Deep sleep is only working in debugging and not without debugging
I am using nrf52811 in my PCB, and sdk version 16.00
I am encountering a challenge related to implementing deep sleep functionality, and as a beginner, I've been struggling to configure it correctly. Despite my best efforts, my device does not seem to enter sleep mode in its normal standalone operation. I've verified this by monitoring its current consumption, which remains nearly the same as in active mode.
CASE 1: STANDALONE
What happens is that the device disconnects from Bluetooth Low Energy (BLE), and I cannot reconnect it unless the device detects a low signal on GPIO pin 18.
CASE 1: DEBUGGING MODE
Additionally, when the device disconnects from BLE, I observe a fatal error in the debug terminal and receive an "ERROR 8 (0*8) GATT_CONN_TIMEOUT" message in the nrf_connect mobile app. The device remains in this state until it detects a low signal on GPIO pin 18.
I've been grappling with this issue for about 10 days now and haven't been able to pinpoint the root cause or find a solution. I've attached my code below for review, and I would appreciate it if someone could help me identify where I might be making a mistake.
  • I'm glad to hear that it's working now. If the peripheral turns off without properly terminating the connection, the central connection will time out. This means it will take longer for the central to detect that the connection has been lost.
    AIRAM said:
    From a resource i got to know that buy adding this in deep sleep function the error can go away,
    If the sleep function is called from an interrupt context, such as from the app timer callback, the program will never exit this while loop. This is because the Softdevice event that is supposed to clear the 'm_conn_handle' variable will become blocked. The simplest solution to this is to replace the while loop with a busy wait and hope the connection is successfully terminated after the delay.
    #include "nrf_delay.h"
        (void) sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        /* Wait for connection to be terminated*/
        nrf_delay_ms(100);
  • Thank You so much Vidar Berg , it's working right, Now
