The matter zap tool opens a. zap file, is error
Please refer to the following image. Some clusters have warnings, may I ask what is missing from these?
I use D: ordinacsemi v2.4.1 nrf samples matter light_ Bulb's .zap
On the other hand, there is an error message stating 'Error: Unable to find cluster extension by component.';
I don't know where I made a mistake. Please help me, thank you
  • This problem has been bothering me for a week, please help me, thank you.
    Environment:
    Raspberry Pie (Border Router)
    router
    Ubuntu 20.04(Linux Host)
    Board (Light_Blub)
    Chih TooL:
    Using pre compiled, version 2.4.1
    Releases · nrfconnect/sdk-connectedhomeip (github.com)
    I can see the device 'matterLight' on my computer
    yida@yida-ThinkPad-E470:~$ ./chip-tool-debug pairing ble-thread 1 hex:0e080000000000010000000300000d35060004001fffe00208ee7e4a2d48cdfd7e0708fd131483b543b1000510253bf95c157a90fe0984c54686572c74030f4f70656e5468726561642d643666370102d6f70410e2b8eaa64e39fc95ac12cc7b8757bd410c0402a0f7f8 20202021 3840
    [1693455991.857097][4839:4839] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1693455991.857259][4839:4839] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1693455991.857292][4839:4839] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1693455991.857312][4839:4839] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1693455991.857419][4839:4839] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-GRdMES)
    [1693455991.857580][4839:4839] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1693455991.857592][4839:4839] CHIP:DL: NVS set: chip-counters/reboot-count = 4 (0x4)
    [1693455991.857767][4839:4839] CHIP:DL: Got Ethernet interface: enp4s0
    [1693455991.857872][4839:4839] CHIP:DL: Found the primary Ethernet interface:enp4s0
    [1693455991.857981][4839:4839] CHIP:DL: Got WiFi interface: wlp5s0
    [1693455991.858096][4839:4839] CHIP:DL: Found the primary WiFi interface:wlp5s0
    [1693455991.858111][4839:4839] CHIP:IN: UDP::Init bind&listen port=0
    [1693455991.858167][4839:4839] CHIP:IN: UDP::Init bound to port=35531
    [1693455991.858173][4839:4839] CHIP:IN: UDP::Init bind&listen port=0
    [1693455991.858190][4839:4839] CHIP:IN: UDP::Init bound to port=60013
    [1693455991.858194][4839:4839] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1693455991.858198][4839:4839] CHIP:IN: TransportMgr initialized
    [1693455991.858210][4839:4839] CHIP:FP: Initializing FabricTable from persistent storage
    [1693455991.858251][4839:4839] CHIP:TS: Last Known Good Time: 2023-07-11T07:53:58
    [1693455991.858390][4839:4839] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x9E45793F71B1363E, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
    [1693455991.858814][4839:4839] CHIP:ZCL: Using ZAP configuration...
    [1693455991.860751][4839:4839] CHIP:DL: Avahi client registered
    [1693455991.861340][4839:4839] CHIP:CTL: System State Initialized...
    [1693455991.861376][4839:4839] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1693455991.861388][4839:4839] CHIP:CTL: Setting attestation nonce to random value
    [1693455991.861395][4839:4839] CHIP:CTL: Setting CSR nonce to random value
    [1693455991.861515][4839:4841] CHIP:DL: CHIP task running
    [1693455991.861566][4839:4841] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
    [1693455991.861642][4839:4841] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1693455991.861651][4839:4841] CHIP:CTL: Setting attestation nonce to random value
    [1693455991.861656][4839:4841] CHIP:CTL: Setting CSR nonce to random value
    [1693455991.865085][4839:4841] CHIP:CTL: Generating NOC
    [1693455991.868697][4839:4841] CHIP:FP: Validating NOC chain
    [1693455991.884270][4839:4841] CHIP:FP: NOC chain validation successful
    [1693455991.884290][4839:4841] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
    [1693455991.884297][4839:4841] CHIP:TS: Last Known Good Time: 2023-07-11T07:53:58
    [1693455991.884301][4839:4841] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1693455991.884305][4839:4841] CHIP:TS: Retaining current Last Known Good Time
    [1693455991.884814][4839:4841] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1693455991.885274][4839:4841] CHIP:TS: Committing Last Known Good Time to storage: 2023-07-11T07:53:58
    [1693455991.885681][4839:4841] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 9E45793F71B1363E)
    [1693455991.889681][4839:4841] CHIP:CTL: Setting thread operational dataset from parameters
    [1693455991.889689][4839:4841] CHIP:CTL: Setting attestation nonce to random value
    [1693455991.889695][4839:4841] CHIP:CTL: Setting CSR nonce to random value
    [1693455991.889701][4839:4841] CHIP:CTL: Commission called for node ID 0x0000000000000001
    [1693455991.891513][4839:4840] CHIP:DL: TRACE: Bus acquired for name C-12e7
    [1693455991.895595][4839:4841] CHIP:DL: PlatformBlueZInit init success
    [1693455991.897811][4839:4840] CHIP:BLE: BLE removing known devices.
