AWS IoT FOTA Error nRF7002DK: Failed to create socket, err 12
After a lot of trial and error, I finally have an AWS IoT build running on my 7002dk. I am running the sample from the main branch of nRF Connect building with the command line.
west build -b nrf7002dk_nrf5340_cpuapp
west flash
My dev kit is successfully connecting to the broker and sending shadow updates. However, I need to make a proof of concept FOTA. Following the guide, I am able to get an update job started over https.
However, I am getting an error saying: download_client: Failed to create socket, err 12.
I am not sure where to look to start debugging. What am I missing?
[00:01:36.774,902] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 21781
[00:01:36.775,207] <inf> download_client: Downloading: app_update.bin [0]
[00:01:36.775,268] <inf> aws_iot_sample: AWS_IOT_EVT_FOTA_START
[00:01:36.814,697] <err> download_client: Failed to create socket, err 12
[00:01:36.814,727] <err> fota_download: Download client error
[00:01:36.814,758] <err> aws_fota: FOTA_DOWNLOAD_EVT_ERROR
[00:01:36.814,788] <err> aws_iot: AWS_FOTA_EVT_ERROR
[00:01:36.814,788] <inf> aws_iot_sample: AWS_IOT_EVT_FOTA_ERROR
[00:01:36.966,064] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 26704
[00:01:37.106,048] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 31885
Maybe some relevant config settings:
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_STATIC="thing_name"
CONFIG_AWS_IOT_BROKER_HOST_NAME="aws_endpoint"
CONFIG_AWS_IOT_SEC_TAG=201
CONFIG_AWS_FOTA_DOWNLOAD_SECURITY_TAG=401
CONFIG_WIFI_CREDENTIALS_STATIC=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="ssid"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="pass"
  • Hi
    Errno 2 refers to there being no such file directory or entry, so I guess it's referring to either of the parameters for the connect() function aren't found in your project:
    err = connect(dl->fd, &dl->remote_addr, addrlen);
    Double check what these values actually return or what directories/entries they are pulled from to see if that helps you at all.
    Simon
  • Hi Simon,
    I include the CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=y configuration option in my prj.conf file. Here is what the download_client is logging now:
    [00:01:29.936,431] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 60158
    [00:01:29.937,347] <dbg> download_client: set_state: state = 1
    [00:01:29.937,377] <inf> download_client: Downloading: app_update.bin [0]
    [00:01:29.937,438] <inf> aws_iot_sample: AWS_IOT_EVT_FOTA_START
    [00:01:30.241,943] <dbg> download_client: client_connect: Protocol not specified, defaulting to HTTP(S)
    [00:01:30.242,004] <dbg> download_client: client_connect: Port not specified, using default: 443
    [00:01:30.242,004] <dbg> download_client: client_connect: family: 1, type: 1, proto: 258
    [00:01:30.242,614] <inf> download_client: Setting up TLS credentials, sec tag count 1
    [00:01:30.242,736] <inf> download_client: Connecting to silver-firmware-ota.s3.us-east-1.amazonaws.com
    [00:01:30.242,767] <inf> download_client: fd 9, addrlen 8, fam IPv4, port 443
    [00:01:30.336,761] <err> download_client: Unable to connect, errno 2
    [00:01:30.338,012] <dbg> download_client: set_state: state = 0
    [00:01:30.338,012] <inf> aws_iot_sample: AWS_IOT_EVT_FOTA_DL_PROGRESS, (100%)
    [00:01:30.343,750] <err> fota_download: Download client error
    [00:01:30.495,941] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 11081
    [00:01:30.497,497] <inf> aws_iot_sample: AWS_IOT_EVT_FOTA_DONE
    [00:01:30.505,096] <inf> aws_iot_sample: AWS_IOT_EVT_DISCONNECTED
    [00:01:30.505,126] <wrn> aws_iot_sample: Unexpected FOTA image type
    Does this add any clarity? Am I missing a configuration somewhere? Is FOTA working currently with the latest aws_iot sample?
  • Hi
    After this fix was added to increase the number of TLS contexts and file descriptors the AWS_IoT should be able to do FOTA. I see that the port you're using is the default one, can you confirm is this is intended or not, and that silver-firmware-ota.s3.us-east-1.amazonaws.com is the server you want to connect to? The error is still the same, as one of the params in your connect() function aren't found in your project.
    Simon
  • Hi Simon,
    You are correct, I have not changed the port from the default one. I don't see any mention of ports in the AWS FOTA configuration guide. Is this something I need to configure? Is that on the AWS side or the project side, or both?
    I can confirm that silver-firmware-ota.s3.us-east-1.amazonaws.com is the server I am attempting to connect to.
    Are you implying that I am missing one of the params in my configuration? Can you point me to which configuration variables are missing? Is there a step in the FOTA guide that I missed?
  • I can't see that you're missing anything specifically, I'm just saying what the error code you get implies, which is that either of the parameters in the connect() function of the download_client isn't found when running your project, meaning that either of the parameters in this function aren't fulfilled in your project. I don't have a clear idea of why at the moment I'm afraid, but please check your project what these are set as on your end.
    	if (err) {
    		err = -errno;
    		LOG_ERR("Unable to connect, errno %d", -err);
    Simon
