Custom OOT AMS TMF882X driver - multiple definition of `__device_dts_ord_xx'
Hi everyone,
I am currently trying to implement a new OOT driver for a ToF sensor made by AMS, the TMF882X.
I have made a kind of skeleton driver based on another one (Sensirion SCD4X).
While compiling my driver i get the following error which I cannot track down and find the cause of it.
It seems that there's multiple definitions during linking of my driver.
I could not find much while searching online
I've also posted all my source files for the driver.
Any help would be greatly appreciated.
tmf882x_testing.rar
  • Will do!
    BTW I have uploaded my dts (and driver stubs) in a zip file.
    Don't know if you had a look there or not.
    Maybe there could be something to make the issue clearer.
    Thanks Slight smile
  • Hey Susheel,
    So I tried with the latest SDK 2.4.2 but still the same issue.
    I will sill keep looking into it.
    I am also including the whole project as you requested.
    Maybe there's something there which I cannot see at the moment.
    testing_tmf882x.rar
  • Hello Dorian,
    I have checked your project.
    Directly building for the NRF53DK, I would see the same error as you have mentioned (multiple definitions of log module and __device_ord_134, both of which are pointing to the TMF882X).
    I could see that the source files are referred two times (one time in the main CMakeLists.txt and the other time within the CMakeLists.txt of the respective driver folder). So, I commented out 4 lines from the CMakeLists.txt:
    Line 15 #FILE(GLOB scd4x_drv scd4x_oot_driver/drivers/sensor/scd4x/*.c)
    Line 16 #FILE(GLOB tmf882x_drv tmf882x_oot_driver/drivers/sensor/tmf882x/*.c)
    Line 18 #target_sources(app PRIVATE ${scd4x_drv})
    Line 19 #target_sources(app PRIVATE ${tmf882x_drv})
    Now that error is removed but a new error appears.
    This time the error is related to the __device_ord_133 which is the other sensor.
    I do not think that this is an overlay issue. I have removed your source code from the main and can access TFM sensor as below (it builds correctly).
    However, I do get error when I try to use the other sensor. I think this is some issue in your implementation. I would suggest you to look at zephyr out-of-tree driver example (I think that is within example-application sample) and revise your implementation etc.
    BR, Naeem
  • Hi Naeem,
    Thanks for the tips.
    I made it work in the end by following a similar structure as the one in the example.
    Even made the binfings work.
    I am posting a pic just in case someone else encounters the same issue.