    [1693455991.898425][4839:4840] CHIP:BLE: BLE initiating scan.
    [1693455992.016874][4839:4841] CHIP:DL: Long dispatch time: 127 ms, for event type 2
    [1693455992.136968][4839:4840] CHIP:BLE: Device 43:64:47:98:B2:6A does not look like a CHIP device.
    [1693455992.139170][4839:4840] CHIP:BLE: Device 55:10:7D:B1:6C:94 does not look like a CHIP device.
    [1693455992.144187][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455992.190893][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455992.192647][4839:4840] CHIP:BLE: Device 7B:3E:E8:FB:B9:E5 does not look like a CHIP device.
    [1693455992.198519][4839:4840] CHIP:BLE: Device 4F:42:CC:FF:9D:AD does not look like a CHIP device.
    [1693455992.237858][4839:4840] CHIP:BLE: Device 4A:97:7C:F4:F4:F1 does not look like a CHIP device.
    [1693455992.244527][4839:4840] CHIP:BLE: Device D5:5B:3D:14:B3:8F does not look like a CHIP device.
    [1693455992.302090][4839:4840] CHIP:BLE: Device 5E:1F:73:F2:C2:3F does not look like a CHIP device.
    [1693455992.315487][4839:4840] CHIP:BLE: Device 35:29:5E:75:6B:ED does not look like a CHIP device.
    [1693455992.385728][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455992.447875][4839:4840] CHIP:BLE: Device 55:10:7D:B1:6C:94 does not look like a CHIP device.
    [1693455992.461133][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455992.476969][4839:4840] CHIP:BLE: Device 5F:03:20:5A:24:C4 does not look like a CHIP device.
    [1693455992.535754][4839:4840] CHIP:BLE: Device 55:10:7D:B1:6C:94 does not look like a CHIP device.
    [1693455992.562439][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455992.657832][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455992.675837][4839:4840] CHIP:BLE: Device C3:45:FB:8C:1A:33 does not look like a CHIP device.
    [1693455992.739873][4839:4840] CHIP:BLE: Device 7B:3E:E8:FB:B9:E5 does not look like a CHIP device.
    [1693455992.774767][4839:4840] CHIP:BLE: Device 4A:97:7C:F4:F4:F1 does not look like a CHIP device.
    [1693455992.834091][4839:4840] CHIP:BLE: Device D5:F2:EA:48:13:47 does not look like a CHIP device.
    [1693455992.886850][4839:4840] CHIP:BLE: Device 43:64:47:98:B2:6A does not look like a CHIP device.
    [1693455992.930633][4839:4840] CHIP:BLE: Device 35:29:5E:75:6B:ED does not look like a CHIP device.
    [1693455992.949098][4839:4840] CHIP:BLE: Device DB:9C:17:45:91:C0 does not look like a CHIP device.
    [1693455992.983643][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455993.034911][4839:4840] CHIP:BLE: Device 35:29:5E:75:6B:ED does not look like a CHIP device.
    [1693455993.223787][4839:4840] CHIP:BLE: Device 47:D0:1D:75:59:8C does not look like a CHIP device.
    [1693455993.233188][4839:4840] CHIP:BLE: Device E9:D8:C3:FF:DB:BE does not look like a CHIP device.
