nrf-connect.boardRoots does not work. Custom board are not picked up.
Hi, in the video you can see:
1. Me first removing/re-adding the application by editing .vscode/settings.json just to verify the plugin is picking up the settings.json file.
2. Then I try to create a new build configuration, but my custom boards are not there.
3. I show the folder structure that I have boards in app/boards correctly.
I have also tried using the "Create a new board", but those are not either picked up.
Also tried on Linux, but same there. Attached generated support info.
Tried re-installing the plugin.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro N",
    "osKernel": "10.0.19045",
    "vscode": "1.82.1",
    "electron": "25.8.0",
    "node": "v18.15.0"
  "system": {
    "date": "2023-09-13T23:20:42.266Z",
    "vscodeRoot": "c:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:21:18",
    "osUptime": "119:12:40",
    "cpu": {
      "model": "Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz",
      "speed": "4000 MHz",
      "count": 4
    "memory": {
      "total": "15.94 GB",
      "free": "5.05 GB"
  "workspace": {
    "name": "ZSWatch",
    "workspaceFile": null,
    "folders": [
      "g:\\projects\\ZSWatch"
  "extensions": {
    "internal": {
        "version": "2023.9.169",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64",
        "isActive": true
        "version": "2023.9.29",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.9.29",
        "isActive": true
        "version": "2023.9.57",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.9.57",
        "isActive": true
        "version": "2023.9.31",
        "path": "c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.9.31",
        "isActive": true
    "external": {
      "marus25.cortex-debug": "1.12.0",
      "ms-vscode.cpptools": "1.17.5",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
      "ms-vscode.js-debug": "1.82.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "donjayamanne.githistory": "0.6.20",
      "espressif.esp-idf-extension": "1.6.4",
      "GitHub.copilot": "1.111.404",
      "leizongmin.node-module-intellisense": "1.5.0",
      "mark-wiemer.vscode-autohotkey-plus-plus": "5.0.3",
      "mcu-debug.debug-tracker-vscode": "0.0.15",
      "mcu-debug.memory-view": "0.0.24",
      "mcu-debug.peripheral-viewer": "1.4.6",
      "mcu-debug.rtos-views": "0.0.7",
      "platformio.platformio-ide": "3.3.1",
      "trond-snekvik.gnu-mapfiles": "1.1.0"
  "tools": {
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.0",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.88d",
    "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.19.0",
    "nrfutil": "Not found",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\cmake.exe": "3.20.5",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Scripts\\west.exe": "1.0.0",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\python.exe": "3.8.2",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\ninja.exe": "1.9.0",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\gperf.exe": "3.1",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\dtc.exe": "1.4.7",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\gn.exe": "2105",
    "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "sdks": [
      "version": "2.0.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.0.0"
      "version": "2.1.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.1.0"
      "version": "2.1.2",
      "path": "g:\\nRF-Connect-SDKs\\v2.1.2"
      "version": "2.2.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.2.0"
      "version": "2.3.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.3.0"
      "version": "2.4.0",
      "path": "g:\\nRF-Connect-SDKs\\v2.4.0"
      "version": "2.4.2",
      "path": "g:\\nRF-Connect-SDKs\\v2.4.2"
      "version": "2.4.2",
      "path": "g:\\projects\\ZSWatch"
  "toolchains": [
      "version": "2.0.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.0.0"
      "version": "2.1.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.1.0"
      "version": "2.1.2",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.1.2"
      "version": "2.2.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.2.0"
      "version": "2.3.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\v2.3.0"
      "version": "2.4.0",
      "path": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35"
  "connectedDevices": [],
  "deviceProvider": "nrfutil",
  "config": {
      "topdir": "",
      "toolchain": {
        "path": ""
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}\\app"
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [
      "taskBindings": {},
      "debugging": {
        "flash": true,
        "bindings": {}
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "terminalMode": "character"
    "marus25.cortex-debug": {
      "variableUseNaturalFormat": true,
      "liveWatchRefreshRate": "300",
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "dbgServerLogfile": null
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\ijakk_000",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\ijakk_000",
      "PATH": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\mingw64\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Scripts;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\nanopb\\generator-bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\ijakk_000\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.9.169-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;",
      "ZEPHYR_BASE": "g:\\projects\\ZSWatch\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk",
      "PYTHONPATH": "G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Lib;G:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;",
      "PATH": "D:\\Oculus\\Support\\oculus-runtime;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\PuTTY\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37-32\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;\";C:\\Program Files\\dotnet\\;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs\";C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files (x86)\\astyle;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ijakk_000\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\msys64\\mingw64\\bin;C:\\Users\\ijakk_000\\AppData\\Roaming\\nvm;C:\\Program Files\\nodejs;C:\\Users\\ijakk_000\\AppData\\Local\\Programs\\Python\\Python37;G:\\Programs\\incscape\\bin;"
    "toolchainPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35",
    "toolchainBinPath": "g:\\nRF-Connect-SDKs\\toolchains\\31f4403e35\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.4.0"
  "terminal": {
    "defaultProfile": null
  • jakkra said:
    Your last part that boards in /app/board should show up as custom. It does not show up as custom board for me. Not important as it does show up under "all board". I'll need to validate it one more time in a total clean OS installation that it work. Will double check this.
    That's odd, it shows up in Custom boards for me. I will relay that to the VS Code Extension developers.
    jakkra said:
    One thing I noted that could be an input to the VSCode guys is that if I have two clones of the same repo, then VSCode will pick up the custom board from both projects. When you in the dropdown select your custom board there will be two of the same. This makes it hard to know which board I'll be using. So If I make changed in the custom board in the project I'm building, it may not take effect, as the board chosen in VSCode happend to be the custom board from another copy of the same project.
    Are you working on two different VS Code workspace, or two different instances of VS Code in this scenario? If you have two different workspaces, you can use VS Code Workspace Settings instead of User Settings or Global Settings, and it ought to separate the custom board list.
  • It's fine as long as I can select it, I'll get back when I tried again on a clean computer.
    Two instances of VSCode who have different folders opened of the same project. But I don't need both VSCode instances running. I'll study the User Settings instead of Global Settings thanks.
  • Just for clarification, you should change either the Folder Settings or Workspace Settings. There are examples of that in the attachment in my first reply.
    User Settings will still be in effect for every VS Code instances.
    I will be out of office next week, but if you need further assistance, please just reply. One of our engineers will help you.
