME "MatterWinCov"
    #define CONFIG_BT_DEVICE_APPEARANCE 0
    #define CONFIG_BT_ID_MAX 1
    #define CONFIG_DFU_MULTI_IMAGE 1
    #define CONFIG_DFU_MULTI_IMAGE_MAX_IMAGE_COUNT 2
    #define CONFIG_DFU_TARGET 1
    #define CONFIG_DFU_TARGET_MCUBOOT 1
    #define CONFIG_DFU_TARGET_STREAM 1
    #define CONFIG_DFU_TARGET_LOG_LEVEL_INF 1
    #define CONFIG_DFU_TARGET_LOG_LEVEL 3
    #define CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME 1
    #define CONFIG_NRF_CLOUD_CLIENT_ID "my-client-id"
    #define CONFIG_NRF_CLOUD_LOG_LEVEL_INF 1
    #define CONFIG_NRF_CLOUD_LOG_LEVEL 3
    #define CONFIG_NORDIC_SECURITY_PROMPTLESS 1
    #define CONFIG_OPENTHREAD_NRF_SECURITY_CHOICE 1
    #define CONFIG_OPENTHREAD_NRF_SECURITY 1
    #define CONFIG_OPENTHREAD_MBEDTLS_LIB_NAME "mbedtls_external"
    #define CONFIG_OPENTHREAD_THREAD_STACK_SIZE 6240
    #define CONFIG_OPENTHREAD_RADIO_WORKQUEUE_STACK_SIZE 1024
    #define CONFIG_NFC_NDEF 1
    #define CONFIG_NFC_NDEF_MSG 1
    #define CONFIG_NFC_NDEF_RECORD 1
    #define CONFIG_NFC_NDEF_URI_MSG 1
    #define CONFIG_NFC_NDEF_URI_REC 1
    #define CONFIG_NDEF_FILE_SIZE 1024
    #define CONFIG_NFC_PLATFORM 1
    #define CONFIG_NFCT_IRQ_PRIORITY 1
    #define CONFIG_NFC_PLATFORM_LOG_LEVEL_INF 1
    #define CONFIG_NFC_PLATFORM_LOG_LEVEL 3
    #define CONFIG_MPSL_FEM_API_AVAILABLE 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL_INF 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL 3
    #define CONFIG_MPSL_THREAD_COOP_PRIO 0
    #define CONFIG_MPSL_WORK_STACK_SIZE 1024
    #define CONFIG_MPSL_TIMESLOT_SESSION_COUNT 0
    #define CONFIG_MPSL_LOG_LEVEL_INF 1
    #define CONFIG_MPSL_LOG_LEVEL 3
    #define CONFIG_PARTITION_MANAGER_ENABLED 1
    #define CONFIG_FLASH_MAP_CUSTOM 1
    #define CONFIG_SRAM_SIZE 256
    #define CONFIG_SRAM_BASE_ADDRESS 0x20000000
    #define CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE 0x2000
    #define CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE 0x1000
    #define CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER 1
    #define CONFIG_PM_EXTERNAL_FLASH_BASE 0x0
    #define CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY 1
    #define CONFIG_PM_SRAM_BASE 0x20000000
    #define CONFIG_PM_SRAM_SIZE 0x40000
    #define CONFIG_MGMT_FMFU_LOG_LEVEL_INF 1
    #define CONFIG_MGMT_FMFU_LOG_LEVEL 3
    #define CONFIG_NRF_802154_RADIO_CONFIG 1
    #define CONFIG_NRF_802154_RADIO_CONFIG_PRIO 91
    #define CONFIG_NRF_802154_ACK_TIMEOUT_CUSTOM_US 0
    #define CONFIG_NRF_ACL_FLASH_REGION_SIZE 0x1000
    #define CONFIG_FPROTECT_BLOCK_SIZE 0x1000
    #define CONFIG_DK_LIBRARY 1
    #define CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL 10
    #define CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS 1
    #define CONFIG_DK_LIBRARY_LOG_LEVEL_INF 1
    #define CONFIG_DK_LIBRARY_LOG_LEVEL 3
    #define CONFIG_MULTITHREADING_LOCK 1
    #define CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE 0x1000
    #define CONFIG_ENTROPY_CC3XX 1
    #define CONFIG_HW_CC3XX 1
    #define CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS 1
    #define CONFIG_CLOCK_CONTROL_MPSL 1
    #define CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL 1
    #define CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT 1
    #define CONFIG_TEMP_NRF5_MPSL 1
    #define CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS 1
    #define CONFIG_ZEPHYR_NRF_MODULE 1
    #define CONFIG_ZEPHYR_HOSTAP_MODULE 1
    #define CONFIG_SIGN_IMAGES 1
    #define CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE 1
    #define CONFIG_MCUBOOT_IMAGE_VERSION "0.0.0+0"
    #define CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_DT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD 1
    #define CONFIG_DFU_MULTI_IMAGE_PACKAGE_APP 1
    #define CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS 1
    #define CONFIG_ZEPHYR_MCUBOOT_MODULE 1
    #define CONFIG_ZEPHYR_MBEDTLS_MODULE 1
    #define CONFIG_MBEDTLS_PROMPTLESS 1
    #define CONFIG_MBEDTLS_CFG_FILE "nrf-config.h"
    #define CONFIG_MBEDTLS_SSL_EXPORT_KEYS 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED 1
    #define CONFIG_MBEDTLS_ECDSA_DETERMINISTIC 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED 1
    #define CONFIG_MBEDTLS_ECDH_C 1
    #define CONFIG_MBEDTLS_ECDSA_C 1
    #define CONFIG_MBEDTLS_MAC_SHA256_ENABLED 1
    #define CONFIG_MBEDTLS_USER_CONFIG_FILE "nrf-config-user.h"
    #define CONFIG_MBEDTLS_PKCS5_C 1
    #define CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_C 1
    #define CONFIG_PSA_WANT_ALG_CTR_DRBG 1
    #define CONFIG_PSA_WANT_ALG_HMAC_DRBG 1
    #define CONFIG_PSA_HAS_KEY_SUPPORT 1
    #define CONFIG_PSA_WANT_KEY_TYPE_DERIVE 1
    #define CONFIG_PSA_WANT_KEY_TYPE_HMAC 1
    #define CONFIG_PSA_WANT_KEY_TYPE_AES 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR 1
    #define CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY 1
    #define CONFIG_PSA_HAS_AEAD_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_CCM 1