    [1693455993.260438][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455993.295423][4839:4840] CHIP:BLE: Device 7B:3E:E8:FB:B9:E5 does not look like a CHIP device.
    [1693455993.305372][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455993.321427][4839:4840] CHIP:BLE: Device 4A:97:7C:F4:F4:F1 does not look like a CHIP device.
    [1693455993.428689][4839:4840] CHIP:BLE: Device 43:64:47:98:B2:6A does not look like a CHIP device.
    [1693455993.483470][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455993.560753][4839:4840] CHIP:BLE: Device 35:29:5E:75:6B:ED does not look like a CHIP device.
    [1693455993.567996][4839:4840] CHIP:BLE: Device 4F:42:CC:FF:9D:AD does not look like a CHIP device.
    [1693455993.749640][4839:4840] CHIP:BLE: Device D9:B1:89:CD:26:BC does not look like a CHIP device.
    [1693455993.948121][4839:4840] CHIP:BLE: Device D2:D6:AF:FC:48:F7 does not look like a CHIP device.
    [1693455993.948480][4839:4840] CHIP:BLE: Device F3:3D:4D:DB:DC:EE does not look like a CHIP device.
    [1693455993.995691][4839:4840] CHIP:BLE: Device 35:29:5E:75:6B:ED does not look like a CHIP device.
    [1693455994.125540][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455994.193786][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455994.308404][4839:4840] CHIP:BLE: Device 4F:42:CC:FF:9D:AD does not look like a CHIP device.
    [1693455994.309306][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455994.398003][4839:4840] CHIP:BLE: Device 4F:42:CC:FF:9D:AD does not look like a CHIP device.
    [1693455994.677452][4839:4840] CHIP:BLE: Device C3:45:FB:8C:1A:33 does not look like a CHIP device.
    [1693455994.837861][4839:4840] CHIP:BLE: Device D5:F2:EA:48:13:47 does not look like a CHIP device.
    [1693455995.176084][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455995.187870][4839:4840] CHIP:BLE: Device 02:67:D8:9B:04:BD does not look like a CHIP device.
    [1693455995.227377][4839:4840] CHIP:BLE: Device 7B:3E:E8:FB:B9:E5 does not look like a CHIP device.
    [1693455995.754318][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455995.755287][4839:4840] CHIP:BLE: Device D9:B1:89:CD:26:BC does not look like a CHIP device.
    [1693455995.761597][4839:4840] CHIP:BLE: Device CF:AD:81:30:E7:BB does not look like a CHIP device.
    [1693455995.770820][4839:4840] CHIP:BLE: Device 4F:42:CC:FF:9D:AD does not look like a CHIP device.
    [1693455995.802829][4839:4840] CHIP:BLE: Device 7B:3E:E8:FB:B9:E5 does not look like a CHIP device.
    [1693455995.803547][4839:4840] CHIP:BLE: Device 77:F8:C2:66:E0:EE does not look like a CHIP device.
    [1693455995.810845][4839:4840] CHIP:BLE: Device 02:67:D8:9B:04:BD does not look like a CHIP device.
    [1693455996.677254][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455996.678400][4839:4840] CHIP:BLE: Device C3:45:FB:8C:1A:33 does not look like a CHIP device.
    [1693455997.478034][4839:4840] CHIP:BLE: Device E2:13:C2:7B:C0:70 does not look like a CHIP device.
    [1693455998.197236][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455998.446706][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455998.625719][4839:4840] CHIP:BLE: Device 48:5F:74:67:2F:30 does not look like a CHIP device.
    [1693455998.680855][4839:4840] CHIP:BLE: Device C3:45:FB:8C:1A:33 does not look like a CHIP device.
    [1693455998.723092][4839:4840] CHIP:BLE: Device 5A:92:DF:03:CE:2E does not look like a CHIP device.
    [1693455998.782864][4839:4840] CHIP:BLE: Device 52:B6:FE:0D:52:8E does not look like a CHIP device.
    [1693455998.844840][4839:4840] CHIP:BLE: Device 4A:97:7C:F4:F4:F1 does not look like a CHIP device.
    [1693455998.845869][4839:4840] CHIP:BLE: Device D5:F2:EA:48:13:47 does not look like a CHIP device.
