mcumgr communication times out with NMP when nRF5340 supports DFU.
Hell,
I wrote an application with DFU support added to nRF5340, and mcumgr communication on the Linux machine connected via UART times out.
environment
  • Development PC :Windows10
  • Development environment :Visual Studio Code
  • SDK :nRF Connect SDK v2.3.0
procedure
  1. Modify the hello world sample and enable the DFU function on nRF5340 according to the website below.
    1. https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu#serial_dfu
  2. Disable the mass storage function of nRF5340 using J-Link Commander's MSDDisable command.
  3. Write the modified application to nRF5340 using VScode.
  4. Connect Linux machine and nRF5340 with UART.
  5. Communicate with the following command from the Linux machine.
  6. Timeout occurred
mcumgr --conntypeserial --connstring "/dev/ttyLP3,baud=115200" image list
Error: NMP timeout
Since the uart signal is being sent, it seems that the problem is with the application written to the nRF5340.
Please tell me how to make uart DFU work with nRF5340.
  • Hi Håkon,
    Sorry for the late reply.
    Windows PC - mcumgr image list communication between nRF5340-DK was successful.
    When it previously failed on a Windows PC, as you pointed out, it was because the serial terminal was using the port.
    However, it fails between Linux - nRF5340 modules.
    Linux - It was successful between nRF5340-DK, so I think it's a problem with the nRF5340 module.
    Is there a pin setting when using DFU?
    (e.g. RESET pin etc.)
    Q1: Does your module have an external 32k?
    If not; you should set:
    Note that this should also be set in hci_rpmsg:
    my_project/child_image/hci_rpmsg.conf
    and mcuboot:
    my_project/child_image/mcuboot.conf
    Q2: Does your module have DCDC inductors in-place?
    If not, you need to set:
    CONFIG_BOARD_ENABLE_DCDC_APP=n
    CONFIG_BOARD_ENABLE_DCDC_NET=n
    CONFIG_BOARD_ENABLE_DCDC_HV=n
    This also applies to any child_image's, as described above.
    Q3:
    I assume this also means that windows is failing on these modules?
    When using smp_svr, it is the application that handles DFU, so no need to use any GPIO.
    If you are using mcuboot recovery, ie. application is unaware of DFU, then you use a GPIO or a trigger to enter mcuboot recovery mode.
    Håkon
  • Hi Håkon,
    Thank you for the information. solved.
    There is no external 32k on the module, it uses an internal clock.
    After adding the file below containing the clock settings as you pointed out, mcumgr communication was successful.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
    I am glad to hear that the issue was solved, and that you took the time to write a reply with the fix to your issue.
    If you have any more issues or questions, feel free to contact us at support again.
    I hope you have a wonderful weekend!
    Håkon