    #define CONFIG_PSA_HAS_MAC_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_CMAC 1
    #define CONFIG_PSA_WANT_ALG_HMAC 1
    #define CONFIG_PSA_HAS_HASH_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_SHA_256 1
    #define CONFIG_PSA_HAS_CIPHER_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_ECB_NO_PADDING 1
    #define CONFIG_PSA_WANT_ALG_CBC_NO_PADDING 1
    #define CONFIG_PSA_WANT_ALG_CBC_PKCS7 1
    #define CONFIG_PSA_WANT_ALG_CTR 1
    #define CONFIG_PSA_HAS_KEY_DERIVATION 1
    #define CONFIG_PSA_WANT_ALG_HKDF 1
    #define CONFIG_PSA_WANT_ALG_TLS12_PRF 1
    #define CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT 1
    #define CONFIG_PSA_HAS_ECC_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_ECDH 1
    #define CONFIG_PSA_WANT_ALG_ECDSA 1
    #define CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA 1
    #define CONFIG_PSA_WANT_ECC_SECP_R1_256 1
    #define CONFIG_PSA_WANT_ALG_STREAM_CIPHER 1
    #define CONFIG_BOOTLOADER_MCUBOOT 1
    #define CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE 1
    #define CONFIG_MBEDTLS_X509_LIBRARY 1
    #define CONFIG_MBEDTLS_CMAC_C 1
    #define CONFIG_MBEDTLS_CCM_C 1
    #define CONFIG_MBEDTLS_LEGACY_CRYPTO_C 1
    #define CONFIG_ZEPHYR_CJSON_MODULE 1
    #define CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE 1
    #define CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE 1
    #define CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE 1
    #define CONFIG_OPENTHREAD 1
    #define CONFIG_OPENTHREAD_THREAD_VERSION_1_3 1
    #define CONFIG_OPENTHREAD_THREAD_VERSION "1.3"
    #define CONFIG_OPENTHREAD_COAP 1
    #define CONFIG_OPENTHREAD_CHILD_SUPERVISION 1
    #define CONFIG_OPENTHREAD_CSL_RECEIVER 1
    #define CONFIG_OPENTHREAD_DHCP6_CLIENT 1
    #define CONFIG_OPENTHREAD_DNS_CLIENT 1
    #define CONFIG_OPENTHREAD_DUA 1
    #define CONFIG_OPENTHREAD_ECDSA 1
    #define CONFIG_OPENTHREAD_EXTERNAL_HEAP 1
    #define CONFIG_OPENTHREAD_IP6_FRAGM 1
    #define CONFIG_OPENTHREAD_JOINER 1
    #define CONFIG_OPENTHREAD_MLR 1
    #define CONFIG_OPENTHREAD_MTD_NETDIAG 1
    #define CONFIG_OPENTHREAD_SLAAC 1
    #define CONFIG_OPENTHREAD_SNTP_CLIENT 1
    #define CONFIG_OPENTHREAD_LINK_METRICS_INITIATOR 1
    #define CONFIG_OPENTHREAD_SRP_CLIENT 1
    #define CONFIG_OPENTHREAD_PANID 43981
    #define CONFIG_OPENTHREAD_CHANNEL 11
    #define CONFIG_OPENTHREAD_NETWORK_NAME "ot_zephyr"
    #define CONFIG_OPENTHREAD_XPANID "de:ad:00:be:ef:00:ca:fe"
    #define CONFIG_OPENTHREAD_NETWORKKEY ""
    #define CONFIG_OPENTHREAD_MTD 1
    #define CONFIG_OPENTHREAD_MTD_SED 1
    #define CONFIG_OPENTHREAD_POLL_PERIOD 236000
    #define CONFIG_OPENTHREAD_MAX_CHILDREN 1
    #define CONFIG_OPENTHREAD_CONFIG_PLATFORM_INFO "Zephyr"
    #define CONFIG_OPENTHREAD_RADIO_LINK_IEEE_802_15_4_ENABLE 1
    #define CONFIG_OPENTHREAD_CSL_AUTO_SYNC 1
    #define CONFIG_OPENTHREAD_CLI_MAX_LINE_LENGTH 384
    #define CONFIG_OPENTHREAD_IP6_MAX_EXT_UCAST_ADDRS 4
    #define CONFIG_OPENTHREAD_IP6_MAX_EXT_MCAST_ADDRS 2
    #define CONFIG_ZEPHYR_OPENTHREAD_MODULE 1
    #define CONFIG_ZEPHYR_CANOPENNODE_MODULE 1
    #define CONFIG_ZEPHYR_CHRE_MODULE 1
    #define CONFIG_ZEPHYR_HAL_NORDIC_MODULE 1
    #define CONFIG_HAS_NORDIC_DRIVERS 1
    #define CONFIG_NRF_802154_RADIO_DRIVER 1
    #define CONFIG_NRF_802154_MULTIPROTOCOL_SUPPORT 1
    #define CONFIG_NRF_802154_CCA_MODE_ED 1
    #define CONFIG_NRF_802154_CCA_ED_THRESHOLD 45
    #define CONFIG_NRF_802154_CCA_CORR_THRESHOLD 45
    #define CONFIG_NRF_802154_CCA_CORR_LIMIT 2
    #define CONFIG_NRF_802154_PENDING_SHORT_ADDRESSES 16
    #define CONFIG_NRF_802154_PENDING_EXTENDED_ADDRESSES 16
    #define CONFIG_NRF_802154_RX_BUFFERS 16
    #define CONFIG_NRF_802154_TEMPERATURE_UPDATE 1
    #define CONFIG_NRF_802154_TEMPERATURE_UPDATE_INIT_PRIO 91
    #define CONFIG_NRF_802154_TEMPERATURE_UPDATE_PERIOD 60000
    #define CONFIG_HAS_NRFX 1
    #define CONFIG_NRFX_GPIOTE 1
    #define CONFIG_NRFX_NFCT 1
    #define CONFIG_NRFX_NVMC 1
    #define CONFIG_NRFX_PPI 1
    #define CONFIG_NRFX_PWM 1
    #define CONFIG_NRFX_PWM0 1
    #define CONFIG_NRFX_QSPI 1
    #define CONFIG_NRFX_TIMER 1
    #define CONFIG_NRFX_TIMER4 1
    #define CONFIG_ZEPHYR_LIBLC3_MODULE 1
    #define CONFIG_ZEPHYR_LITTLEFS_MODULE 1
    #define CONFIG_ZEPHYR_LORAMAC_NODE_MODULE 1
    #define CONFIG_ZEPHYR_LVGL_MODULE 1
    #define CONFIG_ZEPHYR_LZ4_MODULE 1
    #define CONFIG_ZEPHYR_NANOPB_MODULE 1
    #define CONFIG_ZEPHYR_PICOLIBC_MODULE 1
    #define CONFIG_ZEPHYR_TRACERECORDER_MODULE 1
    #define CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE 1
    #define CONFIG_ZEPHYR_ZCBOR_MODULE 1
    #define CONFIG_ZCBOR 1
    #define CONFIG_ZCBOR_ASSERT 1
    #define CONFIG_ZEPHYR_ZSCILIB_MODULE 1
    #define CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE 0x4e8
    #define CONFIG_NFC_T2T_NRFXLIB 1
    #define CONFIG_MPSL 1
    #define CONFIG_MPSL_BUILD_TYPE_LIB 1
    #define CONFIG_NRFXLIB_CRYPTO 1
    #define CONFIG_CRYPTOCELL_CC310_USABLE 1
    #define CONFIG_CRYPTOCELL_USABLE 1