    [1693455999.001215][4839:4840] CHIP:BLE: New device scanned: CC:5E:B5:42:C3:48
    [1693455999.001263][4839:4840] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1693456002.027697][4839:4841] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
    [1693456009.009391][4839:4841] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
    [1693456009.009445][4839:4841] CHIP:DIS: Closing all BLE connections
    [1693456009.009636][4839:4840] CHIP:DL: FAIL: ConnectDevice : Operation was cancelled (19)
    [1693456009.009853][4839:4841] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
    [1693456111.861977][4839:4839] CHIP:CTL: Shutting down the commissioner
    [1693456111.862036][4839:4839] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1693456111.862062][4839:4839] CHIP:CTL: Shutting down the controller
    [1693456111.862097][4839:4839] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1693456111.862125][4839:4839] CHIP:FP: Forgetting fabric 0x1
    [1693456111.862163][4839:4839] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:53:58
    [1693456111.862398][4839:4839] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:53:58
    [1693456111.862427][4839:4839] CHIP:TS: Reverted Last Known Good Time to previous value
    [1693456111.862470][4839:4839] CHIP:CTL: Shutting down the commissioner
    [1693456111.862498][4839:4839] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1693456111.862522][4839:4839] CHIP:CTL: Shutting down the controller
    [1693456111.862541][4839:4839] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1693456111.863739][4839:4839] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1693456111.863833][4839:4839] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1693456111.863882][4839:4839] CHIP:FP: Shutting down FabricTable
    [1693456111.863918][4839:4839] CHIP:TS: Pending Last Known Good Time: 2023-07-11T07:53:58
    [1693456111.864103][4839:4839] CHIP:TS: Previous Last Known Good Time: 2023-07-11T07:53:58
    [1693456111.864126][4839:4839] CHIP:TS: Reverted Last Known Good Time to previous value
    [1693456111.864355][4839:4839] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-v57lyA)
    [1693456111.865010][4839:4839] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1693456111.865071][4839:4839] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1693456111.865095][4839:4839] CHIP:DL: Inet Layer shutdown
    [1693456111.865114][4839:4839] CHIP:DL: BLE shutdown
    [1693456111.865685][4839:4839] CHIP:DL: System Layer shutdown
    [1693456111.866303][4839:4839] CHIP:TOO: Run command failure: examples/chip-tool/commands/common/CHIPCommand.cpp:537: CHIP Error 0x00000032: Timeout
    It looks like a problem with BLE connectivity. The device handling it like bluetooth card or USB HCI. Not sure what device was used, could be the one built in "ThinkPad-E470". In case of those errors, it is worth checking the system logs for bluetooth errors.
    What instructions do you follow? Could you provide the link?
    -Amanda H.
    I am using a customer board,
    I really can't find the problem, so I used the Bluetooth example to test the Bluetooth connection, but the connection failed, as follows:
    Tools: nRF connect for Mobile, Bluetooth: Peripheral Status, Customer Board (52840)
    1. VS Code Open "Bluetooth: Peripheral Status', prjconf adds enable RTT instruction.
    2. 'Build Configuration'
    3. Flash and “Connect RTT”,Then, connect to 'Nordic_Status' through 'nRF Connect for mobile'
    I: HW Platform: Nordic Semiconductor (0x0002)
    I: HW Variant: nRF52x (0x0002)
    I: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
    I: No ID address. App must call settings_load()
    Bluetooth initialized
    I: Identity: CC:68:EF:6F:CF:85 (random)
    I: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
    I: LMP: version 5.4 (0x0d) subver 0x1077
    Advertising successfully started
    Connected
    Disconnected (reason 62)
    3
  • Complete prompt:
    SEGGER J-Link V7.88j - Real time terminal output
    SEGGER J-Link V10.1, SN=600105955
    Process: JLinkExe
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    Starting Bluetooth Peripheral Status example
    I: 8 Sectors of 4096 bytes
    I: alloc wra: 0, ea0
    I: data wra: 0, 11c
    I: SoftDevice Controller build revision:
    I: e0 7e 2e c1 5e 05 85 23 |.~..^..#
    I: 46 15 dc fa 8e 29 7d 70 |F....)}p
    I: 10 93 a5 fc             |....
    Connected
