Hi
I am trying to test Wi-Fi 6 Target Wake Time (TWT) in a matter device. I have built and run the light bulb example, but I can't seem to find a way to make it run with TWT. Is there a way to configure the sample to use TWT?
Hi
This is the code I have added to the Matter template sample. It is added to the AppTask::ChipEventhandler() inside the wifi Change if statement. the only difference from the TWT sample is that I have hardcoded some of the parameters and removed the 0 in the initialization of the params struct since it made an error.
You should merge the https://github.com/nrfconnect/sdk-nrf/blob/main/samples/wifi/twt/Kconfig to the app/Kconfig to get those values for the parameters.
-Amanda H.
Hi
I do not have a problem with the hardcoded parameters. My problem is that the code that works in the TWT sample does not work in the matter sample. I have tried to debug both, to see what the difference is.
^this is the iface from the matter code from last post^
^This is the iface from the TWT sample that works^
The matter sample does not have an ipv4 address, which I think might be the problem since it is failing on this part of wifi_set_twt() in "zephyr/subsys/net/l2/wifi/wifi_mgmt.c
hope you can help me find the problem.
-Martin
Martin Hauser said:The matter sample does not have an ipv4 address, which I think might be the problem since it is failing on this part of wifi_set_twt() in "zephyr/subsys/net/l2/wifi/wifi_mgmt.c
Do you add ipv4 address into the prj.conf as this https://github.com/nrfconnect/sdk-nrf/blob/ea31b211be92f0f837cec1a70be665ec6ff712c3/samples/wifi/twt/prj.conf#L83-L85?
-Amanda H.
I got it to work, it needed an ipv6 address since matter runs on ipv6.
now when the TWT connection is set up the rest of the sample does not work, but I will look further into it before writing again.
- Martin