    #define CONFIG_NRF_OBERON 1
    #define CONFIG_NRF_CC3XX_PLATFORM 1
    #define CONFIG_CC3XX_MUTEX_LOCK 1
    #define CONFIG_NORDIC_SECURITY_BACKEND 1
    #define CONFIG_NRF_SECURITY 1
    #define CONFIG_GENERATE_MBEDTLS_CFG_FILE 1
    #define CONFIG_MBEDTLS_X509_USE_C 1
    #define CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE 1
    #define CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE 1
    #define CONFIG_MBEDTLS_X509_CRL_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_CSR_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_CRT_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_REMOVE_INFO 1
    #define CONFIG_MBEDTLS_SSL_CLI_C 1
    #define CONFIG_MBEDTLS_SSL_SRV_C 1
    #define CONFIG_MBEDTLS_SSL_TLS_C 1
    #define CONFIG_MBEDTLS_SSL_PROTO_TLS1_2 1
    #define CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC 1
    #define CONFIG_MBEDTLS_SSL_COOKIE_C 1
    #define CONFIG_MBEDTLS_SSL_DTLS_ANTI_REPLAY 1
    #define CONFIG_MBEDTLS_SSL_DTLS_HELLO_VERIFY 1
    #define CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES 1
    #define CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION 1
    #define CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE 1
    #define CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN 900
    #define CONFIG_MBEDTLS_SSL_CIPHERSUITES ""
    #define CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_CBC_OR_GCM_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS 1
    #define CONFIG_PSA_CRYPTO_ACCELERATOR_DRIVER_PRESENT 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT 1
    #define CONFIG_MBEDTLS_PSA_ACCEL_KEY_TYPE_SUPPORT 1
    #define CONFIG_MBEDTLS_PSA_ACCEL_KEY_TYPE_ECC_KEY_PAIR 1
    #define CONFIG_MBEDTLS_PSA_ACCEL_KEY_TYPE_ECC_PUBLIC_KEY 1
    #define CONFIG_MBEDTLS_PSA_ACCEL_KEY_TYPE_AES 1
    #define CONFIG_PSA_CRYPTO_DRIVER_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_CIPHER_SUPPORT_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_AEAD_SUPPORT_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_HASH_SUPPORT_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_ASYM_SIGN_SUPPORT_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_ECC_SUPPORT_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_HAS_ACCEL_KEY_TYPES_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_NO_PADDING_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_PKCS7_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_CCM_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_CTR_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_DETERMINISTIC_ECDSA_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_ECB_NO_PADDING_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDH_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_ECDSA_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_224_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_256_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ALG_STREAM_CIPHER_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_256_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_BUILTIN 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_HAS_MAC_SUPPORT 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_ALG_CMAC 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_ALG_HKDF 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_ALG_HMAC 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_ALG_TLS12_PRF 1
    #define CONFIG_MBEDTLS_PSA_BUILTIN_MAC 1
    #define CONFIG_MBEDTLS_USE_PSA_CRYPTO 1
    #define CONFIG_MBEDTLS_PLATFORM_MEMORY 1
    #define CONFIG_MBEDTLS_PLATFORM_C 1
    #define CONFIG_MBEDTLS_MEMORY_C 1
    #define CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C 1
    #define CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT 1
    #define CONFIG_MBEDTLS_PLATFORM_ZEROIZE_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT 1
    #define CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT 1
    #define CONFIG_MBEDTLS_AES_ENCRYPT_ALT 1
    #define CONFIG_MBEDTLS_AES_DECRYPT_ALT 1
    #define CONFIG_MBEDTLS_CHACHA20_ALT 1
    #define CONFIG_MBEDTLS_POLY1305_ALT 1
    #define CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT 1
    #define CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_GENKEY_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_SIGN_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_VERIFY_ALT 1
    #define CONFIG_MBEDTLS_ECJPAKE_ALT 1
    #define CONFIG_MBEDTLS_SHA1_ALT 1
    #define CONFIG_MBEDTLS_SHA224_ALT 1
    #define CONFIG_MBEDTLS_SHA256_ALT 1
    #define CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256 1
    #define CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES 1
    #define CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY 1
    #define CONFIG_OBERON_ONLY_PSA_ENABLED 1
    #define CONFIG_OBERON_ONLY_ENABLED 1
    #define CONFIG_MBEDTLS_MPI_WINDOW_SIZE 6
    #define CONFIG_MBEDTLS_MPI_MAX_SIZE 256
    #define CONFIG_NRF_SECURITY_RNG 1
    #define CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY 1
    #define CONFIG_MBEDTLS_HMAC_DRBG_C 1
    #define CONFIG_MBEDTLS_HKDF_C 1
    #define CONFIG_MBEDTLS_CIPHER_C 1
    #define CONFIG_MBEDTLS_MD_C 1
    #define CONFIG_MBEDTLS_PK_PARSE_C 1
    #define CONFIG_OPENTHREAD_LIBRARY 1
    #define CONFIG_OPENTHREAD_NORDIC_LIBRARY 1
    #define CONFIG_OPENTHREAD_NORDIC_LIBRARY_MTD 1
    #define CONFIG_NRF_802154_SOURCE_NRFXLIB 1
    #define CONFIG_NRF_802154_SL 1
    #define CONFIG_LC3_ENC_CHAN_MAX 1
    #define CONFIG_LC3_DEC_CHAN_MAX 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT 1
    #define CONFIG_ZEPHYR_NRFXLIB_MODULE 1
    #define CONFIG_CHIP 1
    #define CONFIG_CHIP_DEVICE_VENDOR_ID 65521
    #define CONFIG_CHIP_DEVICE_VENDOR_NAME "Nordic Semiconductor ASA"
    #define CONFIG_CHIP_DEVICE_PRODUCT_ID 32784
    #define CONFIG_CHIP_DEVICE_PRODUCT_NAME "not-specified"
    #define CONFIG_CHIP_DEVICE_HARDWARE_VERSION 0
    #define CONFIG_CHIP_DEVICE_HARDWARE_VERSION_STRING "prerelease"
    #define CONFIG_CHIP_DEVICE_SOFTWARE_VERSION 0
    #define CONFIG_CHIP_DEVICE_SOFTWARE_VERSION_STRING "prerelease"
    #define CONFIG_CHIP_DEVICE_MANUFACTURING_DATE "2022-01-01"
    #define CONFIG_CHIP_DEVICE_SERIAL_NUMBER "11223344556677889900"
    #define CONFIG_CHIP_DEVICE_ROTATING_DEVICE_UID "91a9c12a7c80700a31ddcfa7fce63e44"
    #define CONFIG_CHIP_DEVICE_TYPE 65535
    #define CONFIG_CHIP_DEVICE_DISCRIMINATOR 0xF00
    #define CONFIG_CHIP_DEVICE_SPAKE2_PASSCODE 20202021
    #define CONFIG_CHIP_DEVICE_SPAKE2_IT 1000
    #define CONFIG_CHIP_DEVICE_SPAKE2_SALT "U1BBS0UyUCBLZXkgU2FsdA=="
    #define CONFIG_CHIP_DEVICE_SPAKE2_TEST_VERIFIER "uWFwqugDNGiEck/po7KHwwMwwqZgN10XuyBajPGuyzUEV/iree4lOrao5GuwnlQ65CJzbeUB49s31EH+NEkg0JVI5MGCQGMMT/SRPFNRODm3wH/MBiehuFc6FJ/NH6Rmzw=="
    #define CONFIG_CHIP_DEVICE_ENABLE_KEY "00112233445566778899AABBCCDDEEFF"
    #define CONFIG_CHIP_OPERATIONAL_TIME_SAVE_INTERVAL 10
    #define CONFIG_CHIP_PROJECT_CONFIG "main/include/CHIPProjectConfig.h"
    #define CONFIG_CHIP_ENABLE_DNSSD_SRP 1
    #define CONFIG_CHIP_ENABLE_DNS_CLIENT 1
    #define CONFIG_CHIP_ENABLE_SLEEPY_END_DEVICE_SUPPORT 1
    #define CONFIG_CHIP_SED_IDLE_INTERVAL 500
    #define CONFIG_CHIP_SED_ACTIVE_INTERVAL 500
    #define CONFIG_CHIP_OPENTHREAD_CONFIG ""
    #define CONFIG_MATTER_LOG_LEVEL_DBG 1
    #define CONFIG_MATTER_LOG_LEVEL 4
    #define CONFIG_APP_LINK_WITH_CHIP 1
    #define CONFIG_CHIP_OTA_IMAGE_BUILD 1
    #define CONFIG_CHIP_OTA_IMAGE_FILE_NAME "matter.ota"
    #define CONFIG_CHIP_OTA_IMAGE_EXTRA_ARGS ""
    #define CONFIG_CHIP_OTA_REQUESTOR_BUFFER_SIZE 1024
    #define CONFIG_CHIP_OTA_REQUESTOR_REBOOT_ON_APPLY 1
    #define CONFIG_CHIP_EXAMPLE_DEVICE_INFO_PROVIDER 1
    #define CONFIG_CHIP_DEBUG_SYMBOLS 1
    #define CONFIG_CHIP_FACTORY_DATA_VERSION 1
    #define CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE 1
    #define CONFIG_HAS_CMSIS_CORE 1
    #define CONFIG_HAS_CMSIS_CORE_M 1
    #define CONFIG_TINYCRYPT_AES 1
    #define CONFIG_TINYCRYPT_AES_CMAC 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL 3
    #define CONFIG_BOARD_REVISION ""
    #define CONFIG_BOARD_NRF52840DK_NRF52840 1
    #define CONFIG_BOARD_ENABLE_DCDC 1
    #define CONFIG_BOARD_ENABLE_DCDC_HV 1
    #define CONFIG_SOC_SERIES_NRF52X 1
    #define CONFIG_CPU_HAS_ARM_MPU 1
    #define CONFIG_HAS_SWO 1
    #define CONFIG_SOC_FAMILY "nordic_nrf"
    #define CONFIG_SOC_FAMILY_NRF 1
    #define CONFIG_HAS_HW_NRF_ACL 1
    #define CONFIG_HAS_HW_NRF_CC310 1
    #define CONFIG_HAS_HW_NRF_CCM 1
    #define CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT 1
    #define CONFIG_HAS_HW_NRF_CLOCK 1
    #define CONFIG_HAS_HW_NRF_ECB 1
    #define CONFIG_HAS_HW_NRF_EGU0 1
    #define CONFIG_HAS_HW_NRF_EGU1 1
    #define CONFIG_HAS_HW_NRF_EGU2 1
    #define CONFIG_HAS_HW_NRF_EGU3 1
    #define CONFIG_HAS_HW_NRF_EGU4 1
    #define CONFIG_HAS_HW_NRF_EGU5 1
    #define CONFIG_HAS_HW_NRF_GPIO0 1
    #define CONFIG_HAS_HW_NRF_GPIO1 1
    #define CONFIG_HAS_HW_NRF_GPIOTE 1
    #define CONFIG_HAS_HW_NRF_MWU 1
    #define CONFIG_HAS_HW_NRF_NVMC_PE 1
    #define CONFIG_HAS_HW_NRF_POWER 1
    #define CONFIG_HAS_HW_NRF_PPI 1
    #define CONFIG_HAS_HW_NRF_PWM0 1
    #define CONFIG_HAS_HW_NRF_QSPI 1
    #define CONFIG_HAS_HW_NRF_RADIO_BLE_2M 1
    #define CONFIG_HAS_HW_NRF_RADIO_BLE_CODED 1
    #define CONFIG_HAS_HW_NRF_RADIO_IEEE802154 1
    #define CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH 1
    #define CONFIG_HAS_HW_NRF_RNG 1
    #define CONFIG_HAS_HW_NRF_RTC0 1
    #define CONFIG_HAS_HW_NRF_RTC1 1
    #define CONFIG_HAS_HW_NRF_RTC2 1
    #define CONFIG_HAS_HW_NRF_SWI0 1
    #define CONFIG_HAS_HW_NRF_SWI1 1
    #define CONFIG_HAS_HW_NRF_SWI2 1
    #define CONFIG_HAS_HW_NRF_SWI3 1
    #define CONFIG_HAS_HW_NRF_SWI4 1
    #define CONFIG_HAS_HW_NRF_SWI5 1
    #define CONFIG_HAS_HW_NRF_TEMP 1
    #define CONFIG_HAS_HW_NRF_TIMER0 1
    #define CONFIG_HAS_HW_NRF_TIMER1 1
    #define CONFIG_HAS_HW_NRF_TIMER2 1
    #define CONFIG_HAS_HW_NRF_TIMER3 1
    #define CONFIG_HAS_HW_NRF_TIMER4 1
    #define CONFIG_HAS_HW_NRF_UARTE0 1
    #define CONFIG_HAS_HW_NRF_WDT0 1
    #define CONFIG_NRF_HW_TIMER1_RESERVED 1
    #define CONFIG_NRF_HW_RTC1_RESERVED 1
    #define CONFIG_SOC_NRF52840 1
    #define CONFIG_SOC_NRF52840_QIAA 1
    #define CONFIG_SOC_DCDC_NRF52X 1
    #define CONFIG_SOC_DCDC_NRF52X_HV 1
    #define CONFIG_GPIO_AS_PINRESET 1
    #define CONFIG_NRF_ENABLE_ICACHE 1
    #define CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT 3
    #define CONFIG_NRF_SOC_SECURE_SUPPORTED 1
    #define CONFIG_NRF_APPROTECT_USE_UICR 1
    #define CONFIG_SOC_LOG_LEVEL_INF 1
    #define CONFIG_SOC_LOG_LEVEL 3
    #define CONFIG_SOC_COMPATIBLE_NRF 1
    #define CONFIG_SOC_COMPATIBLE_NRF52X 1
    #define CONFIG_ARCH "arm"
    #define CONFIG_CPU_CORTEX 1
    #define CONFIG_CPU_CORTEX_M 1
    #define CONFIG_ISA_THUMB2 1
    #define CONFIG_ASSEMBLER_ISA_THUMB2 1
    #define CONFIG_COMPILER_ISA_THUMB2 1
    #define CONFIG_STACK_ALIGN_DOUBLE_WORD 1
    #define CONFIG_FAULT_DUMP 2
    #define CONFIG_ARM_STACK_PROTECTION 1
    #define CONFIG_ARM_STORE_EXC_RETURN 1
    #define CONFIG_FP_HARDABI 1
    #define CONFIG_FP16 1
    #define CONFIG_FP16_IEEE 1
    #define CONFIG_CPU_CORTEX_M4 1
    #define CONFIG_CPU_CORTEX_M_HAS_SYSTICK 1
    #define CONFIG_CPU_CORTEX_M_HAS_DWT 1
    #define CONFIG_CPU_CORTEX_M_HAS_BASEPRI 1
    #define CONFIG_CPU_CORTEX_M_HAS_VTOR 1
    #define CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS 1
    #define CONFIG_ARMV7_M_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV7_M_ARMV8_M_FP 1
    #define CONFIG_GEN_ISR_TABLES 1
    #define CONFIG_ZERO_LATENCY_IRQS 1
    #define CONFIG_ZERO_LATENCY_LEVELS 1
    #define CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE 1
    #define CONFIG_GEN_IRQ_VECTOR_TABLE 1
    #define CONFIG_ARM_MPU 1
    #define CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE 32
    #define CONFIG_MPU_STACK_GUARD 1
    #define CONFIG_MPU_STACK_GUARD_MIN_SIZE_FLOAT 128
    #define CONFIG_MPU_ALLOW_FLASH_WRITE 1
    #define CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE 32
    #define CONFIG_ARM 1
    #define CONFIG_ARCH_IS_SET 1
    #define CONFIG_ARCH_LOG_LEVEL_INF 1
    #define CONFIG_ARCH_LOG_LEVEL 3
    #define CONFIG_LITTLE_ENDIAN 1
    #define CONFIG_KOBJECT_TEXT_AREA 256
    #define CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT 100
    #define CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES 16
    #define CONFIG_GEN_PRIV_STACKS 1
    #define CONFIG_DYNAMIC_INTERRUPTS 1
    #define CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN 4
    #define CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS 1
    #define CONFIG_GEN_SW_ISR_TABLE 1
    #define CONFIG_ARCH_SW_ISR_TABLE_ALIGN 4
    #define CONFIG_GEN_IRQ_START_VECTOR 0
    #define CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT 1
    #define CONFIG_ARCH_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_STACK_PROTECTION 1
    #define CONFIG_ARCH_HAS_USERSPACE 1
    #define CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT 1
    #define CONFIG_ARCH_HAS_RAMFUNC_SUPPORT 1
    #define CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION 1
    #define CONFIG_ARCH_SUPPORTS_COREDUMP 1
    #define CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT 1
    #define CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO 1
    #define CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_ARCH_HAS_SUSPEND_TO_RAM 1
    #define CONFIG_ARCH_HAS_THREAD_ABORT 1
    #define CONFIG_ARCH_HAS_CODE_DATA_RELOCATION 1
    #define CONFIG_CPU_HAS_FPU 1
    #define CONFIG_CPU_HAS_MPU 1
    #define CONFIG_MPU 1
    #define CONFIG_MPU_LOG_LEVEL_INF 1
    #define CONFIG_MPU_LOG_LEVEL 3
    #define CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT 1
    #define CONFIG_SRAM_REGION_PERMISSIONS 1
    #define CONFIG_FPU_SHARING 1
    #define CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS 1
    #define CONFIG_KERNEL_LOG_LEVEL_INF 1
    #define CONFIG_KERNEL_LOG_LEVEL 3
    #define CONFIG_MULTITHREADING 1
    #define CONFIG_NUM_COOP_PRIORITIES 16
    #define CONFIG_NUM_PREEMPT_PRIORITIES 15
    #define CONFIG_MAIN_THREAD_PRIORITY 0
    #define CONFIG_COOP_ENABLED 1
    #define CONFIG_PREEMPT_ENABLED 1
    #define CONFIG_PRIORITY_CEILING -127
    #define CONFIG_IDLE_STACK_SIZE 320
    #define CONFIG_ISR_STACK_SIZE 2048
    #define CONFIG_THREAD_STACK_INFO 1
    #define CONFIG_ERRNO 1
    #define CONFIG_SCHED_DUMB 1
    #define CONFIG_WAITQ_DUMB 1
    #define CONFIG_BOOT_BANNER 1
    #define CONFIG_BOOT_DELAY 0
    #define CONFIG_THREAD_MONITOR 1
    #define CONFIG_THREAD_NAME 1
    #define CONFIG_THREAD_MAX_NAME_LEN 32
    #define CONFIG_SYSTEM_WORKQUEUE_PRIORITY -1
    #define CONFIG_ATOMIC_OPERATIONS_BUILTIN 1
    #define CONFIG_TIMESLICING 1
    #define CONFIG_TIMESLICE_SIZE 0
    #define CONFIG_TIMESLICE_PRIORITY 0
    #define CONFIG_POLL 1
    #define CONFIG_NUM_MBOX_ASYNC_MSGS 10
    #define CONFIG_KERNEL_MEM_POOL 1
    #define CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN 1
    #define CONFIG_SWAP_NONATOMIC 1
    #define CONFIG_SYS_CLOCK_EXISTS 1
    #define CONFIG_TIMEOUT_64BIT 1
    #define CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS 365
    #define CONFIG_XIP 1
    #define CONFIG_KERNEL_INIT_PRIORITY_OBJECTS 30
    #define CONFIG_KERNEL_INIT_PRIORITY_DEFAULT 40
    #define CONFIG_KERNEL_INIT_PRIORITY_DEVICE 50
    #define CONFIG_APPLICATION_INIT_PRIORITY 90
    #define CONFIG_STACK_POINTER_RANDOM 0
    #define CONFIG_MP_NUM_CPUS 1
    #define CONFIG_TICKLESS_KERNEL 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_IEEE802154 1
    #define CONFIG_IEEE802154_NRF5_INIT_PRIO 80
    #define CONFIG_IEEE802154_NRF5_EXT_IRQ_MGMT 1
    #define CONFIG_IEEE802154_NRF5_FCS_IN_LENGTH 1
    #define CONFIG_IEEE802154_DRIVER_LOG_LEVEL_INF 1
    #define CONFIG_IEEE802154_DRIVER_LOG_LEVEL 3
    #define CONFIG_CONSOLE 1
    #define CONFIG_CONSOLE_INPUT_MAX_LINE_LEN 128
    #define CONFIG_CONSOLE_HAS_DRIVER 1
    #define CONFIG_CONSOLE_INIT_PRIORITY 60
    #define CONFIG_UART_CONSOLE 1
    #define CONFIG_UART_CONSOLE_INPUT_EXPIRED 1
    #define CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT 15000
    #define CONFIG_UART_CONSOLE_LOG_LEVEL_INF 1
    #define CONFIG_UART_CONSOLE_LOG_LEVEL 3
    #define CONFIG_HAS_SEGGER_RTT 1
    #define CONFIG_ETH_INIT_PRIORITY 80
    #define CONFIG_SERIAL_HAS_DRIVER 1
    #define CONFIG_SERIAL_SUPPORT_ASYNC 1
    #define CONFIG_SERIAL_SUPPORT_INTERRUPT 1
    #define CONFIG_UART_LOG_LEVEL_INF 1
    #define CONFIG_UART_LOG_LEVEL 3
    #define CONFIG_UART_USE_RUNTIME_CONFIGURE 1
    #define CONFIG_UART_NRFX 1
    #define CONFIG_UART_0_NRF_UARTE 1
    #define CONFIG_UART_0_ENHANCED_POLL_OUT 1
    #define CONFIG_UART_0_INTERRUPT_DRIVEN 1
    #define CONFIG_UART_0_NRF_TX_BUFFER_SIZE 32
    #define CONFIG_UART_ENHANCED_POLL_OUT 1
    #define CONFIG_NRF_UARTE_PERIPHERAL 1
    #define CONFIG_INTC_INIT_PRIORITY 40
    #define CONFIG_INTC_LOG_LEVEL_INF 1
    #define CONFIG_INTC_LOG_LEVEL 3
    #define CONFIG_SYSTEM_CLOCK_INIT_PRIORITY 0
    #define CONFIG_TICKLESS_CAPABLE 1
    #define CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS 1
    #define CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY 1
    #define CONFIG_ENTROPY_LOG_LEVEL_INF 1
    #define CONFIG_ENTROPY_LOG_LEVEL 3
    #define CONFIG_ENTROPY_INIT_PRIORITY 50
    #define CONFIG_ENTROPY_NRF5_RNG 1
    #define CONFIG_ENTROPY_NRF5_THR_POOL_SIZE 8
    #define CONFIG_ENTROPY_NRF5_THR_THRESHOLD 4
    #define CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE 16
    #define CONFIG_ENTROPY_NRF5_ISR_THRESHOLD 12
    #define CONFIG_ENTROPY_BT_HCI 1
    #define CONFIG_ENTROPY_HAS_DRIVER 1
    #define CONFIG_GPIO_LOG_LEVEL_INF 1
    #define CONFIG_GPIO_LOG_LEVEL 3
    #define CONFIG_GPIO_NRFX 1
    #define CONFIG_FXL6408_LOG_LEVEL_INF 1
    #define CONFIG_FXL6408_LOG_LEVEL 3
    #define CONFIG_PWM 1
    #define CONFIG_PWM_LOG_LEVEL_INF 1
    #define CONFIG_PWM_LOG_LEVEL 3
    #define CONFIG_PWM_INIT_PRIORITY 50
    #define CONFIG_PWM_SHELL 1
    #define CONFIG_PWM_NRFX 1
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF 1
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL 3
    #define CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT 1
    #define CONFIG_CLOCK_CONTROL_NRF 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM 1
    #define CONFIG_CLOCK_CONTROL_NRF_ACCURACY 50
    #define CONFIG_FLASH_HAS_DRIVER_ENABLED 1
    #define CONFIG_FLASH_HAS_PAGE_LAYOUT 1
    #define CONFIG_FLASH_JESD216 1
    #define CONFIG_FLASH 1
    #define CONFIG_FLASH_LOG_LEVEL_INF 1
    #define CONFIG_FLASH_LOG_LEVEL 3
    #define CONFIG_FLASH_PAGE_LAYOUT 1
    #define CONFIG_FLASH_INIT_PRIORITY 50
    #define CONFIG_SOC_FLASH_NRF 1
    #define CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER 10
    #define CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY 80
    #define CONFIG_SENSOR_LOG_LEVEL_INF 1
    #define CONFIG_SENSOR_LOG_LEVEL 3
    #define CONFIG_SENSOR_INIT_PRIORITY 90
    #define CONFIG_TEMP_NRF5_FORCE_ALT 1
    #define CONFIG_TEMP_NRF5 1
    #define CONFIG_TMP112_FULL_SCALE_RUNTIME 1
    #define CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME 1
    #define CONFIG_HWINFO 1
    #define CONFIG_HWINFO_LOG_LEVEL_INF 1
    #define CONFIG_HWINFO_LOG_LEVEL 3
    #define CONFIG_HWINFO_SHELL 1
    #define CONFIG_HWINFO_NRF 1
    #define CONFIG_PINCTRL_LOG_LEVEL_INF 1
    #define CONFIG_PINCTRL_LOG_LEVEL 3
    #define CONFIG_PINCTRL_STORE_REG 1
    #define CONFIG_PINCTRL_NRF 1
    #define CONFIG_USBC_LOG_LEVEL_INF 1
    #define CONFIG_USBC_LOG_LEVEL 3
    #define CONFIG_REQUIRES_FULL_LIBC 1
    #define CONFIG_SUPPORT_MINIMAL_LIBC 1
    #define CONFIG_PICOLIBC_SUPPORTED 1
    #define CONFIG_NEWLIB_LIBC 1
    #define CONFIG_HAS_NEWLIB_LIBC_NANO 1
    #define CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE 2048
    #define CONFIG_STDOUT_CONSOLE 1
    #define CONFIG_RING_BUFFER 1
    #define CONFIG_NOTIFY 1
    #define CONFIG_ONOFF 1
    #define CONFIG_REBOOT 1
    #define CONFIG_CBPRINTF_COMPLETE 1
    #define CONFIG_CBPRINTF_FULL_INTEGRAL 1
    #define CONFIG_CBPRINTF_FP_SUPPORT 1
    #define CONFIG_CBPRINTF_N_SPECIFIER 1
    #define CONFIG_CBPRINTF_LIBC_SUBSTS 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL 3
    #define CONFIG_SYS_HEAP_ALLOC_LOOPS 3
    #define CONFIG_SYS_HEAP_SMALL_ONLY 1
    #define CONFIG_POSIX_MAX_FDS 16
    #define CONFIG_POSIX_API 1
    #define CONFIG_POSIX_CLOCK 1
    #define CONFIG_MAX_TIMER_COUNT 5
    #define CONFIG_POSIX_MQUEUE 1
    #define CONFIG_MSG_COUNT_MAX 16
    #define CONFIG_MSG_SIZE_MAX 16
    #define CONFIG_MQUEUE_NAMELEN_MAX 16
    #define CONFIG_APP_LINK_WITH_POSIX_SUBSYS 1
    #define CONFIG_EVENTFD 1
    #define CONFIG_EVENTFD_MAX 1
    #define CONFIG_FNMATCH 1
    #define CONFIG_BT_LOG_LEVEL_INF 1
    #define CONFIG_BT_LOG_LEVEL 3
    #define CONFIG_BT_HCI 1
    #define CONFIG_BT_CONN_TX 1
    #define CONFIG_BT_CTLR_LE_ENC_SUPPORT 1
    #define CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT 1
    #define CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT 1
    #define CONFIG_BT_CTLR_PRIVACY_SUPPORT 1
    #define CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT 1
    #define CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT 1
    #define CONFIG_BT_CTLR_PHY_2M_SUPPORT 1
    #define CONFIG_BT_CTLR_PHY_CODED_SUPPORT 1
    #define CONFIG_BT_CTLR_ADV_EXT_SUPPORT 1
    #define CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT 1
    #define CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT 1
    #define CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT 1
    #define CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT 1
    #define CONFIG_BT_CTLR_CONN_RSSI_SUPPORT 1
    #define CONFIG_BT_CTLR_ECDH_SUPPORT 1
    #define CONFIG_BT_CTLR_CRYPTO 1
    #define CONFIG_BT_CTLR_HCI_VS_BUILD_INFO ""
    #define CONFIG_BT_CTLR_AD_DATA_BACKUP 1
    #define CONFIG_BT_CTLR_RX_BUFFERS 1
    #define CONFIG_BT_CTLR_TX_PWR_0 1
    #define CONFIG_BT_CTLR_TX_PWR_ANTENNA 0
    #define CONFIG_BT_CTLR_EXT_REJ_IND 1
    #define CONFIG_BT_CTLR_DATA_LENGTH 1
    #define CONFIG_BT_CTLR_PHY 1
    #define CONFIG_BT_CTLR_PHY_2M 1
    #define CONFIG_BT_CTLR_CHAN_SEL_2 1
    #define CONFIG_BT_COMPANY_ID 0x05F1
    #define CONFIG_CPLUSPLUS 1
    #define CONFIG_STD_CPP14 1
    #define CONFIG_LIB_CPLUSPLUS 1
    #define CONFIG_CPP_STATIC_INIT_GNU 1
    #define CONFIG_PRINTK 1
    #define CONFIG_EARLY_CONSOLE 1
    #define CONFIG_ASSERT_LEVEL 2
    #define CONFIG_SPIN_VALIDATE 1
    #define CONFIG_ASSERT_VERBOSE 1
    #define CONFIG_NVS 1
    #define CONFIG_NVS_LOG_LEVEL_INF 1
    #define CONFIG_NVS_LOG_LEVEL 3
    #define CONFIG_LOG_MODE_MINIMAL 1
    #define CONFIG_LOG_OVERRIDE_LEVEL 0
    #define CONFIG_LOG_MAX_LEVEL 4
    #define CONFIG_LOG_USE_VLA 1
    #define CONFIG_NET_BUF 1
    #define CONFIG_NET_BUF_USER_DATA_SIZE 0
    #define CONFIG_NET_BUF_LOG_LEVEL_INF 1
    #define CONFIG_NET_BUF_LOG_LEVEL 3
    #define CONFIG_NETWORKING 1
    #define CONFIG_NET_L2_PHY_IEEE802154 1
    #define CONFIG_OPENTHREAD_LOG_LEVEL 0
    #define CONFIG_OPENTHREAD_L2_LOG_LEVEL 0
    #define CONFIG_OPENTHREAD_THREAD_PRIORITY 8
    #define CONFIG_OPENTHREAD_PKT_LIST_SIZE 10
    #define CONFIG_OPENTHREAD_SHELL 1
    #define CONFIG_OPENTHREAD_PLATFORM_INFO "ZEPHYR"
    #define CONFIG_OPENTHREAD_CUSTOM_PARAMETERS ""
    #define CONFIG_OPENTHREAD_NUM_MESSAGE_BUFFERS 128
    #define CONFIG_OPENTHREAD_MESSAGE_BUFFER_SIZE 128
    #define CONFIG_OPENTHREAD_MAX_STATECHANGE_HANDLERS 2
    #define CONFIG_OPENTHREAD_TMF_ADDRESS_CACHE_ENTRIES 20
    #define CONFIG_OPENTHREAD_MAC_SOFTWARE_ACK_TIMEOUT_ENABLE 1
    #define CONFIG_OPENTHREAD_MAC_SOFTWARE_RETRANSMIT_ENABLE 1
    #define CONFIG_OPENTHREAD_MAC_SOFTWARE_CSMA_BACKOFF_ENABLE 1
    #define CONFIG_NET_IP 1
    #define CONFIG_NET_NATIVE 1
    #define CONFIG_NET_NATIVE_IPV6 1
    #define CONFIG_NET_NATIVE_UDP 1
    #define CONFIG_NET_INIT_PRIO 90
    #define CONFIG_NET_IP_DSCP_ECN 1
    #define CONFIG_NET_IF_MAX_IPV6_COUNT 1
    #define CONFIG_NET_IF_IPV6_PREFIX_COUNT 2
    #define CONFIG_NET_INITIAL_HOP_LIMIT 64
    #define CONFIG_NET_IPV6_MAX_NEIGHBORS 8
    #define CONFIG_NET_IPV6_LOG_LEVEL 0
    #define CONFIG_NET_ICMPV6_LOG_LEVEL 0
    #define CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL 0
    #define CONFIG_NET_TC_TX_COUNT 0
    #define CONFIG_NET_TC_RX_COUNT 1
    #define CONFIG_NET_TC_THREAD_COOPERATIVE 1
    #define CONFIG_NET_TC_NUM_PRIORITIES 16
    #define CONFIG_NET_TC_MAPPING_STRICT 1
    #define CONFIG_NET_TX_DEFAULT_PRIORITY 1
    #define CONFIG_NET_RX_DEFAULT_PRIORITY 0
    #define CONFIG_NET_IP_ADDR_CHECK 1
    #define CONFIG_NET_UDP 1
    #define CONFIG_NET_UDP_CHECKSUM 1
    #define CONFIG_NET_UDP_LOG_LEVEL 0
    #define CONFIG_NET_MAX_CONTEXTS 6
    #define CONFIG_NET_CONTEXT_SYNC_RECV 1
    #define CONFIG_NET_CONTEXT_CHECK 1
    #define CONFIG_NET_CONTEXT_DSCP_ECN 1
    #define CONFIG_NET_BUF_FIXED_DATA_SIZE 1
    #define CONFIG_NET_BUF_DATA_SIZE 128
    #define CONFIG_NET_DEFAULT_IF_FIRST 1
    #define CONFIG_NET_TX_STACK_SIZE 1200
    #define CONFIG_NET_RX_STACK_SIZE 1500
    #define CONFIG_NET_PKT_LOG_LEVEL 0
    #define CONFIG_NET_DEBUG_NET_PKT_EXTERNALS 0
    #define CONFIG_NET_CORE_LOG_LEVEL 0
    #define CONFIG_NET_IF_LOG_LEVEL 0
    #define CONFIG_NET_TC_LOG_LEVEL 0
    #define CONFIG_NET_UTILS_LOG_LEVEL 0
    #define CONFIG_NET_CONTEXT_LOG_LEVEL 0
    #define CONFIG_NET_CONN_LOG_LEVEL 0
    #define CONFIG_NET_ROUTE_LOG_LEVEL 0
    #define CONFIG_NET_HTTP_LOG_LEVEL 0
    #define CONFIG_NET_CONFIG_AUTO_INIT 1
    #define CONFIG_NET_CONFIG_INIT_PRIO 95
    #define CONFIG_NET_CONFIG_INIT_TIMEOUT 30
    #define CONFIG_NET_CONFIG_LOG_LEVEL 0
    #define CONFIG_NET_SOCKETS 1
    #define CONFIG_NET_SOCKETS_PRIORITY_DEFAULT 50
    #define CONFIG_NET_SOCKETS_POLL_MAX 3
    #define CONFIG_NET_SOCKETS_CONNECT_TIMEOUT 3000
    #define CONFIG_NET_SOCKETS_TLS_PRIORITY 45
    #define CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH 1
    #define CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY 40
    #define CONFIG_NET_SOCKETS_LOG_LEVEL 0
    #define CONFIG_PM_LOG_LEVEL_INF 1
    #define CONFIG_PM_LOG_LEVEL 3
    #define CONFIG_PM_POLICY_DEFAULT 1
    #define CONFIG_SHELL_LOG_LEVEL_INF 1
    #define CONFIG_SHELL_LOG_LEVEL 3
    #define CONFIG_SHELL_BACKENDS 1
    #define CONFIG_SHELL_BACKEND_SERIAL 1
    #define CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY 0
    #define CONFIG_SHELL_PROMPT_UART "uart:~$ "
    #define CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN 1
    #define CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE 8
    #define CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE 64
    #define CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT 100
    #define CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE 10
    #define CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL 5
    #define CONFIG_SHELL_BACKSPACE_MODE_DELETE 1
    #define CONFIG_SHELL_CMD_BUFF_SIZE 256
    #define CONFIG_SHELL_PRINTF_BUFF_SIZE 30
    #define CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH 80
    #define CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT 24
    #define CONFIG_SHELL_ARGC_MAX 20
    #define CONFIG_SHELL_TAB 1
    #define CONFIG_SHELL_TAB_AUTOCOMPLETION 1
    #define CONFIG_SHELL_WILDCARD 1
    #define CONFIG_SHELL_ECHO_STATUS 1
    #define CONFIG_SHELL_VT100_COMMANDS 1
    #define CONFIG_SHELL_VT100_COLORS 1
    #define CONFIG_SHELL_METAKEYS 1
    #define CONFIG_SHELL_HELP 1
    #define CONFIG_SHELL_HELP_OPT_PARSE 1
    #define CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT 1
    #define CONFIG_SHELL_HISTORY 1
    #define CONFIG_SHELL_HISTORY_BUFFER 512
    #define CONFIG_SHELL_STATS 1
    #define CONFIG_SHELL_CMDS 1
    #define CONFIG_SHELL_CMDS_RESIZE 1
    #define CONFIG_SHELL_CMD_ROOT ""
    #define CONFIG_KERNEL_SHELL 1
    #define CONFIG_KERNEL_SHELL_REBOOT_DELAY 0
    #define CONFIG_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_TRAILER_SWAP_TYPE 1
    #define CONFIG_IMG_BLOCK_BUF_SIZE 512
    #define CONFIG_IMG_MANAGER_LOG_LEVEL_INF 1
    #define CONFIG_IMG_MANAGER_LOG_LEVEL 3
    #define CONFIG_XOSHIRO_RANDOM_GENERATOR 1
    #define CONFIG_CSPRING_ENABLED 1
    #define CONFIG_HARDWARE_DEVICE_CS_GENERATOR 1
    #define CONFIG_FLASH_MAP 1
    #define CONFIG_STREAM_FLASH 1
    #define CONFIG_STREAM_FLASH_ERASE 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL_INF 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL 3
    #define CONFIG_SETTINGS 1
    #define CONFIG_SETTINGS_LOG_LEVEL_INF 1
    #define CONFIG_SETTINGS_LOG_LEVEL 3
    #define CONFIG_SETTINGS_DYNAMIC_HANDLERS 1
    #define CONFIG_SETTINGS_NVS 1
    #define CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT 1
    #define CONFIG_SETTINGS_NVS_SECTOR_COUNT 8
    #define CONFIG_TOOLCHAIN_ZEPHYR_0_15 1
    #define CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_LINKER_ORPHAN_SECTION_WARN 1
    #define CONFIG_HAS_FLASH_LOAD_OFFSET 1
    #define CONFIG_USE_DT_CODE_PARTITION 1
    #define CONFIG_FLASH_LOAD_OFFSET 0xc000
    #define CONFIG_FLASH_LOAD_SIZE 0x67000
    #define CONFIG_LD_LINKER_SCRIPT_SUPPORTED 1
    #define CONFIG_LD_LINKER_TEMPLATE 1
    #define CONFIG_KERNEL_ENTRY "__start"
    #define CONFIG_LINKER_SORT_BY_ALIGNMENT 1
    #define CONFIG_SRAM_OFFSET 0x0
    #define CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT 1
    #define CONFIG_LINKER_LAST_SECTION_ID_PATTERN 0xE015E015
    #define CONFIG_SIZE_OPTIMIZATIONS 1
    #define CONFIG_COMPILER_COLOR_DIAGNOSTICS 1
    #define CONFIG_FORTIFY_SOURCE_COMPILE_TIME 1
    #define CONFIG_COMPILER_OPT ""
    #define CONFIG_RUNTIME_ERROR_CHECKS 1
    #define CONFIG_KERNEL_BIN_NAME "zephyr"
    #define CONFIG_OUTPUT_STAT 1
    #define CONFIG_OUTPUT_DISASSEMBLY 1
    #define CONFIG_OUTPUT_PRINT_MEMORY_USAGE 1
    #define CONFIG_BUILD_OUTPUT_BIN 1
    #define CONFIG_BUILD_OUTPUT_META 1
    #define CONFIG_WARN_DEPRECATED 1
    #define CONFIG_ENFORCE_ZEPHYR_STDINT 1
    #define CONFIG_MCUBOOT_SIGNATURE_KEY_FILE ""
    #define CONFIG_COMPAT_INCLUDES 1
